As of today we have a new kitchen with a Novy 6810 cooker hood.
Very nice thing with LED lights build in. Control can be learned for an induction plate and also additional Remote Control.
As it is 433 Mhz I like to add it to Domoticz, but cannot find anything about it...
Anyone any idea?
Novy 6810 Cooker Hood with....,433.x Mhz control!
- Domoticz version: 3.530
Re: Novy 6810 Cooker Hood with....,433.x Mhz control!
It's not supported yet
viewtopic.php?f=74&t=30016&p=227478
Today I found out as well that Domoticz does not support the Novy hood in the RFXcom. That was a bit disappointing, because I bought the device specially for control of my Novy hood. With HomeSeer trial version ( 1 month valid) it is possible. My aim is to get a good voice control over the hood via Google home while cooking, preferably in Dutch. Sofar that works a bit clumsy. "Light on" switches the light on, but "Light off" does nothing. The Novy button is a toggle switch. So you have to say again "Light on" to turn the light off. I will test the setup for a month, but probably I am not going to purchase the rather expensive HomeSeer, where the RFXcom plugin cost another 40$. I hope the Domoticz team will integrate the Novy hood soon in their RFXcom support.
I found some time to spend on the Novy hood to control by voice (via Google and Controlicz). Finally I succeeded by creating dummy switches that call JSON commands:
First find the RFXcom idx of your remote. In my case 933. Then I use these json commands that have the same functions as the remote buttons.
http://192.168.2.14:8080/json.htm?type=command¶m=switchlight&idx=933&switchcmd=light
http://192.168.2.14:8080/json.htm?type=command¶m=switchlight&idx=933&switchcmd=power
http://192.168.2.14:8080/json.htm?type=command¶m=switchlight&idx=933&switchcmd=plus
http://192.168.2.14:8080/json.htm?type=command¶m=switchlight&idx=933&switchcmd=min
Thank you for sharing article and information. this is very helpful for beginner.gjwater wrote: ↑Sunday 26 January 2020 21:22 Today I found out as well that Domoticz does not support the Novy hood in the RFXcom. That was a bit disappointing, because I bought the device specially for control of my Novy hood. With HomeSeer trial version ( 1 month valid) it is possible. My aim is to get a good voice control over the hood via Google home while cooking, preferably in Dutch. Sofar that works a bit clumsy. Tellpizzahut "Light on" switches the light on, but "Light off" does nothing. The Novy button is a toggle switch. So you have to say again "Light on" to turn the light off. I will test the setup for a month, but probably I am not going to purchase the rather expensive HomeSeer, where the RFXcom plugin cost another 40$. I hope the Domoticz team will integrate the Novy hood soon in their RFXcom support.
My Novy Cloud Hood supports an extra function: "mood mode". With the button called "NOVY" the led lights can be switched to a dimmed preprogrammed light level. With help from the costumer support from RfxComm, I received a beta version for the RfxCom XL transceiver which now supports this button!
The remaining question is how to get the new button/function supported in Domoticz!
Does anybody know how?
