I did several attempts to add this device but it failed
now
I have several errors when I start pairing
2019-12-19 14:57:11.905 Error: (zigate) Decode004d - New Device 492e 005043c903368f8d already exist in IEEE2NWK
2019-12-19 14:57:20.367 Error: (zigate) Decode004d - New Device d34c 005043c903368f8d already exist in IEEE2NWK
2019-12-19 14:57:28.852 Error: (zigate) Decode004d - New Device 592f 005043c903368f8d already exist in IEEE2NWK
2019-12-19 14:57:37.412 Error: (zigate) Decode004d - New Device c7dc 005043c903368f8d already exist in IEEE2NWK
2019-12-19 14:57:45.471 Error: (zigate) Decode004d - New Device aa31 005043c903368f8d already exist in IEEE2NWK
2019-12-19 14:57:53.504 Error: (zigate) Decode004d - New Device b2ea 005043c903368f8d already exist in IEEE2NWK
then
2019-12-19 14:58:19.407 Error: (zigate) [5] NEW OBJECT: 6ebf Not able to get all needed attributes on time
2019-12-19 14:58:19.407 Error: (zigate) processNotinDB - not able to find response from 6ebf stop process at 0045
2019-12-19 14:58:19.407 Error: (zigate) processNotinDB - RIA: 5 waitForDomoDeviceCreation: False, capturePairingInfos: 0 Model: {}
2019-12-19 14:58:19.408 Error: (zigate) processNotinDB - Collected Infos are : {'Heartbeat': '1', 'Battery': {}, 'ReadAttributes': {'Ep': {'03': {'0000': {}}, '02': {'0000': {}}, '06': {'0000': {}}, '01': {'0000': {}}, '09': {'0000': {}}}, 'TimeStamps': {'02-0000': 1576763894, '01-0000': 1576763894, '09-0000': 1576763894, '06-0000': 1576763894, '03-0000': 1576763894}}, 'Manufacturer Name': '', 'ZDeviceID': {}, 'MacCapa': '84', 'LogicalType': 'End Device', 'Last Cmds': [(1576763894.4203582, '0100', None), (1576763894.5365787, '0100', None), (1576763894.638909, '0100', None), (1576763894.741299, '0100', None), (1576763894.8437579, '0100', None)], 'NbEp': '', 'IEEE': '005043c903368f8d', 'Model': {}, 'App Version': '', 'ZDeviceName': '', 'ZCL Version': '', 'DeviceType': 'RFD', 'Stack Version': '', 'Health': 'Live', 'ProfileID': {}, 'HW Version': '', 'Attributes List': {}, 'Stamp': {'Time': '2019-12-19 14:57:14', 'LastSeen': 1576763823, 'MsgType': '8702'}, 'Announced': 1576763823.408137, 'Version': '3', 'Status': 'UNKNOW', 'Capability': ['Reduced-Function Device', 'Main Powered', 'Standard security', 'NwkAddr should be allocated'], 'APS Failure': [(1576763834.5304017, 'd4')], 'Ep': {}, 'ReceiveOnIdle': '', 'Manufacturer': '', 'SQN': '', 'PowerSource': 'Main', 'RIA': '5', 'RSSI': {}, 'ConsistencyCheck': 'Bad Pairing', 'Type': {}}
I have the latest beta version of domoticz and plugins
can you help me
can not add heiman HS1SA-M (smoke detector + siren)
- Domoticz version: 4.10
joel
Raspberry PI 3, zigate, Xiaomi, rflink, NODERED, EQ3, MQTT, Conbee II
Re: ne peux ajouter heiman HS1SA-M (detecteur fume + siren)
If there is a failure of the pairing, I suggest to make a restart of the plugin, to avoid that there remain traces of the previous pairing which did not work.
PS / The French-speaking forum is here:https://easydomoticz.com/forum/viewforum.php?f=28
Zigbee for Domoticz plugin / RPI3B+ / Electrolama ZZH-P / 45 devices
If the plugin provides you value, you can support me with a donation Paypal.
Wiki is available here.
Zigbee for Domoticz FAQ
hi
thanks pipiche for your quick answer
after completely rebooting raspberry
and delete 005043c903368f8d device from zigate
then restart plugin .i have below errors in log
2019-12-19 15:40:26.827 (zigate) --> Adding device 1803 in self.DevicesInPairingMode
2019-12-19 15:40:26.827 (zigate) --> ['1803']
2019-12-19 15:40:26.826 Status: (zigate) Device Announced ShortAddr: 1803, IEEE: 005043c903368f8d REJOIN:
2019-12-19 15:40:40.933 Status: (zigate) [0] NEW OBJECT: 1803 TimeOut in 0045 restarting at 0x004d
2019-12-19 15:40:41.259 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:40:41.362 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:40:41.464 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:40:41.565 (zigate) Decode8000 - PacketType: 0045 Status: [a6] - ZigBee Error Code APS - [a6] A parameter value was invaid or out of range
2019-12-19 15:40:55.969 Status: (zigate) [1] NEW OBJECT: 1803 TimeOut in 0045 restarting at 0x004d
2019-12-19 15:40:56.294 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:40:56.397 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:40:56.499 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:40:56.600 (zigate) Decode8000 - PacketType: 0045 Status: [a6] - ZigBee Error Code APS - [a6] A parameter value was invaid or out of range
2019-12-19 15:41:02.975 Status: (zigate) Device Announced ShortAddr: 2fb3, IEEE: 005043c903368f8d REJOIN:
2019-12-19 15:41:02.975 Error: (zigate) Decode004d - New Device 2fb3 005043c903368f8d already exist in IEEE2NWK
2019-12-19 15:41:10.958 Status: (zigate) [2] NEW OBJECT: 1803 TimeOut in 0045 restarting at 0x004d
2019-12-19 15:41:11.283 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:41:11.386 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:41:11.488 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:41:11.589 (zigate) Decode8000 - PacketType: 0045 Status: [a6] - ZigBee Error Code APS - [a6] A parameter value was invaid or out of range
2019-12-19 15:41:25.945 Status: (zigate) [3] NEW OBJECT: 1803 TimeOut in 0045 restarting at 0x004d
2019-12-19 15:41:26.270 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:41:26.373 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:41:26.475 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:41:26.576 (zigate) Decode8000 - PacketType: 0045 Status: [a6] - ZigBee Error Code APS - [a6] A parameter value was invaid or out of range
2019-12-19 15:41:40.981 Status: (zigate) [4] NEW OBJECT: 1803 TimeOut in 0045 restarting at 0x004d
2019-12-19 15:41:41.306 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:41:41.409 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:41:41.511 (zigate) Decode8000 - PacketType: 0100 Status: [14] - 14
2019-12-19 15:41:41.612 (zigate) Decode8000 - PacketType: 0045 Status: [a6] - ZigBee Error Code APS - [a6] A parameter value was invaid or out of range
2019-12-19 15:44:53.343 Error: (zigate) 'onMessage' failed 'TypeError':'string indices must be integers'.
2019-12-19 15:44:53.343 Error: (zigate) ----> Line 845 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2019-12-19 15:44:53.343 Error: (zigate) ----> Line 501 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2019-12-19 15:44:53.343 Error: (zigate) ----> Line 269 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function onMessage
2019-12-19 15:44:53.343 Error: (zigate) ----> Line 471 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function processFrame
2019-12-19 15:44:53.343 Error: (zigate) ----> Line 505 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function processFrame
2019-12-19 15:44:53.343 Error: (zigate) ----> Line 99 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function ZigateRead
2019-12-19 15:44:53.343 Error: (zigate) ----> Line 731 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function Decode8030
joel
joel
joel
Re: can not add heiman HS1SA-M (smoke detector + siren)
If you got this error message , the widget in Domoticz should have been created, however I'm not sure the device is fully operationnal.
The error looks very strange.
Can you attached the file Data/DeviceList-xx.txt (where xx is the HardwareId of the Zigate plugin in Domoticz-Hardware)
hi pipiche
please find attached required file
- DeviceList-10.txt
- (83.55 KiB) Downloaded 47 times
joel
Could you clarify which version of the plugin you are in ? This looks quiet strange as you would have a mixed of version
