Open Weather Map
Dave47
Domoticz version: 2023.1
Open Weather Map
Post by Dave47 »
I use Open Weather Map for the weather
when i go to the settings in Dashticz, the weather
I try to change and save settings there.
Nothing changes in the settings
I also tried changing the settings in CONFIG.JS
what am I doing wrong?
Dave47
Re: Open Weather Map
Post by Dave47 »
Nobody?
Lokonli
Post by Lokonli »
Dave47 wrote: Sunday 27 October 2019 14:57 I use Open Weather Map for the weather
If you want to save the settings from Dashticz then:
1) PHP must be enabled
2) The WWW user (normally root) must have write permission to the file config/CONFIG.js
See the documentation:
https://dashticz.readthedocs.io/en/mast ... stall.html
Manually changing CONFIG.js should of course work as well.
What is the current situation, and what are you trying to achieve? No solution in the documentation?
https://dashticz.readthedocs.io/en/mast ... ather.html
Dave47
Post by Dave47 »
Ok i found it.
