Graph for one phase of my P1 connection not working
ykuijs
I recently upgraded my electricity to a 3 phase connection. The new power meter also had a P1 port, so I connected it to my Domoticz system. I am now trying to show the power used for each phase. Phase 1 and 2 are displaying just fine, however phase 3 doesn't show any graph, but does show the correct current usage in the header so it is able retrieve data from Domoticz. However, the graph for Last Month does show some output, similar to the graph in Domoticz.
All graphs in Domoticz for this device are displaying just fine, so the device is generating output. Currently I am not using any graph customization (yet).
How can I get this third graph to also work like the other two phases?
- FireWizard
Re: Graph for one phase of my P1 connection
One question.
You posted recently another issue, where you indicated, that you use Dashticz.
Do you mean the Dashticz graphs here as well?
If so, how do the Domoticz sensors and graphs look like?
One question.
Lokonli
Re: Graph for one phase of my P1 connection not working
Can you send the Domoticz json output of the 3-phase device? Then I'll have a look.ykuijs wrote: Wednesday 04 December 2019 22:49 I recently upgraded my electricity to a 3 phase connection. The new power meter also had a P1 port, so I connected it to my Domoticz system. I am now trying to show the power used for each phase. Phase 1 and 2 are displaying just fine, however phase 3 doesn't show any graph, but does show the correct current usage in the header so it is able retrieve data from Domoticz. However, the graph for Last Month does show some output, similar to the graph in Domoticz.
ykuijs
@FireWizard, yes I mean the graphs in Dashticz. The graphs in Domoticz look just fine.
@Lokonli, here the info you requested:
The JSON output for phase 2 (which is working fine):
The JSON output for phase 3 (which isn't working):
"ActTime" : 1575532613,
"AstrTwilightEnd" : "18:33",
"AstrTwilightStart" : "06:26",
"CivTwilightEnd" : "17:09",
"CivTwilightStart" : "07:50",
"DayLength" : "08:00",
"NautTwilightEnd" : "17:52",
"NautTwilightStart" : "07:07",
"ServerTime" : "2019-12-05 08:56:53",
"SunAtSouth" : "12:30",
"Sunrise" : "08:29",
"Sunset" : "16:30",
"app_version" : "4.10717",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "54 Watt",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 7,
"HardwareName" : "Slimme Meter",
"HardwareType" : "P1 Smart Meter USB",
"HardwareTypeVal" : 4,
"HaveTimeout" : false,
"ID" : "0000000",
"LastUpdate" : "2019-12-05 08:56:52",
"Name" : "Stroomverbruik Fase 2",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "Electric",
"Timers" : "false",
"Type" : "Usage",
"TypeImg" : "current",
"Unit" : 2,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "44"
"status" : "OK",
"title" : "Devices"
}Code: Select all
"ActTime" : 1575532701,
"ServerTime" : "2019-12-05 08:58:21",
"Sunset" : "16:30",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "0 Watt",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 7,
"ID" : "0000000",
"LastUpdate" : "2019-12-05 08:58:21",
"Name" : "Stroomverbruik Fase 3",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Timers" : "false",
"Type" : "Usage",
"Unit" : 3,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "45"
"status" : "OK",
"title" : "Devices"
Lokonli
I don't have a 3 phase device, so it's difficult to reproduce.
Could you post the graph data as well?
The first line (idx44) is your phase 2, and the second line (idx45) your phase 3.
http://<Domoticz IP address>/json.htm?type=graph&sensor=counter&idx=44&range=day&method=1
http://<Domoticz IP address>/json.htm?type=graph&sensor=counter&idx=45&range=day&method=1
ykuijs
Here the requested graph data:
Phase 2 (idx 44)
Phase 3 (idx 45)
The third phase isn't being used constantly, but has a boiler, dishwasher, oven connected. I would suspect the graph to display spikes, like it does in Domoticz.
Phase 2 (idx 44)
"result" : [
"d" : "2019-12-11 22:30",
"u" : 198.0
"d" : "2019-12-11 22:35",
"u" : 92.0
"d" : "2019-12-11 22:40",
"u" : 96.0
"d" : "2019-12-11 22:45",
"u" : 84.0
"d" : "2019-12-11 22:50",
"u" : 123.0
"d" : "2019-12-11 22:55",
"u" : 133.0
"d" : "2019-12-11 23:00",
"u" : 45.0
"d" : "2019-12-11 23:05",
"u" : 45.0
"d" : "2019-12-11 23:10",
"u" : 45.0
"d" : "2019-12-11 23:15",
"u" : 44.0
"d" : "2019-12-11 23:20",
"u" : 131.0
"d" : "2019-12-11 23:25",
"u" : 45.0
"d" : "2019-12-11 23:30",
"u" : 44.0
"d" : "2019-12-11 23:35",
"u" : 45.0
"d" : "2019-12-11 23:40",
"u" : 45.0
"d" : "2019-12-11 23:45",
"u" : 45.0
"d" : "2019-12-11 23:50",
"u" : 124.0
"d" : "2019-12-11 23:55",
"u" : 46.0
"d" : "2019-12-12 00:00",
"u" : 46.0
"d" : "2019-12-12 00:05",
"u" : 46.0
"d" : "2019-12-12 00:10",
"u" : 45.0
"d" : "2019-12-12 00:15",
"u" : 45.0
"d" : "2019-12-12 00:20",
"u" : 124.0
"d" : "2019-12-12 00:25",
"u" : 102.0
"d" : "2019-12-12 00:30",
"u" : 106.0
"d" : "2019-12-12 00:35",
"u" : 46.0
"d" : "2019-12-12 00:40",
"u" : 45.0
"d" : "2019-12-12 00:45",
"u" : 46.0
"d" : "2019-12-12 00:50",
"u" : 126.0
"d" : "2019-12-12 00:55",
"u" : 45.0
"d" : "2019-12-12 01:00",
"u" : 45.0
"d" : "2019-12-12 01:05",
"u" : 46.0
"d" : "2019-12-12 01:10",
"u" : 46.0
"d" : "2019-12-12 01:15",
"u" : 45.0
"d" : "2019-12-12 01:20",
"u" : 46.0
"d" : "2019-12-12 01:25",
"u" : 126.0
"d" : "2019-12-12 01:30",
"u" : 45.0
"d" : "2019-12-12 01:35",
"u" : 46.0
"d" : "2019-12-12 01:40",
"u" : 47.0
"d" : "2019-12-12 01:45",
"u" : 132.0
"d" : "2019-12-12 01:50",
"u" : 46.0
"d" : "2019-12-12 01:55",
"u" : 45.0
"d" : "2019-12-12 02:00",
"u" : 45.0
"d" : "2019-12-12 02:05",
"u" : 46.0
"d" : "2019-12-12 02:10",
"u" : 45.0
"d" : "2019-12-12 02:15",
"u" : 46.0
"d" : "2019-12-12 02:20",
"u" : 126.0
"d" : "2019-12-12 02:25",
"u" : 45.0
"d" : "2019-12-12 02:30",
"u" : 45.0
"d" : "2019-12-12 02:35",
"u" : 46.0
"d" : "2019-12-12 02:40",
"u" : 46.0
"d" : "2019-12-12 02:45",
"u" : 125.0
"d" : "2019-12-12 02:50",
"u" : 46.0
"d" : "2019-12-12 02:55",
"u" : 47.0
"d" : "2019-12-12 03:00",
"u" : 45.0
"d" : "2019-12-12 03:05",
"u" : 46.0
"d" : "2019-12-12 03:10",
"u" : 46.0
"d" : "2019-12-12 03:15",
"u" : 127.0
"d" : "2019-12-12 03:20",
"u" : 46.0
"d" : "2019-12-12 03:25",
"u" : 46.0
"d" : "2019-12-12 03:30",
"u" : 46.0
"d" : "2019-12-12 03:35",
"u" : 46.0
"d" : "2019-12-12 03:40",
"u" : 45.0
"d" : "2019-12-12 03:45",
"u" : 130.0
"d" : "2019-12-12 03:50",
"u" : 45.0
"d" : "2019-12-12 03:55",
"u" : 45.0
"d" : "2019-12-12 04:00",
"u" : 46.0
"d" : "2019-12-12 04:05",
"u" : 46.0
"d" : "2019-12-12 04:10",
"u" : 46.0
"d" : "2019-12-12 04:15",
"u" : 46.0
"d" : "2019-12-12 04:20",
"u" : 46.0
"d" : "2019-12-12 04:25",
"u" : 126.0
"d" : "2019-12-12 04:30",
"u" : 46.0
"d" : "2019-12-12 04:35",
"u" : 45.0
"d" : "2019-12-12 04:40",
"u" : 46.0
"d" : "2019-12-12 04:45",
"u" : 46.0
"d" : "2019-12-12 04:50",
"u" : 127.0
"d" : "2019-12-12 04:55",
"u" : 46.0
"d" : "2019-12-12 05:00",
"u" : 46.0
"d" : "2019-12-12 05:05",
"u" : 45.0
"d" : "2019-12-12 05:10",
"u" : 45.0
"d" : "2019-12-12 05:15",
"u" : 45.0
"d" : "2019-12-12 05:20",
"u" : 45.0
"d" : "2019-12-12 05:25",
"u" : 44.0
"d" : "2019-12-12 05:30",
"u" : 44.0
"d" : "2019-12-12 05:35",
"u" : 44.0
"d" : "2019-12-12 05:40",
"u" : 45.0
"d" : "2019-12-12 05:45",
"u" : 79.0
"d" : "2019-12-12 05:50",
"u" : 122.0
"d" : "2019-12-12 05:55",
"u" : 122.0
"d" : "2019-12-12 06:00",
"u" : 71.0
"d" : "2019-12-12 06:05",
"u" : 123.0
"d" : "2019-12-12 06:10",
"u" : 126.0
"d" : "2019-12-12 06:15",
"u" : 184.0
"d" : "2019-12-12 06:20",
"u" : 187.0
"d" : "2019-12-12 06:25",
"u" : 125.0
"d" : "2019-12-12 06:30",
"u" : 126.0
"d" : "2019-12-12 06:35",
"u" : 125.0
"d" : "2019-12-12 06:40",
"u" : 202.0
"d" : "2019-12-12 06:45",
"u" : 743.0
"d" : "2019-12-12 06:50",
"u" : 243.0
"d" : "2019-12-12 06:55",
"u" : 243.0
"d" : "2019-12-12 07:00",
"u" : 241.0
"d" : "2019-12-12 07:05",
"u" : 324.0
"d" : "2019-12-12 07:10",
"u" : 221.0
"d" : "2019-12-12 07:15",
"u" : 199.0
"d" : "2019-12-12 07:20",
"u" : 211.0
"d" : "2019-12-12 07:25",
"u" : 214.0
"d" : "2019-12-12 07:30",
"u" : 225.0
"d" : "2019-12-12 07:35",
"u" : 295.0
"d" : "2019-12-12 07:40",
"u" : 210.0
"d" : "2019-12-12 07:45",
"u" : 202.0
"d" : "2019-12-12 07:50",
"u" : 195.0
"d" : "2019-12-12 07:55",
"u" : 100.0
"d" : "2019-12-12 08:00",
"u" : 116.0
"d" : "2019-12-12 08:05",
"u" : 211.0
"d" : "2019-12-12 08:10",
"u" : 137.0
"d" : "2019-12-12 08:15",
"u" : 125.0
"d" : "2019-12-12 08:20",
"u" : 101.0
"d" : "2019-12-12 08:25",
"u" : 85.0
"d" : "2019-12-12 08:30",
"u" : 162.0
"d" : "2019-12-12 08:35",
"u" : 72.0
"d" : "2019-12-12 08:40",
"u" : 117.0
"d" : "2019-12-12 08:45",
"u" : 135.0
"d" : "2019-12-12 08:50",
"u" : 59.0
"d" : "2019-12-12 08:55",
"u" : 72.0
"d" : "2019-12-12 09:00",
"u" : 63.0
"d" : "2019-12-12 09:05",
"u" : 107.0
"d" : "2019-12-12 09:10",
"u" : 125.0
"d" : "2019-12-12 09:15",
"u" : 217.0
"d" : "2019-12-12 09:20",
"u" : 204.0
"d" : "2019-12-12 09:25",
"u" : 85.0
"d" : "2019-12-12 09:30",
"u" : 74.0
"d" : "2019-12-12 09:35",
"u" : 59.0
"d" : "2019-12-12 09:40",
"u" : 162.0
"d" : "2019-12-12 09:45",
"u" : 71.0
"d" : "2019-12-12 09:50",
"u" : 75.0
"d" : "2019-12-12 09:55",
"u" : 65.0
"d" : "2019-12-12 10:00",
"u" : 76.0
"d" : "2019-12-12 10:05",
"u" : 67.0
"d" : "2019-12-12 10:10",
"u" : 54.0
"d" : "2019-12-12 10:15",
"u" : 66.0
"d" : "2019-12-12 10:20",
"u" : 136.0
"d" : "2019-12-12 10:25",
"u" : 65.0
"d" : "2019-12-12 10:30",
"u" : 52.0
"d" : "2019-12-12 10:35",
"u" : 65.0
"d" : "2019-12-12 10:40",
"u" : 54.0
"d" : "2019-12-12 10:45",
"u" : 120.0
"d" : "2019-12-12 10:50",
"u" : 121.0
"d" : "2019-12-12 10:55",
"u" : 200.0
"d" : "2019-12-12 11:00",
"u" : 87.0
"d" : "2019-12-12 11:05",
"u" : 78.0
"d" : "2019-12-12 11:10",
"u" : 74.0
"d" : "2019-12-12 11:15",
"u" : 57.0
"d" : "2019-12-12 11:20",
"u" : 74.0
"d" : "2019-12-12 11:25",
"u" : 56.0
"d" : "2019-12-12 11:30",
"u" : 136.0
"d" : "2019-12-12 11:35",
"u" : 57.0
"d" : "2019-12-12 11:40",
"u" : 53.0
"d" : "2019-12-12 11:45",
"u" : 113.0
"d" : "2019-12-12 11:50",
"u" : 114.0
"d" : "2019-12-12 11:55",
"u" : 56.0
"d" : "2019-12-12 12:00",
"u" : 55.0
"d" : "2019-12-12 12:05",
"u" : 144.0
"d" : "2019-12-12 12:10",
"u" : 54.0
"d" : "2019-12-12 12:15",
"u" : 66.0
"d" : "2019-12-12 12:20",
"u" : 52.0
"d" : "2019-12-12 12:25",
"u" : 151.0
"d" : "2019-12-12 12:30",
"u" : 53.0
"d" : "2019-12-12 12:35",
"u" : 65.0
"d" : "2019-12-12 12:40",
"u" : 53.0
"d" : "2019-12-12 12:45",
"u" : 91.0
"d" : "2019-12-12 12:50",
"u" : 119.0
"d" : "2019-12-12 12:55",
"u" : 168.0
"d" : "2019-12-12 13:00",
"u" : 69.0
"d" : "2019-12-12 13:05",
"u" : 54.0
"d" : "2019-12-12 13:10",
"u" : 40.0
"d" : "2019-12-12 13:15",
"u" : 57.0
"d" : "2019-12-12 13:20",
"u" : 53.0
"d" : "2019-12-12 13:25",
"u" : 135.0
"d" : "2019-12-12 13:30",
"u" : 52.0
"d" : "2019-12-12 13:35",
"u" : 66.0
"d" : "2019-12-12 13:40",
"u" : 54.0
"d" : "2019-12-12 13:45",
"u" : 65.0
"d" : "2019-12-12 13:50",
"u" : 59.0
"d" : "2019-12-12 13:55",
"u" : 157.0
"d" : "2019-12-12 14:00",
"u" : 53.0
"d" : "2019-12-12 14:05",
"u" : 65.0
"d" : "2019-12-12 14:10",
"u" : 51.0
"d" : "2019-12-12 14:15",
"u" : 64.0
"d" : "2019-12-12 14:20",
"u" : 52.0
"d" : "2019-12-12 14:25",
"u" : 64.0
"d" : "2019-12-12 14:30",
"u" : 144.0
"d" : "2019-12-12 14:35",
"u" : 76.0
"d" : "2019-12-12 14:40",
"u" : 79.0
"d" : "2019-12-12 14:45",
"u" : 73.0
"d" : "2019-12-12 14:50",
"u" : 66.0
"d" : "2019-12-12 14:55",
"u" : 114.0
"d" : "2019-12-12 15:00",
"u" : 120.0
"d" : "2019-12-12 15:05",
"u" : 159.0
"d" : "2019-12-12 15:10",
"u" : 66.0
"d" : "2019-12-12 15:15",
"u" : 79.0
"d" : "2019-12-12 15:20",
"u" : 66.0
"d" : "2019-12-12 15:25",
"u" : 77.0
"d" : "2019-12-12 15:30",
"u" : 66.0
"d" : "2019-12-12 15:35",
"u" : 78.0
"d" : "2019-12-12 15:40",
"u" : 170.0
"d" : "2019-12-12 15:45",
"u" : 131.0
"d" : "2019-12-12 15:50",
"u" : 132.0
"d" : "2019-12-12 15:55",
"u" : 104.0
"d" : "2019-12-12 16:00",
"u" : 82.0
"d" : "2019-12-12 16:05",
"u" : 81.0
"d" : "2019-12-12 16:10",
"u" : 80.0
"d" : "2019-12-12 16:15",
"u" : 79.0
"d" : "2019-12-12 16:20",
"u" : 80.0
"d" : "2019-12-12 16:25",
"u" : 80.0
"d" : "2019-12-12 16:30",
"u" : 82.0
"d" : "2019-12-12 16:35",
"u" : 83.0
"d" : "2019-12-12 16:40",
"u" : 83.0
"d" : "2019-12-12 16:45",
"u" : 98.0
"d" : "2019-12-12 16:50",
"u" : 106.0
"d" : "2019-12-12 16:55",
"u" : 181.0
"d" : "2019-12-12 17:00",
"u" : 99.0
"d" : "2019-12-12 17:05",
"u" : 116.0
"d" : "2019-12-12 17:10",
"u" : 114.0
"d" : "2019-12-12 17:15",
"u" : 108.0
"d" : "2019-12-12 17:20",
"u" : 107.0
"d" : "2019-12-12 17:25",
"u" : 107.0
"d" : "2019-12-12 17:30",
"u" : 107.0
"d" : "2019-12-12 17:35",
"u" : 96.0
"d" : "2019-12-12 17:40",
"u" : 108.0
"d" : "2019-12-12 17:45",
"u" : 94.0
"d" : "2019-12-12 17:50",
"u" : 167.0
"d" : "2019-12-12 17:55",
"u" : 244.0
"d" : "2019-12-12 18:00",
"u" : 115.0
"d" : "2019-12-12 18:05",
"u" : 96.0
"d" : "2019-12-12 18:10",
"u" : 116.0
"d" : "2019-12-12 18:15",
"u" : 95.0
"d" : "2019-12-12 18:20",
"u" : 456.0
"d" : "2019-12-12 18:25",
"u" : 109.0
"d" : "2019-12-12 18:30",
"u" : 109.0
"d" : "2019-12-12 18:35",
"u" : 121.0
"d" : "2019-12-12 18:40",
"u" : 105.0
"d" : "2019-12-12 18:45",
"u" : 161.0
"d" : "2019-12-12 18:50",
"u" : 96.0
"d" : "2019-12-12 18:55",
"u" : 148.0
"d" : "2019-12-12 19:00",
"u" : 161.0
"d" : "2019-12-12 19:05",
"u" : 120.0
"d" : "2019-12-12 19:10",
"u" : 190.0
"d" : "2019-12-12 19:15",
"u" : 186.0
"d" : "2019-12-12 19:20",
"u" : 97.0
"d" : "2019-12-12 19:25",
"u" : 98.0
"d" : "2019-12-12 19:30",
"u" : 109.0
"d" : "2019-12-12 19:35",
"u" : 97.0
"d" : "2019-12-12 19:40",
"u" : 190.0
"d" : "2019-12-12 19:45",
"u" : 141.0
"d" : "2019-12-12 19:50",
"u" : 110.0
"d" : "2019-12-12 19:55",
"u" : 97.0
"d" : "2019-12-12 20:00",
"u" : 144.0
"d" : "2019-12-12 20:05",
"u" : 241.0
"d" : "2019-12-12 20:10",
"u" : 132.0
"d" : "2019-12-12 20:15",
"u" : 117.0
"d" : "2019-12-12 20:20",
"u" : 101.0
"d" : "2019-12-12 20:25",
"u" : 94.0
"d" : "2019-12-12 20:30",
"u" : 99.0
"d" : "2019-12-12 20:35",
"u" : 97.0
"d" : "2019-12-12 20:40",
"u" : 187.0
"d" : "2019-12-12 20:45",
"u" : 95.0
"d" : "2019-12-12 20:50",
"u" : 106.0
"d" : "2019-12-12 20:55",
"u" : 157.0
"d" : "2019-12-12 21:00",
"u" : 249.0
"d" : "2019-12-12 21:05",
"u" : 95.0
"d" : "2019-12-12 21:10",
"u" : 107.0
"d" : "2019-12-12 21:15",
"u" : 96.0
"d" : "2019-12-12 21:20",
"u" : 141.0
"d" : "2019-12-12 21:25",
"u" : 161.0
"d" : "2019-12-12 21:30",
"u" : 211.0
"d" : "2019-12-12 21:35",
"u" : 148.0
"d" : "2019-12-12 21:40",
"u" : 109.0
"d" : "2019-12-12 21:45",
"u" : 95.0
"d" : "2019-12-12 21:50",
"u" : 107.0
"d" : "2019-12-12 21:55",
"u" : 95.0
"d" : "2019-12-12 22:00",
"u" : 189.0
"d" : "2019-12-12 22:05",
"u" : 95.0
"d" : "2019-12-12 22:10",
"u" : 107.0
"d" : "2019-12-12 22:15",
"u" : 96.0
"d" : "2019-12-12 22:20",
"u" : 108.0
"d" : "2019-12-12 22:25",
"u" : 189.0
"d" : "2019-12-12 22:30",
"u" : 131.0
"status" : "OK",
"title" : "Graph counter day"
"result" : [
"u" : 2025.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 2105.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 2204.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 2078.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 2124.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 2.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 2136.0
"u" : 4064.0
"u" : 2133.0
"u" : 2166.0
"u" : 84.0
"u" : 84.0
"u" : 84.0
"u" : 84.0
"u" : 84.0
"u" : 2151.0
"u" : 85.0
"u" : 84.0
"u" : 84.0
"u" : 84.0
"u" : 85.0
"u" : 2188.0
"u" : 2106.0
"u" : 2105.0
"u" : 86.0
"u" : 0.0
"u" : 21.0
"u" : 21.0
"u" : 21.0
"u" : 21.0
"u" : 22.0
"u" : 21.0
"u" : 20.0
"u" : 21.0
"u" : 20.0
"u" : 20.0
"u" : 20.0
"u" : 20.0
"u" : 20.0
"u" : 21.0
"u" : 2.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"d" : "2019-12-12 22:35",
"u" : 0.0
"status" : "OK",
ykuijs
Last night (shortly after posting previous post) the "Last hours" graph showed some output, but the "Today" graph still didn't work:
Last Hours:
Today:
Graph in Domoticz:
This morning both graphs weren't working again. So it probably looks like an issue where the usage is consistently low, but has spikes every now and then.
Last Hours:
Today:
Graph in Domoticz:
Lokonli
I've to check how the chart.js module handles subsampling of device data, because the main difference between 'laatste uren' and 'vandaag' is the amount of data that is received.
Just to be sure, can you post the block definition for your graphs from config.js?
Which exact Dashticz version are you running?
In the latest beta there is an update on the chart x-axis setting, which might solve this issue.
Lokonli
I think I've found the issue:
If the first datapoint is 0, then whole data range will not be used...
I'll fix it this weekend.
ykuijs
I haven't defined any graph settings yet, so am using the default settings. Wanted to make sure it wasn't caused by anything I didLokonli wrote: Friday 13 December 2019 11:17 I've to check how the chart.js module handles subsampling of device data, because the main difference between 'laatste uren' and 'vandaag' is the amount of data that is received.
I am using v3.1.2 Master
That is excellent, that totally makes sense based on the behavior I have seen so far. Waiting anxiously for the update! Thanks for your effort!Lokonli wrote: Friday 13 December 2019 11:32 I think I've found the issue:
Lokonli
Should be fixed in latest beta. Can you test?ykuijs wrote: Friday 13 December 2019 13:15I haven't defined any graph settings yet, so am using the default settings. Wanted to make sure it wasn't caused by anything I didLokonli wrote: Friday 13 December 2019 11:17 I've to check how the chart.js module handles subsampling of device data, because the main difference between 'laatste uren' and 'vandaag' is the amount of data that is received.
ykuijs
Just pulled the latest bits from GitHub and used that. It is a little better, but isn't correct yet:
The graph for "Laatste Uren" now shows info, however just one data point with the value of 2019. I think this is displaying the year instead of the data from Domoticz:
The x-axis for graph for "Vandaag" shows increments of 10 or 15 minutes, but at the end of the graph jumps from 21.30 to 6.15
The data for this phase:
"result" : [
"d" : "2019-12-13 10:50",
"u" : 75.0
"d" : "2019-12-13 10:55",
"u" : 137.0
"d" : "2019-12-13 11:00",
"u" : 127.0
"d" : "2019-12-13 11:05",
"u" : 80.0
"d" : "2019-12-13 11:10",
"u" : 68.0
"d" : "2019-12-13 11:15",
"u" : 80.0
"d" : "2019-12-13 11:20",
"u" : 146.0
"d" : "2019-12-13 11:25",
"u" : 77.0
"d" : "2019-12-13 11:30",
"u" : 67.0
"d" : "2019-12-13 11:35",
"u" : 79.0
"d" : "2019-12-13 11:40",
"u" : 154.0
"d" : "2019-12-13 11:45",
"u" : 79.0
"d" : "2019-12-13 11:50",
"u" : 66.0
"d" : "2019-12-13 11:55",
"u" : 110.0
"d" : "2019-12-13 12:00",
"u" : 132.0
"d" : "2019-12-13 12:05",
"u" : 133.0
"d" : "2019-12-13 12:10",
"u" : 110.0
"d" : "2019-12-13 12:15",
"u" : 71.0
"d" : "2019-12-13 12:20",
"u" : 68.0
"d" : "2019-12-13 12:25",
"u" : 85.0
"d" : "2019-12-13 12:30",
"u" : 56.0
"d" : "2019-12-13 12:35",
"u" : 146.0
"d" : "2019-12-13 12:40",
"u" : 55.0
"d" : "2019-12-13 12:45",
"u" : 68.0
"d" : "2019-12-13 12:50",
"u" : 54.0
"d" : "2019-12-13 12:55",
"u" : 65.0
"d" : "2019-12-13 13:00",
"u" : 57.0
"d" : "2019-12-13 13:05",
"u" : 65.0
"d" : "2019-12-13 13:10",
"u" : 136.0
"d" : "2019-12-13 13:15",
"u" : 73.0
"d" : "2019-12-13 13:20",
"u" : 120.0
"d" : "2019-12-13 13:25",
"u" : 120.0
"d" : "2019-12-13 13:30",
"u" : 84.0
"d" : "2019-12-13 13:35",
"u" : 66.0
"d" : "2019-12-13 13:40",
"u" : 67.0
"d" : "2019-12-13 13:45",
"u" : 54.0
"d" : "2019-12-13 13:50",
"u" : 207.0
"d" : "2019-12-13 13:55",
"u" : 115.0
"d" : "2019-12-13 14:00",
"u" : 66.0
"d" : "2019-12-13 14:05",
"u" : 54.0
"d" : "2019-12-13 14:10",
"u" : 66.0
"d" : "2019-12-13 14:15",
"u" : 54.0
"d" : "2019-12-13 14:20",
"u" : 101.0
"d" : "2019-12-13 14:25",
"u" : 120.0
"d" : "2019-12-13 14:30",
"u" : 169.0
"d" : "2019-12-13 14:35",
"u" : 87.0
"d" : "2019-12-13 14:40",
"u" : 74.0
"d" : "2019-12-13 14:45",
"u" : 80.0
"d" : "2019-12-13 14:50",
"u" : 151.0
"d" : "2019-12-13 14:55",
"u" : 79.0
"d" : "2019-12-13 15:00",
"u" : 66.0
"d" : "2019-12-13 15:05",
"u" : 87.0
"d" : "2019-12-13 15:10",
"u" : 78.0
"d" : "2019-12-13 15:15",
"u" : 79.0
"d" : "2019-12-13 15:20",
"u" : 85.0
"d" : "2019-12-13 15:25",
"u" : 155.0
"d" : "2019-12-13 15:30",
"u" : 211.0
"d" : "2019-12-13 15:35",
"u" : 133.0
"d" : "2019-12-13 15:40",
"u" : 87.0
"d" : "2019-12-13 15:45",
"u" : 80.0
"d" : "2019-12-13 15:50",
"u" : 67.0
"d" : "2019-12-13 15:55",
"u" : 68.0
"d" : "2019-12-13 16:00",
"u" : 69.0
"d" : "2019-12-13 16:05",
"u" : 147.0
"d" : "2019-12-13 16:10",
"u" : 86.0
"d" : "2019-12-13 16:15",
"u" : 73.0
"d" : "2019-12-13 16:20",
"u" : 79.0
"d" : "2019-12-13 16:25",
"u" : 67.0
"d" : "2019-12-13 16:30",
"u" : 77.0
"d" : "2019-12-13 16:35",
"u" : 168.0
"d" : "2019-12-13 16:40",
"u" : 153.0
"d" : "2019-12-13 16:45",
"u" : 141.0
"d" : "2019-12-13 16:50",
"u" : 93.0
"d" : "2019-12-13 16:55",
"u" : 81.0
"d" : "2019-12-13 17:00",
"u" : 94.0
"d" : "2019-12-13 17:05",
"u" : 74.0
"d" : "2019-12-13 17:10",
"u" : 89.0
"d" : "2019-12-13 17:15",
"u" : 166.0
"d" : "2019-12-13 17:20",
"u" : 107.0
"d" : "2019-12-13 17:25",
"u" : 89.0
"d" : "2019-12-13 17:30",
"u" : 101.0
"d" : "2019-12-13 17:35",
"u" : 96.0
"d" : "2019-12-13 17:40",
"u" : 101.0
"d" : "2019-12-13 17:45",
"u" : 88.0
"d" : "2019-12-13 17:50",
"u" : 223.0
"d" : "2019-12-13 17:55",
"u" : 169.0
"d" : "2019-12-13 18:00",
"u" : 144.0
"d" : "2019-12-13 18:05",
"u" : 116.0
"d" : "2019-12-13 18:10",
"u" : 103.0
"d" : "2019-12-13 18:15",
"u" : 195.0
"d" : "2019-12-13 18:20",
"u" : 106.0
"d" : "2019-12-13 18:25",
"u" : 104.0
"d" : "2019-12-13 18:30",
"u" : 104.0
"d" : "2019-12-13 18:35",
"u" : 255.0
"d" : "2019-12-13 18:40",
"u" : 233.0
"d" : "2019-12-13 18:45",
"u" : 230.0
"d" : "2019-12-13 18:50",
"u" : 228.0
"d" : "2019-12-13 18:55",
"u" : 200.0
"d" : "2019-12-13 19:00",
"u" : 180.0
"d" : "2019-12-13 19:05",
"u" : 202.0
"d" : "2019-12-13 19:10",
"u" : 178.0
"d" : "2019-12-13 19:15",
"u" : 101.0
"d" : "2019-12-13 19:20",
"u" : 181.0
"d" : "2019-12-13 19:25",
"u" : 102.0
"d" : "2019-12-13 19:30",
"u" : 156.0
"d" : "2019-12-13 19:35",
"u" : 162.0
"d" : "2019-12-13 19:40",
"u" : 101.0
"d" : "2019-12-13 19:45",
"u" : 101.0
"d" : "2019-12-13 19:50",
"u" : 228.0
"d" : "2019-12-13 19:55",
"u" : 193.0
"d" : "2019-12-13 20:00",
"u" : 208.0
"d" : "2019-12-13 20:05",
"u" : 135.0
"d" : "2019-12-13 20:10",
"u" : 124.0
"d" : "2019-12-13 20:15",
"u" : 126.0
"d" : "2019-12-13 20:20",
"u" : 110.0
"d" : "2019-12-13 20:25",
"u" : 115.0
"d" : "2019-12-13 20:30",
"u" : 187.0
"d" : "2019-12-13 20:35",
"u" : 115.0
"d" : "2019-12-13 20:40",
"u" : 101.0
"d" : "2019-12-13 20:45",
"u" : 123.0
"d" : "2019-12-13 20:50",
"u" : 101.0
"d" : "2019-12-13 20:55",
"u" : 255.0
"d" : "2019-12-13 21:00",
"u" : 101.0
"d" : "2019-12-13 21:05",
"u" : 102.0
"d" : "2019-12-13 21:10",
"u" : 108.0
"d" : "2019-12-13 21:15",
"u" : 108.0
"d" : "2019-12-13 21:20",
"u" : 129.0
"d" : "2019-12-13 21:25",
"u" : 183.0
"d" : "2019-12-13 21:30",
"u" : 166.0
"d" : "2019-12-13 21:35",
"u" : 87.0
"d" : "2019-12-13 21:40",
"u" : 70.0
"d" : "2019-12-13 21:45",
"u" : 70.0
"d" : "2019-12-13 21:50",
"u" : 83.0
"d" : "2019-12-13 21:55",
"u" : 152.0
"d" : "2019-12-13 22:00",
"u" : 81.0
"d" : "2019-12-13 22:05",
"u" : 70.0
"d" : "2019-12-13 22:10",
"u" : 95.0
"d" : "2019-12-13 22:15",
"u" : 101.0
"d" : "2019-12-13 22:20",
"u" : 150.0
"d" : "2019-12-13 22:25",
"u" : 143.0
"d" : "2019-12-13 22:30",
"u" : 69.0
"d" : "2019-12-13 22:35",
"u" : 69.0
"d" : "2019-12-13 22:40",
"u" : 55.0
"d" : "2019-12-13 22:45",
"u" : 55.0
"d" : "2019-12-13 22:50",
"u" : 54.0
"d" : "2019-12-13 22:55",
"u" : 53.0
"d" : "2019-12-13 23:00",
"u" : 131.0
"d" : "2019-12-13 23:05",
"u" : 53.0
"d" : "2019-12-13 23:10",
"u" : 53.0
"d" : "2019-12-13 23:15",
"u" : 57.0
"d" : "2019-12-13 23:20",
"u" : 137.0
"d" : "2019-12-13 23:25",
"u" : 53.0
"d" : "2019-12-13 23:30",
"u" : 51.0
"d" : "2019-12-13 23:35",
"u" : 50.0
"d" : "2019-12-13 23:40",
"u" : 51.0
"d" : "2019-12-13 23:45",
"u" : 140.0
"d" : "2019-12-13 23:50",
"u" : 51.0
"d" : "2019-12-13 23:55",
"u" : 51.0
"d" : "2019-12-14 00:00",
"u" : 51.0
"d" : "2019-12-14 00:05",
"u" : 51.0
"d" : "2019-12-14 00:10",
"u" : 52.0
"d" : "2019-12-14 00:15",
"u" : 52.0
"d" : "2019-12-14 00:20",
"u" : 132.0
"d" : "2019-12-14 00:25",
"u" : 52.0
"d" : "2019-12-14 00:30",
"u" : 51.0
"d" : "2019-12-14 00:35",
"u" : 52.0
"d" : "2019-12-14 00:40",
"u" : 77.0
"d" : "2019-12-14 00:45",
"u" : 51.0
"d" : "2019-12-14 00:50",
"u" : 138.0
"d" : "2019-12-14 00:55",
"u" : 51.0
"d" : "2019-12-14 01:00",
"u" : 52.0
"d" : "2019-12-14 01:05",
"u" : 51.0
"d" : "2019-12-14 01:10",
"u" : 58.0
"d" : "2019-12-14 01:15",
"u" : 58.0
"d" : "2019-12-14 01:20",
"u" : 59.0
"d" : "2019-12-14 01:25",
"u" : 134.0
"d" : "2019-12-14 01:30",
"u" : 53.0
"d" : "2019-12-14 01:35",
"u" : 47.0
"d" : "2019-12-14 01:40",
"u" : 47.0
"d" : "2019-12-14 01:45",
"u" : 46.0
"d" : "2019-12-14 01:50",
"u" : 46.0
"d" : "2019-12-14 01:55",
"u" : 102.0
"d" : "2019-12-14 02:00",
"u" : 105.0
"d" : "2019-12-14 02:05",
"u" : 46.0
"d" : "2019-12-14 02:10",
"u" : 47.0
"d" : "2019-12-14 02:15",
"u" : 46.0
"d" : "2019-12-14 02:20",
"u" : 128.0
"d" : "2019-12-14 02:25",
"u" : 46.0
"d" : "2019-12-14 02:30",
"u" : 45.0
"d" : "2019-12-14 02:35",
"u" : 46.0
"d" : "2019-12-14 02:40",
"u" : 45.0
"d" : "2019-12-14 02:45",
"u" : 46.0
"d" : "2019-12-14 02:50",
"u" : 127.0
"d" : "2019-12-14 02:55",
"u" : 45.0
"d" : "2019-12-14 03:00",
"u" : 46.0
"d" : "2019-12-14 03:05",
"u" : 45.0
"d" : "2019-12-14 03:10",
"u" : 131.0
"d" : "2019-12-14 03:15",
"u" : 46.0
"d" : "2019-12-14 03:20",
"u" : 46.0
"d" : "2019-12-14 03:25",
"u" : 46.0
"d" : "2019-12-14 03:30",
"u" : 46.0
"d" : "2019-12-14 03:35",
"u" : 47.0
"d" : "2019-12-14 03:40",
"u" : 126.0
"d" : "2019-12-14 03:45",
"u" : 47.0
"d" : "2019-12-14 03:50",
"u" : 46.0
"d" : "2019-12-14 03:55",
"u" : 47.0
"d" : "2019-12-14 04:00",
"u" : 129.0
"d" : "2019-12-14 04:05",
"u" : 46.0
"d" : "2019-12-14 04:10",
"u" : 47.0
"d" : "2019-12-14 04:15",
"u" : 47.0
"d" : "2019-12-14 04:20",
"u" : 45.0
"d" : "2019-12-14 04:25",
"u" : 47.0
"d" : "2019-12-14 04:30",
"u" : 46.0
"d" : "2019-12-14 04:35",
"u" : 46.0
"d" : "2019-12-14 04:40",
"u" : 128.0
"d" : "2019-12-14 04:45",
"u" : 47.0
"d" : "2019-12-14 04:50",
"u" : 46.0
"d" : "2019-12-14 04:55",
"u" : 46.0
"d" : "2019-12-14 05:00",
"u" : 46.0
"d" : "2019-12-14 05:05",
"u" : 46.0
"d" : "2019-12-14 05:10",
"u" : 74.0
"d" : "2019-12-14 05:15",
"u" : 47.0
"d" : "2019-12-14 05:20",
"u" : 46.0
"d" : "2019-12-14 05:25",
"u" : 47.0
"d" : "2019-12-14 05:30",
"u" : 126.0
"d" : "2019-12-14 05:35",
"u" : 46.0
"d" : "2019-12-14 05:40",
"u" : 46.0
"d" : "2019-12-14 05:45",
"u" : 47.0
"d" : "2019-12-14 05:50",
"u" : 45.0
"d" : "2019-12-14 05:55",
"u" : 48.0
"d" : "2019-12-14 06:00",
"u" : 47.0
"d" : "2019-12-14 06:05",
"u" : 45.0
"d" : "2019-12-14 06:10",
"u" : 125.0
"d" : "2019-12-14 06:15",
"u" : 47.0
"d" : "2019-12-14 06:20",
"u" : 45.0
"d" : "2019-12-14 06:25",
"u" : 45.0
"d" : "2019-12-14 06:30",
"u" : 125.0
"d" : "2019-12-14 06:35",
"u" : 205.0
"d" : "2019-12-14 06:40",
"u" : 125.0
"d" : "2019-12-14 06:45",
"u" : 124.0
"d" : "2019-12-14 06:50",
"u" : 125.0
"d" : "2019-12-14 06:55",
"u" : 126.0
"d" : "2019-12-14 07:00",
"u" : 125.0
"d" : "2019-12-14 07:05",
"u" : 211.0
"d" : "2019-12-14 07:10",
"u" : 125.0
"d" : "2019-12-14 07:15",
"u" : 116.0
"d" : "2019-12-14 07:20",
"u" : 76.0
"d" : "2019-12-14 07:25",
"u" : 104.0
"d" : "2019-12-14 07:30",
"u" : 121.0
"d" : "2019-12-14 07:35",
"u" : 132.0
"d" : "2019-12-14 07:40",
"u" : 59.0
"d" : "2019-12-14 07:45",
"u" : 152.0
"d" : "2019-12-14 07:50",
"u" : 99.0
"d" : "2019-12-14 07:55",
"u" : 109.0
"d" : "2019-12-14 08:00",
"u" : 96.0
"d" : "2019-12-14 08:05",
"u" : 189.0
"d" : "2019-12-14 08:10",
"u" : 98.0
"d" : "2019-12-14 08:15",
"u" : 231.0
"d" : "2019-12-14 08:20",
"u" : 226.0
"d" : "2019-12-14 08:25",
"u" : 229.0
"d" : "2019-12-14 08:30",
"u" : 283.0
"d" : "2019-12-14 08:35",
"u" : 268.0
"d" : "2019-12-14 08:40",
"u" : 900.0
"d" : "2019-12-14 08:45",
"u" : 267.0
"d" : "2019-12-14 08:50",
"u" : 241.0
"d" : "2019-12-14 08:55",
"u" : 140.0
"d" : "2019-12-14 09:00",
"u" : 138.0
"d" : "2019-12-14 09:05",
"u" : 183.0
"d" : "2019-12-14 09:10",
"u" : 90.0
"d" : "2019-12-14 09:15",
"u" : 70.0
"d" : "2019-12-14 09:20",
"u" : 69.0
"d" : "2019-12-14 09:25",
"u" : 78.0
"d" : "2019-12-14 09:30",
"u" : 66.0
"d" : "2019-12-14 09:35",
"u" : 166.0
"d" : "2019-12-14 09:40",
"u" : 172.0
"d" : "2019-12-14 09:45",
"u" : 316.0
"d" : "2019-12-14 09:50",
"u" : 256.0
"d" : "2019-12-14 09:55",
"u" : 144.0
"d" : "2019-12-14 10:00",
"u" : 68.0
"d" : "2019-12-14 10:05",
"u" : 127.0
"d" : "2019-12-14 10:10",
"u" : 133.0
"d" : "2019-12-14 10:15",
"u" : 222.0
"d" : "2019-12-14 10:20",
"u" : 204.0
"d" : "2019-12-14 10:25",
"u" : 155.0
"d" : "2019-12-14 10:30",
"u" : 68.0
"d" : "2019-12-14 10:35",
"u" : 87.0
"d" : "2019-12-14 10:40",
"u" : 55.0
"d" : "2019-12-14 10:45",
"u" : 123.0
"d" : "2019-12-14 10:50",
"u" : 56.0
"status" : "OK",
Lokonli
I don't see any relation between the data and the graph. Can you double check you sent the right data? (it resembles your phase 2 data ...)
Then of course there still is something strange between 21:30 and 6:00.
Does Domoticz show a correct graph in that time frame?
What are the high tariff-low tariff electricity switching moments in your city?
ykuijs
Oeps, sorry. You are correct, my bad
The high/low tariff switching moments are: Evening 23.00, morning 7.00.
The x-axis for the first two phases is exactly the same, but the third is different:
The graph for that timeframe in Domoticz is displaying correctly:
"result" : [
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 2038.0
"u" : 0.0
"u" : 2140.0
"u" : 4060.0
"u" : 3992.0
"u" : 84.0
"u" : 85.0
"u" : 85.0
"u" : 84.0
"u" : 84.0
"u" : 83.0
"u" : 84.0
"u" : 83.0
"u" : 83.0
"u" : 83.0
"u" : 16.0
"u" : 84.0
"u" : 2090.0
"u" : 2141.0
"u" : 2167.0
"u" : 86.0
"u" : 0.0
"u" : 22.0
"u" : 21.0
"u" : 21.0
"u" : 20.0
"u" : 20.0
"u" : 2063.0
"u" : 20.0
"u" : 21.0
"u" : 20.0
"u" : 19.0
"u" : 20.0
"u" : 20.0
"u" : 22.0
"u" : 21.0
"u" : 2.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 2034.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 2048.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 2019.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"u" : 0.0
"d" : "2019-12-14 10:55",
"u" : 0.0
"d" : "2019-12-14 11:00",
"u" : 0.0
"d" : "2019-12-14 11:05",
"u" : 0.0
"d" : "2019-12-14 11:10",
"u" : 0.0
"d" : "2019-12-14 11:15",
"u" : 0.0
"d" : "2019-12-14 11:20",
"u" : 0.0
"d" : "2019-12-14 11:25",
"u" : 0.0
"d" : "2019-12-14 11:30",
"u" : 0.0
"d" : "2019-12-14 11:35",
"u" : 0.0
"d" : "2019-12-14 11:40",
"u" : 0.0
"d" : "2019-12-14 11:45",
"u" : 0.0
"d" : "2019-12-14 11:50",
"u" : 0.0
"d" : "2019-12-14 11:55",
"u" : 0.0
"d" : "2019-12-14 12:00",
"u" : 0.0
"d" : "2019-12-14 12:05",
"u" : 0.0
"d" : "2019-12-14 12:10",
"u" : 0.0
"d" : "2019-12-14 12:15",
"u" : 0.0
"d" : "2019-12-14 12:20",
"u" : 0.0
"d" : "2019-12-14 12:25",
"u" : 0.0
"d" : "2019-12-14 12:30",
"u" : 0.0
"d" : "2019-12-14 12:35",
"u" : 0.0
"d" : "2019-12-14 12:40",
"u" : 0.0
"d" : "2019-12-14 12:45",
"u" : 0.0
"d" : "2019-12-14 12:50",
"u" : 0.0
"d" : "2019-12-14 12:55",
"u" : 0.0
"d" : "2019-12-14 13:00",
"u" : 2093.0
"d" : "2019-12-14 13:05",
"u" : 0.0
"d" : "2019-12-14 13:10",
"u" : 0.0
"d" : "2019-12-14 13:15",
"u" : 0.0
"d" : "2019-12-14 13:20",
"u" : 0.0
"d" : "2019-12-14 13:25",
"u" : 0.0
"status" : "OK",
Lokonli
Thank, clear.
All 0 values disappeared.
I've made a fix in latest beta. Can you test again?
ykuijs
Yes, that worked like a charm!! This also fixed the min/max values for the "Afgelopen maand" graph (monthly graphs don't show the average data points (u), but the min/max values (u_min and u_max)). So far that only showed the max values, since the min values had a value of 0. Now the graph shows two lines (one max/one min), just like it does in Domoticz!
Thanks a million!
Thanks a million!
Lokonli
Good! Thanks for the feedback.
mojojojo490
- Domoticz version: 2020.2
Hi @ykuis
Can you post your final code? So we can see what solution you have made?
Starter RPi3B, Domoticz Stable 2020.2, 10x Qubino Mini Dimmer, 1x Qubino shutter
Plugwise Anna + Adam + 2x Koen-4 & 1x Floor; SolarEdge SE3000H
Dashticz v3
Dashticz v3
