I use Open Weather Map for the weather
when i go to the settings in Dashticz, the weather
I try to change and save settings there.
Nothing changes in the settings
I also tried changing the settings in CONFIG.JS
what am I doing wrong?
Open Weather Map
Dave47
- Target OS: -
- Domoticz version: 2023.1
Re: Open Weather Map
Nobody?
Lokonli
If you want to save the settings from Dashticz then:Dave47 wrote: Sunday 27 October 2019 14:57 I use Open Weather Map for the weather
1) PHP must be enabled
2) The WWW user (normally root) must have write permission to the file config/CONFIG.js
See the documentation:
https://dashticz.readthedocs.io/en/mast ... stall.html
Manually changing CONFIG.js should of course work as well.
What is the current situation, and what are you trying to achieve? No solution in the documentation?
https://dashticz.readthedocs.io/en/mast ... ather.html
Dave47
- Target OS: -
Ok i found it.
