I just setup zigbee2mqtt and it seems to work fine.
The only device that I cannot get to work is the xiaomi cube. It adds a couple of devices but I am not really sure what to do with them.
Is there a tutorial for setting up the cube in domoticz?
I added a shot of the created devices to my post.
Aqara/ Xiaomi Cube turotial
Nephylim
- 1.JPG (76.1 KiB) Viewed 892 times
henkiev
Re: Aqara/ Xiaomi Cube turotial
Hi nephulim,
Just was wondering about that one.
In above picture you can push the green arrows to add the device you want i added the device that gives the switch not using batteries for now.
then i renamed my cube to CUBE1
then i added an ikea light and some other devices, but below the device to control is : zig-stalamp- ikea-e27
then i went to configuration settings and clicked on events, then i create a lua event.. with below. (devicetype)
HOpe this helps, cheers.
print ("***************** luacube2222 *******************");
if otherdevices['CUBE1'] == 'Rotate Left' then
print('Lichtsterkte Naar Beneden')
print(otherdevices_svalues['zig-stalamp- ikea-e27'])
dimTo = (otherdevices_svalues['zig-stalamp- ikea-e27']-10)
print(' nieuw:' .. dimTo .. ' ')
commandArray['zig-stalamp- ikea-e27'] = 'Set Level:'..dimTo..' '
commandArray['CUBE1'] = 'Off'
if otherdevices['CUBE1'] == 'Rotate Right' then
print('Lichtsterkte Naar Boven')
dimTo = (otherdevices_svalues['zig-stalamp- ikea-e27']+10)
henkiev
Also sharing some other lua script for the other options.
I created for what I found on the internet . i do not know the source but nothing worked for me, and below does:
Hope this helps some people.
--lua device
--maak groep Woonkamer Lampen en maak groep CUBE1 OFF en zet daarin je cube1 op niveau 0%
--maak de scene heu10 , hue60 , hue95 en zet daarin je apparaat heu lamp op het niveau
print("***************** luacube *******************")
if otherdevices['CUBE1']=='Flip 90' then
commandArray['Group:Woonkamer Lampen'] = 'On'
commandArray['Group:CUBE1 OFF'] = 'Off'
print ("0 CUBE1 Flip 90 zet lampen Aan en CUBE1 uit na 30 sec ");
if otherdevices['CUBE1']=='Shake' then
commandArray['Group:Woonkamer Lampen'] = 'Off'
print ("1 CUBE1 SHAKE zet lampen uit en CUBE1 uit na 30 sec ");
if otherdevices['CUBE1']=='Tap' then
commandArray['Group:buitenverlichting'] = 'On'
print ("2 CUBE1 Tap zet buitenverlichting lampen Aan en CUBE1 uit na 30 sec ");
--if otherdevices['CUBE1']=='Rotate Right'
-- and otherdevices['zig-stalamp- ikea-e27']=='On' then
-- commandArray['Scene:kamer80'] = 'On'
-- commandArray['Group:CUBE1 OFF'] = 'Off'
-- print ("3 CUBE1 Rotate Right zet stalamp hoger kamer80 ");
-- return commandArray
--end
-- if otherdevices['CUBE1']=='Rotate Left'
-- commandArray['Scene:kamer10'] = 'On'
-- print ("4 CUBE1 Rotate Left zet stalamp lager kamer10 ");
--end
if otherdevices['CUBE1']=='Flip 180'
commandArray['Scene:kamer100'] = 'On'
print ("5 CUBE1 flip180 zet stalamp HOOG kamer100 ");
if otherdevices['CUBE1']=='Slide' then
-- commandArray['Group:buitenverlichting'] = 'Off'
-- print ("6 CUBE1 uit na 30 sec ");
if otherdevices['CUBE1']=='Fall' then
-- print ("7 CUBE1 uit na 30 sec ");
--let op hue moet al wel aan staan voor deze scenes 3,4,5
--Flip90 lampen aan
--Tap buitenlampen aan
--Rotate Right staLamp naar 80
--Rotate Left Lamp naar 10
--Flip 180 STA Lamp naar 100
--slide buitenlampen uit
--Shake Shake alle Lampen uit
henkiev
I always turn the CUBE1 to off again after firing
But could also be handy to not do that.
For the second script i have created a group called CUBE1 when you use that switch it puts the device itself to off.
Hope to find some fun other scripts here for the aqaura cube.
