RGBW setcolbrightness impossible?
Solderbro
Domoticz version: 2020.1
Post by Solderbro »
Trying to set the RGBW color with setHex give me two effects here, they are the same with both Fibaro FRGB devices.
2019-08-27 18:45:07.086 Status: EventSystem: Script event triggered: /home/domoticz/domoticz/dzVents/runtime/dzVents.lua
2019-08-27 18:45:07.100 Status: setcolbrightnessvalue: ID: 7e6, bri: 100, color: '{m: 1, RGB: f4fff9, CWWW: 0000, CT: 0}'
2019-08-27 18:45:07.100 Status: Incoming connection from: 127.0.0.1
2019-08-27 18:45:07.100 Error: OpenZWave: Internal Node Device not found! (NodeID: 41, 0x29)
First the light comes up with 100% brightness, from just the setHex command. Second the device crashes out of the net and calls an failure email. Here first the dimmer is set to 90 percent, after that i like to set only the RGB color for the stripe. Do i have to use a combo of both commands? At the moment for brightness and color two different devices are in use.
        local light = domoticz.devices('Kue LED RGB')
        local pir = domoticz.devices('Kue PIR Sensor')
        local color = domoticz.devices('Kue RGBW Color')
        local nachtlicht = domoticz.variables("Nachtlicht")
        local log = domoticz.log
                if nachtlicht.value == 0 then
                print('Taglicht einschalten')
                light.dimTo(90)
                color.setHex(0xF5,0xFF,0xFA)
Solderbro
Raspi 3B+RTC, SSD 128GB, Aeotec Gen5, Eurotronic SpiritZ, Fibaro FRGBW, Zipato PIR, Everspring AN180, Neo Coolcam Plug, Fibaro FGMS, Neo Coolcam Doorsensor, Popp Z-Weather
Re: RGBW setcolbrightness impossible?
Solderbro wrote: Tuesday 27 August 2019 18:53 Trying to set the RGBW color with setHex give me two effects here, they are the same with both Fibaro FRGB devices.
Cannot test because I don't own these devices but in the log you see the call to domoticz. Maybe you will have better results with the setColor method ?
dre68
Domoticz version: latest
Post by dre68 »
I have the same issue happening with my newer Fibaro RGBW switches, my older ones still work fine. All switches are set up the exact same way and colors are set with same command via lua :
/json.htm?type=command&param=setcolbrightnessvalue&idx=123&hue=335&brightness=50&iswhite=false'
Solderbro
Post by Solderbro »
Back, had some work on my fiets
Here the .setcolor does nothing, not even an entry in the logfile and the light stays off.
Took this device
local color = domoticz.devices('Bad RGBWZ Color')
and tried
color.setcolor(255, 255, 255, 90, 255, 2, 0, 0)
Looks like the command is ignored or the device bugged, so let's compare the version.
FIBARO System 0x1000 0x0900
Solderbro
dre68
Post by dre68 »
Mine are all the same ID 0x1000 type 0x0900
008 and 010 are working great, the other 2 have the flashing behaviour
