Venetian Blinds over esp8266
mojso
how to create a script to send commands from domoticz switches via http: //.
using this setup on arduino, esp8266 and servo motor:
https://www.hackster.io/igorF2/wi-servo ... ors-66176e
i plan to use only tilt for the blinds
jf2020
Re: Venetian Blinds over esp8266 and arduino uno
If you want to control one (or two) servo motors over Wifi you can do this directly from the ESP8266! The Arduino is completely useless!! You simply have to connect it to one of the GPIO. Then you can control it like this https://www.letscontrolit.com/wiki/inde ... itle=Servo using ESpEasy (v1) or the newer EspEasy V2 https://espeasy.readthedocs.io/en/lates ... motor.html
jf2020
BTW in addition to the above, you should soon find out (if not already
) that the difficulty is not in the electronics or the command script, but in the mechanical integration of the servo with the blinds (there it really depends of your blinds and the torque required) and in bringing power to the servo / electronics (you normally do not want ugly wires there).
I would recommend that you start by this end of the project
See https://www.youtube.com/watch?v=q0-QmbT0SrQ for an example
mojso
except servo motors i plan to put a potentiometer to manually adjust the blinds using the current adjustment mechanism. i need it, 4 gpio for 2 blinds. but for now I'm interested in how to send a command via http: for example blinds in 90 degree position
mojso
still in test phase but works great
Wemos d1 mini - Espeasy firmware
Servo sg90
Cardan joint - home made
[youtube] https://youtu.be/bK5VLNLT7_g [/youtube]
Control from Domoticz (open , close , servo position from 0 to 100%)
Servo sg90
-- Blinds dimmer script using ESPEasy by mojso
-- 1. put the script in Events as Lua script
-- 2.in setup -> more option --> user variable put in variable name dimmer -- , variable type string and update
-- 3.Setup -> Hardware dymmy device
--create virtual device, Select rgb switch,
-- Then in Switches find the created device end click edit. -- then in switch type select blinds precentage and save
DomDevice = 'Blinds'; -- device name
IP = '192.168.1.149';
Stopsignal = '9000';
PIN = "12"; -- D6 WEMOS PIN 12
if devicechanged[DomDevice] then
if(devicechanged[DomDevice]=='Off') then
print ("OFF dim = "..uservariables['dimmer']);
CalcValue = 0; -- default 0
else if(devicechanged[DomDevice]=='On') then
DomValue = uservariables['dimmer'];
print ("ON dim = "..uservariables['dimmer']);
CalcValue = DomValue;
print("Other");
DomValue = otherdevices_svalues[DomDevice];
CalcValue = math.floor(DomValue / 100 * 180);
commandArray['Variable:dimmer'] = tostring(CalcValue);
print ("dim Level = "..uservariables['dimmer']);
runcommand = "curl 'http://" .. IP .. "/control?cmd=Servo,1," ..PIN.. "," .. CalcValue .. "'";
os.execute(runcommand);
print("Servo value= "..CalcValue);
local delay = 2
runcommand2 = "curl 'http://" .. IP .. "/control?cmd=Servo,1," ..PIN.. "," .. Stopsignal .. "'";
os.execute('(sleep '..delay..';' ..runcommand2.. ')');
return commandArray- Attachments
- s1.jpg (60.57 KiB) Viewed 1494 times
pietje1951
Hi mojso,
That looks great.
I think you made switches in Domoticz.
I am a absolutely beginner.
Could you explain how you made it work with Domoticz ?
I plan to use this principe to operate a valve for our woodstove.
Thank you in advance !
Piet
That looks great.
Piet
mojso
-- 1. Put the script in Events as Lua script
-- 2. In setup -> more option --> user variable
put in variable name dimmer ,
-- 3.Setup -> Hardware dymmy device create virtual device, Select rgb switch, Then in Switches find the created device end click edit. then in switch type select blinds precentage and save
pietje1951
Hello mojso,
Thank you for your help. But with me it doesn't work, maybe I do something stupid.
The ESP and the servo work perfectly.
Within Domoticz it doesn't work.
I tried to follow your advice.
Maybe you can see what I do wrong.
-- 2.in setup -> user variable put in variable name dimmer -- , variable type string and update
DomDevice = 'Klep kachel'; -- device name
IP = '192.168.178.147';
PIN = "4"; -- D6 WEMOS PIN 12
print("Other");
runcommand = "curl 'http://" .. IP .. "/control?cmd=Servo,2," ..PIN.. "," .. CalcValue .. "'";
local delay = 2
runcommand2 = "curl 'http://" .. IP .. "/control?cmd=Servo,2," ..PIN.. "," .. Stopsignal .. "'";
The log says:
2020-12-21 17:33:37.031 Status: User: Admin initiated a switch command (189/Klep kachel/Set Level)
2020-12-21 17:33:37.156 Status: LUA: Other
2020-12-21 17:33:37.157 Error: EventSystem: in Script #17 ven blinds: [string "-- Blinds dimmer script using ESPEasy by mojs..."]:27: attempt to concatenate a nil value (field 'dimmer')
I hope you can help me !
Greetings, Pietje
print("Other");
local delay = 2
The log says:
Greetings, Pietje
mojso
- 20201221_175749.jpg (227.7 KiB) Viewed 1235 times
pietje1951
It Works!
I didn't read properly, sorry !
Thank you very much!
Have a Nice christmas
Pietje
It Works!
Pietje
mojso
I'm glad it works, have a nice Christmas toopietje1951 wrote: Monday 21 December 2020 21:43 Hi,
It Works!
Pietje
