I am building my design in dashticz and i have a question if it is possible to make one background for multiple blocks.
Like the second image(photoshop) below. First image is what you get in Dashticz and second image is what i want. So is it possible to do this.
I think the space between the original blocks are made by the column and the column you can't edit with css i believe.
webrazor wrote: Monday 13 January 2020 10:57
It should be possible to change this via custom.css
I think it's the css margin setting. If you right-click on a block, and then on inspect, then in the developer window of your browser you can change/add the css settings.
For the first block you have to change the margin-right setting, for the middle block margin-left and margin-right, for the right block only the margin-left setting.
Lokonli wrote: Monday 13 January 2020 11:35
I already tried setting the margin/padding/border to 0px this dit not change a thing. When i increase the px number the margin/padding/border gets bigger. It looks like this is set in the column.
