ID of zwave devices
ropske
Domoticz version: V3_8394
ID of zwave devices
Post by ropske »
does anyone has a list of what ID's has what kind of function of zwave devices?
is there also an idea to know what ID is linked to what hardware?
sometimes very diffycult to know what ID is linked to what device
thanks
jvdz
Domoticz version: 4.107
Re: ID of zwave devices
Post by jvdz »
A patch was made to make this easy to figure but reverted due as "not needed".
A compromise was reached by highlighting the ZWAVEID in de Device ID column in de Devices view.
See the detailed discussion: https://github.com/domoticz/domoticz/co ... 17e275f09b
Jos
ropske
Post by ropske »
So how can we see the highlighted id?
Thank you
jvdz
Post by jvdz »
I should show up in the Devices list for the ZWAVE devices in the standard theme as shown in the thread I pointed you to.
I can't check whether that is still the case or not as I am not running any of the recent versions, but in your list it seems to be missing.
Jos
ropske
Post by ropske »
I'm running now V4.10717 and default theme, but it is not in anymore it seems
jvdz
Post by jvdz »
I am sorry to see this rather simply patch I made has met so much objection. There are several threads in this forum about it and a couple in Github, where you can see how many have argued for having this patch in but it aint happening. You probably seen I sort-of gave up arguing. :(
I will simply apply a patch to each new release I load to facilitate this for myself.
Jos
ropske
Post by ropske »
Can i install your patch manually? And if yes, how todo it?
Thank you
jvdz
Post by jvdz »
This is the original thread where the proposal was posted and further discussed: https://www.domoticz.com/forum/viewtopi ... 36#p163786 and resulted in this initial pull request with these code changes: https://github.com/domoticz/domoticz/pull/2033/files
This patch will show the ZWAVEID in HEX behind the DeviceID.
It was then changed to Highlight by this patch: https://github.com/domoticz/domoticz/pull/2664/files.
I haven't installed the 4.**** version as yet as my current setup is rocksolid. My test system is running 4.10262, but it seems changes were made after that version to the filestructure as the file /www/app/DevicesController.js doesn't exist anymore in the latest Beta.
A quick search found that in file www/app/Devices.js line 255 contains the part that was modified originally in the second patch:
				var ID = device.ID;
				if (typeof(device.HardwareTypeVal) != 'undefined' && device.HardwareTypeVal == 21) {
					if (device.ID.substr(-4, 2) == '00') {
						ID = device.ID.substr(1,device.ID.length-2) + '<span class="ui-state-default">' + device.ID.substr(-2, 2) + '</span>';
					} else {
						ID = device.ID.substr(1,device.ID.length-4) + '<span class="ui-state-default">' + device.ID.substr(-4, 2) + '</span>' + device.ID.substr(-2, 2);
So I have no idea why it doesn't highlight for you, but you could try to check in Chrome with the developer mode (F12) and check out the generated source for the page/device to see if it is there. Also check if the class "ui-state-default" is still valid and different from the rest of the formatting.
Jos
Users browsing this forum: Amazon [Bot], Bing [Bot] and 1 guest
