Login
Dave47
- Target OS: -
- Domoticz version: 2023.1
Login
I have a login page for Dashticz.
Is it possible to make the login time longer than 1 hour?
Where can I change these settings?
I am currently saving the password in the browser.
I prefer a longer login time
- HansieNL
Re: Login
Dashticz configuration settings are stored in CONFIG.js.
For overview of all configuration options see: https://dashticz.readthedocs.io/en/bet ... ation.html
There’s an option dashticz_refresh. Number of minutes to refresh the Dashticz dashboard.
Blah blah blah
Lokonli
Re: Login
It's set on line 9 in the file js/login.jsDave47 wrote: Wednesday 09 October 2019 19:07 I tried that.
For example: dasticz_refresh = 15 minutes,
Nothing changes. I don't have to log in again after 15 minutes
After 1 hour i must login again.
is there maybe another solution?
We could make it a configuration setting.
- HansieNL
Re: Login
Do I have to use dashticz V3 then? No
Can I adjust it myself at this time? If you know how to edit a text file
What exactly should I do in the file? ...
Change in login.js the following lines:
to:
var sessionTimeout = 1; //session timeout after x hour(s)
var loginDuration = new Date();
loginDuration.setTime(loginDuration.getTime() + (sessionTimeout * 60 * 60 * 1000));Code: Select all
var sessionTimeout = 15; //session timeout after x minute(s)
loginDuration.setTime(loginDuration.getTime() + (sessionTimeout * 60 * 1000));Blah blah blah
- HansieNL
Re: Login
You can now set the session timeout in the latest Dashticz beta.
https://github.com/Dashticz/dashticz/tree/beta
Blah blah blah
- HansieNL
Re: Login
Can you give us some more information how and where you installed Dashticz?Dave47 wrote: Tuesday 15 October 2019 11:24 i cant change settings in Dashticz_v3.
When I save, nothing changes for all settings
Looks like your problem is related to the following part(s) of the installation:
Since Beta 2.4.6 (October 2018) the installation instruction changed. Main reason is that for most functionality PHP support in the web server is needed. The Domoticz web server doesn’t support PHP. That means that Dashticz needs to be installed under a different web server with PHP enabled.
If you want to be able to save the settings via Dashticz to CONFIG.js then you have to give write permission to CONFIG.js for root:
chmod a+w /home/pi/dashticz/custom/CONFIG.jsBlah blah blah
Dave47
- Target OS: -
Re: Login
I have install Dashticz_v3 in /home/pi/www/dashticz_v3/ next to /home/pi/www/dashticz_v2/
v2 is going well
And then i do sudo ln -s $(pwd)/dashticz_v3/ /var/www/html
Above works
then i do
chmod a+w /home/pi/dashticz_v3/custom/CONFIG.js
That gives me the following: cannot acces
i have the sollution:
chmod -R a+rX $(pwd)/dashticz_v3
chmod a+w $(pwd)/dashticz_v3/custom/CONFIG.js
Not: chmod a+w /home/pi/dashticz_v3/custom/CONFIG.js
v2 is going well
Above works
then i do
