Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
mantoz
Domoticz version: 2024.7
Post by mantoz »
Madgeni wrote: Friday 04 October 2019 12:01 Ok, reverted - sync your devices and they should be as they were
Thanks Madgeni,
It works. Much better this way!
mantoz
Madgeni
Post by Madgeni »
Hi all - native selector switch support is now available, and should be in all languages.
"Hey Google, set <selectorswitch> mode to <level>"
Enjoy!
tjabas
Post by tjabas »
I have some rainsensors, windsensors, and a power sensor that i want to work with controlicz, is there any news about that?
Madgeni
Post by Madgeni »
Hi - sensors are still not available with Google (except temp sensors - which i work around)
0rsa
Post by 0rsa »
Madgeni wrote: Thursday 24 October 2019 10:51 Hi all - native selector switch support is now available, and should be in all languages.
Enjoy!
I don't succeed to get it working in French.
Xiaomi vacuum 1S with these commands:
I tried a lot of different voice commands to Google assistant but he only understands On/Off which has no effect to the vacuum.
Also, in Google home app, my vacuum is seen as a "simple switch". When a switch selector is successfully added to the app, is there a different status available than a simple switch?
Madgeni
Post by Madgeni »
hi -
Can you send a support note from your Controlicz profile, and i'll take a look.
In terms of the switch icon, there's no selector icon, and currently no touch controls available at the moment. As soon as that changes, i'll implement it
maxtrash
Post by maxtrash »
Have been busy setting up EQ3 max thermostats in domoticz and google home. The hardware plugin creates many devices for each radiator valve (thermostat, temperature, valve percentage and selector switch). I added all of them to a roomplan (so in Domoticz I would see them when selecting the room), but only the thermostat was assigned to the controlicz user. I did this so in order not to confuse google home with too many devices.
However, also the 3 devices which were not assigned to the controlicz user were still shown as "in a roomplan" on the controlicz site. This surprised me.
I removed them from the floorplan to solve the issue but did I miss something?
Madgeni
Post by Madgeni »
Can you restart domoticz and check again?
maxtrash
Post by maxtrash »
Now I have a strange problem with Domoticz. After adding the new device to the room it is there. I go to other screens of domoticz and return: still there.
now I reboot (using option in domoticz) and after reboot the device is no longer in the specified room. Will investigate further...
update: after manually stopping domoticz before rebooting it seems to keep the new device.
the issue with Controlicz is still present: the device is in a room plan but not assigned to user "controlicz" and still being shown in controlicz as being in a roomplan
Madgeni
Post by Madgeni »
What permissions do the user have?
maxtrash
Post by maxtrash »
rights is set to "user'.
Everything else is off (like sharing and active menus)
maxtrash
Post by maxtrash »
omg: the main user name / password was set to controlicz as well, exposing all devices. Sorry for the confusion.
lumjajo
Domoticz version: 4.10717
Post by lumjajo »
Since one week or so I have controlicz now working with Alexa ..or better working from time to time.
Every other day, Alex does not react or says the devices are not reachable. When I look into controlicz, my devices are visible and the connection is ok. so everything works from there. Then I make a redicover of all devices (in floorplans of course) and ...nothing happens.
So overall, there is no reliably solution available right now. HA bridge worked for me for over 2 or 3 years and suddenly stopped and commands are not fulfilled anymore. I switched to Controlizs. It worked for 2 days...suddenly also stopped...what else?
Madgeni
Post by Madgeni »
Hi -
sorry you are having issues. Contact me from your Controlicz profile, and i'll happily take a look
andreasm80
Post by andreasm80 »
Been using Controlicz successfully with Google Home/assistant for around half a year. Dont remember exactly, but since a couple of months ago without any changes from me something annoying began.
I have several rooms where there are 3-4 lights defined. In Google home they are grouped together in their respective room.
Before this worked like a charm, I could say "Turn of/on Dining Room" and all lights in that room turned off/on, where GH just replied the action with name of the respective room. Now GH replies with "OK, turning the Dining Room 1 (which is one of the lights in the same room), Sorry cant reach two lights right now, please try again later". But the light are being turned off. And when I say "Turn on Dining Room" GH replies with "Turning on Dining Room 2 (which is one of the lights in that room), Sorry cant reach two light right now, please try again later"..
So everyting works, GH does what I say, but it is really annoying that GH gives this lengthy error each time turning off/on the different rooms.
I have tried changing the names being announced from Domoticz to Controllicz, I have unpaired Controllicz from Google Home, but no change.
Someone been having the same issue? Is it something I can adjust from my side?
gschmidt
Post by gschmidt »
Hi madgeni,
Happily using controlicz for 2 years now.
I was wondering whether a 2 way voicecontrol is possible?
E.g. A voice/audio message to Google home when a doorbell is pushed
Madgeni
Post by Madgeni »
andreasm80 wrote: Sunday 01 December 2019 9:37 Been using Controlicz successfully with Google Home/assistant for around half a year. Dont remember exactly, but since a couple of months ago without any changes from me something annoying began.
Hi - it does the same for me, am investigating. It's not directly related to Controlicz, but there's clearly a behaviour issue. For example, two switches in my front room respond as expected, however two lights in my hall have the same behaviour as you (both work, only one reports - despite both providing a response).
Will look into it.
markjgabb
Domoticz version: 3.8153
Post by markjgabb »
I'll join the crew experiencing this... I find it's never one light in particular. It quite often can be random as to which lights won't respond properly
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
Madgeni
Post by Madgeni »
It seems to only be lights, not switches. I'm working with Google on it this evening
maxtrash
Post by maxtrash »
Madgeni wrote: Monday 02 December 2019 21:02 It seems to only be lights, not switches. I'm working with Google on it this evening
great to hear you still have a good relationship with google. Also encountering the same issues with lights.
No issue for me paying for software development and support like this.
Users browsing this forum: Ahrefs [Bot] and 1 guest
