Controlling Toon [HACKED] from Domoticz
madpatrick
Domoticz version: 2025.2
Re: Controlling Toon [HACKED] from Domoticz
Post by madpatrick »
Peebee01
Domoticz version: 4.1071
Post by Peebee01 »
Now it works
My mistake was that I had the right UV, they did not have the “current value” shown tothe right of it. I assumed this current value would get written by the script based on the information from the Toon, but it looks like this is the link to the devices....
So modifying the UV and the devices fixed it.
Thanks for your support!
Dick60
Post by Dick60 »
Can anybody help me with the BurnerInfo script.
	-- Update the toon burner selector to current program state
			CurrentToonBurnerValue = otherdevices_svalues[ToonBurnerName]
			if     currentBurnerInfo == 0 then currentBurnerInfo = '0' -- uit
			elseif currentBurnerInfo == 1 then currentBurnerInfo = '10' -- cv aan
			elseif currentBurnerInfo == 2 then currentBurnerInfo = '20' -- warmwater aan
			if CurrentToonBurnerValue ~= currentBurnerInfo then  -- Update toon burner selector if it has changed
				print ('Updating Toon burner info')
				commandArray[7] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonBurnerName], currentBurnerInfo)}
This script will update the selectionswitch of the burners status.
What I want is ;
As soon as the burnerinfo=0 ------turn an On/Off switch to Off (SW1)
As soon as the burnerinfo=1-------turn an On/Off switch to On (SW1)
Already strugling with this several days but all testing result in failures.
madpatrick
Dick60
Post by Dick60 »
I Asked the same question on the site to refered to but I do not understand the script. I dont know the domoticz command. That is why I asked it again on the domoticz forum. I only want to control an dummy on/off switch in Domoticz.
Sjoek
Domoticz version: V4.10717
Post by Sjoek »
Hello everyone!
My Toon and Domoticz worked fine for 2 years, but last week i saw that the Toon Heating and information stopped working.
I have an error in the logs and cannot find any problem in the scripts, should be ok, since it was running fine for years.
This is the error:
2019-12-08 22:52:32.403 Error: EventSystem: in Toon_Getinfo: /home/sjoek/domoticz/scripts/lua/JSON.lua:660: html passed to JSON:decode(): <?xml version="1.0" encoding="iso-8859-1"?>
2019-12-08 22:52:32.403 <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
2019-12-08 22:52:32.403 "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
2019-12-08 22:52:32.403 <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
2019-12-08 22:52:32.403 <head>
2019-12-08 22:52:32.403 <title>403 - Forbidden</title>
2019-12-08 22:52:32.403 </head>
2019-12-08 22:52:32.403 <body>
2019-12-08 22:52:32.403 <h1>403 - Forbidden</h1>
2019-12-08 22:52:32.403 </body>
2019-12-08 22:52:32.403 </html>
Set Toon Hardware off en then back on like Francis did, did not work for me.
Do you guys have any idea?
Larsoss
Post by Larsoss »
Cant get it working.
https://ibb.co/jHYFWLT
I put the script in Lua - Device
And this is what in my script. The only thing what is working are my Swithes - Toon Scenes. Nothing else.
Name Toon
    ToonThermostatSensorName = uservariables['UV_ToonThermostatSensorName'] -- Sensor showing current setpoint
    ToonTemperatureSensorName = uservariables['UV_ToonTemperatureSensorName'] -- Sensor showing current room temperature
    ToonScenesSensorName  = uservariables['UV_ToonScenesSensorName'] -- Sensor showing current program
    ToonAutoProgramSensorName = uservariables['UV_ToonAutoProgramSensorName'] -- Sensor showing current auto program status
	ToonBurnerName = uservariables['UV_ToonBurnerName']
	ToonProgramInformationSensorName = uservariables['UV_ToonProgramInformationSensorName'] -- Sensor showing displaying program information status
	ToonBoilerTempSetpoint = uservariables['UV_ToonBoilerTempSetpointSensorName'] -- Sensor showing current internal boiler temp
    ToonIP = uservariables['UV_ToonIP']
    DomoticzIP = uservariables['UV_DomoticzIP']
-- Choose the correct platform which Domoticz runs on
-- Remove -- before the line which applies for your situation, set -- for all other platforms
--  json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()  -- For Raspberry
--  json = assert(loadfile "/opt/domoticz/scripts/lua/JSON.lua")()  -- For Linux (LEDE)
  json = assert(loadfile "C:\\Program Files (x86)\\Domoticz\\scripts\\lua\\json.lua")() -- For Windows
--  json = assert(loadfile "/volume1/@appstore/domoticz/var/scripts/lua/JSON.lua")() -- For Synology
    local handle = assert(io.popen(string.format('curl -m 5 http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
        local ThermostatInfo = handle:read('*all')
    handle:close()
-- JSON data from Toon contains a extra "," which should not be there.
ThermostatInfo = string.gsub(ThermostatInfo, ",}", "}")
    jsonThermostatInfo = json:decode(ThermostatInfo)
    if jsonThermostatInfo ~= nil then
    currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
    currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
    currentProgramState = tonumber(jsonThermostatInfo.programState)
    currentActiveState = tonumber(jsonThermostatInfo.activeState)
    currentNextTime = jsonThermostatInfo.nextTime
	currentBurnerInfo = tonumber(jsonThermostatInfo.burnerInfo)
    currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
	currentBoilerSetPoint = tonumber(jsonThermostatInfo.currentInternalBoilerSetpoint)
        if currentSetpoint ~= nil then
            -- Update the thermostat sensor to current setpoint
            if otherdevices_svalues[ToonThermostatSensorName]*100 ~= currentSetpoint*100 then
                print('Updating thermostat sensor to new set point: ' ..currentSetpoint)
                commandArray[1] = {['Variable:UV_ToonChangedByDomoticz'] = '1'} -- Set variable changed to 1 to prevent script ToonSetPoint from shooting an event at Toon
                commandArray[2] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonThermostatSensorName], currentSetpoint)}
        if currentTemperature ~= nil then
            -- Update the temperature sensor to current room temperature
            if otherdevices_svalues[ToonTemperatureSensorName]*100 ~= currentTemperature*100 then
                print('Updating the temperature sensor to new value: ' ..currentTemperature)
                commandArray[3] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonTemperatureSensorName], currentTemperature)}
        if currentBoilerSetPoint ~= nil then
			-- Update the temperature of boiler
			if otherdevices_svalues[ToonBoilerTempSetpoint]*100 ~= currentBoilerSetPoint*100 then
				print('Updating the boiler temperature to new value: ' ..currentBoilerSetPoint)
				commandArray[3] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonBoilerTempSetpoint], currentBoilerSetPoint)}
        if currentActiveState ~= nil then
            -- Update the toon scene selector sensor to current program state
            CurrentToonScenesSensorValue = otherdevices_svalues[ToonScenesSensorName]
            if currentActiveState == -1 then currentActiveState = '50' -- Manual
            elseif currentActiveState == 0 then currentActiveState = '40' -- Comfort
            elseif currentActiveState == 1 then currentActiveState = '30' -- Home
            elseif currentActiveState == 2 then currentActiveState = '20' -- Sleep
            elseif currentActiveState == 3 then currentActiveState = '10' -- Away
            if CurrentToonScenesSensorValue ~= currentActiveState then  -- Update toon selector if it has changed
                print ('Updating Toon Scenes selector')
                commandArray[4] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonScenesSensorName], currentActiveState)}
        if currentProgramState ~= nil then
            -- Updates the toon auto program switch
            CurrentToonAutoProgramSensorValue = otherdevices_svalues[ToonAutoProgramSensorName]
           if currentProgramState == 0 then currentProgramState = '10' -- No
            elseif currentProgramState == 1 then currentProgramState = '20' -- Yes
            elseif currentProgramState == 2 then currentProgramState = '30' -- Temporary
            if CurrentToonAutoProgramSensorValue ~= currentProgramState then -- Update toon auto program selector if it has changed
                print ('Updating Toon Auto Program selector')
                commandArray[5] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonAutoProgramSensorName], currentProgramState)}
        if currentNextTime ~= nil and currentNextSetPoint ~= nil then
            -- Updates the toon program information text box
            CurrentToomProgramInformationSensorValue = otherdevices_svalues[ToonProgramInformationSensorName]
            if currentNextTime == 0 or currentNextSetPoint == 0 then
                ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°'
                ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°'
            if CurrentToomProgramInformationSensorValue ~= ToonProgramInformationSensorValue then
                commandArray[6] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonProgramInformationSensorName], ToonProgramInformationSensorValue)}
Script name ToonSetpoint
-- script_time_toonselector.lua
-- Reads the Toon Thermostat Setpoint Temperature and updates the
-- selector in Domoticz to represent the current Active State.
-- Off scene is an option, leave it out if not needed.
-- Action commands will not be executed.
-- Settings: Configure as desired
-- Name of the switch with the temperature setpoint.
ThermostatSetPointName = 'ToonThermostat' --Must match the name of you SetPoint device
-- Temperature SetPoints.
OffSetPoint = '6.00' --optional
AwaySetPoint = '17.50'
SleepSetPoint = '19.00'
HomeSetPoint = '20.50'
ComfortSetPoint = '21.00'
-- Name of the selector for Toon
ToonSelector = 'ToonScenes' --Must match (including case) the name of your Selector Switch
-- Name of the levels in the selector
OffLevel = 'Off' --optional
AwayLevel = 'Away'
SleepLevel = 'Sleep'
HomeLevel = 'Home'
ComfortLevel = 'Comfort'
-- Values from each level name
OffLevelValue = '0' --optional
AwayLevelValue = '10'
SleepLevelValue = '20'
HomeLevelValue = '30'
ComfortLevelValue = '40'
-- End of settings
-- Toon Thermostat SetPoint:
ThermostatSetPoint = otherdevices_svalues[ThermostatSetPointName]
if (ThermostatSetPoint == HomeSetPoint) then
        --print("SetPoint equals to Home");
		if (otherdevices[ToonSelector] ~= HomeLevel) then
		print("Updating '" .. ToonSelector .. "' selector to '" .. HomeLevel .. "'")
		commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..HomeLevelValue
elseif (ThermostatSetPoint == ComfortSetPoint) then
        --print("SetPoint equals to Comfort");
		if (otherdevices[ToonSelector] ~= ComfortLevel) then
		print("Updating '" .. ToonSelector .. "' selector to '" .. ComfortLevel .. "'")
		commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..ComfortLevelValue
elseif (ThermostatSetPoint == SleepSetPoint) then
        --print("SetPoint equals to Sleep");
		if (otherdevices[ToonSelector] ~= SleepLevel) then
		print("Updating '" .. ToonSelector .. "' selector to '" .. SleepLevel .. "'")
		commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..SleepLevelValue
elseif (ThermostatSetPoint == AwaySetPoint) then
        --print("SetPoint equals to Away");
		if (otherdevices[ToonSelector] ~= AwayLevel) then
		print("Updating '" .. ToonSelector .. "' selector to '" .. AwayLevel .. "'")
		commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..AwayLevelValue
-- Optional
elseif (ThermostatSetPoint == OffSetPoint) then
        --print("SetPoint equals to Off");
		if (otherdevices[ToonSelector] ~= OffLevel) then
		print("Updating '" .. ToonSelector .. "' selector to '" .. OffLevel .. "'")
		commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..OffLevelValue
And the last of them is
ToonThermostat
    for deviceName,deviceValue in pairs(devicechanged) do
        if (deviceName == ToonThermostatSensorName) then
            if uservariables['UV_ToonChangedByDomoticz'] == 1 then
                commandArray['Variable:UV_ToonChangedByDomoticz'] = '0'
                SetPoint = otherdevices_svalues[ToonThermostatSensorName]
                ToonCommand = string.format('http://%s/happ_thermstat?action=setSetpoint&Setpoint=%s', ToonIP, SetPoint*100)
                print('Setting Toon setpoint to '.. SetPoint)
                commandArray['OpenURL'] = ToonCommand
Raspberry 4 - USB boot Domoticz /|\ Raspberry 2B - Dashticz /|\ Tasmota device's /|\ Philips Hue & Yeelight
madpatrick
How are your user variables set ?
annesdomotic
Domoticz version: 4.9700
Post by annesdomotic »
perhaps this is useful, almost everything works with these scripts. except the boiler in and out.
setpoint:
devices = {
'ToonThermostat'
domoticz.openURL(string.format('http://%s/happ_thermstat?action=setSetpoint&Setpoint=%s', domoticz.variables('UV_ToonIP').value, device.setPoint*100))
domoticz.log('Setting Toon setpoint to '.. device.setPoint)
script:
timer = {
'every minute'
execute = function(domoticz)
local ToonThermostat = domoticz.variables('UV_ToonThermostatSensorName').value -- Sensor showing current setpoint
local ToonTemperature = domoticz.variables('UV_ToonTemperatureSensorName').value -- Sensor showing current room temperature
local ToonBoilerTempIn = domoticz.variables('UV_ToonboilerInTempName').value -- Sensor showing water temp return
local ToonBoilerTempOut = domoticz.variables('UV_ToonboilerOutTempName').value -- Sensor showing current water temp out
local ToonBoilerPressure = domoticz.variables('UV_ToonboilerPressure').value -- Sensor showing current room temperature
local ToonBoilerModulation = domoticz.variables('UV_ToonboilerModulationLevel').value -- Sensor showing current Boiler Modulation
local ToonScenes = domoticz.variables('UV_ToonScenesSensorName').value -- Sensor showing current program
local ToonAutoProgram = domoticz.variables('UV_ToonAutoProgramSensorName').value -- Sensor showing current auto program status
local ToonProgramInformation = domoticz.variables('UV_ToonProgramInformationSensorName').value -- Sensor showing displaying program information status
local ToonIP = domoticz.variables('UV_ToonIP').value
local DomoticzIP = domoticz.variables('UV_DomoticzIP').value
local ToonBurnerName = domoticz.variables('UV_ToonBurnerName').value
local P1SmartMeterPower = domoticz.variables('UV_P1SmartMeterElectra').value
local P1SmartMeterGas1 = domoticz.variables('UV_P1SmartMeterGasMeterStand').value
local ToonBoilerSetpoint = domoticz.variables('UV_ToonBoilerTempSetpointSensorName').value -- Sensor showing current boiler set point water temp out
-- Handle json
local json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Linux
local handle = assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
handle:close()
local jsonThermostatInfo = json:decode(ThermostatInfo)
if jsonThermostatInfo == nil then
return
local handle2 = assert(io.popen(string.format('curl http://%s/boilerstatus/boilervalues.txt', ToonIP)))
local BoilerInfo = handle2:read('*all')
handle2:close()
BoilerInfo = string.gsub(BoilerInfo, ",}", "}")
jsonBoilerInfo = json:decode(BoilerInfo)
--http://192.168.2.193/hdrv_zwave?action=getDevices.json
local handle4 = assert(io.popen(string.format('curl http://%s/hdrv_zwave?action=getDevices.json', ToonIP)))
local GasPowerInfo = handle4:read('*all')
handle4:close()
-- JSON data from Toon contains a extra "." which should not be there.
-- GasPowerInfo = string.gsub(GasPowerInfo, "dev_4.", "dev_4")
-- GasPowerInfo = string.gsub(GasPowerInfo, "dev_4:", "dev_4\":")
-- local jsonGasPower = json:decode(GasPowerInfo)
-- domoticz.log(jsonGasPower)
local CurrentElectricityFlowHoog = tonumber(jsonGasPower.dev_44.CurrentElectricityFlow )
local CurrentElectricityQuantityHoog = tonumber(jsonGasPower.dev_44.CurrentElectricityQuantity)
local CurrentElectricityFlowLaag = tonumber(jsonGasPower.dev_46.CurrentElectricityFlow )
local CurrentElectricityQuantityLaag = tonumber(jsonGasPower.dev_46.CurrentElectricityQuantity)
local CurrentGasFlow = tonumber(jsonGasPower.dev_41.CurrentGasFlow)
local CurrentGasQuantity = tonumber(jsonGasPower.dev_41.CurrentGasQuantity)
local CurrentElectricityQuantity = CurrentElectricityFlowHoog + CurrentElectricityFlowLaag
local CurrentElectricityDeliveredLaag = 0
local CurrentElectricityDeliveredHoog = 0
local totalDeliveredPower = 0
-- domoticz.devices(P1SmartMeterPower).updateP1(CurrentElectricityQuantityLaag, CurrentElectricityQuantityHoog, CurrentElectricityDeliveredLaag, CurrentElectricityDeliveredHoog, CurrentElectricityQuantity, totalDeliveredPower).silent()
-- domoticz.devices(P1SmartMeterGas1).updateGas(CurrentGasQuantity).silent()
-- Update the Boiler Water In to current value
local currentboilerInTemp = tonumber(jsonBoilerInfo.boilerInTemp)
if domoticz.utils.round(domoticz.devices(ToonBoilerTempIn).temperature,0) ~= domoticz.utils.round(currentboilerInTemp,0) then
-- domoticz.log('Updating Boiler Water In to current value: ' ..currentboilerInTemp)
domoticz.devices(ToonBoilerTempIn).updateTemperature(currentboilerInTemp).silent()
-- Update the Boiler water Out to current value
local currentboilerOutTemp = tonumber(jsonBoilerInfo.boilerOutTemp)
if domoticz.utils.round(domoticz.devices(ToonBoilerTempOut).temperature,0) ~= domoticz.utils.round(currentboilerOutTemp,0) then
-- domoticz.log('Updating Boiler Water Out to current value: ' ..currentboilerOutTemp)
domoticz.devices(ToonBoilerTempOut).updateTemperature(currentboilerOutTemp).silent()
-- Update the Boiler water Pressure to current value
local currentBoilerPressure = tonumber(jsonBoilerInfo.boilerPressure)
if domoticz.utils.round(domoticz.devices(ToonBoilerPressure)._nValue,0) ~= domoticz.utils.round(currentBoilerPressure,0) then
-- domoticz.log('Updating Boiler Pressure to current value: ' ..currentBoilerPressure)
domoticz.devices(ToonBoilerPressure).updatePressure(currentBoilerPressure).silent()
local currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
local currentTemperature = domoticz.utils.round(tonumber(jsonThermostatInfo.currentTemp) / 100,1)
local currentProgramState = tonumber(jsonThermostatInfo.programState)
if currentProgramState == 0 then currentProgramState = 10 -- No
elseif currentProgramState == 1 then currentProgramState = 20 -- Yes
elseif currentProgramState == 2 then currentProgramState = 30 -- Temporary
local currentActiveState = tonumber(jsonThermostatInfo.activeState)
if currentActiveState == -1 then currentActiveState = 50 -- Manual
elseif currentActiveState == 0 then currentActiveState = 40 -- Comfort
elseif currentActiveState == 1 then currentActiveState = 30 -- Home
elseif currentActiveState == 2 then currentActiveState = 20 -- Sleep
elseif currentActiveState == 3 then currentActiveState = 10 -- Away<br> elseif currentActiveState == 4 then currentActiveState = 60 -- Holiday
local currentBurnerInfo = tonumber(jsonThermostatInfo.burnerInfo)
local CurrentToonBurnerValue = domoticz.devices(ToonBurnerName).level
if currentBurnerInfo == 0 then currentBurnerInfo = 0 -- uit
elseif currentBurnerInfo == 1 then currentBurnerInfo = 10 -- cv aan
elseif currentBurnerInfo == 2 then currentBurnerInfo = 20 -- warmwater aan<br> elseif currentBurnerInfo == 3 then currentBurnerInfo = 10 -- voorverwarmen volgend setpoint
-- domoticz.log('Updating Toon burner info:')
domoticz.devices(ToonBurnerName).switchSelector(currentBurnerInfo)
-- Update the modulation level of the burner
local currentModulationLevel = tonumber(jsonThermostatInfo.currentModulationLevel)
if domoticz.devices(ToonBoilerModulation).percentage + 1 ~= currentModulationLevel + 1 then
-- domoticz.log('Updating the Modulation sensor to new value: ' ..currentModulationLevel)
domoticz.devices(ToonBoilerModulation).updatePercentage(currentModulationLevel)
-- Update the temperature Boiler setpoint to current boiler set point
local currentInternalBoilerSetpoint = jsonThermostatInfo.currentInternalBoilerSetpoint+1
if domoticz.utils.round(domoticz.devices(ToonBoilerSetpoint).temperature, 1) ~= domoticz.utils.round(currentInternalBoilerSetpoint, 1) then
-- domoticz.log('Updating the Boiler internal temperature setpoint to new value: ' ..currentInternalBoilerSetpoint)
domoticz.devices(ToonBoilerSetpoint).updateTemperature(currentInternalBoilerSetpoint)
if domoticz.devices(ToonThermostat).setPoint*100 ~= currentSetpoint*100 then
-- domoticz.log('Updating thermostat sensor to new set point: ' ..currentSetpoint)
domoticz.devices(ToonThermostat).updateSetPoint(currentSetpoint).silent()
if domoticz.utils.round(domoticz.devices(ToonTemperature).temperature, 1) ~= domoticz.utils.round(currentTemperature, 1) then
-- domoticz.log('Updating the temperature sensor to new value: ' ..currentTemperature)
domoticz.devices(ToonTemperature).updateTemperature(currentTemperature)
if domoticz.devices(ToonScenes).level ~= currentActiveState then -- Update toon selector if it has changed
-- domoticz.log('Updating Toon Scenes selector to: '..currentActiveState)
domoticz.devices(ToonScenes).switchSelector(currentActiveState).silent()
if domoticz.devices(ToonAutoProgram).level ~= currentProgramState then -- Update toon auto program selector if it has changed
-- domoticz.log('Updating Toon Auto Program selector to: '..currentProgramState)
domoticz.devices(ToonAutoProgram).switchSelector(currentProgramState).silent()
local currentNextTime = jsonThermostatInfo.nextTime
local currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
if domoticz.devices(ToonProgramInformation).text ~= ToonProgramInformationSensorValue then
-- domoticz.log('Updating Toon Program Information to: '..ToonProgramInformationSensorValue)
domoticz.devices(ToonProgramInformation).updateText(ToonProgramInformationSensorValue)
* raspberry pi3b+
* rooted toon 2
EdwinK
Post by EdwinK »
Thanks for this. Luckily, for me it's working since a few weeks.
Did you know that if you put your scripts in [c o d e] and [/ c o d e] (remove spaces) it will make it more readable, and easier to copy/paste.
Larsoss
Post by Larsoss »
annesdomotic wrote: Saturday 14 December 2019 8:20 perhaps this is useful, almost everything works with these scripts. except the boiler in and out.
setpoint:
devices = {
'ToonThermostat'
script:
timer = {
'every minute'
-- Handle json
handle:close()
return
handle2:close()
handle4:close()
Don't know what you want me to do with this.
Please put them in code display?
Larsoss
Post by Larsoss »
madpatrick wrote: Tuesday 10 December 2019 21:55 How are your user variables set ?
Hi Patrick,
See my screenshot. https://ibb.co/0X1GtKh
madpatrick
Larsoss wrote: Saturday 14 December 2019 17:35
Hi Patrick,
Hello Larsoss,
I see that you are using 3 scripts. I'm only using 2 scripts.
Toon_setpoint
		devices = {
			'Toon Thermostaat'
Toon_script
   logging = {
      level = domoticz.LOG_FORCE, -- Select one of LOG_INFO, LOG_DEBUG, LOG_ERROR, LOG_FORCE to override system log level
      marker = "-=# P1 Toon #=-"
      timer = {
         'every minute'
        local ToonThermostat        = domoticz.variables('UV_ToonThermostat').value -- Sensor showing current setpoint
        local ToonTemperature       = domoticz.variables('UV_ToonTemperature').value -- Sensor showing current room temperature
        local ToonBoilerTempIn      = domoticz.variables('UV_ToonBoilerTempIn').value -- Sensor showing water temp return
        local ToonBoilerTempOut     = domoticz.variables('UV_ToonBoilerTempOut').value -- Sensor showing current water temp out
        local ToonBoilerPressure    = domoticz.variables('UV_ToonBoilerPressure').value -- Sensor showing current room temperature
        local ToonBoilerModulation  = domoticz.variables('UV_ToonBoilerModulation').value -- Sensor showing current Boiler Modulation
        local ToonScenes            = domoticz.variables('UV_ToonScenes').value -- Sensor showing current program
        local ToonAutoProgram       = domoticz.variables('UV_ToonAutoProgram').value -- Sensor showing current auto program status
        local ToonProgramInformation = domoticz.variables('UV_ToonProgramInformation').value -- Sensor showing displaying program information status
        local ToonBoilerSetpoint    = domoticz.variables('UV_ToonBoilerTempSetpoint').value  -- Sensor showing current boiler set point water temp out
-- Handle json
        -- local json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()  -- For Linux
        local json = assert(loadfile "/var/domoticz/scripts/lua/JSON.lua")()  -- For Linux (ClearOS)
        handle:close()
            return
        handle2:close()
-- http://IP_TOON/hdrv_zwave?action=getDevices.json
        handle4:close()
        GasPowerInfo = string.gsub(GasPowerInfo, "dev_2.", "dev_2")
        GasPowerInfo = string.gsub(GasPowerInfo, "dev_2:", "dev_2\":")
-- Update the powerconsumption
         local CurrentElectricityFlowHoog = tonumber(jsonGasPower.dev_24.CurrentElectricityFlow )           --stroomverbruik momenteel hoogtarief
         local CurrentElectricityFlowLaag = tonumber(jsonGasPower.dev_26.CurrentElectricityFlow )           --stroomverbruik momenteel laagtarief
         local CurrentElectricityQuantityHoog = tonumber(jsonGasPower.dev_24.CurrentElectricityQuantity)    --stroomverbruik totaal hoogtarief
         local CurrentElectricityQuantityLaag = tonumber(jsonGasPower.dev_26.CurrentElectricityQuantity)    --stroomverbruik totaal laagtarief
         local CurrentElectricityDeliveredHoog = tonumber(jsonGasPower.dev_25.CurrentElectricityQuantity)   --stroomgeleverd momenteel hoogtarief
         local CurrentElectricityDeliveredLaag = tonumber(jsonGasPower.dev_27.CurrentElectricityQuantity)   --stroomgeleverd momenteel laagtarief
         local CurrentElectricityQuantity =   CurrentElectricityFlowHoog + CurrentElectricityFlowLaag       --stroomverbruik totaal aktueel
         local totalDeliveredPower2 = CurrentElectricityDeliveredHoog/1000 + CurrentElectricityDeliveredLaag/1000      --stroomverbruik totaal geleverd
         local CurrentGasFlow = tonumber(jsonGasPower.dev_21.CurrentGasFlow)
         local CurrentGasQuantity = tonumber(jsonGasPower.dev_21.CurrentGasQuantity)
        --domoticz.log('*** P1 from toon: ' .. CurrentElectricityQuantityLaag/1000 .. 'kwh USAGE1 | ' ..CurrentElectricityQuantityHoog/1000 .. 'kwh USAGE2 | ' .. CurrentElectricityDeliveredLaag/1000 .. 'kwh RETURN1 | ' .. CurrentElectricityDeliveredHoog/1000 .. 'kwh RETURN2 | ' .. CurrentElectricityQuantity .. 'w consumed | '.. totalDeliveredPower2 .. 'w produced', domoticz.LOG_FORCE)
        currentboilerInTemp = tonumber(string.format("%.0f", currentboilerInTemp))  -- afgeronde getallen is voldoende [PdB]
        currentboilerOutTemp = tonumber(string.format("%.0f", currentboilerOutTemp))  -- afgeronde getallen is voldoende [PdB]
--      currentBoilerPressure = tonumber(string.format("%.1f", currentBoilerPressure))  -- 1 decimaal is voldoende [PdB]
            domoticz.log('Updating Boiler Pressure to current value: ' ..currentBoilerPressure, domoticz.LOG_INFO)
-- Update the current temperature setpoint
        local currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
              currentTemperature = tonumber(string.format("%.1f", currentTemperature))  -- 1 decimaal is voldoende [PdB]
-- Update the current auto program
-- Update the current scene by state
-- Update the current scene by temperature
		local currentActiveTemp = tonumber(jsonThermostatInfo.currentSetpoint) / 100
		    if currentActiveTemp == 20.5 then currentActiveState = 40 -- Comfort
		        elseif currentActiveTemp == 19.5 then currentActiveState = 30 -- Home
		        elseif currentActiveTemp == 17 then currentActiveState = 20 -- Sleep
		        elseif currentActiveTemp == 18.5 then currentActiveState = 10 -- Away
		        else	currentActiveState = 50 -- Manual
            elseif currentBurnerInfo == 3 then currentBurnerInfo = 30 -- voorverwarmen volgend setpoint
--      local currentNextTime = jsonThermostatInfo.nextTime
--      local currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
--      if currentNextTime == 0 or currentNextSetPoint == 0 then
--          ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°'
--      else
--          ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°'
--      end
--      if domoticz.devices(ToonProgramInformation).text ~= ToonProgramInformationSensorValue then
--          domoticz.devices(ToonProgramInformation).updateText(ToonProgramInformationSensorValue)
--      end
Maybe this helps you to get a better start.
I don't work with the other script, so diffcult to check for you.
Also check your log file. This could help
I'm using differente UserVariable names the the other script, but basicly it is the same priciple.
Larsoss
Post by Larsoss »
madpatrick wrote: Saturday 14 December 2019 18:20
Hi Patrick,
Hello Larsoss,
Toon_setpoint
		devices = {
			'Toon Thermostaat'
Toon_script
   logging = {
      timer = {
         'every minute'
-- Handle json
        handle:close()
            return
        handle2:close()
        handle4:close()
--      else
--      end
--      end
Ok, i did copy paste, changed the name of my script to the names you wright.
-- Handle json
    --    local json = assert(loadfile "/var/domoticz/scripts/lua/JSON.lua")()  -- For Linux (ClearOS)
Changed this one to my raspberry.
-- http://192.168.1.120/hdrv_zwave?action=getDevices.json
        handle4:close()
And here i changed it to my ip for my toon.
Don't see any changed.. maybe restart my Toon? Restart my Pi?
madpatrick
restart is not necessary
-- in the beginnen in a line, means a comment and not a command
Also check if the location of JSON.lua is correct
Larsoss
Post by Larsoss »
madpatrick wrote: Saturday 14 December 2019 18:36 restart is not necessary
I did checked that, just before you asked about it. And it's there.
madpatrick
did you changed the UV ? I've different names
Further more, what is working and what not.
If you like a can watch at your system with teamviewer
Larsoss
Post by Larsoss »
madpatrick wrote: Saturday 14 December 2019 18:46 did you changed the UV ? I've different names
I did not change the UV. And yes please help me with teamviewer. :D
madpatrick
You have a PM
Larsoss
Post by Larsoss »
madpatrick wrote: Saturday 14 December 2019 18:54 You have a PM
Thanks Patrick for the support.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 1 guest
