Login
Dave47
Domoticz version: 2023.1
Login
Post by Dave47 »
I have a login page for Dashticz.
Is it possible to make the login time longer than 1 hour?
Where can I change these settings?
I am currently saving the password in the browser.
I prefer a longer login time
HansieNL
Re: Login
Post by HansieNL »
Dashticz configuration settings are stored in CONFIG.js.
For overview of all configuration options see: https://dashticz.readthedocs.io/en/bet ... ation.html
There’s an option dashticz_refresh. Number of minutes to refresh the Dashticz dashboard.
Blah blah blah
Dave47
Re: Login
Post by Dave47 »
I tried that.
For example: dasticz_refresh = 15 minutes,
Nothing changes. I don't have to log in again after 15 minutes
After 1 hour i must login again.
is there maybe another solution?
Lokonli
Re: Login
Post by Lokonli »
Dave47 wrote: Wednesday 09 October 2019 19:07 I tried that.
It's set on line 9 in the file js/login.js
We could make it a configuration setting.
Dave47
Re: Login
Post by Dave47 »
that is nice
Do I have to use dashticz V3 then?
Can I adjust it myself at this time?
What exactly should I do in the file?
HansieNL
Re: Login
Post by HansieNL »
Do I have to use dashticz V3 then? No
Can I adjust it myself at this time? If you know how to edit a text file ;-)
What exactly should I do in the file? ...
Change in login.js the following lines:
var sessionTimeout = 1; //session timeout after x hour(s)
var loginDuration = new Date();
loginDuration.setTime(loginDuration.getTime() + (sessionTimeout * 60 * 60 * 1000));
to:
var sessionTimeout = 15; //session timeout after x minute(s)
loginDuration.setTime(loginDuration.getTime() + (sessionTimeout * 60 * 1000));
Blah blah blah
Dave47
Re: Login
Post by Dave47 »
Ok i change only sesionTimeout.
I want more jours :D
HansieNL
Re: Login
Post by HansieNL »
You can now set the session timeout in the latest Dashticz beta.
https://github.com/Dashticz/dashticz/tree/beta
Blah blah blah
Dave47
Re: Login
Post by Dave47 »
i cant change settings in Dashticz_v3.
When I save, nothing changes for all settings
HansieNL
Re: Login
Post by HansieNL »
Dave47 wrote: Tuesday 15 October 2019 11:24 i cant change settings in Dashticz_v3.
Can you give us some more information how and where you installed Dashticz?
Looks like your problem is related to the following part(s) of the installation:
Since Beta 2.4.6 (October 2018) the installation instruction changed. Main reason is that for most functionality PHP support in the web server is needed. The Domoticz web server doesn’t support PHP. That means that Dashticz needs to be installed under a different web server with PHP enabled.
If you want to be able to save the settings via Dashticz to CONFIG.js then you have to give write permission to CONFIG.js for root:
 chmod a+w /home/pi/dashticz/custom/CONFIG.js
For complete manual see: https://dashticz.readthedocs.io/en/beta/
Blah blah blah
Dave47
Re: Login
Post by Dave47 »
I have install Dashticz_v3 in /home/pi/www/dashticz_v3/ next to /home/pi/www/dashticz_v2/
v2 is going well
And then i do sudo ln -s $(pwd)/dashticz_v3/ /var/www/html
Above works
then i do
chmod a+w /home/pi/dashticz_v3/custom/CONFIG.js
That gives me the following: cannot acces
i have the sollution:
chmod -R a+rX $(pwd)/dashticz_v3
chmod a+w $(pwd)/dashticz_v3/custom/CONFIG.js
Not: chmod a+w /home/pi/dashticz_v3/custom/CONFIG.js
