Python Plugin: Omnik Inverter local webinterface
sincze
Domoticz version: 2024.4
Post by sincze »
I recently released some PHP scripts that are able to read data from a solar web-portal over the internet.
https://github.com/sincze/Domoticz
Valuable feedback was collected and some Omnik users did not want to retrieve the data from an Internet web portal.
But they also could not use an existing solution because of a different serial number.
https://github.com/Woutrrr/Omnik-Data-Logger.git
So I started to create this Plugin it works with an Omnik4000 v1.
https://github.com/sincze/Domoticz-Omni ... ree/master
It will read data from the inverter itself that is available in the webinterface.
Prereqs: Python version 3.5 & Domoticz V4.11034 (beta)
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
rgroothuis
Re: Python Plugin: Omnik Inverter local webinterface
Post by rgroothuis »
Thanks, this looks good. I like the idea of a simple plug-in to get the solar panel data into Domoticz.
Questions:
1) Will this plug-in also work with: omnik5000tl2
2) Is the data collected from the web-portal or directly, locally, from the Omnik device itself?
Thanks.
sincze
Post by sincze »
rgroothuis wrote: Tuesday 03 December 2019 23:10 Thanks, this looks good. I like the idea of a simple plug-in to get the solar panel data into Domoticz.
Questions:
Thanks.
Depends on the firmware within the inverter, would be nice to give it a try and report back.
In the end we could try to add it as well if it is not supported.
http://xxx.xxx.x.xxx/js/status.js will give you a status page of your inverter, the data is extracted from that.
It looks for a string like this:
var webData="NLDN2017****,NL1-V1.0-0118-4,V2.0-0028,omnik4000tl ,4000,584,345,33734,,4,";
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
rgroothuis
sincze wrote: Wednesday 04 December 2019 8:57
This is what status.js is giving me:
var version= "H4.01.51MW.2.01W1.0.64(2018-01-251-D)";
var m2mMid = "626267437";
var wlanMac= "BC:54:F9:F7:4C:74";
var m2mRssi= "55%";
var wanIp= "192.168.0.189";
var nmac= "BC54F9F74C77";
var fephy= "off";
var yz_device_type="258";
var yz_device_num="1";
var myDeviceArray=new Array();myDeviceArray[0]="AABN502018CQ3038,V5.27Build261,V5.43Build182,omnik5000tl2,5000,696,33,434,,1,";
I don't have a line with var webData=...............
sincze
Post by sincze »
No worries looks the same as the tl3000.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
rgroothuis
Regardless which inverter I select webData or myDeviceArray I get the following error message:
2019-12-04 13:02:26.336 Error: OmnikSolarPanel hardware (11) thread seems to have ended unexpectedly
How can I debug this.
FYI, after this occurs and I try to disable the Omnik plugin, the Domoticz system becomes unresponsive, I need to do a restart from the command line.
rgroothuis
rgroothuis wrote: Wednesday 04 December 2019 13:05 Regardless which inverter I select webData or myDeviceArray I get the following error message:
@sincze: any suggestion on how to address this? What the issue is? How to debug the problem?
MeAlbert
Domoticz version: 2020.1
Post by MeAlbert »
I have put the plugin to Domoticz and it works partly.
I get 3 devices but only the 'switch' stating the status of the inverter works. The power is 0 and the kWh is 0.
My inverter is caled solarsmart. If i give the /js/status.js I get the following string
 var webData="A0415D0056,V1.10,V1.10,SolarSmart 2.5KW,  2500,26,17,80484,,1,";
So it reads the values but they are not processed.
Who can help
Last edited by MeAlbert on Saturday 07 December 2019 13:11, edited 1 time in total.
MeAlbert
Post by MeAlbert »
To add some more info to my previous post.
2019-12-07 10:12:18.114 Status: (Sauna Panelen) Initialized version 1.0.1, author 'sincze'
2019-12-07 10:12:18.115 Status: (Sauna Panelen) Entering work loop.
2019-12-07 10:12:18.270 Error: (Sauna Panelen) 'onMessage' failed 'KeyError'.
2019-12-07 10:12:18.270 Error: (Sauna Panelen) ----> Line 221 in '/home/pi/domoticz/plugins/Domoticz-Omnik-Local-Web-Plugin/plugin.py'
2019-12-07 10:12:18.270 Error: (Sauna Panelen) ----> Line 133 in '/home/pi/domoticz/plugins/Domoticz-Omnik-Local-Web-Plugin/plugin.py'
2019-12-07 10:12:20.772 (Sauna Panelen) Queued asyncronous read aborted (192.168.xx.xx:80).
2019-12-07 10:13:27.020 Error: Sauna Panelen hardware (11) thread seems to have ended unexpectedly
this is what I get in my log when I put basic and messages on. I can manage Python but maybe this is to much for me to handle.
Domoticz version: 2025.1
Thank you for this plugin.
It works like a charm with my Omnik Solar Inverter type 1500 TL, Wifi interface 809xxxxxxx
For the record: I had to use the "myDeviceArray" type inverter in the plugin.
Basssment
Domoticz version: 4.9700
Post by Basssment »
Hello Thank you for this plugin.
i'm facing some error's wich I cant firuge out
I do get the output correct when I run LiveStats.py
but when i run OmnikExport.py I get:
2020-06-28 20:22:17,341 DEBUG Importing output plugin
File "OmnikExport.py", line 170, in
omnik_exporter.run()
File "OmnikExport.py", line 52, in run
import(plugin_name)
ValueError: Empty module name
anny idea what could be wrong in my case? :(
Edit, got it working forgot to select the right output type.
arnaudarduino
Post by arnaudarduino »
Deze plugin werkt bij mijn Omnik inverter 3k tl3 . [myDeviceArray[0]="AANN302**********9,V5.04Build230,V4.13Build262,Omnik3000tl ,3000,439,123,683,,1,";;
Top .
arnaudarduino
And stopped :(
sincze
Post by sincze »
What does the log say ??
Debugging with just 'stopped ' is very hard. :D
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
arnaudarduino
Sorry , did the post in github.
I get this failure, and no kwh and w in Domoticz
This what in the log problem
2021-04-05 14:56:56.708 Error: Feithzonnig hardware (22) thread seems to have ended unexpectedly
Whit ip/js/status.js i get this, so there is value
`var version= "H4.01.51MW.2.01W1.0.65(2018-02-271-D)";
var m2mMid = "644401429";
var wlanMac= "F0:FE:6B:E4:EB:64";
var m2mRssi= "100%";
var wanIp= "192.168.2.251";
var nmac= "F0FE6BE4EB67";
var fephy= "off";
var init_inv_type="0";
myDeviceArray[0]="AANN302019184099,V5.04Build230,V4.13Build262,Omnik3000tl ,3000,976,136,17685,,1,";
var fephy= "off";
myDeviceArray[0]="AANN302019184099,V5.04Build230,V4.13Build262,Omnik3000tl ,3000,2160,160,17688,,0,";
var fephy= "off";
myDeviceArray[0]="AANN302019184099,V5.04Build230,V4.13Build262,Omnik3000tl ,3000,2845,523,17724,,0,";
This the info from my inverter
Device information
Device serial number644401429
Firmware versionH4.01.51MW.2.01W1.0.65(2018-02-271-D)
Wireless AP modeEnable
SSIDAP_644401429
IP address10.10.100.254
MAC addressF0:FE:6B:E4:EB:64
Wireless STA modeEnable
Router SSIDdevolo-f4068d7414ea
Signal quality100%
IP address192.168.2.251
MAC addressF0:FE:6B:E4:EB:65
Cable modeDisable
IP address
MAC address`
Number1
Inverter serial number
AANN302019184099
Firmware version (main)V5.04Build230
Firmware version (slave)V4.13Build**262**
Inverter modelOmnik3000tl
Rated power3000 W
Current power55 W
Yield today13.21 kWh
Total yield1842.1 kWh
Alerts---
Last updated0 min ago
Same issue as ..."
Omnik local web-plugin crashes/hangs system"
I hope you can help.
arnaudarduino
Over Domoticz
Version: 4.10717
Build Hash: b38b49e5
Compile Date: 2019-05-09 13:04:08
dzVents Version: 2.4.19
Python Version: 3.5.3 (default, Nov 18 2020, 21:09:16) [GCC 6.3.0 20170516]
Uptime: 35 Seconden
update 13182 won't install.
Its become more important because, omnik portal is not free anymore, cost about 6euro a year.
Did you test the link from the Domoticz server or from another device? Could be that it can not be reached from the server.
What does the log file says if you update the omnik plugin hardware? The plugin will restart and probably give some extra details. Also you can set the debug level higher on the plugin.
arnaudarduino
Systeem updaten , upgraden ,totaly crashed.
Txs any way
Later
henkie
Post by henkie »
arnaudarduino wrote: Saturday 01 August 2020 9:53 Deze plugin werkt bij mijn Omnik inverter 3k tl3 . [myDeviceArray[0]="AANN302**********9,V5.04Build230,V4.13Build262,Omnik3000tl ,3000,439,123,683,,1,";;
Top .
Hi, do you by any chance have the latest firmware for omniksol 3K-TL3? I've been looking for it everywhere but cannot find it. My inverter is showing "waiting 0" errors and the newest firmware might be able to fix the issue. Thanks in advance!
parallax
Post by parallax »
henkie wrote: Friday 27 August 2021 14:30 Hi, do you by any chance have the latest firmware for omniksol 3K-TL3? I've been looking for it everywhere but cannot find it. My inverter is showing "waiting 0" errors and the newest firmware might be able to fix the issue. Thanks in advance!
Hi Henkie, did you find the firmware for your inverter? I'm facing the same issue.
Thx for any help!
