can not add heiman HS1SA-M (smoke detector + siren)
joellevy
Domoticz version: 4.10
Post by joellevy »
I did several attempts to add this device but it failed
now
I have several errors when I start pairing
2019-12-19 14:57:11.905 Error: (zigate) Decode004d - New Device 492e 005043c903368f8d already exist in IEEE2NWK
2019-12-19 14:57:20.367 Error: (zigate) Decode004d - New Device d34c 005043c903368f8d already exist in IEEE2NWK
2019-12-19 14:57:28.852 Error: (zigate) Decode004d - New Device 592f 005043c903368f8d already exist in IEEE2NWK
2019-12-19 14:57:37.412 Error: (zigate) Decode004d - New Device c7dc 005043c903368f8d already exist in IEEE2NWK
2019-12-19 14:57:45.471 Error: (zigate) Decode004d - New Device aa31 005043c903368f8d already exist in IEEE2NWK
2019-12-19 14:57:53.504 Error: (zigate) Decode004d - New Device b2ea 005043c903368f8d already exist in IEEE2NWK
then
2019-12-19 14:58:19.407 Error: (zigate) [5] NEW OBJECT: 6ebf Not able to get all needed attributes on time
2019-12-19 14:58:19.407 Error: (zigate) processNotinDB - not able to find response from 6ebf stop process at 0045
2019-12-19 14:58:19.407 Error: (zigate) processNotinDB - RIA: 5 waitForDomoDeviceCreation: False, capturePairingInfos: 0 Model: {}
2019-12-19 14:58:19.408 Error: (zigate) processNotinDB - Collected Infos are : {'Heartbeat': '1', 'Battery': {}, 'ReadAttributes': {'Ep': {'03': {'0000': {}}, '02': {'0000': {}}, '06': {'0000': {}}, '01': {'0000': {}}, '09': {'0000': {}}}, 'TimeStamps': {'02-0000': 1576763894, '01-0000': 1576763894, '09-0000': 1576763894, '06-0000': 1576763894, '03-0000': 1576763894}}, 'Manufacturer Name': '', 'ZDeviceID': {}, 'MacCapa': '84', 'LogicalType': 'End Device', 'Last Cmds': [(1576763894.4203582, '0100', None), (1576763894.5365787, '0100', None), (1576763894.638909, '0100', None), (1576763894.741299, '0100', None), (1576763894.8437579, '0100', None)], 'NbEp': '', 'IEEE': '005043c903368f8d', 'Model': {}, 'App Version': '', 'ZDeviceName': '', 'ZCL Version': '', 'DeviceType': 'RFD', 'Stack Version': '', 'Health': 'Live', 'ProfileID': {}, 'HW Version': '', 'Attributes List': {}, 'Stamp': {'Time': '2019-12-19 14:57:14', 'LastSeen': 1576763823, 'MsgType': '8702'}, 'Announced': 1576763823.408137, 'Version': '3', 'Status': 'UNKNOW', 'Capability': ['Reduced-Function Device', 'Main Powered', 'Standard security', 'NwkAddr should be allocated'], 'APS Failure': [(1576763834.5304017, 'd4')], 'Ep': {}, 'ReceiveOnIdle': '', 'Manufacturer': '', 'SQN': '', 'PowerSource': 'Main', 'RIA': '5', 'RSSI': {}, 'ConsistencyCheck': 'Bad Pairing', 'Type': {}}
I have the latest beta version of domoticz and plugins
can you help me
joel
Raspberry PI 3, zigate, Xiaomi, rflink, NODERED, EQ3, MQTT, Conbee II
pipiche
Re: ne peux ajouter heiman HS1SA-M (detecteur fume + siren)
Post by pipiche »
If there is a failure of the pairing, I suggest to make a restart of the plugin, to avoid that there remain traces of the previous pairing which did not work.
PS / The French-speaking forum is here:https://easydomoticz.com/forum/viewforum.php?f=28
Wiki is available here.
Zigbee for Domoticz FAQ
joellevy
Post by joellevy »
hi
thanks pipiche for your quick answer
after completely rebooting raspberry
and delete 005043c903368f8d device from zigate
then restart plugin .i have below errors in log
2019-12-19 15:40:26.827 (zigate) --> Adding device 1803 in self.DevicesInPairingMode
2019-12-19 15:40:26.827 (zigate) --> ['1803']
2019-12-19 15:40:26.826 Status: (zigate) Device Announced ShortAddr: 1803, IEEE: 005043c903368f8d REJOIN:
2019-12-19 15:40:40.933 Status: (zigate) [0] NEW OBJECT: 1803 TimeOut in 0045 restarting at 0x004d
2019-12-19 15:40:41.259 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:40:41.362 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:40:41.464 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:40:41.565 (zigate) Decode8000 - PacketType: 0045 Status: [a6] - ZigBee Error Code APS - [a6] A parameter value was invaid or out of range
2019-12-19 15:40:55.969 Status: (zigate) [1] NEW OBJECT: 1803 TimeOut in 0045 restarting at 0x004d
2019-12-19 15:40:56.294 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:40:56.397 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:40:56.499 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:40:56.600 (zigate) Decode8000 - PacketType: 0045 Status: [a6] - ZigBee Error Code APS - [a6] A parameter value was invaid or out of range
2019-12-19 15:41:02.975 Status: (zigate) Device Announced ShortAddr: 2fb3, IEEE: 005043c903368f8d REJOIN:
2019-12-19 15:41:02.975 Error: (zigate) Decode004d - New Device 2fb3 005043c903368f8d already exist in IEEE2NWK
2019-12-19 15:41:10.958 Status: (zigate) [2] NEW OBJECT: 1803 TimeOut in 0045 restarting at 0x004d
2019-12-19 15:41:11.283 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:41:11.386 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:41:11.488 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:41:11.589 (zigate) Decode8000 - PacketType: 0045 Status: [a6] - ZigBee Error Code APS - [a6] A parameter value was invaid or out of range
2019-12-19 15:41:25.945 Status: (zigate) [3] NEW OBJECT: 1803 TimeOut in 0045 restarting at 0x004d
2019-12-19 15:41:26.270 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:41:26.373 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:41:26.475 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:41:26.576 (zigate) Decode8000 - PacketType: 0045 Status: [a6] - ZigBee Error Code APS - [a6] A parameter value was invaid or out of range
2019-12-19 15:41:40.981 Status: (zigate) [4] NEW OBJECT: 1803 TimeOut in 0045 restarting at 0x004d
2019-12-19 15:41:41.306 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:41:41.409 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:41:41.511 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:41:41.612 (zigate) Decode8000 - PacketType: 0045 Status: [a6] - ZigBee Error Code APS - [a6] A parameter value was invaid or out of range
2019-12-19 15:44:53.343 Error: (zigate) 'onMessage' failed 'TypeError':'string indices must be integers'.
2019-12-19 15:44:53.343 Error: (zigate) ----> Line 845 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2019-12-19 15:44:53.343 Error: (zigate) ----> Line 501 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2019-12-19 15:44:53.343 Error: (zigate) ----> Line 269 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function onMessage
2019-12-19 15:44:53.343 Error: (zigate) ----> Line 471 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function processFrame
2019-12-19 15:44:53.343 Error: (zigate) ----> Line 505 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function processFrame
2019-12-19 15:44:53.343 Error: (zigate) ----> Line 99 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function ZigateRead
2019-12-19 15:44:53.343 Error: (zigate) ----> Line 731 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function Decode8030
joel
joel
pipiche
Re: can not add heiman HS1SA-M (smoke detector + siren)
Post by pipiche »
If you got this error message , the widget in Domoticz should have been created, however I'm not sure the device is fully operationnal.
The error looks very strange.
Can you attached the file Data/DeviceList-xx.txt (where xx is the HardwareId of the Zigate plugin in Domoticz-Hardware)
joellevy
Post by joellevy »
hi pipiche
please find attached required file
DeviceList-10.txt
(83.55 KiB) Downloaded 46 times
joel
pipiche
Post by pipiche »
Could you clarify which version of the plugin you are in ? This looks quiet strange as you would have a mixed of version
