Room thermostaat
Dave47
- Target OS: -
- Domoticz version: 2023.1
Room thermostaat
Which room thermostat for heating boiler can I use best with domoticz?
My thought goes out to Honeywell T6,
but it is not easy to get it working properly in Domoticz.
I want to be able to set the temperature in domoticz, higher and lower
and I want to integrate everything into Dashticz
A thermostat for on / off
What are your findings?
schulpr
Re: Room thermostaat
I use Thermosmart. Works fine ibDonoticz.Dave47 wrote:Which room thermostat for heating boiler can I use best with domoticz?
Dave47
- Target OS: -
which type of thermosmart and is it only the thermostat or also a boiler module?
Can you show me a picture how it look likes in Domoticz/Dashticz?
schulpr
I don't use Dashticz. Didn't start home automation for still pushing buttonsDave47 wrote:I use Thermosmart. Works fine ibDonoticz.
. In Domoticz it's just a simple + and - if you need to adjust the temperature.Verzonden vanaf mijn iPhone met Tapatalk
Dave47
- Target OS: -
Is it only 1 Device + and -?In Domoticz it's just a simple + and - if you need to adjust the temperature.
Or more devices?
schulpr
If you install the hardware plugin in Domoticz then you can check all the possibilities yourself.Dave47 wrote:Is it only 1 Device + and -?In Domoticz it's just a simple + and - if you need to adjust the temperature.
Or more devices?
Dave47
- Target OS: -
Ok. It is better to know this before you decide to buy.
Misscien thermosmart or Honeywell. I do not know yet.
Do you have a delay time with WiFi?
schulpr
No, there's almost no delay. One or two seconds at most.Dave47 wrote:Ok. It is better to know this before you decide to buy.
Dave47
- Target OS: -
Ok. Schedule in Thermostat or Domoticz?
schulpr
I have the schedule in the Thermosmart website but you can do it in Domoticz too.Dave47 wrote:Ok. Schedule in Thermostat or Domoticz?
Dave47
- Target OS: -
do the timers not work if there is no internet access?
for example, if I have set 25 degrees.
switch off at 10 pm but there is no internet?
the timers don't work then I think so.
schulpr
All the programmed timers still work, you can't change the timers without internet connection.Dave47 wrote:do the timers not work if there is no internet access?
Dave47
- Target OS: -
are you sure without internet?
schulpr
Yes, the schedule is in the thermostat. Like I said, you aren't able to adjust the schedule without an internet connection.Dave47 wrote:are you sure without internet?
Dave47
- Target OS: -
app reviews are not that good
in Schedule you can only
Use 15 degrees, 18 and 20?
can't you change that?
