HowTo: monitor Synology NAS
mbliek
Re: HowTo: monitor Synology NAS
Post by mbliek »
Is the power consumption available by SNMP?
bierlaagh
Domoticz version: 4.9984
Post by bierlaagh »
sorry mbliek i thougt there was, as far as i know now there is only one power status in Synology SNMP: good or fail (well i know when it fails :D )
i still have one other issue.
free space giving me the good status on the utility page
free space on utility.jpg (33.06 KiB) Viewed 9724 times
but on my room page it gives me a 0 or 1 or 2.
free space on dashboard.jpg (20.41 KiB) Viewed 9724 times
and i cannot figure out why.
here is my script (free space has IDX 45 and 46)
#!/bin/bash
# Settings
# 1.3.6.1.4.1.6574.1.2.0
NASIP="192.168.5.2" # NAS IP Address
PASSWORD="public" # SNMP Password
DOMO_IP="192.168.5.3" # Domoticz IP Address
DOMO_PORT="8080" # Domoticz Port
#NAS_HD1_TEMP_IDX="37" # NAS HD1 Temp IDX
#NAS_HD2_TEMP_IDX="38" # NAS HD2 Temp IDX
#NAS_HD1_SPACE_IDX="42" # NAS HD1 Temp IDX
#NAS_HD2_SPACE_IDX="43" # NAS HD2 Temp IDX
NAS_IDX="40" # NAS Switch IDX
NAS_SYS_TEMP_IDX="44" #NAS SYSTEM Temp IDX
NAS_HD3_TEMP_IDX="16" # NAS HD3 Temp IDX
NAS_HD4_TEMP_IDX="17" # NAS HD4 Temp IDX
NAS_HD1_SPACE_IDX="45" # NAS HD1 space IDX
NAS_HD2_SPACE_IDX="46" # NAS HD2 space IDX
NAS_HD3_SPACE_IDX="19" # NAS HD3 Temp IDX
NAS_HD4_SPACE_IDX="20" # NAS HD4 Temp IDX
# Check if NAS in online
PINGTIME=`ping -c 1 -q $NASIP | awk -F"/" '{print $5}' | xargs`
echo $PINGTIME
if expr "$PINGTIME" '>' 0
then
 curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$NAS_IDX" | grep "Status" | grep "On" > /dev/null
 if [ $? -eq 0 ] ; then
 echo "NAS already ON"
 # Temperature HD1
 HDtemp1=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.4.1.6574.2.1.1.6.0`
 # Send data
 curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD1_TEMP_IDX&nvalue=0&svalue=$HDtemp1"
 # Temperature HD2
 HDtemp2=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.4.1.6574.2.1.1.6.1`
 # Send data
 curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD2_TEMP_IDX&nvalue=0&svalue=$HDtemp2"
 # Temperature HD3
# HDtemp3=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.4.1.6574.2.1.1.6.2`
 # Send data
 #curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD3_TEMP_IDX&nvalue=0&svalue=$HDtemp3"
 # Temperature HD4
 #HDtemp4=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.4.1.6574.2.1.1.6.3`
 # Send data
 #curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD4_TEMP_IDX&nvalue=0&svalue=$HDtemp4"
 # Temperature SYSTEM								.1.3.6.1.4.1.6574.1.2.0
 SYStemp=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.4.1.6574.1.2.0`
 # Send data
 curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_SYS_TEMP_IDX&nvalue=0&svalue=$SYStemp"
 # Free space Volym1
 HDUnit=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.4.36`
 HDTotal=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.5.36`
 HDUsed=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.6.36`
 HDFree=$((($HDTotal - $HDUsed) * $HDUnit / 1024 / 1024 / 1024))
 # Send data
 curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD1_SPACE_IDX&nvalue=0&svalue=$HDFree"
 # Free space Volym 2
 HDUnit=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.4.37`
 HDTotal=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.5.37`
 HDUsed=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.6.37`
# Send data
 curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD2_SPACE_IDX&nvalue=0&svalue=$HDFree"
 # Free space Volym 3
 #HDUnit=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.4.38`
 #HDTotal=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.5.38`
 #HDUsed=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.6.38`
 #HDFree=$((($HDTotal - $HDUsed) * $HDUnit / 1024 / 1024 / 1024))
 # Send data
 #curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD3_SPACE_IDX&nvalue=0&svalue=$HDFree"
 # Free space volymusb1
 #HDUnit=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.4.39`
 #HDTotal=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.5.39`
 #HDUsed=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.6.39`
 # Send data
 curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD4_SPACE_IDX&nvalue=0&svalue=$HDFree"
 echo "NAS ON"
 # Send data
 curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$NAS_IDX&switchcmd=On"
 # Temperature HD1
 # Send data
 # Temperature HD2
 # Send data
 # Temperature HD3
 #HDtemp3=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.4.1.6574.2.1.1.6.2`
 # Send data
 # Temperature HD4
 # Send data
 # Send data
 # Free space Volym 1
 # Send data
 # Send data
 # Send data
 # Send data
 fi
 curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$NAS_IDX" | grep "Status" | grep "Off" > /dev/null
 echo "NAS already OFF"
 exit
 echo "NAS OFF"
 # Send data
 curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$NAS_IDX&switchcmd=Off"
 fi
fi
if someone know why, please tell me i'm a little stuck here...
1x Raspberry PI 3 With Domoticz V.3.7318
1X RFXtrx433 USB 433.92MHz
1X Synology DS213j Nas
Toon by Eneco including Toon Zon
several KAKU switches and dimmers
Mysensors WIFI Gateway including meters, switches en humidity sensors
Wifi Dimmers (home made)
theezeefje
Post by theezeefje »
any ideas ?
I have turned on SNMP on my DS213+,
when I try to snmpget data from the device, I receive the following error:
root@archimedes:~# snmpget -c public -v2c -O qv 192.168.0.15 .1.3.6.1.4.1.6574.1.2.0
No Such Object available on this agent at this OID
root@archimedes:~#
are there any recent oid changes ?
mbliek
Post by mbliek »
Could be, but it can also be possible that your system don't provide that OID....
I'm using a QNAP NAS so I don't know if they changed the OID's
bierlaagh
Post by bierlaagh »
@theezeefje could it be you forgot space between -v and 2c ? The oid is for system temperature and shoul work on a Sinology
theezeefje
root@archimedes:~# snmpget -c public -v 2c -O qv 192.168.0.15 .1.3.6.1.4.1.6574.1.2.0
root@archimedes:~#
no diff.
-v2c should work.
bierlaagh
Post by bierlaagh »
strange...
this is my output on my PI when i contact my nas
pi@raspberrypi ~ $ snmpget -c public -v 2c -O qv 192.168.5.2 .1.3.6.1.4.1.6574.1.2.0
57
could it be that the 213+ does not support system temperature?
and is this oid the only one that does not work?
roblom
Post by roblom »
Create 1 virtual switch and 3 virtual temperature sensors.
I think it needs to be
Create 1 virtual switch and 2 virtual temperature sensors and 1 virtual counter.
Also
NAS_HD_SPACE_IDX="4"        # NAS HD1 Temp IDX
Needs to be
NAS_HD_SPACE_IDX="4"        # NAS HD Space IDX
roblom
Post by roblom »
bierlaagh wrote:strange...
57
I have a DS213+ and can confirm the given script works also on a DS213+.
stappel
Post by stappel »
For DSM 5.1beta the disk has moved in snmp iod
It's now .39 instead of ,36
sincze
Domoticz version: 2024.4
Post by sincze »
stappel wrote:For DSM 5.1beta the disk has moved in snmp iod
Any suggestions to get this working with DS412+?
snmpget -v 2c -c <community> -O qv <IPOFNAS> 1.3.6.1.4.1.6574.2.1.1.2
No results for a disk temperature
This does work:
snmpget -v 2c -c <community> -O qv <IPOFNAS> 1.3.6.1.4.1.6574.1.2.0
It will result the system temperature
SNMP DSM5
SNMP DSM5
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
BigDog
Domoticz version: V3.9269
Post by BigDog »
have updated to DSM 5.1 :) and yep the code has changed..
have anybody changed the script in the wiki? :)
or the changes that must be made?
becose HD1 isnt showing temp and space :)
36 change to 39 dont work wil look Further @ home..
Greetz BigDog
1X Raspberry4B : Domoticz Version 2023.1 [Linux 5.10.63-v7l+ armv7l]
1X Conbee II : 2.25.3 - 26720700
1X RFXtrx433 USB Firmware:183
1X Mysensors Gateway 1.5 -3
6X ESP8266: Tosmota firmware
Zigbee : 6 Operators, 13 Sensors
sincze
Post by sincze »
BigDog wrote:have updated to DSM 5.1 :) and yep the code has changed..
Greetz BigDog
Ok, just updated to 5.1. as well.
Will wait.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
roblom
Post by roblom »
My DS213+ is running DSM 5.1. The temperature is still given in Domoticz but the diskspace isn't logged anymore.
sincze
Post by sincze »
decrxgarage wrote:My DS213+ is running DSM 5.1. The temperature is still given in Domoticz but the diskspace isn't logged anymore.
I can confirm the temperature is still working indeed DSM 5.1.
Just installed the script.
I do get some values for the HD usage however those are not in my script.
snmpget -c public-domoticz -v2c -O qv 192.168.2.12 .1.3.6.1.2.1.25.2.3.1.4.36
snmpget -c public-domoticz -v2c -O qv 192.168.2.12 .1.3.6.1.2.1.25.2.3.1.5.36
snmpget -c public-domoticz -v2c -O qv 192.168.2.12 1.3.6.1.2.1.25.2.3.1.6.36
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MAidEN
Post by MAidEN »
I had add a monitor of CPU and Memory of my Synology with DSM 5.1.
I had this code on my nas.sh :
#Variables
 NAS_MEM_IDX="55"        # NAS MEM IDX
 NAS_CPU_IDX="56"        # NAS CPU IDX
# Free Memory Available in %
	MemAvailable=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.4.6.0`
        MemAvailableinMo=$(($MemAvailable / 1024))
	MemUsepercent=$((($MemAvailableinMo * 100) / 1024))
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_MEM_IDX&nvalue=0&svalue=$MemUsepercent"
	# CPU utilisation
        CpuUser=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.11.9.0`
	CpuSystem=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.11.10.0`
	CpuUse=$(($CpuUser + $CpuSystem))
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_CPU_IDX&nvalue=0&svalue=$CpuUse"
Change Variable with your IDX virtual device (type General and Pourcentage)
And is ok :mrgreen:
sincze
Post by sincze »
MAidEN wrote:Hi all,
:mrgreen:
Works great. Updated my nas.sh.
Thank you. :D
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MAidEN
Post by MAidEN »
I don't know no why but my storage counter doesn't work :?
When I browse with snmp reader, I see the OID 1.3.6.1.2.1.25.2.3.1.6.36 who was egal HD Used is egal to 0 :
OID 36 is a good volume of my SHM group disk :
My synology is on DSM 5.1
Have you any ideas of my problem?
zaadstra
Post by zaadstra »
I was wondering, does the querying the temp's and diskspace prevent the Syno disks from sleeping?
roblom
Post by roblom »
#Variables
        # Send data
	# CPU utilisation
        # Send data
And is ok :mrgreen:
Maybe you can add it to the NAS wiki.
