Ginlong, Omnik Solar, Solarman and Trannergy Inverters Topic is solved
sincze
Domoticz version: 2024.4
Re: Ginlong, Omnik Solar, Solarman and Trannergy Inverters
Post by sincze »
Can you try
nc -l localhost 10000 > log.txt
Netcat will listen for a connection on port 10000, redirect anything received to log.txt.
In the ginlock direct all traffic to IP of your raspberry and port 10000
The file will fill up for you :) around every 5 minutes an entry. If you want you can parse the file to retrieve your values. However they are encoded I would say.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
Toulon7559
Domoticz version: mixed
Post by Toulon7559 »
@sincze
Your latest hints directed me to a python script which should perform the processing function at the receiving side in Server_B, including dissect and conversion to 'workable' file-formats.
[Left out the scriptlines for direct upload to PVOutput, because not yet required]
The Ginlong inverter and Server_B are in the same IP-range on a common LAN.
Setting of Ginlong Setup for Server_B to port 9999 and to the IP-address of the receiving server and to required protocol.
When testrunning the script from Putty's CLI, Server_B reports that it starts and listens, connects to the inverter (in my case at IP=192.168.0.112), and then waits , waits, waits ........
Start Ginlong inverter WiFi/LAN-poller script
9999
Socket now listening
Connected with 192.168.0.112:54296
Makes no difference which protocol has been set in the Inverter Setup for Server_B.
The Ginlong Inverter reports that it has pingable interface to Server_B
What could be wrong/missing in the script and/or at the interface?
#!/usr/bin/python3
# Line 02
# Version 00, as adapted from 2018-material from Tweakers Forum by Toulon7559 20190128
#  Copyright 2018
#  The source script was derived from script read_ginlong.py by Graham Whiteside, v0.3 Oct 2015.
#  Further developed from the source script from Tweakers-Forum dating from 2016.
#  This is free software: you can redistribute it and/or modify it under the terms of the
#  GNU General Public License as published by the Free Software Foundation, either version 3 of the
#  License, or (at your option) any later version.
#  This software is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without
#  even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
#  General Public License for more details.
#  You can browse the GNU license here: <http://www.gnu.org/licenses/>.
# Line 20
#  Python program to read data sent from a single Ginlong/Solis xK-2G and 4G inverters
#  equipped with Wifi or cabled LAN-interface
#  Requires setting up the inverter Wifi/LAN to send data to the computer running the read-ginlong script.
#  Settings located in the advanced settings, then remote Server_B.
#  Add a new 'remote server B' with the ip address of your computer and port 9999 and restart.
#  The inverter will then send data over Wifi/LAN every five minutes.
#  Output logfile format (space separated):-
#   Date  Time   Watts_now   Day_kWh   Total_kWh
#  Output of status to webserver file, format (space separated) file overwritten each update:-
#   Date Time Watts_now Day_kWh Total_kWh DC_volts_1 DC_amps_1 DC_volts_2 DC_amps_2 AC_volts AC_amps AC_freq kwh_yesterday kwh_month kwh_last_month
#  Output of live status to PVoutput.org site.
#   Requires a PV output account and the API access enabled.
#   Apikey and System ID from PV output need to be filled in the script !!!
#  The program is deliberately left simple without error reporting. It is intended
#  as a 'starting point' and proof of concept. It could easily be modified to provide more
#  information from the inverter.
# Line 45
# requires Python3.4 or better
import socket, binascii, time, urllib, urllib.request
# change these values to suit your requirements:-
HOST = ''                # Hostname or ip address of interface, leave blank for all
PORT = 9999                             # listening on port 9999 or 3200
logfile = 'ginlong.log'                 # location of output log file
webfile = 'ginlong.status'              # location of web file
# Line 54
# inverter values found (so far) all big endian 16 bit unsigned:-
header        = '685951b0'              # hex stream header [original 685951b0]
data_size     = 260                     # hex stream size [original 206, elsewhere 270 & actual len=216 ]
inverter_temp = 31                  # offset 31 & 32 temperature (/10)
inverter_vdc1 = 33                  # offset 33 & 34 DC volts chain 1 (/10)
inverter_vdc2 = 35                  # offset 35 & 36 DC volts chain 2 (/10)
inverter_adc1 = 39                  # offset 39 & 40 DC amps chain 1 (/10)
inverter_adc2 = 41                  # offset 41 & 42 DC amps chain 2 (/10)
inverter_aac  = 45                  # offset 45 & 46 AC output amps (/10)
inverter_vac  = 51                  # offset 51 & 52 AC output volts (/10)
inverter_freq = 57                  # offset 57 & 58 AC frequency (/100)
inverter_now  = 59                  # offset 59 & 60 current generation Watts
inverter_yes  = 67                  # offset 67 & 68 yesterday kwh (/100)
inverter_day  = 69                  # offset 69 & 70 daily kWh (/100) or Wh (*10)
inverter_tot  = 73                  # offset 73 & 74 total kWh (/10)
inverter_mth  = 87                  # offset 87 & 88 total kWh for month
inverter_lmth = 91                  # offset 91 & 92 total kWh for last month
# Line 72
print ('Start Ginlong inverter WiFi/LAN-poller script')
sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)   # create socket on required port
print (HOST)
print (PORT)
sock.bind((HOST, PORT))
# Line 80
while True:                                        # loop forever
    sock.listen(1)                  # listen on port
    print ('Socket now listening')
    conn, addr = sock.accept()              # wait for inverter connection
    print ('Connected with ' + addr[0] + ':' + str(addr[1]))
    rawdata = conn.recv(1000)               # read incoming data
    hexdata = binascii.hexlify(rawdata)             # convert data to hex
# Line 89
    print (hexdata)
  #  if(hexdata[0:8] == header and len(hexdata) == data_size):      # check for valid data (not working!!!)
    if(len(hexdata) <= data_size):
                                                 # extract main values and convert to decimal
        watt_now = str(int(hexdata[inverter_now*2:inverter_now*2+4],16))            # generating power in watts
        print (hexdata[inverter_now*2:inverter_now*2+4])
        kwh_day_num = float(int(hexdata[inverter_day*2:inverter_day*2+4],16))/100   # running total kwh for day
        kwh_day = str(kwh_day_num)
        wh_day = str(int(hexdata[inverter_day*2:inverter_day*2+4],16) * 10)         # running total kwh for day
        kwh_total = str(int(hexdata[inverter_tot*2:inverter_tot*2+4],16)/10)        # running total kwh from installation                                               # Line 100
        temp = str(float(int(hexdata[inverter_temp*2:inverter_temp*2+4],16))/10)    # temperature # extract dc input values and convert to decimal
        v1 =float(int(hexdata[inverter_vdc1*2:inverter_vdc1*2+4],16))/10                # input dc volts from chain 1
        dc_volts1= str(v1)
        v2 = float(int(hexdata[inverter_vdc2*2:inverter_vdc2*2+4],16))/10               # input dc volts from chain 2
        dc_volts2= str(v2)
        a1 = float(int(hexdata[inverter_adc1*2:inverter_adc1*2+4],16))/10               # input dc amps from chain 1
        dc_amps1 = str(a1)
        a2 = float(int(hexdata[inverter_adc2*2:inverter_adc2*2+4],16))/10               # input dc amps from chain 2
        dc_amps2 = str(a2)
                                                # extract other ac values and convert to decimal
        ac_volts = str(float(int(hexdata[inverter_vac*2:inverter_vac*2+4],16))/10)  # output ac volts
        ac_amps = str(float(int(hexdata[inverter_aac*2:inverter_aac*2+4],16))/10)   # output ac amps
        ac_freq = str(float(int(hexdata[inverter_freq*2:inverter_freq*2+4],16))/100)    # output ac frequency hertz
# Line 114
    # Extract other historical values from inverter and convert to decimal
        kwh_yesterday = str(float(int(hexdata[inverter_yes*2:inverter_yes*2+4],16))/100)    # yesterday's kwh
        kwh_month = str(int(hexdata[inverter_mth*2:inverter_mth*2+4],16))           # running total kwh for month
        kwh_lastmonth = str(int(hexdata[inverter_lmth*2:inverter_lmth*2+4],16))         # running total kwh for last month
        # DateTime
        t = (time.strftime("%R"))                       # Get time
        d = (time.strftime("%Y%m%d"))                   # Get date
# Line 123
#Local logging
        # write data to logfile, main values only
        log = open(logfile,'a')
        log.write(d + ' ' + t + ' ' + watt_now + ' ' + kwh_day + ' ' + kwh_total + '\n')
        log.close()
        # output status, overwrite all values, possibly for webpage
        web = open(webfile,'w')
        web.write(d + ' ' + t + ' ' + watt_now + ' ' + kwh_day + ' ' + kwh_total + ' ' + dc_volts1 + ' ' + dc_amps1 + ' ' + dc_volts2 + ' ' + dc_amps2 + ' ' + ac_volts + ' ' + ac_amps + ' ' + ac_freq + ' ' + kwh_yesterday + ' ' + kwh_month + ' ' + kwh_lastmonth + ' ' + temp + '\n')
        web.close()
# Line 136
conn.close()
sincze
Post by sincze »
Hahaha nicely done.
Well I just waited for 5 minutes max and started to receive data. I checked the omnik portal for the timestamp of a new entry. They were spot on the same.. Server A omnik.. Server B mine.
Debug Time:
I think we need to figure out first if you also receive data.
Netcat and the write to file can confirm this. Or just write to your terminal.
If you wire shark in between you should see the same packages to your server B as to Server A.
Also identifying the protocol. I guess plaint http :)
If that works we can move to your great script.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Toulon7559
@Sincze
:( It doesn't work: nothing received.
Headscratching.
Related to this case, perhaps the network-configuration an aspect to consider in settings and calls?
For this aspect, the network is divided in 2 LAN-segments:
'front'-LAN1 is for the ESP8266s and the inverters+loggers, communicating with main router1.
'back'-LAN2 is separated from LAN1 by a router2, and house for the other computers.
Some computers, incl. Server_B have cable to LAN2 in combination with (Wifi + related IP) to main router1 at LAN1.
Till this moment never a communication problem, but obvious 'a first time' is possible.
Perhaps necessary to 'force' Server_B to connect in a specific way to LAN1 for communication with the Ginlong inverter?
[Although the ping-test from the inverter and the reverse reaction from Server_B do not indicate a blocking]
sincze
Post by sincze »
Toulon7559 wrote:@Sincze
Headscratching.
You have a spare pi that you can put in LAN1 for testing the assumption.. it seems something is working :)
Multiple routers (sometimes NAT behind NAT) not always a good solution. However it can work. My personal advise. 1 router and create vlans :) the firewall will control who can talk to what.
In my case the IOT stuff (front) can only talk to Domoticz on a specific port in 'back'
But let's try the spare pi part or put a nic of server B in front network.
Ginlock Omnik I think all do the same trick different destination...
Sent from my ONEPLUS A6003 using Tapatalk
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Toulon7559
;-) as indicated here, already an extra Raspberry planned & reserved to separately get all 'power-related' functions at LAN1.
Just have to find enough time to organise & test that Raspberry and the shifted interfaces.
Till that time fiddling with the Domoticz2-Raspberry at LAN2.
As 'make-shift' solution perhaps Router2 give a temporary port-forwarding for port 9999 and tell the Ginlong-inverter to use the cable-interface to Server_B: not 'clean', but may be a practical solution.
sincze
Post by sincze »
Toulon7559 wrote:;-) as indicated here, already an extra Raspberry planned & reserved to separately get all 'power-related' functions at LAN1.
Maybe openwrt installed on 1 of the routers?? Use a netcat there??? Skips the part of ordering a spare pi :)
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Toulon7559
Quick test: setting port forwarding in the routers doesn't get Server_B operational in this configuration.
The 3 'Expansion'-Raspberries are at my desk:
8-) just lack of time for installation of one at LAN1 ......
sincze
Post by sincze »
Hahaha automation on a tight budget :) we will figure it out.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Post by sincze »
I stumbled upon this option for local processing.
http://www.mb200d.nl/wordpress/2015/11/ ... -wifi-kit/
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Post by sincze »
Created a plugin now for Omnik. (local processing)
https://github.com/sincze/Domoticz-Omni ... Web-Plugin
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Stormryder
Post by Stormryder »
galadril wrote: Tuesday 30 April 2019 14:23 Ok i finished a new script for platform 2 of Ginlong, i've added the new script for platform 2 to the bottom of the OP !!
:idea:
Thanks for the OP, just got my PV and want to combine the data with the data from my Smart Meter in Domoticz.
I use Solarman (online platform) to get my data at the moment.
When I try to run the scripts (StationID.py and Solarman.py, which is similar to your ginseng.py platform 1) I get an error on line 29.
AttributeError: 'NoneType' object has no attribute 'text'
I have tried to delete the .text after
token = root.find('token').text
but this results in an error further on in the script.
I know this is an old thread, but hopefully you can still help me out with this one! Thanks
dutchronnie
Post by dutchronnie »
I have a problem wit executing this script with a crontab.
When i start the script on the command line, the script is updating the data fields in a virtual sensor in domoticz.
But when i put it in a crontab nothing happens.
The scrips doesn't generate errors, so i think the script is good.
It must be the cronjob.
The line in the cronjob is as follows
*/5 * * * * /home/pi/domoticz/scripts/trannergy.py
Does somebody know what is wrong?
sincze
Post by sincze »
Is that a:
crontab -e
or
sudo nano /etc/crontab
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
dutchronnie
That is a crontab -e
P6Mole
Post by P6Mole »
Morning all,
Can anyone please help me with the error I am having below?
pi@raspberrypi:~ $ sudo python /home/pi/domoticz/scripts/ginlong.py
Login Succesfull!
File "/home/pi/domoticz/scripts/ginlong.py", line 50, in <module>
TodayIncome = resultJson['result']['plantAllWapper']['plantData'].get('incomeTotal')
TypeError: string indices must be integers
I'm using Raspbian Buster release 10,
Cheers
MeAlbert
Domoticz version: 2020.1
Post by MeAlbert »
rednas wrote: Monday 08 April 2019 14:06 This is the code I use to scrape the info from the status.js file.
Modify it with your ip, username and password for logging into the webpage of the inverter. Also modify the idx of the sensors mentioned in the script.
-- https://www.domoticz.com/forum/viewtopic.php?f=65&t=7941
        timer = { "every minute" },
        httpResponses = { 'trigger-solar-data' }
    logging = {
        --level = domoticz.LOG_DEBUG, -- for debugging
        --level = domoticz.LOG_INFO,
        marker = "Zonnepanelen"
        ip      = '192.168.x.xxx' --ip address of the solar inverter
        user    = 'xxx' --user name for solar inverter
        pw      = 'xxx' --password for solar inverter
        Electric_meter_idx   = 259 --kWhcounter
        E_today_idx          = 268 --custom
        E_total_idx          = 269 --custom
        E_total_c_idx        = 270 --counter
        E_power_idx          = 264 --energy
        function update_kWhcounter_devc(devc, power, energy)
            if (devc~='' and devc~=nil) then
                --if (domoticz.devices(devc).usage ~= power or domoticz.devices(devc).WhTotal ~= energy) then
                    domoticz.devices(devc).updateElectricity(power, energy)
                --end
        function update_custom_devc(devc, value)
                --if (domoticz.devices(devc).state ~= value) then
                    domoticz.devices(devc).updateCustomSensor(value)
                --end
        function update_counterkWh_devc(devc, value)
                --if (domoticz.devices(devc).counter*1000 ~= value) then
                    domoticz.devices(devc).updateCounter(value)
                --end
        function update_energy_devc(devc, value)
                --if (domoticz.devices(devc).WhActual ~= value) then
                    domoticz.devices(devc).updateEnergy(value)
                --end
        function split(s, delimiter)
            result = {};
            for match in (s..delimiter):gmatch("(.-)"..delimiter) do
                table.insert(result, match);
            return result;
        if (item.isTimer) then
            requestURL = 'http://'..user..':'..pw..'@'..ip..'/js/status.js'
            domoticz.openURL({
                url = requestURL,
                --method = 'GET',
                callback = 'trigger-solar-data'
        if (item.isHTTPResponse and item.ok) then
            -- check to which request this response was the result
            if (item.trigger == 'trigger-solar-data') then
                --domoticz.log(item.data)
                idata = string.match(item.data, 'myDeviceArray%[0%]="(.-)";')
                --domoticz.log(idata)
                s = split(idata, ",")
                --for key, value in pairs(s) do
                --    print(key..'='..value)
                --end
                powerW = s[6] -- in W
                etoday = s[7]/100 -- in kWh
                etotal = s[8]/10 -- in kWh
                domoticz.log("Power: "..powerW.." W",domoticz.LOG_FORCE)
                domoticz.log("Today: "..etoday.." kWh",domoticz.LOG_FORCE)
                domoticz.log("Total: "..etotal.." kWh",domoticz.LOG_FORCE)
                update_kWhcounter_devc(Electric_meter_idx, powerW, etotal*1000)
                update_custom_devc(E_today_idx, etoday)
                update_custom_devc(E_total_idx, etotal)
                update_counterkWh_devc(E_total_c_idx, etotal*1000)
                update_energy_devc(E_power_idx, powerW)
The program works fine on my solarsmart inverter. I added something to the beginning to prevent conyinues trying to reach the inverter when there is no power.
        timer = { "every minute at daytime" },
When contact with the inverter is lost there is still a none zero number left in powerW. This is then showed in the graphic as a line above zero.
How could we prevent that?
Marijn
Post by Marijn »
I have adjusted the script a bit. Because Solarmanpv can sometimes not be accessed.
Because of this I got a memoryleak on my raspberry, which caused the raspberry to crash.
I added a try to the login:
#login call
try:
  root = ET.parse(urllib.urlopen(requestURL)).getroot()
except: #Catch all
  print 'Not logged in: ERROR'
  exit()
Original code:
#login call
Marijn
Post by Marijn »
Marijn wrote: Saturday 28 December 2019 12:19 I have adjusted the script a bit. Because Solarmanpv can sometimes not be accessed.
#login call
try:
except: #Catch all
  exit()
That was not the solution. The scripts hangs on this two lines. But it doesn't throw an exception. :(
Now trying:
#login call
try:
  root = ET.parse(urllib2.urlopen(requestURL,timeout=10)).getroot()
except urllib2.UrlError, e: #Catch all
  print e
  exit()
Wilu88
Post by Wilu88 »
Hi. I have account on Ginlong ver 2 and i try use this code:
#!/usr/bin/python
import requests
import urllib, urllib2
#config
username 			= 'USERNAME'				#your username
password 			= 'PASSWORD'				#your password
domain 				= 'm.ginlong.com' 			#domain
plantId 			= '123456' 					#plant id
lan 				= '2' 						#lanuage (2 = English)
#domoticz settings
domoticz_host      		= 'DOMOTICZ_USERNAME:DOMOTICZ_PASSWORD@IP'
domoticz_port      		= '8080'
domoticz_url       		= 'json.htm'			#leave this
domoticz_device_idx    = '58'
# Create session for requests
session = requests.session()
#building url
url = 'http://'+domain+'/cpro/login/validateLogin.json'
params = {
    "userName": username,
    "password": password,
    "lan": lan,
    "domain": domain,
    "userType": "C"
#login call
resultData = session.post(url, params=params)
resultJson = resultData.json()
if resultJson['result'].get('isAccept') == 1:
    print("Login Succesfull!")
else:
    print("Login Failed!!")
    Exit()
# Get plant details
url = 'http://'+domain+'/cpro/epc/plantDetail/showPlantDetailAjax.json'
params = {
    'plantId': int(plantId)
cookies = {'language': lan}
resultData = session.get(url, params=params, cookies=cookies)
ActualPower = resultJson['result']['plantAllWapper']['plantData'].get('power')
etoday = resultJson['result']['plantAllWapper']['plantData'].get('energyToday')
etotal = resultJson['result']['plantAllWapper']['plantData'].get('energyTotal')
multiply='1000.0'
etotal1000 = float(etotal) * float(multiply)
etotalstr=str(etotal1000)
#logging values
print 'TodayIncome: ' + str(TodayIncome)
print 'ActualPower: ' + str(ActualPower)
print 'etoday: ' + str(etoday)
print 'etotal: ' + str(etotal)
print 'etotal 1000: ' + str(etotalstr)
#uploading values to domoticz
url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command&param=udevice&idx=" + domoticz_device_idx+ "&nvalue=0&svalue=" + str(ActualPower) + ";" + str(etotalstr))
urllib.urlopen(url)
But after use command
sudo python dev-domoticz/scripts/ginlong.py
i see reasult:
  File "dev-domoticz/scripts/ginlong.py", line 4, in <module>
    import requests
ImportError: No module named requests
Any idea?
Sorry for my English ;)
