restart hardware service from script  [Solved]
franzelare
Post by franzelare »
i was wondering if it is possible to restart a hardware service through dzvents?
my evo home heating control system web api sometimes stops working, when i restart the service is works fine again.
i know how to detect error strings using dzvents but like to be able to restart a service
2019-12-13 21:59:32.005 Status: (Evo Home) Worker stopped...
2019-12-13 21:59:32.006 Status: (Evo Home) Worker started...
Re: restart hardware service from script  [Solved]
franzelare wrote: Friday 13 December 2019 22:00 i was wondering if it is possible to restart a hardware service through dzvents?
It is possible but not straight forward.
        devices = {
            'evoTrigger'
    logging =
        level = domoticz.LOG_DEBUG
        _G.logMarker =  _G.moduleLabel
        local function evohome(action, delay)
            if action == 'restart' then
                evohome('disable')
                evohome('enable', 3)
            if not(dz) then dz = domoticz end
            local username = 'your userid' -- change
            local password = 'your password' -- change
            local hardwareName = 'Evohome' -- change
            local hardwareIDX = xx  -- change
            local action = ( ( action == 'enable' and 'true' ) or 'false')
            local url =
                 dz.settings['Domoticz url'] .. '/json.htm?type=command&param=updatehardware&htype=75' ..
                '&username=' .. dz.utils.urlEncode(username) ..
                '&password=' .. dz.utils.urlEncode(password) ..
                '&name=' .. dz.utils.urlEncode(hardwareName) ..
                '&idx=' .. tostring(hardwareIDX) ..
                '&enabled=' .. tostring(action)
            dz.openURL(url).afterSec(delay or 0)
        -- call function with one of
            -- evohome('enable') -- or
            --  evohome('disable') -- or
            evohome('restart')
franzelare
thanks!
i put this in a script, so will see at the next failure if it works
Alain
Domoticz version: 2022.1
Post by Alain »
waaren wrote: Saturday 14 December 2019 1:14
        devices = {
            'evoTrigger'
    logging =
                evohome('disable')
            local url =
            evohome('restart')
I am running the ModbusRead and ModbusWrite plugins, but am having a problem with connection errors. The errors arise from the plugin sending a request to the Modbus device from different hardware devices. I have to create a new hardware device for every modbus address and I currently have 21 of them. in the plugin you can set the pollrate and I set them differently for each device, however, after a while, some will send a request to the same modbus device at the same time and it causes communication errors because the modbus device can't handle the multiple requests at the same time. The way to keep these errors to a minimum would be to have a script running that will automatically restart the plugin if a log message with the text "Modbus error decoding or received no data". I'm not very familiar with dzvents, so how would I go about modifying the above script?
I currently restart Domoticz twice a day via a crontab, but that's still not sufficient. More effective would be to restart the hardware device that's throwing the errors as that resets its polling time and gets it out of sync with another device.
Hardware devices
Hardware devices
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | TP-Link | Node-Red | Grafana |
