Domoticz, Zigate , Not able to get all needed attributes on time
pokeron
Post by pokeron »
Hello All,
I flashed the Zigate controller device to version 3.1A and updated the plugin to the latest beta.
After that, I went away for two weeks. When I came back a few devices (XIAOMI battery operated devices) were not responding anymore.
So I did a reconnect with a 'lumi.sensor_magnet' device and everything seemed to be working. The Zigate controller had a notification with 'Reconnect Deur_0112 Rick with 3495/00158d00028a14d3'
But there was no signal sent to the zigate controller and when I removed the magnet from the sensor i saw a blue led blinking once, which is a indicator for me that I must reconnect the sensor.
Because I already did that, I removed the device from domoticz and the notification widget showed me 'Device fully removed Deur_0112 Rick with IEEE: 00158d00028a14d3'
In Domoticz the device was also gone. So I tried to reconnect the sensor again and got the message below :
2019-08-16 21:11:30.797 Error: (Zigate controller) [5] NEW OBJECT: 4b24 Not able to get all needed attributes on time
2019-08-16 21:11:30.797 Error: (Zigate controller) processNotinDB - not able to find response from 4b24 stop process at 0045
2019-08-16 21:11:30.797 Error: (Zigate controller) processNotinDB - RIA: 5 waitForDomoDeviceCreation: False, capturePairingInfos: 0 Model: {}
2019-08-16 21:11:30.797 Error: (Zigate controller) processNotinDB - Collected Infos are : {'Heartbeat': '1', 'ZDeviceName': '', 'Attributes List': {}, 'SQN': '', 'Model': {}, 'ZCL Version': '', 'DeviceType': '', 'LogicalType': '', 'HW Version': '', 'Stamp': {'LastSeen': 1565982614, 'Time': '2019-08-16 21:10:25', 'MsgType': '8702'}, 'ReceiveOnIdle': '', 'Manufacturer Name': '', 'ProfileID': {}, 'Ep': {}, 'Last Cmds': [], 'Health': 'Live', 'Manufacturer': '', 'ReadAttributes': {'Ep': {'06': {'0000': {}}, '09': {'0000': {}}, '03': {'0000': {}}, '01': {'0000': {}}, '02': {'0000': {}}}, 'TimeStamps': {'06-0000': 1565982685, '01-0000': 1565982685, '09-0000': 1565982685, '02-0000': 1565982685, '03-0000': 1565982685}}, 'Capability': ['Reduced-Function Device', 'Standard security', 'NwkAddr should be allocated'], 'RIA': '5', 'App Version': '', 'Version': '3', 'NbEp': '', 'APS Failure': [(1565982625.9178858, 'd4')], 'RSSI': {}, 'Status': 'UNKNOW', 'Type': {}, 'MacCapa': '80', 'IEEE': '00158d00028a14d3', 'Battery': {}, 'ZDeviceID': {}, 'Stack Version': '', 'PowerSource': ''}
Form a 'old' devicelist I have this information regarding the 'lumi.sensor_magnet' :
6cb0 : {'LogicalType': '', 'Heartbeat': '448', 'DeviceType': '', 'ZDeviceName': '', 'ZCL Version': '', 'Stamp': {'Time': '2019-08-13 17:54:16', 'LastSeen': 1565711390, 'MsgType': ' 4d'}, 'NbEp': '', 'Battery': 74, 'Ep': {'01': {'0006': '00', '0000': {}, 'ClusterType': {'439': 'Door'}, '0001': '3045;3045;3045;3045'}}, 'Stack Version': '', 'Type': 'Door', 'RSSI': 114, 'MacCapa': '80', 'IEEE': '00158d00028a14d3', 'SQN': '36', 'Health': 'Live', 'ZDeviceID': {}, 'ReceiveOnIdle': '', 'HW Version': '', 'PowerSource': '', 'Last Cmds': [], 'Manufacturer Name': '', 'ProfileID': {}, 'RIA': '0', 'Bind': {'0006': {'Status': '', 'Stamp': 1550832257, 'Phase': 'requested'}, '0000': {'Status': '', 'Stamp': 1550832257, 'Phase': 'requested'}}, 'Status': 'inDB', 'Manufacturer': '', 'Attributes List': {}, 'App Version': '10', 'Version': '3', 'Model': 'lumi.sensor_magnet'}
I have more Xiaomi devices which are not working anymore like a button, I have no problem with the lumi.sensor_motion.aq2 and the lumi.weather devices.
Any suggestions ?
Zigate Firmware version: 031a
Domoticz version : 4.11074
2019-08-16 21:41:25.586 Status: (Zigate controller) Zigate plugin beta-4.6.005 started
2019-08-16 21:41:25.603 Status: (Zigate controller) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-08-16 21:41:25.604 Status: (Zigate controller) Switching Heartbeat to 5 s interval
2019-08-16 21:41:25.604 Status: (Zigate controller) DomoticzVersion: 4.11074
2019-08-16 21:41:25.604 Status: (Zigate controller) DomoticzHash: b736cab34
2019-08-16 21:41:25.604 Status: (Zigate controller) DomoticzBuildTime: 2019-08-07 11:01:53
2019-08-16 21:41:25.604 Status: (Zigate controller) load PluginConf
2019-08-16 21:41:25.606 Status: (Zigate controller) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-08-16 21:41:25.606 Status: (Zigate controller) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2019-08-16 21:41:25.606 Status: (Zigate controller) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2019-08-16 21:41:25.606 Status: (Zigate controller) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-08-16 21:41:25.606 Status: (Zigate controller) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2019-08-16 21:41:25.606 Status: (Zigate controller) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2019-08-16 21:41:25.606 Status: (Zigate controller) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-03.json
2019-08-16 21:41:25.606 Status: (Zigate controller) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2019-08-16 21:41:25.606 Status: (Zigate controller) debugPairing set to 1
2019-08-16 21:41:25.608 Status: (Zigate controller) TXpower_set set to 1
2019-08-16 21:41:25.608 Status: (Zigate controller) Opening DomoticzDB in raw
2019-08-16 21:41:25.624 Status: (Zigate controller) Domoticz Website credentials ron/('02a92e2e5927418fcb77dabe53cde904',)
2019-08-16 21:41:25.630 Status: (Zigate controller) Plugin Database: DeviceList-3.txt
2019-08-16 21:41:25.654 Status: (Zigate controller) DeviceConf loaded
2019-08-16 21:41:25.654 Status: (Zigate controller) load ListOfDevice
2019-08-16 21:41:26.051 Status: (Zigate controller) Not Loading 4b24 as Status: UNKNOW
2019-08-16 21:41:26.160 Status: (Zigate controller) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-3.txt : 61
2019-08-16 21:41:26.214 Status: (Zigate controller) Transport mode: USB
2019-08-16 21:41:26.216 Status: (Zigate controller) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB-Zigbee
2019-08-16 21:41:26.219 Status: (Zigate controller) Configure Permit To Join
2019-08-16 21:41:26.221 Status: (Zigate controller) Request Accepting new Hardware for ever
2019-08-16 21:41:26.221 Status: (Zigate controller) Trigger a Topology Scan
2019-08-16 21:41:26.223 Status: (Zigate controller) Trigger a Energy Level Scan
2019-08-16 21:41:26.326 Status: (Zigate controller) Major Version Num: 0003
2019-08-16 21:41:26.327 Status: (Zigate controller) Installer Version Number: 031a
2019-08-16 21:41:26.731 Status: (Zigate controller) Accepting new Hardware: On
2019-08-16 21:41:26.856 Status: (Zigate controller) Zigate addresses ieee: 00158d0001ecbbd9 , short addr: 0000
2019-08-16 21:41:26.856 Status: (Zigate controller) Network state UP, PANID: d295 extPANID: 0x7d92efc7f49d0f93 Channel: 11
2019-08-16 21:41:26.989 Status: (Zigate controller) Number of devices recently active in Zigate = 23
2019-08-16 21:41:35.767 Status: (Zigate controller) Zigate set to Certification : CE
2019-08-16 21:41:35.772 Status: (Zigate controller) Start Web Server connection
2019-08-16 21:41:35.814 Status: (Zigate controller) Web backend for Web User Interface started on port: 9440
2019-08-16 21:41:35.814 Status: (Zigate controller) Plugin with Zigate firmware 031a correctly initialized
Best Regards,
Ron
pipiche
Re: Domoticz, Zigate , Not able to get all needed attributes on time
Post by pipiche »
In case a device is not paired anymore, you just have to repair it, you don't need to remove it from Domoticz.
I would recommend you to retry the pairing of the Door contact
Last, I don't know how is the mesh level of the zigbee network, but if devices are disapearing, it could be related to communication issue.
If you have only Xiaomi devices, you might set the Certification to FCC (as this is what Xiaomi rely on). This could help in the communication. ( you can do it from the Web Interface - in the Settings tab)
pokeron
Post by pokeron »
I tried it with another Door contact which is not responding anymore.
If I look at the device log I see :
2019-07-28 08:32:58 Off
2019-07-28 00:20:49 On
2019-07-27 10:16:14 Off
2019-07-26 20:07:02 On
I opened the window and it is not sending info to the Zigate controler.
If I look at the admin page I see :
Screenshot from 2019-08-17 11-55-37.png (15.81 KiB) Viewed 2355 times
If a do a reconnect Domoticz shows me it was done :
Screenshot from 2019-08-17 12-03-11.png (85.56 KiB) Viewed 2355 times
If I touch the Door contact with the magnet I see a blue led blinking once and no action is registered towards the controller.
Screenshot from 2019-08-17 12-07-40.png (64.93 KiB) Viewed 2355 times
What else can I do ?
Best Regards,
Ron
pipiche
Post by pipiche »
Did you set the Certification to FCC ?
What do you have in the logs ?
Screenshot 2019-08-17 at 15.32.51.png (53.28 KiB) Viewed 2348 times
pokeron
Post by pokeron »
I tried it
Screenshot from 2019-08-18 12-12-33.png (76.17 KiB) Viewed 2338 times
The result is the same, it gives these messages in the log :
2019-08-18 12:20:02.823 Status: (Zigate controller) Started.
2019-08-18 12:20:03.576 Status: (Zigate controller) Entering work loop.
2019-08-18 12:20:03.577 Status: (Zigate controller) Initialized version beta-4.6, author 'zaraki673 pipiche38'
2019-08-18 12:20:03.600 Status: (Zigate controller) Zigate plugin beta-4.6.005 started
2019-08-18 12:20:03.600 (Zigate controller) Debug: 2
2019-08-18 12:20:03.600 (Zigate controller) Debug Mode: 2
2019-08-18 12:20:03.600 (Zigate controller) 'SerialPort':'/dev/ttyUSB-Zigbee'
2019-08-18 12:20:03.600 (Zigate controller) 'Address':'0.0.0.0'
2019-08-18 12:20:03.600 (Zigate controller) 'UserDataFolder':'/home/pi/domoticz/'
2019-08-18 12:20:03.600 (Zigate controller) 'Mode1':'USB'
2019-08-18 12:20:03.600 (Zigate controller) 'Name':'Zigate controller'
2019-08-18 12:20:03.600 (Zigate controller) 'Mode6':'2'
2019-08-18 12:20:03.600 (Zigate controller) 'Mode3':'False'
2019-08-18 12:20:03.600 (Zigate controller) 'StartupFolder':'/home/pi/domoticz/'
2019-08-18 12:20:03.600 (Zigate controller) 'HomeFolder':'/home/pi/domoticz/plugins/Domoticz-Zigate/'
2019-08-18 12:20:03.600 (Zigate controller) 'DomoticzBuildTime':'2019-08-07 11:01:53'
2019-08-18 12:20:03.600 (Zigate controller) 'Language':'en'
2019-08-18 12:20:03.600 (Zigate controller) 'Version':'beta-4.6'
2019-08-18 12:20:03.600 (Zigate controller) 'DomoticzVersion':'4.11074'
2019-08-18 12:20:03.600 (Zigate controller) 'Database':'/home/pi/domoticz/domoticz.db'
2019-08-18 12:20:03.600 (Zigate controller) 'Key':'Zigate'
2019-08-18 12:20:03.601 (Zigate controller) 'DomoticzHash':'b736cab34'
2019-08-18 12:20:03.601 (Zigate controller) 'HardwareID':'3'
2019-08-18 12:20:03.601 (Zigate controller) 'Port':'9999'
2019-08-18 12:20:03.601 (Zigate controller) 'Author':'zaraki673 pipiche38'
2019-08-18 12:20:03.601 (Zigate controller) 'Mode2':'255'
2019-08-18 12:20:03.601 (Zigate controller) Device count: 75
2019-08-18 12:20:03.605 (Zigate controller) Device: 16 - ID: 506, Name: 'Raam-0123', nValue: 0, sValue: 'Closed'
2019-08-18 12:20:03.605 (Zigate controller) Device ID: '506'
2019-08-18 12:20:03.605 (Zigate controller) Device Name: 'Raam-0123'
2019-08-18 12:20:03.605 (Zigate controller) Device nValue: 0
2019-08-18 12:20:03.605 (Zigate controller) Device sValue: 'Closed'
2019-08-18 12:20:03.605 (Zigate controller) Device LastLevel: 0
2019-08-18 12:20:03.605 (Zigate controller) Device Options: {}
2019-08-18 12:20:03.621 Status: (Zigate controller) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-08-18 12:20:03.621 Status: (Zigate controller) Switching Heartbeat to 5 s interval
2019-08-18 12:20:03.621 Status: (Zigate controller) DomoticzVersion: 4.11074
2019-08-18 12:20:03.621 Status: (Zigate controller) DomoticzHash: b736cab34
2019-08-18 12:20:03.621 Status: (Zigate controller) DomoticzBuildTime: 2019-08-07 11:01:53
2019-08-18 12:20:03.621 Status: (Zigate controller) load PluginConf
2019-08-18 12:20:03.623 Status: (Zigate controller) CertificationCode set to 2
2019-08-18 12:20:03.623 Status: (Zigate controller) Certification set to FCC
2019-08-18 12:20:03.623 Status: (Zigate controller) TXpower_set set to 1
2019-08-18 12:20:03.623 Status: (Zigate controller) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2019-08-18 12:20:03.623 Status: (Zigate controller) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2019-08-18 12:20:03.623 Status: (Zigate controller) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-08-18 12:20:03.623 Status: (Zigate controller) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2019-08-18 12:20:03.623 Status: (Zigate controller) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2019-08-18 12:20:03.623 Status: (Zigate controller) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2019-08-18 12:20:03.623 Status: (Zigate controller) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-08-18 12:20:03.623 Status: (Zigate controller) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-03.json
2019-08-18 12:20:03.623 Status: (Zigate controller) debugPairing set to 1
2019-08-18 12:20:03.623 Status: (Zigate controller) Opening DomoticzDB in raw
2019-08-18 12:20:03.624 (Zigate controller) Opening /home/pi/domoticz/domoticz.db
2019-08-18 12:20:03.632 (Zigate controller) retreiveWebUserNamePassword - WebUserName: ####
2019-08-18 12:20:03.632 (Zigate controller) retreiveWebUserNamePassword - WebPassword: ####
2019-08-18 12:20:03.648 Status: (Zigate controller) Domoticz Website credentials ron/('####',)
2019-08-18 12:20:03.659 Status: (Zigate controller) Plugin Database: DeviceList-3.txt
2019-08-18 12:20:03.684 Status: (Zigate controller) DeviceConf loaded
2019-08-18 12:20:03.684 Status: (Zigate controller) load ListOfDevice
2019-08-18 12:20:04.104 Status: (Zigate controller) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-3.txt : 60
2019-08-18 12:20:04.158 Status: (Zigate controller) Transport mode: USB
2019-08-18 12:20:04.159 Status: (Zigate controller) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB-Zigbee
2019-08-18 12:20:04.163 (Zigate controller) setTimeServer - Setting UTC Time to : 619446004
2019-08-18 12:20:04.163 Status: (Zigate controller) Configure Permit To Join
2019-08-18 12:20:04.163 Status: (Zigate controller) Request Accepting new Hardware for ever
2019-08-18 12:20:04.163 Status: (Zigate controller) Trigger a Topology Scan
2019-08-18 12:20:04.165 Status: (Zigate controller) Trigger a Energy Level Scan
2019-08-18 12:20:04.269 Status: (Zigate controller) Major Version Num: 0003
2019-08-18 12:20:04.269 Status: (Zigate controller) Installer Version Number: 031a
2019-08-18 12:20:04.473 (Zigate controller) UTC time is: 619446004, Zigate Time is: 619446004 with deviation of :0
2019-08-18 12:20:04.676 (Zigate controller) Permit Join status: 01
2019-08-18 12:20:04.676 (Zigate controller) ---> self.permitTojoin['Starttime']: 1566123604
2019-08-18 12:20:04.676 (Zigate controller) ---> self.permitTojoin['Duration'] : 255
2019-08-18 12:20:04.676 (Zigate controller) ---> Current time : 1566123604
2019-08-18 12:20:04.676 (Zigate controller) ---> self.Ping['Permit'] (prev) : None
2019-08-18 12:20:04.676 Status: (Zigate controller) Accepting new Hardware: On
2019-08-18 12:20:04.676 (Zigate controller) ---> self.Ping['Permit'] (new ) : On
2019-08-18 12:20:04.783 (Zigate controller) Initialize Zigate Data Structure 0000 00158d0001ecbbd9
2019-08-18 12:20:04.801 Status: (Zigate controller) Zigate addresses ieee: 00158d0001ecbbd9 , short addr: 0000
2019-08-18 12:20:04.801 Status: (Zigate controller) Network state UP, PANID: d295 extPANID: 0x7d92efc7f49d0f93 Channel: 11
2019-08-18 12:20:04.937 Status: (Zigate controller) Number of devices recently active in Zigate = 23
2019-08-18 12:20:07.603 (Zigate controller) Decode8045 - Reception Active endpoint response : SQN : 45, Status ZIGATE - [00] Success, short Addr 0000, List 04, Ep list 010a6e15
2019-08-18 12:20:07.707 (Zigate controller) Decode8043 - Reception Simple descriptor response : SQN : 46, Status : ZIGATE - [00] Success, short Addr : 0000, Lenght : 3c
2019-08-18 12:20:07.812 (Zigate controller) Decode8043 - Reception Simple descriptor response : SQN : 47, Status : ZIGATE - [00] Success, short Addr : 0000, Lenght : 3c
2019-08-18 12:20:07.923 (Zigate controller) Decode8043 - Reception Simple descriptor response : SQN : 48, Status : ZIGATE - [00] Success, short Addr : 0000, Lenght : 3c
2019-08-18 12:20:08.025 (Zigate controller) Decode8043 - Reception Simple descriptor response : SQN : 49, Status : ZIGATE - [00] Success, short Addr : 0000, Lenght : 3c
2019-08-18 12:20:13.705 Status: (Zigate controller) Zigate set to Certification : FCC
2019-08-18 12:20:13.706 Status: (Zigate controller) Start Web Server connection
2019-08-18 12:20:13.706 (Zigate controller) Username/Password: ron/('02a92e2e5927418fcb77dabe53cde904',)
2019-08-18 12:20:13.749 Status: (Zigate controller) Web backend for Web User Interface started on port: 9440
2019-08-18 12:20:13.749 Status: (Zigate controller) Plugin with Zigate firmware 031a correctly initialized
2019-08-18 12:20:13.955 Status: (Zigate controller) There is a newer plugin version available on gitHub
2019-08-18 12:21:08.663 Status: (Zigate controller) Device Annoucement ShortAddr: 75b5, IEEE: 00158d00027b5c1e
2019-08-18 12:21:08.663 Status: (Zigate controller) NetworkID : 75b5 is replacing d3fc and is attached to IEEE : 00158d00027b5c1e
2019-08-18 12:21:18.944 (Zigate controller) Decode8000 - PacketType: 0100 Status: [15] - 15
2019-08-18 12:21:19.151 (Zigate controller) Decode8000 - PacketType: 0100 Status: [15] - 15
2019-08-18 12:21:19.263 (Zigate controller) Decode8000 - PacketType: 0100 Status: [15] - 15
so everything seems to be ok ,
Screenshot from 2019-08-18 12-54-05.png (48.38 KiB) Viewed 2338 times
but when I close and open the contact, nothing is sent to Zigate controller, the contact blinks once.
Screenshot from 2019-08-18 12-56-05.png (48.53 KiB) Viewed 2338 times
When I want to go back from FCC to EC and push the validate button it switches back to FCC and i'm not able to go back to EC mode by using the settings page.
I have also a lot of IKEA stuff but the change from EC to FCC did not affect the working of the TRADFRI devices.
I'm not sure how to get more debug info , the setting in the plugin is : Plugin Verbose
Best Regards,
Ron
pipiche
Post by pipiche »
Don’t put the plugin in debug, this doesn’t really help.
Certification is ether FCC or CE ( not EC).
For your Xiaomi I suggest that you leave the plugin in FCC and then do the pairing process on the device side. Without removing anything. And put the Zigate in pairing mode ( flashing blue led)
pokeron
Post by pokeron »
I did , still the same result, maybe the Xiaomi device does not understand what the Zigate controller is sending at the end. I'm away for a week, but I will try a new fresh device when I'm back and update this post. @pipiche, thnx for your quick answers and all the work you do for this nice product. I'm sure we will find a solution ;)
Best Regards,
Ron
pipiche
Post by pipiche »
Just saw on your screenshot that TXpower is set to 1; any reason behind that ? As 1 is putting a lot of attenuation on the Zigate transmission power !!
So make sure that it stay to 0
could you also update the plugin with
git pull
command
pokeron
Post by pokeron »
Hello , I did a pull but the result is the same. it seems more device ('lumi.sensor_magnet'') are detached, and can be reconnected but stay dead after reconnection (once a blink of the blue led when the magnet is removed or attached), TXpower is set to 0. I'm also not able to add more zigbee devices.
Best Regards,
Ron
pipiche
Post by pipiche »
pokeron wrote:Hello , I did a pull but the result is the same. it seems more device ('lumi.sensor_magnet'') are detached, and can be reconnected but stay dead after reconnection (once a blink of the blue led when the magnet is removed or attached), TXpower is set to 0. I'm also not able to add more zigbee devices.
How many devices are connected/paired ?
pokeron
Post by pokeron »
Screenshot from 2019-08-25 19-41-05.png (46.25 KiB) Viewed 2244 times
I'm going to try to add a new fresh motion device :)
Best Regards,
Ron
pokeron
Post by pokeron »
That didn't work either:
2019-08-25 19:49:24.699 (Zigate controller) processNotinDBDevices - NWKID: abba, Status: 0045, RIA: 4, HB_: 3
2019-08-25 19:49:24.703 (Zigate controller) [4] NEW OBJECT: abba Request Model Name
2019-08-25 19:49:24.703 Status: (Zigate controller) [4] NEW OBJECT: abba TimeOut in 0045 restarting at 0x004d
2019-08-25 19:49:25.049 (Zigate controller) Decode8000 - PacketType: 0100 Status: [15] - 15
2019-08-25 19:49:25.150 (Zigate controller) Decode8000 - PacketType: 0100 Status: [15] - 15
2019-08-25 19:49:25.251 (Zigate controller) Decode8000 - PacketType: 0100 Status: [15] - 15
2019-08-25 19:49:29.739 (Zigate controller) processNotinDBDevices - NWKID: abba, Status: 0045, RIA: 5, HB_: 1
2019-08-25 19:49:29.739 Error: (Zigate controller) [5] NEW OBJECT: abba Not able to get all needed attributes on time
2019-08-25 19:49:29.739 Error: (Zigate controller) processNotinDB - not able to find response from abba stop process at 0045
2019-08-25 19:49:29.740 Error: (Zigate controller) processNotinDB - RIA: 5 waitForDomoDeviceCreation: False, capturePairingInfos: 0 Model: {}
2019-08-25 19:49:29.740 Error: (Zigate controller) processNotinDB - Collected Infos are : {'Stamp': {'Time': '2019-08-25 19:49:24', 'LastSeen': 1566755293, 'MsgType': '8702'}, 'ReadAttributes': {'Ep': {'09': {'0000': {}}, '01': {'0000': {}}, '02': {'0000': {}}, '03': {'0000': {}}, '06': {'0000': {}}}, 'TimeStamps': {'01-0000': 1566755364, '09-0000': 1566755364, '03-0000': 1566755364, '02-0000': 1566755364, '06-0000': 1566755364}}, 'Attributes List': {}, 'Capability': ['Reduced-Function Device', 'Standard security', 'NwkAddr should be allocated'], 'Manufacturer': '', 'DeviceType': '', 'IEEE': '00158d00031c8acf', 'HW Version': '', 'LogicalType': '', 'ZDeviceName': '', 'Manufacturer Name': '', 'RIA': '5', 'PowerSource': '', 'Model': {}, 'Ep': {}, 'Type': {}, 'MacCapa': '80', 'RSSI': {}, 'Health': 'Live', 'Heartbeat': '1', 'APS Failure': [(1566755349.8592505, 'd4'), (1566755349.9620738, 'd4'), (1566755350.0643828, 'd4'), (1566755364.844552, 'd4'), (1566755364.9474974, 'd4')], 'ProfileID': {}, 'Stack Version': '', 'ReceiveOnIdle': '', 'App Version': '', 'Status': 'UNKNOW', 'SQN': '', 'ZDeviceID': {}, 'Last Cmds': [], 'ZCL Version': '', 'Version': '3', 'Battery': {}, 'NbEp': ''}
Best Regards,
Ron
pipiche
Post by pipiche »
You are probably reaching the limit of zigate
pipiche
Post by pipiche »
40 devices with direct link with ZiGate and 30 more if you have some router devices. Router device can stock some devices and route to ZiGate.
pokeron
Post by pokeron »
@Pipiche , thnx I think i'm indeed at the limit with my devices.
Best Regards,
Ron
pipiche
Post by pipiche »
pokeron wrote: Wednesday 28 August 2019 17:30 @Pipiche , thnx I think i'm indeed at the limit with my devices.
You might comment here : https://github.com/fairecasoimeme/ZiGate/issues/235 in regards to the Zigate limit
