HowTo: monitor Synology NAS
- mbliek
Re: HowTo: monitor Synology NAS
Is the power consumption available by SNMP?
Op zoek naar een Domoticz Start Set?
- bierlaagh
- Domoticz version: 4.9984
sorry mbliek i thougt there was, as far as i know now there is only one power status in Synology SNMP: good or fail (well i know when it fails
i still have one other issue.
free space giving me the good status on the utility page
but on my room page it gives me a 0 or 1 or 2.
and i cannot figure out why.
here is my script (free space has IDX 45 and 46)
if someone know why, please tell me i'm a little stuck here...
#!/bin/bash
# Settings
# 1.3.6.1.4.1.6574.1.2.0
NASIP="192.168.5.2" # NAS IP Address
PASSWORD="public" # SNMP Password
DOMO_IP="192.168.5.3" # Domoticz IP Address
DOMO_PORT="8080" # Domoticz Port
#NAS_HD1_TEMP_IDX="37" # NAS HD1 Temp IDX
#NAS_HD2_TEMP_IDX="38" # NAS HD2 Temp IDX
#NAS_HD1_SPACE_IDX="42" # NAS HD1 Temp IDX
#NAS_HD2_SPACE_IDX="43" # NAS HD2 Temp IDX
NAS_IDX="40" # NAS Switch IDX
NAS_SYS_TEMP_IDX="44" #NAS SYSTEM Temp IDX
NAS_HD3_TEMP_IDX="16" # NAS HD3 Temp IDX
NAS_HD4_TEMP_IDX="17" # NAS HD4 Temp IDX
NAS_HD1_SPACE_IDX="45" # NAS HD1 space IDX
NAS_HD2_SPACE_IDX="46" # NAS HD2 space IDX
NAS_HD3_SPACE_IDX="19" # NAS HD3 Temp IDX
NAS_HD4_SPACE_IDX="20" # NAS HD4 Temp IDX
# Check if NAS in online
PINGTIME=`ping -c 1 -q $NASIP | awk -F"/" '{print $5}' | xargs`
echo $PINGTIME
if expr "$PINGTIME" '>' 0
then
curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$NAS_IDX" | grep "Status" | grep "On" > /dev/null
if [ $? -eq 0 ] ; then
echo "NAS already ON"
# Temperature HD1
HDtemp1=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.4.1.6574.2.1.1.6.0`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD1_TEMP_IDX&nvalue=0&svalue=$HDtemp1"
# Temperature HD2
HDtemp2=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.4.1.6574.2.1.1.6.1`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD2_TEMP_IDX&nvalue=0&svalue=$HDtemp2"
# Temperature HD3
# HDtemp3=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.4.1.6574.2.1.1.6.2`
# Send data
#curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD3_TEMP_IDX&nvalue=0&svalue=$HDtemp3"
# Temperature HD4
#HDtemp4=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.4.1.6574.2.1.1.6.3`
# Send data
#curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD4_TEMP_IDX&nvalue=0&svalue=$HDtemp4"
# Temperature SYSTEM .1.3.6.1.4.1.6574.1.2.0
SYStemp=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.4.1.6574.1.2.0`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_SYS_TEMP_IDX&nvalue=0&svalue=$SYStemp"
# Free space Volym1
HDUnit=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.4.36`
HDTotal=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.5.36`
HDUsed=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.6.36`
HDFree=$((($HDTotal - $HDUsed) * $HDUnit / 1024 / 1024 / 1024))
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD1_SPACE_IDX&nvalue=0&svalue=$HDFree"
# Free space Volym 2
HDUnit=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.4.37`
HDTotal=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.5.37`
HDUsed=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.6.37`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD2_SPACE_IDX&nvalue=0&svalue=$HDFree"
# Free space Volym 3
#HDUnit=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.4.38`
#HDTotal=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.5.38`
#HDUsed=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.6.38`
#HDFree=$((($HDTotal - $HDUsed) * $HDUnit / 1024 / 1024 / 1024))
# Send data
#curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD3_SPACE_IDX&nvalue=0&svalue=$HDFree"
# Free space volymusb1
#HDUnit=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.4.39`
#HDTotal=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.5.39`
#HDUsed=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.6.39`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD4_SPACE_IDX&nvalue=0&svalue=$HDFree"
echo "NAS ON"
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=switchlight&idx=$NAS_IDX&switchcmd=On"
# Temperature HD1
# Send data
# Temperature HD2
# Send data
# Temperature HD3
#HDtemp3=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.4.1.6574.2.1.1.6.2`
# Send data
# Temperature HD4
# Send data
# Send data
# Free space Volym 1
# Send data
# Send data
# Send data
# Send data
fi
curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$NAS_IDX" | grep "Status" | grep "Off" > /dev/null
echo "NAS already OFF"
exit
echo "NAS OFF"
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=switchlight&idx=$NAS_IDX&switchcmd=Off"
fi
fi
1x Raspberry PI 3 With Domoticz V.3.7318
1X RFXtrx433 USB 433.92MHz
1X Synology DS213j Nas
Toon by Eneco including Toon Zon
several KAKU switches and dimmers
Mysensors WIFI Gateway including meters, switches en humidity sensors
Wifi Dimmers (home made)
theezeefje
any ideas ?
I have turned on SNMP on my DS213+,
when I try to snmpget data from the device, I receive the following error:
are there any recent oid changes ?
root@archimedes:~# snmpget -c public -v2c -O qv 192.168.0.15 .1.3.6.1.4.1.6574.1.2.0
No Such Object available on this agent at this OID
root@archimedes:~#
- mbliek
Could be, but it can also be possible that your system don't provide that OID....
I'm using a QNAP NAS so I don't know if they changed the OID's
- bierlaagh
@theezeefje could it be you forgot space between -v and 2c ? The oid is for system temperature and shoul work on a Sinology
theezeefje
root@archimedes:~# snmpget -c public -v 2c -O qv 192.168.0.15 .1.3.6.1.4.1.6574.1.2.0
root@archimedes:~#
-v2c should work.
- bierlaagh
strange...
this is my output on my PI when i contact my nas
could it be that the 213+ does not support system temperature?
and is this oid the only one that does not work?
pi@raspberrypi ~ $ snmpget -c public -v 2c -O qv 192.168.5.2 .1.3.6.1.4.1.6574.1.2.0
57
roblom
I think it needs to beCreate 1 virtual switch and 3 virtual temperature sensors.
AlsoCreate 1 virtual switch and 2 virtual temperature sensors and 1 virtual counter.
NAS_HD_SPACE_IDX="4" # NAS HD1 Temp IDXCode: Select all
NAS_HD_SPACE_IDX="4" # NAS HD Space IDX-
roblom
I have a DS213+ and can confirm the given script works also on a DS213+.bierlaagh wrote:strange...
could it be that the 213+ does not support system temperature?Code: Select all
pi@raspberrypi ~ $ snmpget -c public -v 2c -O qv 192.168.5.2 .1.3.6.1.4.1.6574.1.2.0 57
stappel
For DSM 5.1beta the disk has moved in snmp iod
It's now .39 instead of ,36
- sincze
- Domoticz version: 2024.4
Any suggestions to get this working with DS412+?stappel wrote:For DSM 5.1beta the disk has moved in snmp iod
snmpget -v 2c -c <community> -O qv <IPOFNAS> 1.3.6.1.4.1.6574.2.1.1.2
No results for a disk temperature
This does work:
snmpget -v 2c -c <community> -O qv <IPOFNAS> 1.3.6.1.4.1.6574.1.2.0
It will result the system temperature
- SNMP2.PNG (74.73 KiB) Viewed 7865 times
- SNMP DSM5
- SNMP.PNG (74.52 KiB) Viewed 7865 times
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
BigDog
- Domoticz version: V3.9269
have updated to DSM 5.1
and yep the code has changed..
have anybody changed the script in the wiki?
or the changes that must be made?
becose HD1 isnt showing temp and space
36 change to 39 dont work wil look Further @ home..
Greetz BigDog
Greetz BigDog
1X Raspberry4B : Domoticz Version 2023.1 [Linux 5.10.63-v7l+ armv7l]
1X Conbee II : 2.25.3 - 26720700
1X RFXtrx433 USB Firmware:183
1X Mysensors Gateway 1.5 -3
6X ESP8266: Tosmota firmware
Zigbee : 6 Operators, 13 Sensors
- sincze
Ok, just updated to 5.1. as well.BigDog wrote:have updated to DSM 5.1and yep the code has changed..
have anybody changed the script in the wiki?![]()
becose HD1 isnt showing temp and space![]()
Greetz BigDog
Will wait.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
roblom
My DS213+ is running DSM 5.1. The temperature is still given in Domoticz but the diskspace isn't logged anymore.
- sincze
decrxgarage wrote:My DS213+ is running DSM 5.1. The temperature is still given in Domoticz but the diskspace isn't logged anymore.
I can confirm the temperature is still working indeed DSM 5.1.
Just installed the script.
I do get some values for the HD usage however those are not in my script.
snmpget -c public-domoticz -v2c -O qv 192.168.2.12 .1.3.6.1.2.1.25.2.3.1.4.36
snmpget -c public-domoticz -v2c -O qv 192.168.2.12 .1.3.6.1.2.1.25.2.3.1.5.36
snmpget -c public-domoticz -v2c -O qv 192.168.2.12 1.3.6.1.2.1.25.2.3.1.6.36
- syno-SNMP.PNG (65.95 KiB) Viewed 7731 times
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MAidEN
I had add a monitor of CPU and Memory of my Synology with DSM 5.1.
I had this code on my nas.sh :
Change Variable with your IDX virtual device (type General and Pourcentage)
And is ok
#Variables
NAS_MEM_IDX="55" # NAS MEM IDX
NAS_CPU_IDX="56" # NAS CPU IDX
# Free Memory Available in %
MemAvailable=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.4.6.0`
MemAvailableinMo=$(($MemAvailable / 1024))
MemUsepercent=$((($MemAvailableinMo * 100) / 1024))
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_MEM_IDX&nvalue=0&svalue=$MemUsepercent"
# CPU utilisation
CpuUser=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.11.9.0`
CpuSystem=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.11.10.0`
CpuUse=$(($CpuUser + $CpuSystem))
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_CPU_IDX&nvalue=0&svalue=$CpuUse"
And is ok
- sincze
Works great. Updated my nas.sh.MAidEN wrote:Hi all,
Thank you.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MAidEN
I don't know no why but my storage counter doesn't work
When I browse with snmp reader, I see the OID 1.3.6.1.2.1.25.2.3.1.6.36 who was egal HD Used is egal to 0 :
OID 36 is a good volume of my SHM group disk :
My synology is on DSM 5.1
Have you any ideas of my problem?
zaadstra
- Domoticz version: 2020.2
I was wondering, does the querying the temp's and diskspace prevent the Syno disks from sleeping?
roblom
Maybe you can add it to the NAS wiki.MAidEN wrote:Hi all,
Change Variable with your IDX virtual device (type General and Pourcentage)Code: Select all
#Variables NAS_MEM_IDX="55" # NAS MEM IDX NAS_CPU_IDX="56" # NAS CPU IDX # Free Memory Available in % MemAvailable=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.4.6.0` MemAvailableinMo=$(($MemAvailable / 1024)) MemUsepercent=$((($MemAvailableinMo * 100) / 1024)) # Send data curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_MEM_IDX&nvalue=0&svalue=$MemUsepercent" # CPU utilisation CpuUser=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.11.9.0` CpuSystem=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.11.10.0` CpuUse=$(($CpuUser + $CpuSystem)) # Send data curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_CPU_IDX&nvalue=0&svalue=$CpuUse"
And is ok
