Execution scripts problem
czasas
Post by czasas »
Hello could you tell me what Im doing wrong? When I rotate cube in right there should be executed specific scripts, the same for left. Scripts is recognising left and right (printing proper value, but scripts are not executed). Could you help ?
 on ={devices ={'Cube_kat'}},
    execute = function(dz,item)
        local kat = item.nValue
        print(kat)
if kat > 0 then
    print("Zwiekszam glosnosc")
    os.execute ('sh /home/pi/domoticz/scripts/radio/volume_plus.sh')
if kat < 0 then
    print("Zmniejszam glosnosc")
    os.execute ('sh /home/pi/domoticz/scripts/radio/volume_minus.sh')
Re: Execution scripts problem
czasas wrote: Monday 07 October 2019 20:50 Hello could you tell me what Im doing wrong? When I rotate cube in right there should be executed specific scripts, the same for left. Scripts is recognising left and right (printing proper value, but scripts are not executed). Could you help ?
Hard to tell but cannot see anything wrong. Maybe something with domoticz user not having enough authorisation to access the sh script?
I use something similar
return
 on =
    devices =
        'cubeSwitch'
        local cubeState = item.levelName
        dz.log('cube state: ' .. cubeState,dz.LOG_FORCE)
        os.execute ('/bashdir/argtest.sh ' .. cubeState)
Log
2019-10-07 22:57:03.093 Status: dzVents: Info: ------ Start external script: Xcube.lua: Device: "cubeSwitch (Xiaomi)", Index: 1739
2019-10-07 22:57:03.093 Status: dzVents: !Info: cube state: clock_wise
2019-10-07 22:57:03.108 Status: dzVents: Info: ------ Finished Xcube.lua
bash script
cat /bashdir/argtest.sh
#!/bin/bash
echo $(date) $@ >> /usr/local/domotica/data/test$$
created file
cat /usr/local/domotica/data/test14324
Mon 07 Oct 2019 10:57:03 PM CEST clock_wise
czasas
Post by czasas »
Hmmm , I have also 'shake' for one script, the first one below and its working . My permission looks like here:
drwxrwxrwx 2 pi pi 4096 Oct 7 23:24 .
drwxr-xr-x 13 pi pi 4096 Oct 7 18:21 ..
-rwxrwxrwx 1 pi pi 74 Oct 7 18:21 radiozet.sh
-rwxrwxrwx 1 root root 21 Oct 7 18:30 stop.sh
-rwxrwxrwx 1 root root 38 Oct 7 23:24 volume_minus.sh
-rwxrwxrwx 1 root root 38 Oct 7 23:21 volume_plus.sh
czasas wrote: Monday 07 October 2019 23:30 Hmmm , I have also 'shake' for one script, the first one below and its working . My permission looks like here:
Do you have to use sh as shell for these scripts ?
You might get a better indication in the log on what happens if you use this.
return
    on =
        devices =
            'Cube_kat'
        dz.log("nValue of " .. item.name .. ': ' .. item.nValue,dz.LOG_FORCE)
        local function osExecute(cmd)
            local fileHandle     = assert(io.popen(cmd, 'r'))
            local commandOutput  = assert(fileHandle:read('*a'))
            local returnTable    = {fileHandle:close()}
            dz.log("commandOutput: " .. commandOutput,dz.LOG_FORCE)
            dz.log("returncode   : " .. returnTable[3],dz.LOG_FORCE)
        if kat > 0 then
            dz.log("Zwiekszam glosnosc",dz.LOG_FORCE)
            osExecute ('sh /home/pi/domoticz/scripts/radio/volume_plus.sh')
        elseif kat < 0 then
            dz.log("Zmniejszam glosnosc",dz.LOG_FORCE)
            osExecute ('sh /home/pi/domoticz/scripts/radio/volume_minus.sh')
            dz.log("Nic nie robie",dz.LOG_FORCE)
