I did see your fault message:
Unable to make web request: Error: write EPROTO 139776656385856:error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol:../deps/openssl/openssl/ssl/s23_clnt.c:782:
This indicated an error, regarding the https request (openssl) and I saw the link where you have to create your base64 password.
I'm afraid that I cannot test it, by creating a new web-hook, as I control my lights with Node Red and nora node and another one is a Philips Hue, which has native support from Google Assistant.
Strange that you can switch on your light with such a bizarre phrase and not with something normal.
But just a thought.
As you want to control a Domoticz switch, you actually create a https request, that should activate a Domoticz Switch with (in your case) IDX = 3.
This switch activates a component that activates the lamp.
In your first post you mentioned, that you use a RfXtrx433E controller. Do you control devices (lamps) with something like KlikAanKlikUIt (CoCo)?
In this case Google Assistant is not aware of this RFXtrx433E transceiver.
If you tell Google Assistant (your IFTT applet) to switch on a Lamp or Light, Google is going to look into its list of registered lamps
I assume you don't have added the lights in your Google Home app? Do you have any Google Nest device, such as the Speaker or Hub?
If so, they should be added in your Google Home app.
You can see it in the app.
- Screenshot_20200121-213929.png (25.55 KiB) Viewed 6060 times
Probably "Lamps" or "Lights" are "Reserved" words for the Google Assistant and the Assistant will try the find them.
If he/she cannot find it, he/she will tell you, that they cannot be found.
If you think, this is the case, try to avoid the words "Lamp" and "Lights".
But nice that, at least, part one functions well.
