I bought an 433 button on Ali and made an event to switch on the dinnertable light, this works. But somehow this event is also triggered when I switch the kitchen light (or by event of just switch the kitchenlicht) both lights are connected to a Fibaro dimmer(seperate dimmers). And as far as I can see they are in no way connected.
I thought it might be the cheap button so I made a dummy switch to control the dinnertable light but with the same result. So the problems seems to be in the dinnertable event. (Attached as "Eetkamerlamp") I use the state "Group Off" because that's what the button triggers.
Underneath a piece of the logfile that where the dinnertablelight is swithed toghether with the kitchenlight.
2019-11-03 10:04:59.164 (Aeotec Z-wave stick) Light/Switch (Motion Keuken)
2019-11-03 10:04:59.170 EventSystem: Event triggered: Licht Keuken_1
2019-11-03 10:04:59.172 OpenZWave: Domoticz has send a Switch command!, Level: 50, NodeID: 11 (0x0b)
2019-11-03 10:04:59.181 (Aeotec Z-wave stick) Light/Switch (Lamp Keuken)
2019-11-03 10:04:59.187 EventSystem: Event triggered: Licht Eetkamer_1
2019-11-03 10:04:59.222 OpenZWave: Domoticz has send a Switch command!, Level: 255, NodeID: 8 (0x08)
Does someone know how this could happen? I have no slave devices on my kitchenlight, and not working with groups. I only use events.
Would be great!, Thanks!
One event triggers other but it shouldn't Topic is solved
wouterlet
- Eetkamerlamp.png (26.62 KiB) Viewed 311 times
wouterlet
Re: One event triggers other but it shouldn't
After trying and testing I figured out what the problem was. The User Variable was the one causing the problem. I made a new one and now it works fine. Why the variable was causing this stays a mistery for me. But at least this solved my problem. Maybe I can help someone with this.
