Calculate other energy usage using dzVents  [Solved]
RduPre
Post by RduPre »
I measure the energy usage of many devices using zwave devices.
I also know the total usage collected from my P1 energy meter.
What I would like to calculate is how much energy I consume from devices I don't measure. So basically this would be the the P1 usage minus al usage of measured devices?
Can someone of you give me a quick start to get this doen ?
Many thanks in advance,
Rien
Re: Calculate other energy usage using dzVents
RduPre wrote: Sunday 12 January 2020 14:18 What I would like to calculate is how much energy I consume from devices I don't measure. So basically this would be the the P1 usage minus al usage of measured devices?
Something like this ?
return
    on =
        devices =
            'Power',   --  'name' or id of your P1 device
    execute = function(dz, item)
        local usage = item.usage -- P1 usage
        local allMeasured = { 679, 915, 2326 } -- id's of all measured devices
        local delta = usage
        for _, id in ipairs(allMeasured) do
            delta = delta - ( dz.devices(id).actualWatt or dz.devices(id).WhActual ) -- depending on the version
        dz.log('Usage by none measured power consumers  = ' .. delta )
RduPre
Re: Calculate other energy usage using dzVents  [Solved]
Post by RduPre »
I got it working, but due to the the realtime measurements are not at the same time of al devices, it's not accurate (sometimes even a negative value)
Is it possible to use the daily usage instead (see image below)
Schermafbeelding 2020-01-14 om 13.24.32.png (214.27 KiB) Viewed 1516 times
RduPre wrote: Tuesday 14 January 2020 14:13 I got it working, but due to the the realtime measurements are not at the same time of al devices, it's not accurate (sometimes even a negative value)
Is it possible to use the daily usage instead ?
I guess this should do that (not tested)
return
    on =
        devices =
        local usage = item.counterToday -- P1 used Today
        local delta = usage
            delta = delta - ( dz.devices(id).counterToday )
Users browsing this forum: hemant5400z and 1 guest
