Dashticz - Bug report
Lokonli
Re: Dashticz - Bug report
If you have created the all day event in the GMT timezone, and you use the calendar in the Amsterdam timezone then all day events will start at 2am, which is correct.
Can you check the timezone of your all day events?
Do the other events have the correct start time?
I'll check the timezone handling for iCloud later tonight.
Stepdes
- Domoticz version: 2022.1
Ok, now i understand.Lokonli wrote: Sunday 20 October 2019 11:05 If you have created the all day event in the GMT timezone, and you use the calendar in the Amsterdam timezone then all day events will start at 2am, which is correct.
Well all of my systems are now on Brussels timezone and i made a few new all day events, now i have 1am as start hour, so it has definitely something to do with the correct timezone.(winter/summer time?) All my other events are shown at the correct start time
Thnx for your help!
Lokonli
I was able to reproduce some of the issues when I change the timezone of the Dashticz server. However, I cannot explain everything I see. Also in your case I don't understand how the all day events have an incorrect start time, while your normal events have the correct start time. The timezone interpretation happens on several places, and is pretty difficult to follow.Stepdes wrote: Sunday 20 October 2019 11:53Ok, now i understand.Lokonli wrote: Sunday 20 October 2019 11:05 If you have created the all day event in the GMT timezone, and you use the calendar in the Amsterdam timezone then all day events will start at 2am, which is correct.
Thnx for your help!
As a work around, I will add two parameters to calendar block definition:
adjustTZ
adjustAllDayTZ
Stepdes
Hi Lokonli, thanks for your efforts already.I was able to reproduce some of the issues when I change the timezone of the Dashticz server. However, I cannot explain everything I see. Also in your case I don't understand how the all day events have an incorrect start time, while your normal events have the correct start time. The timezone interpretation happens on several places, and is pretty difficult to follow.
As a work around, I will add two parameters to calendar block definition:These can be used to adjust the time zone, by defining an offset in hours. If needed (like in your case) you can use the second parameter to adjust the AllDay events only.Code: Select all
adjustTZ adjustAllDayTZ
This calendar is a shared one and all events are allday events, now i see that depending the person who ads a allday event, the start hour is changing, thats because of the timezone settings of the creator of the event. So the offset parameter will not work for every event. Is it possible to add a parameter to the block definition that avoid showing the start hour? So only date and event like 29/10 - this is an event ?
Regards,
Stephan
magicduck
- Target OS: -
Seems so... But I didn't noticed that until recently... I was thinking it was "cors" problems (well I fucked the php so it was not working).
I use the beta branch, but my try on the master branch give the same results.Do you use the beta or master branch? If beta: Could you test master as well?
On which version it was still working?
(I've never used Sonarr...)
So this is somewhere and my knowledge of javascript is a bit limited ... :/
Lokonli
Then probably it's not the result of a recent change.magicduck wrote: Monday 21 October 2019 21:46Seems so... But I didn't noticed that until recently... I was thinking it was "cors" problems (well I fucked the php so it was not working).
I'll contact you by PM to discuss how to test.
Lokonli
ok, I'll add that parameter as well. (fixAllDay)Stepdes wrote: Monday 21 October 2019 9:24Hi Lokonli, thanks for your efforts already.I was able to reproduce some of the issues when I change the timezone of the Dashticz server. However, I cannot explain everything I see. Also in your case I don't understand how the all day events have an incorrect start time, while your normal events have the correct start time. The timezone interpretation happens on several places, and is pretty difficult to follow.
Regards,
Stephan
Stepdes
Great thnx!
Stepdes
Thnx for the update!Lokonli wrote: Wednesday 23 October 2019 21:21
Could you test the calendar layout changes in the latest beta? Preferably for calFormat:0 as well as calFormat:1
As you can see, first image calFomat 0, second calFormat 1.
The allday events now show without start hour
Lokonli
Perfect. Thanks for testing.
I'm using the latest beta and am trying to create a dashboard.
When using the buttons.buienradar example from read the docs, I get no picture displayed.
Results in the following:
The image locations shows the whole path:
Is this a bug or am I doing something wrong?
buttons.buienradar = {width:12, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weer.nl/verwachting/nederland/son/189656/'}Code: Select all
<img src="img/http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256" class="icon">Code: Select all
http://dashticz.localhost/img/http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256-
jaaap
It must be btnimage. Make it:
Does that help?
buttons.buienradar = {width:12, isimage:true, refreshimage:60000, btnimage: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weer.nl/verwachting/nederland/son/189656/'}
The btnimage works, thanks!
My username reminds me to rtfm before asking
ben53252642
Did you find a solution for this?freakshock wrote: Tuesday 24 April 2018 21:22 Not sure if this is a Dashticz bug, but I hope someone can help with this.
I use the buienradar image with a buienalarm url, to show a graph of the coming rain.
Lately however this is not working anymore. When the url is opened independently of dashticz (not within a frame) it works.
For instance this url:
http://www.buienalarm.nl/widget/graphic ... lor=4395c7
This is my code in config.js:When clicking the buienradar image it just shows an empty frame. Anyone?Code: Select all
var buttons = {} buttons.buienradar = {width:12, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.buienalarm.nl/widget/graphic?lat=51.692134&lon=5.290004&title=Den%20Bosch&color=4395c7'}![]()
I'm trying to display an image snapshot from my Foscam from the url:
http://192.168.0.61/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=admin&pwd=passwordCode: Select all
var buttons = {}
buttons.webcam = {
image:"//192.168.0.61/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=admin&pwd=password",
url:"//192.168.0.61/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=admin&pwd=password",
isimage:true,
width: 12,
refresh: 2000
"This content can't be shown in a frame"
- HansieNL
@ben53252642 : Some pages will not load in a frame because the publisher of the webpage doesn't allow that. The only thing you can try is to load that page in an own webpage and link to that page.
Blah blah blah
Lokonli
In this case the url points to an image, not an html page, I guess.HansieNL wrote: Tuesday 26 November 2019 13:12 @ben53252642 : Some pages will not load in a frame because the publisher of the webpage doesn't allow that. The only thing you can try is to load that page in an own webpage and link to that page.
What we could do is open the image directly, not within an iframe. We could show it as a popup window.
Would that be useful?
Lokonli
The normal buienalarm url works pretty well in an iframe. For instance:HansieNL wrote: Tuesday 26 November 2019 13:12 @ben53252642 : Some pages will not load in a frame because the publisher of the webpage doesn't allow that. The only thing you can try is to load that page in an own webpage and link to that page.
width:12, refreshimage:1000*60*15,
btnimage: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=360&h=300',
url:'https://www.buienalarm.nl/venlo-limburg-nederland/51.36234,6.18802',
ben53252642
I've managed to work around the issue using a combination of a php cors proxy hosted on my local Apache server and a dedicated html page.
