Pilot: Home Automation Control (iOS app)
LanWolf
Re: Pilot: Home Automation Control (iOS app)
Post by LanWolf »
you can use telegram for messaging :) works great!
even pictures of the camera included
http://www.domoticz.com/forum/viewtopic.php?f=5&t=1985
*/ Just A Byte /*
patoo77
Post by patoo77 »
Version 1.3.0 is out!
It should fix the "login authentication" issues, broken "unlock" button, and brings support for Domoticz room plans!
Let me know what you think ;-)
bing69
Post by bing69 »
patoo77 wrote:Version 1.3.0 is out!
i think great!! But.....
the switches like this one: http://www.klikaanklikuit.nl/shop/nl/pr ... -acd-3501/
are on/off switches. I see them with on level 100%. I think on or off is good.
patoo77
Post by patoo77 »
Did it work before the update?
bing69
Post by bing69 »
No the same problemImage.
a picture say more then ......
Steven84
Post by Steven84 »
Where can i find 1.3.0? Appstore or testflight?
patoo77
Post by patoo77 »
Steven84 wrote:Where can i find 1.3.0? Appstore or testflight?
App Store ;)
Steven84
Post by Steven84 »
No app store update for iphone 5S
patoo77
Post by patoo77 »
Steven84 wrote:No app store update for iphone 5S
The update has been out for a few hours. Might take a while to get in the App Store worldwide.
bing69
Post by bing69 »
Vaassen is Dutch, and i have the update for the 5s
LanWolf
Post by LanWolf »
Apeldoorn Too :) Running 1.3.0 since this morning :)
*/ Just A Byte /*
Dynamic
Post by Dynamic »
I can't find the roomplans?
patoo77
Post by patoo77 »
Dynamic wrote:I can't find the roomplans?
Should be in the "Data" tab.
Can you see the regular Domoticz categories?
Dynamic
Post by Dynamic »
I see the categories, but the roomplans are missing. They are in my Domoticz-system (running V2.2040)
Fixed: removing the server and adding it again solved it.
patoo77
Post by patoo77 »
Dynamic wrote: I see the categories, but the roomplans are missing. They are in my Domoticz-system (running V2.2040)
That's weird...
There must be something wrong in the update process...
Thanks for reporting it, I will check what's wrong, so it doesn't bug on every app update.
grant
Post by grant »
HI Just wanted to ask if there is anyway to use the app while at home connected to wifi and while away from home on 3g?
At the moment i have it configured for use away from home with the public IP, but this will not work within the home network as it needs to use the private internal ip to communicate.
it would be good if you could add two servers so that it would try the first one and if not able to reach it try the second one?
Grant
patoo77
Post by patoo77 »
grant wrote:HI Just wanted to ask if there is anyway to use the app while at home connected to wifi and while away from home on 3g?
Grant
Hi Grant,
Can't you use the public IP to access it from your home network? Would be much simpler :)
I think you can set that up with your router. That way you can access both from inside and outside.
grant
Post by grant »
No I really don't think that will work due to the routing on the subnet. Has anyone else found a way around this?
Got to say fantastic app! :)
LanWolf
Post by LanWolf »
Grant
Hi Grant,
I would like such a function too, my router (Horizon box) does also not support that. (may routers don't, and since providers hand out locked in routers it is getting more and more difficult to use your own (not possible to use bridge mode in many modems )
*/ Just A Byte /*
markk
Post by markk »
Hi. I'm suddenly getting a message saying "error while trying to connect to server" is there a problem with this?
