Design of block/colum Topic is solved
webrazor
Post by webrazor »
I am building my design in dashticz and i have a question if it is possible to make one background for multiple blocks.
Like the second image(photoshop) below. First image is what you get in Dashticz and second image is what i want. So is it possible to do this.
I think the space between the original blocks are made by the column and the column you can't edit with css i believe.
Lokonli
Re: Design of block/colum
Post by Lokonli »
webrazor wrote: Monday 13 January 2020 10:57 Hello,
It should be possible to change this via custom.css
I think it's the css margin setting. If you right-click on a block, and then on inspect, then in the developer window of your browser you can change/add the css settings.
For the first block you have to change the margin-right setting, for the middle block margin-left and margin-right, for the right block only the margin-left setting.
webrazor
Post by webrazor »
Lokonli wrote: Monday 13 January 2020 11:35 It should be possible to change this via custom.css
I already tried setting the margin/padding/border to 0px this dit not change a thing. When i increase the px number the margin/padding/border gets bigger. It looks like this is set in the column.
clinkadink
Post by clinkadink »
It is the inner div that needs amending (e.g "data-id=174"), not the outer div (e.g: "block_174").
Below are 3 device blocks, with IDs 174 (left), 79 (middle) and 80 (right).
Before ...
After ...
In your custom.css put this, substituting the data-id values with your block device IDs.
[data-id='174'],
[data-id='79'] {
	border-right: 0!important;
[data-id='79'],
[data-id='80'] {
	border-left: 0!important;
webrazor
Post by webrazor »
clinkadink wrote: Monday 13 January 2020 17:18 It is the inner div that needs amending (e.g "data-id=174"), not the outer div (e.g: "block_174").
Perfect thats what i need, thank you!
clinkadink
No probs, glad it worked ;)
