Controlling Toon [HACKED] from Domoticz
- madpatrick
- Domoticz version: 2025.2
Re: Controlling Toon [HACKED] from Domoticz
Peebee01
- Domoticz version: 4.1071
Now it works
My mistake was that I had the right UV, they did not have the “current value” shown tothe right of it. I assumed this current value would get written by the script based on the information from the Toon, but it looks like this is the link to the devices....
So modifying the UV and the devices fixed it.
Thanks for your support!
Now it works
Dick60
Can anybody help me with the BurnerInfo script.
This script will update the selectionswitch of the burners status.
What I want is ;
As soon as the burnerinfo=0 ------turn an On/Off switch to Off (SW1)
As soon as the burnerinfo=1-------turn an On/Off switch to On (SW1)
Already strugling with this several days but all testing result in failures.
-- Update the toon burner selector to current program state
CurrentToonBurnerValue = otherdevices_svalues[ToonBurnerName]
if currentBurnerInfo == 0 then currentBurnerInfo = '0' -- uit
elseif currentBurnerInfo == 1 then currentBurnerInfo = '10' -- cv aan
elseif currentBurnerInfo == 2 then currentBurnerInfo = '20' -- warmwater aan
if CurrentToonBurnerValue ~= currentBurnerInfo then -- Update toon burner selector if it has changed
print ('Updating Toon burner info')
commandArray[7] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonBurnerName], currentBurnerInfo)}
endThis script will update the selectionswitch of the burners status.
What I want is ;
- madpatrick
Dick60
I Asked the same question on the site to refered to but I do not understand the script. I dont know the domoticz command. That is why I asked it again on the domoticz forum. I only want to control an dummy on/off switch in Domoticz.
Sjoek
- Domoticz version: V4.10717
Hello everyone!
My Toon and Domoticz worked fine for 2 years, but last week i saw that the Toon Heating and information stopped working.
I have an error in the logs and cannot find any problem in the scripts, should be ok, since it was running fine for years.
This is the error:
2019-12-08 22:52:32.403 Error: EventSystem: in Toon_Getinfo: /home/sjoek/domoticz/scripts/lua/JSON.lua:660: html passed to JSON:decode(): <?xml version="1.0" encoding="iso-8859-1"?>
2019-12-08 22:52:32.403 <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
2019-12-08 22:52:32.403 "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
2019-12-08 22:52:32.403 <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
2019-12-08 22:52:32.403 <head>
2019-12-08 22:52:32.403 <title>403 - Forbidden</title>
2019-12-08 22:52:32.403 </head>
2019-12-08 22:52:32.403 <body>
2019-12-08 22:52:32.403 <h1>403 - Forbidden</h1>
2019-12-08 22:52:32.403 </body>
2019-12-08 22:52:32.403 </html>
Set Toon Hardware off en then back on like Francis did, did not work for me.
Do you guys have any idea?
This is the error:
Larsoss
- Domoticz version: 2020.2
Cant get it working.
https://ibb.co/jHYFWLT
I put the script in Lua - Device
And this is what in my script. The only thing what is working are my Swithes - Toon Scenes. Nothing else.
Name Toon
Script name ToonSetpoint
And the last of them is
ToonThermostat
Name Toon
ToonThermostatSensorName = uservariables['UV_ToonThermostatSensorName'] -- Sensor showing current setpoint
ToonTemperatureSensorName = uservariables['UV_ToonTemperatureSensorName'] -- Sensor showing current room temperature
ToonScenesSensorName = uservariables['UV_ToonScenesSensorName'] -- Sensor showing current program
ToonAutoProgramSensorName = uservariables['UV_ToonAutoProgramSensorName'] -- Sensor showing current auto program status
ToonBurnerName = uservariables['UV_ToonBurnerName']
ToonProgramInformationSensorName = uservariables['UV_ToonProgramInformationSensorName'] -- Sensor showing displaying program information status
ToonBoilerTempSetpoint = uservariables['UV_ToonBoilerTempSetpointSensorName'] -- Sensor showing current internal boiler temp
ToonIP = uservariables['UV_ToonIP']
DomoticzIP = uservariables['UV_DomoticzIP']
-- Choose the correct platform which Domoticz runs on
-- Remove -- before the line which applies for your situation, set -- for all other platforms
-- json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Raspberry
-- json = assert(loadfile "/opt/domoticz/scripts/lua/JSON.lua")() -- For Linux (LEDE)
json = assert(loadfile "C:\\Program Files (x86)\\Domoticz\\scripts\\lua\\json.lua")() -- For Windows
-- json = assert(loadfile "/volume1/@appstore/domoticz/var/scripts/lua/JSON.lua")() -- For Synology
local handle = assert(io.popen(string.format('curl -m 5 http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
local ThermostatInfo = handle:read('*all')
handle:close()
-- JSON data from Toon contains a extra "," which should not be there.
ThermostatInfo = string.gsub(ThermostatInfo, ",}", "}")
jsonThermostatInfo = json:decode(ThermostatInfo)
if jsonThermostatInfo ~= nil then
currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
currentProgramState = tonumber(jsonThermostatInfo.programState)
currentActiveState = tonumber(jsonThermostatInfo.activeState)
currentNextTime = jsonThermostatInfo.nextTime
currentBurnerInfo = tonumber(jsonThermostatInfo.burnerInfo)
currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
currentBoilerSetPoint = tonumber(jsonThermostatInfo.currentInternalBoilerSetpoint)
if currentSetpoint ~= nil then
-- Update the thermostat sensor to current setpoint
if otherdevices_svalues[ToonThermostatSensorName]*100 ~= currentSetpoint*100 then
print('Updating thermostat sensor to new set point: ' ..currentSetpoint)
commandArray[1] = {['Variable:UV_ToonChangedByDomoticz'] = '1'} -- Set variable changed to 1 to prevent script ToonSetPoint from shooting an event at Toon
commandArray[2] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonThermostatSensorName], currentSetpoint)}
if currentTemperature ~= nil then
-- Update the temperature sensor to current room temperature
if otherdevices_svalues[ToonTemperatureSensorName]*100 ~= currentTemperature*100 then
print('Updating the temperature sensor to new value: ' ..currentTemperature)
commandArray[3] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonTemperatureSensorName], currentTemperature)}
if currentBoilerSetPoint ~= nil then
-- Update the temperature of boiler
if otherdevices_svalues[ToonBoilerTempSetpoint]*100 ~= currentBoilerSetPoint*100 then
print('Updating the boiler temperature to new value: ' ..currentBoilerSetPoint)
commandArray[3] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonBoilerTempSetpoint], currentBoilerSetPoint)}
if currentActiveState ~= nil then
-- Update the toon scene selector sensor to current program state
CurrentToonScenesSensorValue = otherdevices_svalues[ToonScenesSensorName]
if currentActiveState == -1 then currentActiveState = '50' -- Manual
elseif currentActiveState == 0 then currentActiveState = '40' -- Comfort
elseif currentActiveState == 1 then currentActiveState = '30' -- Home
elseif currentActiveState == 2 then currentActiveState = '20' -- Sleep
elseif currentActiveState == 3 then currentActiveState = '10' -- Away
if CurrentToonScenesSensorValue ~= currentActiveState then -- Update toon selector if it has changed
print ('Updating Toon Scenes selector')
commandArray[4] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonScenesSensorName], currentActiveState)}
if currentProgramState ~= nil then
-- Updates the toon auto program switch
CurrentToonAutoProgramSensorValue = otherdevices_svalues[ToonAutoProgramSensorName]
if currentProgramState == 0 then currentProgramState = '10' -- No
elseif currentProgramState == 1 then currentProgramState = '20' -- Yes
elseif currentProgramState == 2 then currentProgramState = '30' -- Temporary
if CurrentToonAutoProgramSensorValue ~= currentProgramState then -- Update toon auto program selector if it has changed
print ('Updating Toon Auto Program selector')
commandArray[5] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonAutoProgramSensorName], currentProgramState)}
if currentNextTime ~= nil and currentNextSetPoint ~= nil then
-- Updates the toon program information text box
CurrentToomProgramInformationSensorValue = otherdevices_svalues[ToonProgramInformationSensorName]
if currentNextTime == 0 or currentNextSetPoint == 0 then
ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°'
ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°'
if CurrentToomProgramInformationSensorValue ~= ToonProgramInformationSensorValue then
commandArray[6] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonProgramInformationSensorName], ToonProgramInformationSensorValue)}
return commandArrayCode: Select all
-- script_time_toonselector.lua
-- Reads the Toon Thermostat Setpoint Temperature and updates the
-- selector in Domoticz to represent the current Active State.
-- Off scene is an option, leave it out if not needed.
-- Action commands will not be executed.
-- Settings: Configure as desired
-- Name of the switch with the temperature setpoint.
ThermostatSetPointName = 'ToonThermostat' --Must match the name of you SetPoint device
-- Temperature SetPoints.
OffSetPoint = '6.00' --optional
AwaySetPoint = '17.50'
SleepSetPoint = '19.00'
HomeSetPoint = '20.50'
ComfortSetPoint = '21.00'
-- Name of the selector for Toon
ToonSelector = 'ToonScenes' --Must match (including case) the name of your Selector Switch
-- Name of the levels in the selector
OffLevel = 'Off' --optional
AwayLevel = 'Away'
SleepLevel = 'Sleep'
HomeLevel = 'Home'
ComfortLevel = 'Comfort'
-- Values from each level name
OffLevelValue = '0' --optional
AwayLevelValue = '10'
SleepLevelValue = '20'
HomeLevelValue = '30'
ComfortLevelValue = '40'
-- End of settings
-- Toon Thermostat SetPoint:
ThermostatSetPoint = otherdevices_svalues[ThermostatSetPointName]
if (ThermostatSetPoint == HomeSetPoint) then
--print("SetPoint equals to Home");
if (otherdevices[ToonSelector] ~= HomeLevel) then
print("Updating '" .. ToonSelector .. "' selector to '" .. HomeLevel .. "'")
commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..HomeLevelValue
elseif (ThermostatSetPoint == ComfortSetPoint) then
--print("SetPoint equals to Comfort");
if (otherdevices[ToonSelector] ~= ComfortLevel) then
print("Updating '" .. ToonSelector .. "' selector to '" .. ComfortLevel .. "'")
commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..ComfortLevelValue
elseif (ThermostatSetPoint == SleepSetPoint) then
--print("SetPoint equals to Sleep");
if (otherdevices[ToonSelector] ~= SleepLevel) then
print("Updating '" .. ToonSelector .. "' selector to '" .. SleepLevel .. "'")
commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..SleepLevelValue
elseif (ThermostatSetPoint == AwaySetPoint) then
--print("SetPoint equals to Away");
if (otherdevices[ToonSelector] ~= AwayLevel) then
print("Updating '" .. ToonSelector .. "' selector to '" .. AwayLevel .. "'")
commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..AwayLevelValue
-- Optional
elseif (ThermostatSetPoint == OffSetPoint) then
--print("SetPoint equals to Off");
if (otherdevices[ToonSelector] ~= OffLevel) then
print("Updating '" .. ToonSelector .. "' selector to '" .. OffLevel .. "'")
commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..OffLevelValue
return commandArrayToonThermostat
for deviceName,deviceValue in pairs(devicechanged) do
if (deviceName == ToonThermostatSensorName) then
if uservariables['UV_ToonChangedByDomoticz'] == 1 then
commandArray['Variable:UV_ToonChangedByDomoticz'] = '0'
SetPoint = otherdevices_svalues[ToonThermostatSensorName]
ToonCommand = string.format('http://%s/happ_thermstat?action=setSetpoint&Setpoint=%s', ToonIP, SetPoint*100)
print('Setting Toon setpoint to '.. SetPoint)
commandArray['OpenURL'] = ToonCommand
return commandArrayRaspberry 4 - USB boot Domoticz /|\ Raspberry 2B - Dashticz /|\ Tasmota device's /|\ Philips Hue & Yeelight
- madpatrick
How are your user variables set ?
annesdomotic
- Domoticz version: 4.9700
perhaps this is useful, almost everything works with these scripts. except the boiler in and out.
setpoint:
devices = {
'ToonThermostat'
domoticz.openURL(string.format('http://%s/happ_thermstat?action=setSetpoint&Setpoint=%s', domoticz.variables('UV_ToonIP').value, device.setPoint*100))
domoticz.log('Setting Toon setpoint to '.. device.setPoint)
script:
timer = {
'every minute'
execute = function(domoticz)
local ToonThermostat = domoticz.variables('UV_ToonThermostatSensorName').value -- Sensor showing current setpoint
local ToonTemperature = domoticz.variables('UV_ToonTemperatureSensorName').value -- Sensor showing current room temperature
local ToonBoilerTempIn = domoticz.variables('UV_ToonboilerInTempName').value -- Sensor showing water temp return
local ToonBoilerTempOut = domoticz.variables('UV_ToonboilerOutTempName').value -- Sensor showing current water temp out
local ToonBoilerPressure = domoticz.variables('UV_ToonboilerPressure').value -- Sensor showing current room temperature
local ToonBoilerModulation = domoticz.variables('UV_ToonboilerModulationLevel').value -- Sensor showing current Boiler Modulation
local ToonScenes = domoticz.variables('UV_ToonScenesSensorName').value -- Sensor showing current program
local ToonAutoProgram = domoticz.variables('UV_ToonAutoProgramSensorName').value -- Sensor showing current auto program status
local ToonProgramInformation = domoticz.variables('UV_ToonProgramInformationSensorName').value -- Sensor showing displaying program information status
local ToonIP = domoticz.variables('UV_ToonIP').value
local DomoticzIP = domoticz.variables('UV_DomoticzIP').value
local ToonBurnerName = domoticz.variables('UV_ToonBurnerName').value
local P1SmartMeterPower = domoticz.variables('UV_P1SmartMeterElectra').value
local P1SmartMeterGas1 = domoticz.variables('UV_P1SmartMeterGasMeterStand').value
local ToonBoilerSetpoint = domoticz.variables('UV_ToonBoilerTempSetpointSensorName').value -- Sensor showing current boiler set point water temp out
-- Handle json
local json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Linux
local handle = assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
handle:close()
local jsonThermostatInfo = json:decode(ThermostatInfo)
if jsonThermostatInfo == nil then
return
local handle2 = assert(io.popen(string.format('curl http://%s/boilerstatus/boilervalues.txt', ToonIP)))
local BoilerInfo = handle2:read('*all')
handle2:close()
BoilerInfo = string.gsub(BoilerInfo, ",}", "}")
jsonBoilerInfo = json:decode(BoilerInfo)
--http://192.168.2.193/hdrv_zwave?action=getDevices.json
local handle4 = assert(io.popen(string.format('curl http://%s/hdrv_zwave?action=getDevices.json', ToonIP)))
local GasPowerInfo = handle4:read('*all')
handle4:close()
-- JSON data from Toon contains a extra "." which should not be there.
-- GasPowerInfo = string.gsub(GasPowerInfo, "dev_4.", "dev_4")
-- GasPowerInfo = string.gsub(GasPowerInfo, "dev_4:", "dev_4\":")
-- local jsonGasPower = json:decode(GasPowerInfo)
-- domoticz.log(jsonGasPower)
local CurrentElectricityFlowHoog = tonumber(jsonGasPower.dev_44.CurrentElectricityFlow )
local CurrentElectricityQuantityHoog = tonumber(jsonGasPower.dev_44.CurrentElectricityQuantity)
local CurrentElectricityFlowLaag = tonumber(jsonGasPower.dev_46.CurrentElectricityFlow )
local CurrentElectricityQuantityLaag = tonumber(jsonGasPower.dev_46.CurrentElectricityQuantity)
local CurrentGasFlow = tonumber(jsonGasPower.dev_41.CurrentGasFlow)
local CurrentGasQuantity = tonumber(jsonGasPower.dev_41.CurrentGasQuantity)
local CurrentElectricityQuantity = CurrentElectricityFlowHoog + CurrentElectricityFlowLaag
local CurrentElectricityDeliveredLaag = 0
local CurrentElectricityDeliveredHoog = 0
local totalDeliveredPower = 0
-- domoticz.devices(P1SmartMeterPower).updateP1(CurrentElectricityQuantityLaag, CurrentElectricityQuantityHoog, CurrentElectricityDeliveredLaag, CurrentElectricityDeliveredHoog, CurrentElectricityQuantity, totalDeliveredPower).silent()
-- domoticz.devices(P1SmartMeterGas1).updateGas(CurrentGasQuantity).silent()
-- Update the Boiler Water In to current value
local currentboilerInTemp = tonumber(jsonBoilerInfo.boilerInTemp)
if domoticz.utils.round(domoticz.devices(ToonBoilerTempIn).temperature,0) ~= domoticz.utils.round(currentboilerInTemp,0) then
-- domoticz.log('Updating Boiler Water In to current value: ' ..currentboilerInTemp)
domoticz.devices(ToonBoilerTempIn).updateTemperature(currentboilerInTemp).silent()
-- Update the Boiler water Out to current value
local currentboilerOutTemp = tonumber(jsonBoilerInfo.boilerOutTemp)
if domoticz.utils.round(domoticz.devices(ToonBoilerTempOut).temperature,0) ~= domoticz.utils.round(currentboilerOutTemp,0) then
-- domoticz.log('Updating Boiler Water Out to current value: ' ..currentboilerOutTemp)
domoticz.devices(ToonBoilerTempOut).updateTemperature(currentboilerOutTemp).silent()
-- Update the Boiler water Pressure to current value
local currentBoilerPressure = tonumber(jsonBoilerInfo.boilerPressure)
if domoticz.utils.round(domoticz.devices(ToonBoilerPressure)._nValue,0) ~= domoticz.utils.round(currentBoilerPressure,0) then
-- domoticz.log('Updating Boiler Pressure to current value: ' ..currentBoilerPressure)
domoticz.devices(ToonBoilerPressure).updatePressure(currentBoilerPressure).silent()
local currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
local currentTemperature = domoticz.utils.round(tonumber(jsonThermostatInfo.currentTemp) / 100,1)
local currentProgramState = tonumber(jsonThermostatInfo.programState)
if currentProgramState == 0 then currentProgramState = 10 -- No
elseif currentProgramState == 1 then currentProgramState = 20 -- Yes
elseif currentProgramState == 2 then currentProgramState = 30 -- Temporary
local currentActiveState = tonumber(jsonThermostatInfo.activeState)
if currentActiveState == -1 then currentActiveState = 50 -- Manual
elseif currentActiveState == 0 then currentActiveState = 40 -- Comfort
elseif currentActiveState == 1 then currentActiveState = 30 -- Home
elseif currentActiveState == 2 then currentActiveState = 20 -- Sleep
elseif currentActiveState == 3 then currentActiveState = 10 -- Away<br> elseif currentActiveState == 4 then currentActiveState = 60 -- Holiday
local currentBurnerInfo = tonumber(jsonThermostatInfo.burnerInfo)
local CurrentToonBurnerValue = domoticz.devices(ToonBurnerName).level
if currentBurnerInfo == 0 then currentBurnerInfo = 0 -- uit
elseif currentBurnerInfo == 1 then currentBurnerInfo = 10 -- cv aan
elseif currentBurnerInfo == 2 then currentBurnerInfo = 20 -- warmwater aan<br> elseif currentBurnerInfo == 3 then currentBurnerInfo = 10 -- voorverwarmen volgend setpoint
-- domoticz.log('Updating Toon burner info:')
domoticz.devices(ToonBurnerName).switchSelector(currentBurnerInfo)
-- Update the modulation level of the burner
local currentModulationLevel = tonumber(jsonThermostatInfo.currentModulationLevel)
if domoticz.devices(ToonBoilerModulation).percentage + 1 ~= currentModulationLevel + 1 then
-- domoticz.log('Updating the Modulation sensor to new value: ' ..currentModulationLevel)
domoticz.devices(ToonBoilerModulation).updatePercentage(currentModulationLevel)
-- Update the temperature Boiler setpoint to current boiler set point
local currentInternalBoilerSetpoint = jsonThermostatInfo.currentInternalBoilerSetpoint+1
if domoticz.utils.round(domoticz.devices(ToonBoilerSetpoint).temperature, 1) ~= domoticz.utils.round(currentInternalBoilerSetpoint, 1) then
-- domoticz.log('Updating the Boiler internal temperature setpoint to new value: ' ..currentInternalBoilerSetpoint)
domoticz.devices(ToonBoilerSetpoint).updateTemperature(currentInternalBoilerSetpoint)
if domoticz.devices(ToonThermostat).setPoint*100 ~= currentSetpoint*100 then
-- domoticz.log('Updating thermostat sensor to new set point: ' ..currentSetpoint)
domoticz.devices(ToonThermostat).updateSetPoint(currentSetpoint).silent()
if domoticz.utils.round(domoticz.devices(ToonTemperature).temperature, 1) ~= domoticz.utils.round(currentTemperature, 1) then
-- domoticz.log('Updating the temperature sensor to new value: ' ..currentTemperature)
domoticz.devices(ToonTemperature).updateTemperature(currentTemperature)
if domoticz.devices(ToonScenes).level ~= currentActiveState then -- Update toon selector if it has changed
-- domoticz.log('Updating Toon Scenes selector to: '..currentActiveState)
domoticz.devices(ToonScenes).switchSelector(currentActiveState).silent()
if domoticz.devices(ToonAutoProgram).level ~= currentProgramState then -- Update toon auto program selector if it has changed
-- domoticz.log('Updating Toon Auto Program selector to: '..currentProgramState)
domoticz.devices(ToonAutoProgram).switchSelector(currentProgramState).silent()
local currentNextTime = jsonThermostatInfo.nextTime
local currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
if domoticz.devices(ToonProgramInformation).text ~= ToonProgramInformationSensorValue then
-- domoticz.log('Updating Toon Program Information to: '..ToonProgramInformationSensorValue)
domoticz.devices(ToonProgramInformation).updateText(ToonProgramInformationSensorValue)
setpoint:
devices = {
'ToonThermostat'
script:
timer = {
'every minute'
-- Handle json
handle:close()
return
handle2:close()
handle4:close()
* raspberry pi3b+
* rooted toon 2
* rooted toon 2
- EdwinK
- Domoticz version: BETA
Thanks for this. Luckily, for me it's working since a few weeks.
Did you know that if you put your scripts in [c o d e] and [/ c o d e] (remove spaces) it will make it more readable, and easier to copy/paste.
Larsoss
Don't know what you want me to do with this.annesdomotic wrote: Saturday 14 December 2019 8:20 perhaps this is useful, almost everything works with these scripts. except the boiler in and out.
setpoint:
devices = {
'ToonThermostat'
script:
timer = {
'every minute'
-- Handle json
handle:close()
return
handle2:close()
handle4:close()
Please put them in code display?
Larsoss
- madpatrick
Hello Larsoss,Larsoss wrote: Saturday 14 December 2019 17:35Hi Patrick,
See my screenshot. https://ibb.co/0X1GtKh
I see that you are using 3 scripts. I'm only using 2 scripts.
Toon_setpoint
devices = {
'Toon Thermostaat'
}Code: Select all
logging = {
level = domoticz.LOG_FORCE, -- Select one of LOG_INFO, LOG_DEBUG, LOG_ERROR, LOG_FORCE to override system log level
marker = "-=# P1 Toon #=-"
timer = {
'every minute'
local ToonThermostat = domoticz.variables('UV_ToonThermostat').value -- Sensor showing current setpoint
local ToonTemperature = domoticz.variables('UV_ToonTemperature').value -- Sensor showing current room temperature
local ToonBoilerTempIn = domoticz.variables('UV_ToonBoilerTempIn').value -- Sensor showing water temp return
local ToonBoilerTempOut = domoticz.variables('UV_ToonBoilerTempOut').value -- Sensor showing current water temp out
local ToonBoilerPressure = domoticz.variables('UV_ToonBoilerPressure').value -- Sensor showing current room temperature
local ToonBoilerModulation = domoticz.variables('UV_ToonBoilerModulation').value -- Sensor showing current Boiler Modulation
local ToonScenes = domoticz.variables('UV_ToonScenes').value -- Sensor showing current program
local ToonAutoProgram = domoticz.variables('UV_ToonAutoProgram').value -- Sensor showing current auto program status
local ToonProgramInformation = domoticz.variables('UV_ToonProgramInformation').value -- Sensor showing displaying program information status
local ToonBoilerSetpoint = domoticz.variables('UV_ToonBoilerTempSetpoint').value -- Sensor showing current boiler set point water temp out
-- Handle json
-- local json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Linux
local json = assert(loadfile "/var/domoticz/scripts/lua/JSON.lua")() -- For Linux (ClearOS)
handle:close()
return
handle2:close()
-- http://IP_TOON/hdrv_zwave?action=getDevices.json
handle4:close()
GasPowerInfo = string.gsub(GasPowerInfo, "dev_2.", "dev_2")
GasPowerInfo = string.gsub(GasPowerInfo, "dev_2:", "dev_2\":")
-- Update the powerconsumption
local CurrentElectricityFlowHoog = tonumber(jsonGasPower.dev_24.CurrentElectricityFlow ) --stroomverbruik momenteel hoogtarief
local CurrentElectricityFlowLaag = tonumber(jsonGasPower.dev_26.CurrentElectricityFlow ) --stroomverbruik momenteel laagtarief
local CurrentElectricityQuantityHoog = tonumber(jsonGasPower.dev_24.CurrentElectricityQuantity) --stroomverbruik totaal hoogtarief
local CurrentElectricityQuantityLaag = tonumber(jsonGasPower.dev_26.CurrentElectricityQuantity) --stroomverbruik totaal laagtarief
local CurrentElectricityDeliveredHoog = tonumber(jsonGasPower.dev_25.CurrentElectricityQuantity) --stroomgeleverd momenteel hoogtarief
local CurrentElectricityDeliveredLaag = tonumber(jsonGasPower.dev_27.CurrentElectricityQuantity) --stroomgeleverd momenteel laagtarief
local CurrentElectricityQuantity = CurrentElectricityFlowHoog + CurrentElectricityFlowLaag --stroomverbruik totaal aktueel
local totalDeliveredPower2 = CurrentElectricityDeliveredHoog/1000 + CurrentElectricityDeliveredLaag/1000 --stroomverbruik totaal geleverd
local CurrentGasFlow = tonumber(jsonGasPower.dev_21.CurrentGasFlow)
local CurrentGasQuantity = tonumber(jsonGasPower.dev_21.CurrentGasQuantity)
--domoticz.log('*** P1 from toon: ' .. CurrentElectricityQuantityLaag/1000 .. 'kwh USAGE1 | ' ..CurrentElectricityQuantityHoog/1000 .. 'kwh USAGE2 | ' .. CurrentElectricityDeliveredLaag/1000 .. 'kwh RETURN1 | ' .. CurrentElectricityDeliveredHoog/1000 .. 'kwh RETURN2 | ' .. CurrentElectricityQuantity .. 'w consumed | '.. totalDeliveredPower2 .. 'w produced', domoticz.LOG_FORCE)
currentboilerInTemp = tonumber(string.format("%.0f", currentboilerInTemp)) -- afgeronde getallen is voldoende [PdB]
currentboilerOutTemp = tonumber(string.format("%.0f", currentboilerOutTemp)) -- afgeronde getallen is voldoende [PdB]
-- currentBoilerPressure = tonumber(string.format("%.1f", currentBoilerPressure)) -- 1 decimaal is voldoende [PdB]
domoticz.log('Updating Boiler Pressure to current value: ' ..currentBoilerPressure, domoticz.LOG_INFO)
-- Update the current temperature setpoint
local currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
currentTemperature = tonumber(string.format("%.1f", currentTemperature)) -- 1 decimaal is voldoende [PdB]
-- Update the current auto program
-- Update the current scene by state
-- Update the current scene by temperature
local currentActiveTemp = tonumber(jsonThermostatInfo.currentSetpoint) / 100
if currentActiveTemp == 20.5 then currentActiveState = 40 -- Comfort
elseif currentActiveTemp == 19.5 then currentActiveState = 30 -- Home
elseif currentActiveTemp == 17 then currentActiveState = 20 -- Sleep
elseif currentActiveTemp == 18.5 then currentActiveState = 10 -- Away
else currentActiveState = 50 -- Manual
elseif currentBurnerInfo == 3 then currentBurnerInfo = 30 -- voorverwarmen volgend setpoint
-- local currentNextTime = jsonThermostatInfo.nextTime
-- local currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
-- if currentNextTime == 0 or currentNextSetPoint == 0 then
-- ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°'
-- else
-- ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°'
-- end
-- if domoticz.devices(ToonProgramInformation).text ~= ToonProgramInformationSensorValue then
-- domoticz.devices(ToonProgramInformation).updateText(ToonProgramInformationSensorValue)
-- end
}I don't work with the other script, so diffcult to check for you.
Also check your log file. This could help
I'm using differente UserVariable names the the other script, but basicly it is the same priciple.
Larsoss
Ok, i did copy paste, changed the name of my script to the names you wright.madpatrick wrote: Saturday 14 December 2019 18:20Hello Larsoss,Larsoss wrote: Saturday 14 December 2019 17:35Hi Patrick,
Toon_setpointToon_scriptCode: Select all
return { on = { devices = { 'Toon Thermostaat' } }, execute = function(domoticz, device) domoticz.openURL(string.format('http://%s/happ_thermstat?action=setSetpoint&Setpoint=%s', domoticz.variables('UV_ToonIP').value, device.setPoint*100)) domoticz.log('Setting Toon setpoint to '.. device.setPoint) end }Maybe this helps you to get a better start.Code: Select all
return { logging = { level = domoticz.LOG_FORCE, -- Select one of LOG_INFO, LOG_DEBUG, LOG_ERROR, LOG_FORCE to override system log level marker = "-=# P1 Toon #=-" }, on = { timer = { 'every minute' } }, execute = function(domoticz) local ToonThermostat = domoticz.variables('UV_ToonThermostat').value -- Sensor showing current setpoint local ToonTemperature = domoticz.variables('UV_ToonTemperature').value -- Sensor showing current room temperature local ToonBoilerTempIn = domoticz.variables('UV_ToonBoilerTempIn').value -- Sensor showing water temp return local ToonBoilerTempOut = domoticz.variables('UV_ToonBoilerTempOut').value -- Sensor showing current water temp out local ToonBoilerPressure = domoticz.variables('UV_ToonBoilerPressure').value -- Sensor showing current room temperature local ToonBoilerModulation = domoticz.variables('UV_ToonBoilerModulation').value -- Sensor showing current Boiler Modulation local ToonScenes = domoticz.variables('UV_ToonScenes').value -- Sensor showing current program local ToonAutoProgram = domoticz.variables('UV_ToonAutoProgram').value -- Sensor showing current auto program status local ToonProgramInformation = domoticz.variables('UV_ToonProgramInformation').value -- Sensor showing displaying program information status local ToonIP = domoticz.variables('UV_ToonIP').value local DomoticzIP = domoticz.variables('UV_DomoticzIP').value local ToonBurnerName = domoticz.variables('UV_ToonBurnerName').value local P1SmartMeterPower = domoticz.variables('UV_P1SmartMeterElectra').value local P1SmartMeterGas1 = domoticz.variables('UV_P1SmartMeterGasMeterStand').value local ToonBoilerSetpoint = domoticz.variables('UV_ToonBoilerTempSetpoint').value -- Sensor showing current boiler set point water temp out -- Handle json -- local json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Linux local json = assert(loadfile "/var/domoticz/scripts/lua/JSON.lua")() -- For Linux (ClearOS) local handle = assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP))) local ThermostatInfo = handle:read('*all') handle:close() local jsonThermostatInfo = json:decode(ThermostatInfo) if jsonThermostatInfo == nil then return end local handle2 = assert(io.popen(string.format('curl http://%s/boilerstatus/boilervalues.txt', ToonIP))) local BoilerInfo = handle2:read('*all') handle2:close() -- JSON data from Toon contains a extra "," which should not be there. BoilerInfo = string.gsub(BoilerInfo, ",}", "}") jsonBoilerInfo = json:decode(BoilerInfo) -- http://IP_TOON/hdrv_zwave?action=getDevices.json local handle4 = assert(io.popen(string.format('curl http://%s/hdrv_zwave?action=getDevices.json', ToonIP))) local GasPowerInfo = handle4:read('*all') handle4:close() -- JSON data from Toon contains a extra "." which should not be there. GasPowerInfo = string.gsub(GasPowerInfo, "dev_2.", "dev_2") GasPowerInfo = string.gsub(GasPowerInfo, "dev_2:", "dev_2\":") local jsonGasPower = json:decode(GasPowerInfo) -- Update the powerconsumption local CurrentElectricityFlowHoog = tonumber(jsonGasPower.dev_24.CurrentElectricityFlow ) --stroomverbruik momenteel hoogtarief local CurrentElectricityFlowLaag = tonumber(jsonGasPower.dev_26.CurrentElectricityFlow ) --stroomverbruik momenteel laagtarief local CurrentElectricityQuantityHoog = tonumber(jsonGasPower.dev_24.CurrentElectricityQuantity) --stroomverbruik totaal hoogtarief local CurrentElectricityQuantityLaag = tonumber(jsonGasPower.dev_26.CurrentElectricityQuantity) --stroomverbruik totaal laagtarief local CurrentElectricityDeliveredHoog = tonumber(jsonGasPower.dev_25.CurrentElectricityQuantity) --stroomgeleverd momenteel hoogtarief local CurrentElectricityDeliveredLaag = tonumber(jsonGasPower.dev_27.CurrentElectricityQuantity) --stroomgeleverd momenteel laagtarief local CurrentElectricityQuantity = CurrentElectricityFlowHoog + CurrentElectricityFlowLaag --stroomverbruik totaal aktueel local totalDeliveredPower = 0 local totalDeliveredPower2 = CurrentElectricityDeliveredHoog/1000 + CurrentElectricityDeliveredLaag/1000 --stroomverbruik totaal geleverd local CurrentGasFlow = tonumber(jsonGasPower.dev_21.CurrentGasFlow) local CurrentGasQuantity = tonumber(jsonGasPower.dev_21.CurrentGasQuantity) domoticz.devices(P1SmartMeterPower).updateP1(CurrentElectricityQuantityLaag, CurrentElectricityQuantityHoog, CurrentElectricityDeliveredLaag, CurrentElectricityDeliveredHoog, CurrentElectricityQuantity, totalDeliveredPower).silent() domoticz.devices(P1SmartMeterGas1).updateGas(CurrentGasQuantity).silent() --domoticz.log('*** P1 from toon: ' .. CurrentElectricityQuantityLaag/1000 .. 'kwh USAGE1 | ' ..CurrentElectricityQuantityHoog/1000 .. 'kwh USAGE2 | ' .. CurrentElectricityDeliveredLaag/1000 .. 'kwh RETURN1 | ' .. CurrentElectricityDeliveredHoog/1000 .. 'kwh RETURN2 | ' .. CurrentElectricityQuantity .. 'w consumed | '.. totalDeliveredPower2 .. 'w produced', domoticz.LOG_FORCE) -- Update the Boiler Water In to current value local currentboilerInTemp = tonumber(jsonBoilerInfo.boilerInTemp) currentboilerInTemp = tonumber(string.format("%.0f", currentboilerInTemp)) -- afgeronde getallen is voldoende [PdB] if domoticz.utils.round(domoticz.devices(ToonBoilerTempIn).temperature,0) ~= domoticz.utils.round(currentboilerInTemp,0) then domoticz.log('Updating Boiler Water In to current value: ' ..currentboilerInTemp) domoticz.devices(ToonBoilerTempIn).updateTemperature(currentboilerInTemp).silent() end -- Update the Boiler water Out to current value local currentboilerOutTemp = tonumber(jsonBoilerInfo.boilerOutTemp) currentboilerOutTemp = tonumber(string.format("%.0f", currentboilerOutTemp)) -- afgeronde getallen is voldoende [PdB] if domoticz.utils.round(domoticz.devices(ToonBoilerTempOut).temperature,0) ~= domoticz.utils.round(currentboilerOutTemp,0) then domoticz.log('Updating Boiler Water Out to current value: ' ..currentboilerOutTemp) domoticz.devices(ToonBoilerTempOut).updateTemperature(currentboilerOutTemp).silent() end -- Update the Boiler water Pressure to current value local currentBoilerPressure = tonumber(jsonBoilerInfo.boilerPressure) -- currentBoilerPressure = tonumber(string.format("%.1f", currentBoilerPressure)) -- 1 decimaal is voldoende [PdB] if domoticz.utils.round(domoticz.devices(ToonBoilerPressure)._nValue,0) ~= domoticz.utils.round(currentBoilerPressure,0) then domoticz.log('Updating Boiler Pressure to current value: ' ..currentBoilerPressure, domoticz.LOG_INFO) domoticz.devices(ToonBoilerPressure).updatePressure(currentBoilerPressure).silent() end -- Update the current temperature setpoint local currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100 local currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100 currentTemperature = tonumber(string.format("%.1f", currentTemperature)) -- 1 decimaal is voldoende [PdB] -- Update the current auto program local currentProgramState = tonumber(jsonThermostatInfo.programState) if currentProgramState == 0 then currentProgramState = 10 -- No elseif currentProgramState == 1 then currentProgramState = 20 -- Yes elseif currentProgramState == 2 then currentProgramState = 30 -- Temporary end -- Update the current scene by state local currentActiveState = tonumber(jsonThermostatInfo.activeState) if currentActiveState == -1 then currentActiveState = 50 -- Manual elseif currentActiveState == 0 then currentActiveState = 40 -- Comfort elseif currentActiveState == 1 then currentActiveState = 30 -- Home elseif currentActiveState == 2 then currentActiveState = 20 -- Sleep elseif currentActiveState == 3 then currentActiveState = 10 -- Away end -- Update the current scene by temperature local currentActiveTemp = tonumber(jsonThermostatInfo.currentSetpoint) / 100 if currentActiveTemp == 20.5 then currentActiveState = 40 -- Comfort elseif currentActiveTemp == 19.5 then currentActiveState = 30 -- Home elseif currentActiveTemp == 17 then currentActiveState = 20 -- Sleep elseif currentActiveTemp == 18.5 then currentActiveState = 10 -- Away else currentActiveState = 50 -- Manual end -- Update the toon burner selector to current program state local currentBurnerInfo = tonumber(jsonThermostatInfo.burnerInfo) local CurrentToonBurnerValue = domoticz.devices(ToonBurnerName).level if currentBurnerInfo == 0 then currentBurnerInfo = 0 -- uit elseif currentBurnerInfo == 1 then currentBurnerInfo = 10 -- cv aan elseif currentBurnerInfo == 2 then currentBurnerInfo = 20 -- warmwater aan elseif currentBurnerInfo == 3 then currentBurnerInfo = 30 -- voorverwarmen volgend setpoint end -- Update toon burner selector if it has changed if CurrentToonBurnerValue ~= currentBurnerInfo then domoticz.log('Updating Toon burner info:') domoticz.devices(ToonBurnerName).switchSelector(currentBurnerInfo) end -- Update the modulation level of the burner local currentModulationLevel = tonumber(jsonThermostatInfo.currentModulationLevel) if domoticz.devices(ToonBoilerModulation).percentage + 1 ~= currentModulationLevel + 1 then domoticz.log('Updating the Modulation sensor to new value: ' ..currentModulationLevel) domoticz.devices(ToonBoilerModulation).updatePercentage(currentModulationLevel) end -- Update the temperature Boiler setpoint to current boiler set point local currentInternalBoilerSetpoint = jsonThermostatInfo.currentInternalBoilerSetpoint+1 if domoticz.utils.round(domoticz.devices(ToonBoilerSetpoint).temperature, 1) ~= domoticz.utils.round(currentInternalBoilerSetpoint, 1) then domoticz.log('Updating the Boiler internal temperature setpoint to new value: ' ..currentInternalBoilerSetpoint) domoticz.devices(ToonBoilerSetpoint).updateTemperature(currentInternalBoilerSetpoint) end -- Update the thermostat sensor to current setpoint if domoticz.devices(ToonThermostat).setPoint*100 ~= currentSetpoint*100 then domoticz.log('Updating thermostat sensor to new set point: ' ..currentSetpoint) domoticz.devices(ToonThermostat).updateSetPoint(currentSetpoint).silent() end -- Update the temperature sensor to current room temperature if domoticz.utils.round(domoticz.devices(ToonTemperature).temperature, 1) ~= domoticz.utils.round(currentTemperature, 1) then domoticz.log('Updating the temperature sensor to new value: ' ..currentTemperature) domoticz.devices(ToonTemperature).updateTemperature(currentTemperature) end -- Update the toon scene selector sensor to current program state if domoticz.devices(ToonScenes).level ~= currentActiveState then -- Update toon selector if it has changed domoticz.log('Updating Toon Scenes selector to: '..currentActiveState) domoticz.devices(ToonScenes).switchSelector(currentActiveState).silent() end -- Updates the toon auto program switch if domoticz.devices(ToonAutoProgram).level ~= currentProgramState then -- Update toon auto program selector if it has changed domoticz.log('Updating Toon Auto Program selector to: '..currentProgramState) domoticz.devices(ToonAutoProgram).switchSelector(currentProgramState).silent() end -- Updates the toon program information text box -- local currentNextTime = jsonThermostatInfo.nextTime -- local currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100 -- if currentNextTime == 0 or currentNextSetPoint == 0 then -- ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°' -- else -- ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°' -- end -- if domoticz.devices(ToonProgramInformation).text ~= ToonProgramInformationSensorValue then -- domoticz.log('Updating Toon Program Information to: '..ToonProgramInformationSensorValue) -- domoticz.devices(ToonProgramInformation).updateText(ToonProgramInformationSensorValue) -- end end }
-- Handle json
-- local json = assert(loadfile "/var/domoticz/scripts/lua/JSON.lua")() -- For Linux (ClearOS)
-- http://192.168.1.120/hdrv_zwave?action=getDevices.json
handle4:close()Don't see any changed.. maybe restart my Toon? Restart my Pi?
- madpatrick
restart is not necessary
-- in the beginnen in a line, means a comment and not a command
Also check if the location of JSON.lua is correct
Larsoss
I did checked that, just before you asked about it. And it's there.madpatrick wrote: Saturday 14 December 2019 18:36 restart is not necessary
- madpatrick
did you changed the UV ? I've different names
Further more, what is working and what not.
If you like a can watch at your system with teamviewer
Larsoss
I did not change the UV. And yes please help me with teamviewer.madpatrick wrote: Saturday 14 December 2019 18:46 did you changed the UV ? I've different names
- madpatrick
You have a PM
Larsoss
Thanks Patrick for the support.
