Graph for one phase of my P1 connection not working
ykuijs
Post by ykuijs »
I recently upgraded my electricity to a 3 phase connection. The new power meter also had a P1 port, so I connected it to my Domoticz system. I am now trying to show the power used for each phase. Phase 1 and 2 are displaying just fine, however phase 3 doesn't show any graph, but does show the correct current usage in the header so it is able retrieve data from Domoticz. However, the graph for Last Month does show some output, similar to the graph in Domoticz.
All graphs in Domoticz for this device are displaying just fine, so the device is generating output. Currently I am not using any graph customization (yet).
How can I get this third graph to also work like the other two phases?
FireWizard
Re: Graph for one phase of my P1 connection
Post by FireWizard »
One question.
You posted recently another issue, where you indicated, that you use Dashticz.
Do you mean the Dashticz graphs here as well?
If so, how do the Domoticz sensors and graphs look like?
Lokonli
Re: Graph for one phase of my P1 connection not working
Post by Lokonli »
ykuijs wrote: Wednesday 04 December 2019 22:49 I recently upgraded my electricity to a 3 phase connection. The new power meter also had a P1 port, so I connected it to my Domoticz system. I am now trying to show the power used for each phase. Phase 1 and 2 are displaying just fine, however phase 3 doesn't show any graph, but does show the correct current usage in the header so it is able retrieve data from Domoticz. However, the graph for Last Month does show some output, similar to the graph in Domoticz.
Can you send the Domoticz json output of the 3-phase device? Then I'll have a look.
ykuijs
Post by ykuijs »
@FireWizard, yes I mean the graphs in Dashticz. The graphs in Domoticz look just fine.
@Lokonli, here the info you requested:
The JSON output for phase 2 (which is working fine):
   "ActTime" : 1575532613,
   "AstrTwilightEnd" : "18:33",
   "AstrTwilightStart" : "06:26",
   "CivTwilightEnd" : "17:09",
   "CivTwilightStart" : "07:50",
   "DayLength" : "08:00",
   "NautTwilightEnd" : "17:52",
   "NautTwilightStart" : "07:07",
   "ServerTime" : "2019-12-05 08:56:53",
   "SunAtSouth" : "12:30",
   "Sunrise" : "08:29",
   "Sunset" : "16:30",
   "app_version" : "4.10717",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "54 Watt",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 7,
         "HardwareName" : "Slimme Meter",
         "HardwareType" : "P1 Smart Meter USB",
         "HardwareTypeVal" : 4,
         "HaveTimeout" : false,
         "ID" : "0000000",
         "LastUpdate" : "2019-12-05 08:56:52",
         "Name" : "Stroomverbruik Fase 2",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "Electric",
         "Timers" : "false",
         "Type" : "Usage",
         "TypeImg" : "current",
         "Unit" : 2,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "44"
   "status" : "OK",
   "title" : "Devices"
The JSON output for phase 3 (which isn't working):
   "ActTime" : 1575532701,
   "ServerTime" : "2019-12-05 08:58:21",
   "Sunset" : "16:30",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "0 Watt",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 7,
         "ID" : "0000000",
         "LastUpdate" : "2019-12-05 08:58:21",
         "Name" : "Stroomverbruik Fase 3",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Timers" : "false",
         "Type" : "Usage",
         "Unit" : 3,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "45"
   "status" : "OK",
   "title" : "Devices"
Lokonli
Post by Lokonli »
I don't have a 3 phase device, so it's difficult to reproduce.
Could you post the graph data as well?
http://<Domoticz IP address>/json.htm?type=graph&sensor=counter&idx=44&range=day&method=1
http://<Domoticz IP address>/json.htm?type=graph&sensor=counter&idx=45&range=day&method=1
The first line (idx44) is your phase 2, and the second line (idx45) your phase 3.
ykuijs
Post by ykuijs »
Here the requested graph data:
Phase 2 (idx 44)
   "result" : [
         "d" : "2019-12-11 22:30",
         "u" : 198.0
         "d" : "2019-12-11 22:35",
         "u" : 92.0
         "d" : "2019-12-11 22:40",
         "u" : 96.0
         "d" : "2019-12-11 22:45",
         "u" : 84.0
         "d" : "2019-12-11 22:50",
         "u" : 123.0
         "d" : "2019-12-11 22:55",
         "u" : 133.0
         "d" : "2019-12-11 23:00",
         "u" : 45.0
         "d" : "2019-12-11 23:05",
         "u" : 45.0
         "d" : "2019-12-11 23:10",
         "u" : 45.0
         "d" : "2019-12-11 23:15",
         "u" : 44.0
         "d" : "2019-12-11 23:20",
         "u" : 131.0
         "d" : "2019-12-11 23:25",
         "u" : 45.0
         "d" : "2019-12-11 23:30",
         "u" : 44.0
         "d" : "2019-12-11 23:35",
         "u" : 45.0
         "d" : "2019-12-11 23:40",
         "u" : 45.0
         "d" : "2019-12-11 23:45",
         "u" : 45.0
         "d" : "2019-12-11 23:50",
         "u" : 124.0
         "d" : "2019-12-11 23:55",
         "u" : 46.0
         "d" : "2019-12-12 00:00",
         "u" : 46.0
         "d" : "2019-12-12 00:05",
         "u" : 46.0
         "d" : "2019-12-12 00:10",
         "u" : 45.0
         "d" : "2019-12-12 00:15",
         "u" : 45.0
         "d" : "2019-12-12 00:20",
         "u" : 124.0
         "d" : "2019-12-12 00:25",
         "u" : 102.0
         "d" : "2019-12-12 00:30",
         "u" : 106.0
         "d" : "2019-12-12 00:35",
         "u" : 46.0
         "d" : "2019-12-12 00:40",
         "u" : 45.0
         "d" : "2019-12-12 00:45",
         "u" : 46.0
         "d" : "2019-12-12 00:50",
         "u" : 126.0
         "d" : "2019-12-12 00:55",
         "u" : 45.0
         "d" : "2019-12-12 01:00",
         "u" : 45.0
         "d" : "2019-12-12 01:05",
         "u" : 46.0
         "d" : "2019-12-12 01:10",
         "u" : 46.0
         "d" : "2019-12-12 01:15",
         "u" : 45.0
         "d" : "2019-12-12 01:20",
         "u" : 46.0
         "d" : "2019-12-12 01:25",
         "u" : 126.0
         "d" : "2019-12-12 01:30",
         "u" : 45.0
         "d" : "2019-12-12 01:35",
         "u" : 46.0
         "d" : "2019-12-12 01:40",
         "u" : 47.0
         "d" : "2019-12-12 01:45",
         "u" : 132.0
         "d" : "2019-12-12 01:50",
         "u" : 46.0
         "d" : "2019-12-12 01:55",
         "u" : 45.0
         "d" : "2019-12-12 02:00",
         "u" : 45.0
         "d" : "2019-12-12 02:05",
         "u" : 46.0
         "d" : "2019-12-12 02:10",
         "u" : 45.0
         "d" : "2019-12-12 02:15",
         "u" : 46.0
         "d" : "2019-12-12 02:20",
         "u" : 126.0
         "d" : "2019-12-12 02:25",
         "u" : 45.0
         "d" : "2019-12-12 02:30",
         "u" : 45.0
         "d" : "2019-12-12 02:35",
         "u" : 46.0
         "d" : "2019-12-12 02:40",
         "u" : 46.0
         "d" : "2019-12-12 02:45",
         "u" : 125.0
         "d" : "2019-12-12 02:50",
         "u" : 46.0
         "d" : "2019-12-12 02:55",
         "u" : 47.0
         "d" : "2019-12-12 03:00",
         "u" : 45.0
         "d" : "2019-12-12 03:05",
         "u" : 46.0
         "d" : "2019-12-12 03:10",
         "u" : 46.0
         "d" : "2019-12-12 03:15",
         "u" : 127.0
         "d" : "2019-12-12 03:20",
         "u" : 46.0
         "d" : "2019-12-12 03:25",
         "u" : 46.0
         "d" : "2019-12-12 03:30",
         "u" : 46.0
         "d" : "2019-12-12 03:35",
         "u" : 46.0
         "d" : "2019-12-12 03:40",
         "u" : 45.0
         "d" : "2019-12-12 03:45",
         "u" : 130.0
         "d" : "2019-12-12 03:50",
         "u" : 45.0
         "d" : "2019-12-12 03:55",
         "u" : 45.0
         "d" : "2019-12-12 04:00",
         "u" : 46.0
         "d" : "2019-12-12 04:05",
         "u" : 46.0
         "d" : "2019-12-12 04:10",
         "u" : 46.0
         "d" : "2019-12-12 04:15",
         "u" : 46.0
         "d" : "2019-12-12 04:20",
         "u" : 46.0
         "d" : "2019-12-12 04:25",
         "u" : 126.0
         "d" : "2019-12-12 04:30",
         "u" : 46.0
         "d" : "2019-12-12 04:35",
         "u" : 45.0
         "d" : "2019-12-12 04:40",
         "u" : 46.0
         "d" : "2019-12-12 04:45",
         "u" : 46.0
         "d" : "2019-12-12 04:50",
         "u" : 127.0
         "d" : "2019-12-12 04:55",
         "u" : 46.0
         "d" : "2019-12-12 05:00",
         "u" : 46.0
         "d" : "2019-12-12 05:05",
         "u" : 45.0
         "d" : "2019-12-12 05:10",
         "u" : 45.0
         "d" : "2019-12-12 05:15",
         "u" : 45.0
         "d" : "2019-12-12 05:20",
         "u" : 45.0
         "d" : "2019-12-12 05:25",
         "u" : 44.0
         "d" : "2019-12-12 05:30",
         "u" : 44.0
         "d" : "2019-12-12 05:35",
         "u" : 44.0
         "d" : "2019-12-12 05:40",
         "u" : 45.0
         "d" : "2019-12-12 05:45",
         "u" : 79.0
         "d" : "2019-12-12 05:50",
         "u" : 122.0
         "d" : "2019-12-12 05:55",
         "u" : 122.0
         "d" : "2019-12-12 06:00",
         "u" : 71.0
         "d" : "2019-12-12 06:05",
         "u" : 123.0
         "d" : "2019-12-12 06:10",
         "u" : 126.0
         "d" : "2019-12-12 06:15",
         "u" : 184.0
         "d" : "2019-12-12 06:20",
         "u" : 187.0
         "d" : "2019-12-12 06:25",
         "u" : 125.0
         "d" : "2019-12-12 06:30",
         "u" : 126.0
         "d" : "2019-12-12 06:35",
         "u" : 125.0
         "d" : "2019-12-12 06:40",
         "u" : 202.0
         "d" : "2019-12-12 06:45",
         "u" : 743.0
         "d" : "2019-12-12 06:50",
         "u" : 243.0
         "d" : "2019-12-12 06:55",
         "u" : 243.0
         "d" : "2019-12-12 07:00",
         "u" : 241.0
         "d" : "2019-12-12 07:05",
         "u" : 324.0
         "d" : "2019-12-12 07:10",
         "u" : 221.0
         "d" : "2019-12-12 07:15",
         "u" : 199.0
         "d" : "2019-12-12 07:20",
         "u" : 211.0
         "d" : "2019-12-12 07:25",
         "u" : 214.0
         "d" : "2019-12-12 07:30",
         "u" : 225.0
         "d" : "2019-12-12 07:35",
         "u" : 295.0
         "d" : "2019-12-12 07:40",
         "u" : 210.0
         "d" : "2019-12-12 07:45",
         "u" : 202.0
         "d" : "2019-12-12 07:50",
         "u" : 195.0
         "d" : "2019-12-12 07:55",
         "u" : 100.0
         "d" : "2019-12-12 08:00",
         "u" : 116.0
         "d" : "2019-12-12 08:05",
         "u" : 211.0
         "d" : "2019-12-12 08:10",
         "u" : 137.0
         "d" : "2019-12-12 08:15",
         "u" : 125.0
         "d" : "2019-12-12 08:20",
         "u" : 101.0
         "d" : "2019-12-12 08:25",
         "u" : 85.0
         "d" : "2019-12-12 08:30",
         "u" : 162.0
         "d" : "2019-12-12 08:35",
         "u" : 72.0
         "d" : "2019-12-12 08:40",
         "u" : 117.0
         "d" : "2019-12-12 08:45",
         "u" : 135.0
         "d" : "2019-12-12 08:50",
         "u" : 59.0
         "d" : "2019-12-12 08:55",
         "u" : 72.0
         "d" : "2019-12-12 09:00",
         "u" : 63.0
         "d" : "2019-12-12 09:05",
         "u" : 107.0
         "d" : "2019-12-12 09:10",
         "u" : 125.0
         "d" : "2019-12-12 09:15",
         "u" : 217.0
         "d" : "2019-12-12 09:20",
         "u" : 204.0
         "d" : "2019-12-12 09:25",
         "u" : 85.0
         "d" : "2019-12-12 09:30",
         "u" : 74.0
         "d" : "2019-12-12 09:35",
         "u" : 59.0
         "d" : "2019-12-12 09:40",
         "u" : 162.0
         "d" : "2019-12-12 09:45",
         "u" : 71.0
         "d" : "2019-12-12 09:50",
         "u" : 75.0
         "d" : "2019-12-12 09:55",
         "u" : 65.0
         "d" : "2019-12-12 10:00",
         "u" : 76.0
         "d" : "2019-12-12 10:05",
         "u" : 67.0
         "d" : "2019-12-12 10:10",
         "u" : 54.0
         "d" : "2019-12-12 10:15",
         "u" : 66.0
         "d" : "2019-12-12 10:20",
         "u" : 136.0
         "d" : "2019-12-12 10:25",
         "u" : 65.0
         "d" : "2019-12-12 10:30",
         "u" : 52.0
         "d" : "2019-12-12 10:35",
         "u" : 65.0
         "d" : "2019-12-12 10:40",
         "u" : 54.0
         "d" : "2019-12-12 10:45",
         "u" : 120.0
         "d" : "2019-12-12 10:50",
         "u" : 121.0
         "d" : "2019-12-12 10:55",
         "u" : 200.0
         "d" : "2019-12-12 11:00",
         "u" : 87.0
         "d" : "2019-12-12 11:05",
         "u" : 78.0
         "d" : "2019-12-12 11:10",
         "u" : 74.0
         "d" : "2019-12-12 11:15",
         "u" : 57.0
         "d" : "2019-12-12 11:20",
         "u" : 74.0
         "d" : "2019-12-12 11:25",
         "u" : 56.0
         "d" : "2019-12-12 11:30",
         "u" : 136.0
         "d" : "2019-12-12 11:35",
         "u" : 57.0
         "d" : "2019-12-12 11:40",
         "u" : 53.0
         "d" : "2019-12-12 11:45",
         "u" : 113.0
         "d" : "2019-12-12 11:50",
         "u" : 114.0
         "d" : "2019-12-12 11:55",
         "u" : 56.0
         "d" : "2019-12-12 12:00",
         "u" : 55.0
         "d" : "2019-12-12 12:05",
         "u" : 144.0
         "d" : "2019-12-12 12:10",
         "u" : 54.0
         "d" : "2019-12-12 12:15",
         "u" : 66.0
         "d" : "2019-12-12 12:20",
         "u" : 52.0
         "d" : "2019-12-12 12:25",
         "u" : 151.0
         "d" : "2019-12-12 12:30",
         "u" : 53.0
         "d" : "2019-12-12 12:35",
         "u" : 65.0
         "d" : "2019-12-12 12:40",
         "u" : 53.0
         "d" : "2019-12-12 12:45",
         "u" : 91.0
         "d" : "2019-12-12 12:50",
         "u" : 119.0
         "d" : "2019-12-12 12:55",
         "u" : 168.0
         "d" : "2019-12-12 13:00",
         "u" : 69.0
         "d" : "2019-12-12 13:05",
         "u" : 54.0
         "d" : "2019-12-12 13:10",
         "u" : 40.0
         "d" : "2019-12-12 13:15",
         "u" : 57.0
         "d" : "2019-12-12 13:20",
         "u" : 53.0
         "d" : "2019-12-12 13:25",
         "u" : 135.0
         "d" : "2019-12-12 13:30",
         "u" : 52.0
         "d" : "2019-12-12 13:35",
         "u" : 66.0
         "d" : "2019-12-12 13:40",
         "u" : 54.0
         "d" : "2019-12-12 13:45",
         "u" : 65.0
         "d" : "2019-12-12 13:50",
         "u" : 59.0
         "d" : "2019-12-12 13:55",
         "u" : 157.0
         "d" : "2019-12-12 14:00",
         "u" : 53.0
         "d" : "2019-12-12 14:05",
         "u" : 65.0
         "d" : "2019-12-12 14:10",
         "u" : 51.0
         "d" : "2019-12-12 14:15",
         "u" : 64.0
         "d" : "2019-12-12 14:20",
         "u" : 52.0
         "d" : "2019-12-12 14:25",
         "u" : 64.0
         "d" : "2019-12-12 14:30",
         "u" : 144.0
         "d" : "2019-12-12 14:35",
         "u" : 76.0
         "d" : "2019-12-12 14:40",
         "u" : 79.0
         "d" : "2019-12-12 14:45",
         "u" : 73.0
         "d" : "2019-12-12 14:50",
         "u" : 66.0
         "d" : "2019-12-12 14:55",
         "u" : 114.0
         "d" : "2019-12-12 15:00",
         "u" : 120.0
         "d" : "2019-12-12 15:05",
         "u" : 159.0
         "d" : "2019-12-12 15:10",
         "u" : 66.0
         "d" : "2019-12-12 15:15",
         "u" : 79.0
         "d" : "2019-12-12 15:20",
         "u" : 66.0
         "d" : "2019-12-12 15:25",
         "u" : 77.0
         "d" : "2019-12-12 15:30",
         "u" : 66.0
         "d" : "2019-12-12 15:35",
         "u" : 78.0
         "d" : "2019-12-12 15:40",
         "u" : 170.0
         "d" : "2019-12-12 15:45",
         "u" : 131.0
         "d" : "2019-12-12 15:50",
         "u" : 132.0
         "d" : "2019-12-12 15:55",
         "u" : 104.0
         "d" : "2019-12-12 16:00",
         "u" : 82.0
         "d" : "2019-12-12 16:05",
         "u" : 81.0
         "d" : "2019-12-12 16:10",
         "u" : 80.0
         "d" : "2019-12-12 16:15",
         "u" : 79.0
         "d" : "2019-12-12 16:20",
         "u" : 80.0
         "d" : "2019-12-12 16:25",
         "u" : 80.0
         "d" : "2019-12-12 16:30",
         "u" : 82.0
         "d" : "2019-12-12 16:35",
         "u" : 83.0
         "d" : "2019-12-12 16:40",
         "u" : 83.0
         "d" : "2019-12-12 16:45",
         "u" : 98.0
         "d" : "2019-12-12 16:50",
         "u" : 106.0
         "d" : "2019-12-12 16:55",
         "u" : 181.0
         "d" : "2019-12-12 17:00",
         "u" : 99.0
         "d" : "2019-12-12 17:05",
         "u" : 116.0
         "d" : "2019-12-12 17:10",
         "u" : 114.0
         "d" : "2019-12-12 17:15",
         "u" : 108.0
         "d" : "2019-12-12 17:20",
         "u" : 107.0
         "d" : "2019-12-12 17:25",
         "u" : 107.0
         "d" : "2019-12-12 17:30",
         "u" : 107.0
         "d" : "2019-12-12 17:35",
         "u" : 96.0
         "d" : "2019-12-12 17:40",
         "u" : 108.0
         "d" : "2019-12-12 17:45",
         "u" : 94.0
         "d" : "2019-12-12 17:50",
         "u" : 167.0
         "d" : "2019-12-12 17:55",
         "u" : 244.0
         "d" : "2019-12-12 18:00",
         "u" : 115.0
         "d" : "2019-12-12 18:05",
         "u" : 96.0
         "d" : "2019-12-12 18:10",
         "u" : 116.0
         "d" : "2019-12-12 18:15",
         "u" : 95.0
         "d" : "2019-12-12 18:20",
         "u" : 456.0
         "d" : "2019-12-12 18:25",
         "u" : 109.0
         "d" : "2019-12-12 18:30",
         "u" : 109.0
         "d" : "2019-12-12 18:35",
         "u" : 121.0
         "d" : "2019-12-12 18:40",
         "u" : 105.0
         "d" : "2019-12-12 18:45",
         "u" : 161.0
         "d" : "2019-12-12 18:50",
         "u" : 96.0
         "d" : "2019-12-12 18:55",
         "u" : 148.0
         "d" : "2019-12-12 19:00",
         "u" : 161.0
         "d" : "2019-12-12 19:05",
         "u" : 120.0
         "d" : "2019-12-12 19:10",
         "u" : 190.0
         "d" : "2019-12-12 19:15",
         "u" : 186.0
         "d" : "2019-12-12 19:20",
         "u" : 97.0
         "d" : "2019-12-12 19:25",
         "u" : 98.0
         "d" : "2019-12-12 19:30",
         "u" : 109.0
         "d" : "2019-12-12 19:35",
         "u" : 97.0
         "d" : "2019-12-12 19:40",
         "u" : 190.0
         "d" : "2019-12-12 19:45",
         "u" : 141.0
         "d" : "2019-12-12 19:50",
         "u" : 110.0
         "d" : "2019-12-12 19:55",
         "u" : 97.0
         "d" : "2019-12-12 20:00",
         "u" : 144.0
         "d" : "2019-12-12 20:05",
         "u" : 241.0
         "d" : "2019-12-12 20:10",
         "u" : 132.0
         "d" : "2019-12-12 20:15",
         "u" : 117.0
         "d" : "2019-12-12 20:20",
         "u" : 101.0
         "d" : "2019-12-12 20:25",
         "u" : 94.0
         "d" : "2019-12-12 20:30",
         "u" : 99.0
         "d" : "2019-12-12 20:35",
         "u" : 97.0
         "d" : "2019-12-12 20:40",
         "u" : 187.0
         "d" : "2019-12-12 20:45",
         "u" : 95.0
         "d" : "2019-12-12 20:50",
         "u" : 106.0
         "d" : "2019-12-12 20:55",
         "u" : 157.0
         "d" : "2019-12-12 21:00",
         "u" : 249.0
         "d" : "2019-12-12 21:05",
         "u" : 95.0
         "d" : "2019-12-12 21:10",
         "u" : 107.0
         "d" : "2019-12-12 21:15",
         "u" : 96.0
         "d" : "2019-12-12 21:20",
         "u" : 141.0
         "d" : "2019-12-12 21:25",
         "u" : 161.0
         "d" : "2019-12-12 21:30",
         "u" : 211.0
         "d" : "2019-12-12 21:35",
         "u" : 148.0
         "d" : "2019-12-12 21:40",
         "u" : 109.0
         "d" : "2019-12-12 21:45",
         "u" : 95.0
         "d" : "2019-12-12 21:50",
         "u" : 107.0
         "d" : "2019-12-12 21:55",
         "u" : 95.0
         "d" : "2019-12-12 22:00",
         "u" : 189.0
         "d" : "2019-12-12 22:05",
         "u" : 95.0
         "d" : "2019-12-12 22:10",
         "u" : 107.0
         "d" : "2019-12-12 22:15",
         "u" : 96.0
         "d" : "2019-12-12 22:20",
         "u" : 108.0
         "d" : "2019-12-12 22:25",
         "u" : 189.0
         "d" : "2019-12-12 22:30",
         "u" : 131.0
   "status" : "OK",
   "title" : "Graph counter day"
Phase 3 (idx 45)
   "result" : [
         "u" : 2025.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 2105.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 2204.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 2078.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 2124.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 2.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 2136.0
         "u" : 4064.0
         "u" : 2133.0
         "u" : 2166.0
         "u" : 84.0
         "u" : 84.0
         "u" : 84.0
         "u" : 84.0
         "u" : 84.0
         "u" : 2151.0
         "u" : 85.0
         "u" : 84.0
         "u" : 84.0
         "u" : 84.0
         "u" : 85.0
         "u" : 2188.0
         "u" : 2106.0
         "u" : 2105.0
         "u" : 86.0
         "u" : 0.0
         "u" : 21.0
         "u" : 21.0
         "u" : 21.0
         "u" : 21.0
         "u" : 22.0
         "u" : 21.0
         "u" : 20.0
         "u" : 21.0
         "u" : 20.0
         "u" : 20.0
         "u" : 20.0
         "u" : 20.0
         "u" : 20.0
         "u" : 21.0
         "u" : 2.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "d" : "2019-12-12 22:35",
         "u" : 0.0
   "status" : "OK",
The third phase isn't being used constantly, but has a boiler, dishwasher, oven connected. I would suspect the graph to display spikes, like it does in Domoticz.
ykuijs
Post by ykuijs »
Last night (shortly after posting previous post) the "Last hours" graph showed some output, but the "Today" graph still didn't work:
Last Hours:
Today:
Graph in Domoticz:
This morning both graphs weren't working again. So it probably looks like an issue where the usage is consistently low, but has spikes every now and then.
Lokonli
Post by Lokonli »
I've to check how the chart.js module handles subsampling of device data, because the main difference between 'laatste uren' and 'vandaag' is the amount of data that is received.
Just to be sure, can you post the block definition for your graphs from config.js?
Which exact Dashticz version are you running?
In the latest beta there is an update on the chart x-axis setting, which might solve this issue.
Lokonli
Post by Lokonli »
I think I've found the issue:
If the first datapoint is 0, then whole data range will not be used...
I'll fix it this weekend.
ykuijs
Post by ykuijs »
Lokonli wrote: Friday 13 December 2019 11:17 I've to check how the chart.js module handles subsampling of device data, because the main difference between 'laatste uren' and 'vandaag' is the amount of data that is received.
I haven't defined any graph settings yet, so am using the default settings. Wanted to make sure it wasn't caused by anything I did ;)
I am using v3.1.2 Master
Lokonli wrote: Friday 13 December 2019 11:32 I think I've found the issue:
That is excellent, that totally makes sense based on the behavior I have seen so far. Waiting anxiously for the update! Thanks for your effort!
Lokonli
Post by Lokonli »
ykuijs wrote: Friday 13 December 2019 13:15
Should be fixed in latest beta. Can you test?
ykuijs
Post by ykuijs »
Just pulled the latest bits from GitHub and used that. It is a little better, but isn't correct yet:
The graph for "Laatste Uren" now shows info, however just one data point with the value of 2019. I think this is displaying the year instead of the data from Domoticz:
The x-axis for graph for "Vandaag" shows increments of 10 or 15 minutes, but at the end of the graph jumps from 21.30 to 6.15
The data for this phase:
   "result" : [
         "d" : "2019-12-13 10:50",
         "u" : 75.0
         "d" : "2019-12-13 10:55",
         "u" : 137.0
         "d" : "2019-12-13 11:00",
         "u" : 127.0
         "d" : "2019-12-13 11:05",
         "u" : 80.0
         "d" : "2019-12-13 11:10",
         "u" : 68.0
         "d" : "2019-12-13 11:15",
         "u" : 80.0
         "d" : "2019-12-13 11:20",
         "u" : 146.0
         "d" : "2019-12-13 11:25",
         "u" : 77.0
         "d" : "2019-12-13 11:30",
         "u" : 67.0
         "d" : "2019-12-13 11:35",
         "u" : 79.0
         "d" : "2019-12-13 11:40",
         "u" : 154.0
         "d" : "2019-12-13 11:45",
         "u" : 79.0
         "d" : "2019-12-13 11:50",
         "u" : 66.0
         "d" : "2019-12-13 11:55",
         "u" : 110.0
         "d" : "2019-12-13 12:00",
         "u" : 132.0
         "d" : "2019-12-13 12:05",
         "u" : 133.0
         "d" : "2019-12-13 12:10",
         "u" : 110.0
         "d" : "2019-12-13 12:15",
         "u" : 71.0
         "d" : "2019-12-13 12:20",
         "u" : 68.0
         "d" : "2019-12-13 12:25",
         "u" : 85.0
         "d" : "2019-12-13 12:30",
         "u" : 56.0
         "d" : "2019-12-13 12:35",
         "u" : 146.0
         "d" : "2019-12-13 12:40",
         "u" : 55.0
         "d" : "2019-12-13 12:45",
         "u" : 68.0
         "d" : "2019-12-13 12:50",
         "u" : 54.0
         "d" : "2019-12-13 12:55",
         "u" : 65.0
         "d" : "2019-12-13 13:00",
         "u" : 57.0
         "d" : "2019-12-13 13:05",
         "u" : 65.0
         "d" : "2019-12-13 13:10",
         "u" : 136.0
         "d" : "2019-12-13 13:15",
         "u" : 73.0
         "d" : "2019-12-13 13:20",
         "u" : 120.0
         "d" : "2019-12-13 13:25",
         "u" : 120.0
         "d" : "2019-12-13 13:30",
         "u" : 84.0
         "d" : "2019-12-13 13:35",
         "u" : 66.0
         "d" : "2019-12-13 13:40",
         "u" : 67.0
         "d" : "2019-12-13 13:45",
         "u" : 54.0
         "d" : "2019-12-13 13:50",
         "u" : 207.0
         "d" : "2019-12-13 13:55",
         "u" : 115.0
         "d" : "2019-12-13 14:00",
         "u" : 66.0
         "d" : "2019-12-13 14:05",
         "u" : 54.0
         "d" : "2019-12-13 14:10",
         "u" : 66.0
         "d" : "2019-12-13 14:15",
         "u" : 54.0
         "d" : "2019-12-13 14:20",
         "u" : 101.0
         "d" : "2019-12-13 14:25",
         "u" : 120.0
         "d" : "2019-12-13 14:30",
         "u" : 169.0
         "d" : "2019-12-13 14:35",
         "u" : 87.0
         "d" : "2019-12-13 14:40",
         "u" : 74.0
         "d" : "2019-12-13 14:45",
         "u" : 80.0
         "d" : "2019-12-13 14:50",
         "u" : 151.0
         "d" : "2019-12-13 14:55",
         "u" : 79.0
         "d" : "2019-12-13 15:00",
         "u" : 66.0
         "d" : "2019-12-13 15:05",
         "u" : 87.0
         "d" : "2019-12-13 15:10",
         "u" : 78.0
         "d" : "2019-12-13 15:15",
         "u" : 79.0
         "d" : "2019-12-13 15:20",
         "u" : 85.0
         "d" : "2019-12-13 15:25",
         "u" : 155.0
         "d" : "2019-12-13 15:30",
         "u" : 211.0
         "d" : "2019-12-13 15:35",
         "u" : 133.0
         "d" : "2019-12-13 15:40",
         "u" : 87.0
         "d" : "2019-12-13 15:45",
         "u" : 80.0
         "d" : "2019-12-13 15:50",
         "u" : 67.0
         "d" : "2019-12-13 15:55",
         "u" : 68.0
         "d" : "2019-12-13 16:00",
         "u" : 69.0
         "d" : "2019-12-13 16:05",
         "u" : 147.0
         "d" : "2019-12-13 16:10",
         "u" : 86.0
         "d" : "2019-12-13 16:15",
         "u" : 73.0
         "d" : "2019-12-13 16:20",
         "u" : 79.0
         "d" : "2019-12-13 16:25",
         "u" : 67.0
         "d" : "2019-12-13 16:30",
         "u" : 77.0
         "d" : "2019-12-13 16:35",
         "u" : 168.0
         "d" : "2019-12-13 16:40",
         "u" : 153.0
         "d" : "2019-12-13 16:45",
         "u" : 141.0
         "d" : "2019-12-13 16:50",
         "u" : 93.0
         "d" : "2019-12-13 16:55",
         "u" : 81.0
         "d" : "2019-12-13 17:00",
         "u" : 94.0
         "d" : "2019-12-13 17:05",
         "u" : 74.0
         "d" : "2019-12-13 17:10",
         "u" : 89.0
         "d" : "2019-12-13 17:15",
         "u" : 166.0
         "d" : "2019-12-13 17:20",
         "u" : 107.0
         "d" : "2019-12-13 17:25",
         "u" : 89.0
         "d" : "2019-12-13 17:30",
         "u" : 101.0
         "d" : "2019-12-13 17:35",
         "u" : 96.0
         "d" : "2019-12-13 17:40",
         "u" : 101.0
         "d" : "2019-12-13 17:45",
         "u" : 88.0
         "d" : "2019-12-13 17:50",
         "u" : 223.0
         "d" : "2019-12-13 17:55",
         "u" : 169.0
         "d" : "2019-12-13 18:00",
         "u" : 144.0
         "d" : "2019-12-13 18:05",
         "u" : 116.0
         "d" : "2019-12-13 18:10",
         "u" : 103.0
         "d" : "2019-12-13 18:15",
         "u" : 195.0
         "d" : "2019-12-13 18:20",
         "u" : 106.0
         "d" : "2019-12-13 18:25",
         "u" : 104.0
         "d" : "2019-12-13 18:30",
         "u" : 104.0
         "d" : "2019-12-13 18:35",
         "u" : 255.0
         "d" : "2019-12-13 18:40",
         "u" : 233.0
         "d" : "2019-12-13 18:45",
         "u" : 230.0
         "d" : "2019-12-13 18:50",
         "u" : 228.0
         "d" : "2019-12-13 18:55",
         "u" : 200.0
         "d" : "2019-12-13 19:00",
         "u" : 180.0
         "d" : "2019-12-13 19:05",
         "u" : 202.0
         "d" : "2019-12-13 19:10",
         "u" : 178.0
         "d" : "2019-12-13 19:15",
         "u" : 101.0
         "d" : "2019-12-13 19:20",
         "u" : 181.0
         "d" : "2019-12-13 19:25",
         "u" : 102.0
         "d" : "2019-12-13 19:30",
         "u" : 156.0
         "d" : "2019-12-13 19:35",
         "u" : 162.0
         "d" : "2019-12-13 19:40",
         "u" : 101.0
         "d" : "2019-12-13 19:45",
         "u" : 101.0
         "d" : "2019-12-13 19:50",
         "u" : 228.0
         "d" : "2019-12-13 19:55",
         "u" : 193.0
         "d" : "2019-12-13 20:00",
         "u" : 208.0
         "d" : "2019-12-13 20:05",
         "u" : 135.0
         "d" : "2019-12-13 20:10",
         "u" : 124.0
         "d" : "2019-12-13 20:15",
         "u" : 126.0
         "d" : "2019-12-13 20:20",
         "u" : 110.0
         "d" : "2019-12-13 20:25",
         "u" : 115.0
         "d" : "2019-12-13 20:30",
         "u" : 187.0
         "d" : "2019-12-13 20:35",
         "u" : 115.0
         "d" : "2019-12-13 20:40",
         "u" : 101.0
         "d" : "2019-12-13 20:45",
         "u" : 123.0
         "d" : "2019-12-13 20:50",
         "u" : 101.0
         "d" : "2019-12-13 20:55",
         "u" : 255.0
         "d" : "2019-12-13 21:00",
         "u" : 101.0
         "d" : "2019-12-13 21:05",
         "u" : 102.0
         "d" : "2019-12-13 21:10",
         "u" : 108.0
         "d" : "2019-12-13 21:15",
         "u" : 108.0
         "d" : "2019-12-13 21:20",
         "u" : 129.0
         "d" : "2019-12-13 21:25",
         "u" : 183.0
         "d" : "2019-12-13 21:30",
         "u" : 166.0
         "d" : "2019-12-13 21:35",
         "u" : 87.0
         "d" : "2019-12-13 21:40",
         "u" : 70.0
         "d" : "2019-12-13 21:45",
         "u" : 70.0
         "d" : "2019-12-13 21:50",
         "u" : 83.0
         "d" : "2019-12-13 21:55",
         "u" : 152.0
         "d" : "2019-12-13 22:00",
         "u" : 81.0
         "d" : "2019-12-13 22:05",
         "u" : 70.0
         "d" : "2019-12-13 22:10",
         "u" : 95.0
         "d" : "2019-12-13 22:15",
         "u" : 101.0
         "d" : "2019-12-13 22:20",
         "u" : 150.0
         "d" : "2019-12-13 22:25",
         "u" : 143.0
         "d" : "2019-12-13 22:30",
         "u" : 69.0
         "d" : "2019-12-13 22:35",
         "u" : 69.0
         "d" : "2019-12-13 22:40",
         "u" : 55.0
         "d" : "2019-12-13 22:45",
         "u" : 55.0
         "d" : "2019-12-13 22:50",
         "u" : 54.0
         "d" : "2019-12-13 22:55",
         "u" : 53.0
         "d" : "2019-12-13 23:00",
         "u" : 131.0
         "d" : "2019-12-13 23:05",
         "u" : 53.0
         "d" : "2019-12-13 23:10",
         "u" : 53.0
         "d" : "2019-12-13 23:15",
         "u" : 57.0
         "d" : "2019-12-13 23:20",
         "u" : 137.0
         "d" : "2019-12-13 23:25",
         "u" : 53.0
         "d" : "2019-12-13 23:30",
         "u" : 51.0
         "d" : "2019-12-13 23:35",
         "u" : 50.0
         "d" : "2019-12-13 23:40",
         "u" : 51.0
         "d" : "2019-12-13 23:45",
         "u" : 140.0
         "d" : "2019-12-13 23:50",
         "u" : 51.0
         "d" : "2019-12-13 23:55",
         "u" : 51.0
         "d" : "2019-12-14 00:00",
         "u" : 51.0
         "d" : "2019-12-14 00:05",
         "u" : 51.0
         "d" : "2019-12-14 00:10",
         "u" : 52.0
         "d" : "2019-12-14 00:15",
         "u" : 52.0
         "d" : "2019-12-14 00:20",
         "u" : 132.0
         "d" : "2019-12-14 00:25",
         "u" : 52.0
         "d" : "2019-12-14 00:30",
         "u" : 51.0
         "d" : "2019-12-14 00:35",
         "u" : 52.0
         "d" : "2019-12-14 00:40",
         "u" : 77.0
         "d" : "2019-12-14 00:45",
         "u" : 51.0
         "d" : "2019-12-14 00:50",
         "u" : 138.0
         "d" : "2019-12-14 00:55",
         "u" : 51.0
         "d" : "2019-12-14 01:00",
         "u" : 52.0
         "d" : "2019-12-14 01:05",
         "u" : 51.0
         "d" : "2019-12-14 01:10",
         "u" : 58.0
         "d" : "2019-12-14 01:15",
         "u" : 58.0
         "d" : "2019-12-14 01:20",
         "u" : 59.0
         "d" : "2019-12-14 01:25",
         "u" : 134.0
         "d" : "2019-12-14 01:30",
         "u" : 53.0
         "d" : "2019-12-14 01:35",
         "u" : 47.0
         "d" : "2019-12-14 01:40",
         "u" : 47.0
         "d" : "2019-12-14 01:45",
         "u" : 46.0
         "d" : "2019-12-14 01:50",
         "u" : 46.0
         "d" : "2019-12-14 01:55",
         "u" : 102.0
         "d" : "2019-12-14 02:00",
         "u" : 105.0
         "d" : "2019-12-14 02:05",
         "u" : 46.0
         "d" : "2019-12-14 02:10",
         "u" : 47.0
         "d" : "2019-12-14 02:15",
         "u" : 46.0
         "d" : "2019-12-14 02:20",
         "u" : 128.0
         "d" : "2019-12-14 02:25",
         "u" : 46.0
         "d" : "2019-12-14 02:30",
         "u" : 45.0
         "d" : "2019-12-14 02:35",
         "u" : 46.0
         "d" : "2019-12-14 02:40",
         "u" : 45.0
         "d" : "2019-12-14 02:45",
         "u" : 46.0
         "d" : "2019-12-14 02:50",
         "u" : 127.0
         "d" : "2019-12-14 02:55",
         "u" : 45.0
         "d" : "2019-12-14 03:00",
         "u" : 46.0
         "d" : "2019-12-14 03:05",
         "u" : 45.0
         "d" : "2019-12-14 03:10",
         "u" : 131.0
         "d" : "2019-12-14 03:15",
         "u" : 46.0
         "d" : "2019-12-14 03:20",
         "u" : 46.0
         "d" : "2019-12-14 03:25",
         "u" : 46.0
         "d" : "2019-12-14 03:30",
         "u" : 46.0
         "d" : "2019-12-14 03:35",
         "u" : 47.0
         "d" : "2019-12-14 03:40",
         "u" : 126.0
         "d" : "2019-12-14 03:45",
         "u" : 47.0
         "d" : "2019-12-14 03:50",
         "u" : 46.0
         "d" : "2019-12-14 03:55",
         "u" : 47.0
         "d" : "2019-12-14 04:00",
         "u" : 129.0
         "d" : "2019-12-14 04:05",
         "u" : 46.0
         "d" : "2019-12-14 04:10",
         "u" : 47.0
         "d" : "2019-12-14 04:15",
         "u" : 47.0
         "d" : "2019-12-14 04:20",
         "u" : 45.0
         "d" : "2019-12-14 04:25",
         "u" : 47.0
         "d" : "2019-12-14 04:30",
         "u" : 46.0
         "d" : "2019-12-14 04:35",
         "u" : 46.0
         "d" : "2019-12-14 04:40",
         "u" : 128.0
         "d" : "2019-12-14 04:45",
         "u" : 47.0
         "d" : "2019-12-14 04:50",
         "u" : 46.0
         "d" : "2019-12-14 04:55",
         "u" : 46.0
         "d" : "2019-12-14 05:00",
         "u" : 46.0
         "d" : "2019-12-14 05:05",
         "u" : 46.0
         "d" : "2019-12-14 05:10",
         "u" : 74.0
         "d" : "2019-12-14 05:15",
         "u" : 47.0
         "d" : "2019-12-14 05:20",
         "u" : 46.0
         "d" : "2019-12-14 05:25",
         "u" : 47.0
         "d" : "2019-12-14 05:30",
         "u" : 126.0
         "d" : "2019-12-14 05:35",
         "u" : 46.0
         "d" : "2019-12-14 05:40",
         "u" : 46.0
         "d" : "2019-12-14 05:45",
         "u" : 47.0
         "d" : "2019-12-14 05:50",
         "u" : 45.0
         "d" : "2019-12-14 05:55",
         "u" : 48.0
         "d" : "2019-12-14 06:00",
         "u" : 47.0
         "d" : "2019-12-14 06:05",
         "u" : 45.0
         "d" : "2019-12-14 06:10",
         "u" : 125.0
         "d" : "2019-12-14 06:15",
         "u" : 47.0
         "d" : "2019-12-14 06:20",
         "u" : 45.0
         "d" : "2019-12-14 06:25",
         "u" : 45.0
         "d" : "2019-12-14 06:30",
         "u" : 125.0
         "d" : "2019-12-14 06:35",
         "u" : 205.0
         "d" : "2019-12-14 06:40",
         "u" : 125.0
         "d" : "2019-12-14 06:45",
         "u" : 124.0
         "d" : "2019-12-14 06:50",
         "u" : 125.0
         "d" : "2019-12-14 06:55",
         "u" : 126.0
         "d" : "2019-12-14 07:00",
         "u" : 125.0
         "d" : "2019-12-14 07:05",
         "u" : 211.0
         "d" : "2019-12-14 07:10",
         "u" : 125.0
         "d" : "2019-12-14 07:15",
         "u" : 116.0
         "d" : "2019-12-14 07:20",
         "u" : 76.0
         "d" : "2019-12-14 07:25",
         "u" : 104.0
         "d" : "2019-12-14 07:30",
         "u" : 121.0
         "d" : "2019-12-14 07:35",
         "u" : 132.0
         "d" : "2019-12-14 07:40",
         "u" : 59.0
         "d" : "2019-12-14 07:45",
         "u" : 152.0
         "d" : "2019-12-14 07:50",
         "u" : 99.0
         "d" : "2019-12-14 07:55",
         "u" : 109.0
         "d" : "2019-12-14 08:00",
         "u" : 96.0
         "d" : "2019-12-14 08:05",
         "u" : 189.0
         "d" : "2019-12-14 08:10",
         "u" : 98.0
         "d" : "2019-12-14 08:15",
         "u" : 231.0
         "d" : "2019-12-14 08:20",
         "u" : 226.0
         "d" : "2019-12-14 08:25",
         "u" : 229.0
         "d" : "2019-12-14 08:30",
         "u" : 283.0
         "d" : "2019-12-14 08:35",
         "u" : 268.0
         "d" : "2019-12-14 08:40",
         "u" : 900.0
         "d" : "2019-12-14 08:45",
         "u" : 267.0
         "d" : "2019-12-14 08:50",
         "u" : 241.0
         "d" : "2019-12-14 08:55",
         "u" : 140.0
         "d" : "2019-12-14 09:00",
         "u" : 138.0
         "d" : "2019-12-14 09:05",
         "u" : 183.0
         "d" : "2019-12-14 09:10",
         "u" : 90.0
         "d" : "2019-12-14 09:15",
         "u" : 70.0
         "d" : "2019-12-14 09:20",
         "u" : 69.0
         "d" : "2019-12-14 09:25",
         "u" : 78.0
         "d" : "2019-12-14 09:30",
         "u" : 66.0
         "d" : "2019-12-14 09:35",
         "u" : 166.0
         "d" : "2019-12-14 09:40",
         "u" : 172.0
         "d" : "2019-12-14 09:45",
         "u" : 316.0
         "d" : "2019-12-14 09:50",
         "u" : 256.0
         "d" : "2019-12-14 09:55",
         "u" : 144.0
         "d" : "2019-12-14 10:00",
         "u" : 68.0
         "d" : "2019-12-14 10:05",
         "u" : 127.0
         "d" : "2019-12-14 10:10",
         "u" : 133.0
         "d" : "2019-12-14 10:15",
         "u" : 222.0
         "d" : "2019-12-14 10:20",
         "u" : 204.0
         "d" : "2019-12-14 10:25",
         "u" : 155.0
         "d" : "2019-12-14 10:30",
         "u" : 68.0
         "d" : "2019-12-14 10:35",
         "u" : 87.0
         "d" : "2019-12-14 10:40",
         "u" : 55.0
         "d" : "2019-12-14 10:45",
         "u" : 123.0
         "d" : "2019-12-14 10:50",
         "u" : 56.0
   "status" : "OK",
Lokonli
Post by Lokonli »
I don't see any relation between the data and the graph. Can you double check you sent the right data? (it resembles your phase 2 data ...)
Then of course there still is something strange between 21:30 and 6:00.
Does Domoticz show a correct graph in that time frame?
What are the high tariff-low tariff electricity switching moments in your city?
ykuijs
Post by ykuijs »
Oeps, sorry. You are correct, my bad :)
   "result" : [
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 2038.0
         "u" : 0.0
         "u" : 2140.0
         "u" : 4060.0
         "u" : 3992.0
         "u" : 84.0
         "u" : 85.0
         "u" : 85.0
         "u" : 84.0
         "u" : 84.0
         "u" : 83.0
         "u" : 84.0
         "u" : 83.0
         "u" : 83.0
         "u" : 83.0
         "u" : 16.0
         "u" : 84.0
         "u" : 2090.0
         "u" : 2141.0
         "u" : 2167.0
         "u" : 86.0
         "u" : 0.0
         "u" : 22.0
         "u" : 21.0
         "u" : 21.0
         "u" : 20.0
         "u" : 20.0
         "u" : 2063.0
         "u" : 20.0
         "u" : 21.0
         "u" : 20.0
         "u" : 19.0
         "u" : 20.0
         "u" : 20.0
         "u" : 22.0
         "u" : 21.0
         "u" : 2.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 2034.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 2048.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 2019.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "d" : "2019-12-14 10:55",
         "u" : 0.0
         "d" : "2019-12-14 11:00",
         "u" : 0.0
         "d" : "2019-12-14 11:05",
         "u" : 0.0
         "d" : "2019-12-14 11:10",
         "u" : 0.0
         "d" : "2019-12-14 11:15",
         "u" : 0.0
         "d" : "2019-12-14 11:20",
         "u" : 0.0
         "d" : "2019-12-14 11:25",
         "u" : 0.0
         "d" : "2019-12-14 11:30",
         "u" : 0.0
         "d" : "2019-12-14 11:35",
         "u" : 0.0
         "d" : "2019-12-14 11:40",
         "u" : 0.0
         "d" : "2019-12-14 11:45",
         "u" : 0.0
         "d" : "2019-12-14 11:50",
         "u" : 0.0
         "d" : "2019-12-14 11:55",
         "u" : 0.0
         "d" : "2019-12-14 12:00",
         "u" : 0.0
         "d" : "2019-12-14 12:05",
         "u" : 0.0
         "d" : "2019-12-14 12:10",
         "u" : 0.0
         "d" : "2019-12-14 12:15",
         "u" : 0.0
         "d" : "2019-12-14 12:20",
         "u" : 0.0
         "d" : "2019-12-14 12:25",
         "u" : 0.0
         "d" : "2019-12-14 12:30",
         "u" : 0.0
         "d" : "2019-12-14 12:35",
         "u" : 0.0
         "d" : "2019-12-14 12:40",
         "u" : 0.0
         "d" : "2019-12-14 12:45",
         "u" : 0.0
         "d" : "2019-12-14 12:50",
         "u" : 0.0
         "d" : "2019-12-14 12:55",
         "u" : 0.0
         "d" : "2019-12-14 13:00",
         "u" : 2093.0
         "d" : "2019-12-14 13:05",
         "u" : 0.0
         "d" : "2019-12-14 13:10",
         "u" : 0.0
         "d" : "2019-12-14 13:15",
         "u" : 0.0
         "d" : "2019-12-14 13:20",
         "u" : 0.0
         "d" : "2019-12-14 13:25",
         "u" : 0.0
   "status" : "OK",
The high/low tariff switching moments are: Evening 23.00, morning 7.00.
The x-axis for the first two phases is exactly the same, but the third is different:
The graph for that timeframe in Domoticz is displaying correctly:
Lokonli
Post by Lokonli »
Thank, clear.
All 0 values disappeared.
I've made a fix in latest beta. Can you test again?
ykuijs
Post by ykuijs »
Yes, that worked like a charm!! This also fixed the min/max values for the "Afgelopen maand" graph (monthly graphs don't show the average data points (u), but the min/max values (u_min and u_max)). So far that only showed the max values, since the min values had a value of 0. Now the graph shows two lines (one max/one min), just like it does in Domoticz!
Thanks a million!
Lokonli
Post by Lokonli »
Good! Thanks for the feedback.
mojojojo490
Post by mojojojo490 »
Hi @ykuis
Can you post your final code? So we can see what solution you have made?
Starter RPi3B, Domoticz Stable 2020.2, 10x Qubino Mini Dimmer, 1x Qubino shutter
Plugwise Anna + Adam + 2x Koen-4 & 1x Floor; SolarEdge SE3000H
Dashticz v3
