Room thermostaat
Dave47
Domoticz version: 2023.1
Room thermostaat
Post by Dave47 »
Which room thermostat for heating boiler can I use best with domoticz?
My thought goes out to Honeywell T6,
but it is not easy to get it working properly in Domoticz.
I want to be able to set the temperature in domoticz, higher and lower
and I want to integrate everything into Dashticz
A thermostat for on / off
What are your findings?
schulpr
Re: Room thermostaat
Post by schulpr »
Dave47 wrote:Which room thermostat for heating boiler can I use best with domoticz?
I use Thermosmart. Works fine ibDonoticz.
Dave47
Post by Dave47 »
which type of thermosmart and is it only the thermostat or also a boiler module?
Can you show me a picture how it look likes in Domoticz/Dashticz?
schulpr
Post by schulpr »
I don't use Dashticz. Didn't start home automation for still pushing buttons Image. In Domoticz it's just a simple + and - if you need to adjust the temperature.
Dave47
Post by Dave47 »
Is it only 1 Device + and -?
Or more devices?
schulpr
Post by schulpr »
Or more devices?
If you install the hardware plugin in Domoticz then you can check all the possibilities yourself.
Dave47
Post by Dave47 »
Ok. It is better to know this before you decide to buy.
Misscien thermosmart or Honeywell. I do not know yet.
Do you have a delay time with WiFi?
schulpr
Post by schulpr »
Dave47 wrote:Ok. It is better to know this before you decide to buy.
No, there's almost no delay. One or two seconds at most.
Dave47
Post by Dave47 »
Ok. Schedule in Thermostat or Domoticz?
schulpr
Post by schulpr »
Dave47 wrote:Ok. Schedule in Thermostat or Domoticz?
I have the schedule in the Thermosmart website but you can do it in Domoticz too.
Dave47
Post by Dave47 »
do the timers not work if there is no internet access?
for example, if I have set 25 degrees.
switch off at 10 pm but there is no internet?
the timers don't work then I think so.
schulpr
Post by schulpr »
Dave47 wrote:do the timers not work if there is no internet access?
All the programmed timers still work, you can't change the timers without internet connection.
Dave47
Post by Dave47 »
are you sure without internet? :D
schulpr
Post by schulpr »
Dave47 wrote:are you sure without internet? :D
Yes, the schedule is in the thermostat. Like I said, you aren't able to adjust the schedule without an internet connection.
Dave47
Post by Dave47 »
app reviews are not that good
in Schedule you can only
Use 15 degrees, 18 and 20?
can't you change that?
