[Experimental] New graph module. Testers needed.
Lokonli
Post by Lokonli »
I've developed a new graph module. As an example, it can generate graphs like the following:
Technical:
I switched from morris.js to chart.js for creating the graphs and added some functionality.
The module is still a bit experimental, and not completely backwards compatible. But I think the new functionality is worth the effort for making the change.
I would like to ask you to help by testing this branch, and to leave your feedback here in this topic.
Documentation
https://dashticz.readthedocs.io/en/char ... raphs.html
Priorities
1. Stability/bug fixes
2. Ease-of-use. Default behavior as good as possible, to minimize the need for configuration settings
3. Basic styling
4. Extension of configuration possibilities, functionality, styling
Installation
The functionality is available via a separate branch 'chartjs':
https://github.com/Dashticz/dashticz/tree/chartjs
If you've used git clone or the automatic installation script it should be pretty easy to switch to this branch:
git fetch
git checkout chartjs
You can switch back to the beta branch via:
git checkout beta
If you start making changes in your CONFIG.js to test the graph functionality I would recommend to make a backup of CONFIG.js first.
I cannot guarantee that the configuration settings will not changes in future updates of the graph functionality. It should be stable after I have merged it into beta.
For most users it should work out-of-the-box without changing any setting, although the charts will look differently.
If the functionality is stable enough I'll merge it into Beta, and some time later into Master.
Thanks for your help, and enjoy :)
renerene
Re: [Experimental] New graph module. Testers needed.
Post by renerene »
thank you very much. Will look into it very soon. Looks promising.
just to be sure, before ´git fetch´ there is ´cd dashticz´?
Lokonli
Post by Lokonli »
Yes
EdwinK
Post by EdwinK »
git fetch
root@DiskStation:/volume1/web/dashboard# git checkout chartjs
error: pathspec 'chartjs' did not match any file(s) known to git
renerene
Post by renerene »
Working, Looks great!
git fetch: no problem (was already on dashticz 3)
first, my graphs were gone, with the initial custom.js .
But after I removed the declarations like
blocks['graph_428'] = {
   title: 'Gas',
   width: 6,
.. the graphs were back, with no data
After modifying to
/*	zonnepaneel	Growatt*/
blocks['graph_1354'] = {
    type: 'bar',
    datasetColors: ['yellow']
/*	P1 power gas*/
    type: 'bar',
/*	P1 power stroom*/
blocks['graph_427'] = {
    width:6
    title: 'My Power',
    graph: ['line','bar','bar'],
    custom : {
        "last day": {
            range: 'day',
            filter: '8 hours',
            data: {
                nett: 'd.v+d.v2-d.r1-d.r2',
                usage: 'd.v+d.v2',
                generation: '-d.r1-d.r2'
        "last 2 weeks": {
            range: 'month',
            filter: '14 days',
            data: {
                usage: 'd.v+d.v2',
        "last 6 months": {
            range: 'year',
            filter: '6 months',
            data: {
                usage: 'd.v+d.v2',
    legend: true,
    datasetColors:['blue','red','yellow']
result:
Now time for fine tune, looking for a way to change size... let's see....
Lokonli
Post by Lokonli »
renerene wrote: Saturday 24 August 2019 12:09 Working, Looks great!
   title: 'Gas',
   width: 6,
After modifying to
    type: 'bar',
/*	P1 power gas*/
    type: 'bar',
    width:6
    title: 'My Power',
    custom : {
        "last day": {
            range: 'day',
            filter: '8 hours',
            data: {
                usage: 'd.v+d.v2',
        "last 2 weeks": {
            range: 'month',
            filter: '14 days',
            data: {
                usage: 'd.v+d.v2',
        "last 6 months": {
            range: 'year',
            filter: '6 months',
            data: {
                usage: 'd.v+d.v2',
    legend: true,
result:
Thanks.
There was indeed a bug in the width parameter.
It's fixed
You can update your branch with
git pull
Lokonli
Post by Lokonli »
EdwinK wrote: Saturday 24 August 2019 11:49
git fetch
Are you using the correct repository? It should be: https://github.com/Dashticz/dashticz
Did you use git clone or the installation script? If you just downloaded a release then the git settings are not defined.
You can check with:
#go to your dashticz folder
cd dashticz
git remote -v
This should show:
origin	http://github.com/Dashticz/dashticz (fetch)
origin	http://github.com/Dashticz/dashticz (push)
EdwinK
Post by EdwinK »
Aaah.. I see now.
root@DiskStation:/volume1/web/dashboard# git remote -v
origin https://github.com/dashticzv3/dashticz_v3 (fetch)
origin https://github.com/dashticzv3/dashticz_v3 (push)
renerene
Post by renerene »
thank you for correcting width option.
How can I allign the height? Both graphics have width=6 in screenshot:
Lokonli
Post by Lokonli »
renerene wrote: Saturday 24 August 2019 13:53 thank you for correcting width option.
Can you show how you defined your graphs? Did you use different width parameters?
Lokonli
Post by Lokonli »
EdwinK wrote: Saturday 24 August 2019 13:35 Aaah.. I see now.
You pulled Dashticz from it's previous location.
You can change origin with:
git remote set-url origin https://github.com/Dashticz/dashticz.git
Check with:
git remote -v
Followed with:
git fetch origin
renerene
Post by renerene »
In the screenshot above the width was 5 and 6. However, same height difference with width 6 and 6
/*	P1 power gas*/
    type: 'line',
    datasetColors: ['white'],
    width:6
    width: 6,
    title: 'My Power',
    custom : {
        "last day": {
            range: '8 hrs',
            filter: '8 hours',
            data: {
                usage: 'd.v+d.v2',
        "last 2 weeks": {
            range: 'month',
            filter: '14 days',
            data: {
                usage: 'd.v+d.v2',
        "last 6 months": {
            range: 'year',
            filter: '6 months',
            data: {
                usage: 'd.v+d.v2',
    legend: false,
and
columns[3]['blocks'] = ['graph_427','graph_428','stationclock', frames.weather,'garbage',779,781,'s2','s3','s4', 866, 941,  1352, 1342, 864, 774, 1137, 1225];
Custom.css has no effect:
#graphoutput427 {height: 120px;}
renerene
Post by renerene »
additional: regarding the total amount in the top left corder. It would be great it that would show the total of the selected time interval, not of beginning of measurement/?/year
Lokonli
Post by Lokonli »
The width parameter is indeed not applied correctly. I'll fix it within a few days.
Lokonli
Post by Lokonli »
renerene wrote:additional: regarding the total amount in the top left corder. It would be great it that would show the total of the selected time interval, not of beginning of measurement/?/year
Currently it shows the current value of the device. I'll think of a way how to make it configurable as well.
Lokonli
Post by Lokonli »
I've made some updates to the chartjs branch.
The width parameter should now work correctly.
The height of the graph probably will not be the same as before. You can set the height via the height parameter in the block definition.
To update:
git fetch origin
git pull
or, if you are already on the chartjs branch:
git pull
renerene
Post by renerene »
Thank you for the update. Did a quick check, the graphs have the same height now.
Furthermore:
1) when is the graph updated? Sometimes the last data is more than 10 minutes old. (never quite understood the config['domoticz_refresh'] = '5';
config['dashticz_refresh'] = '60'. Is it in seconds?)
2) is it possible to combine more devices in one graph? Would be great to build one big mother graph with temp inside, temp outside, electricity, solar, gas
Really thankful with your works uptil now. Keep it up.
Lokonli
Post by Lokonli »
renerene wrote: Wednesday 28 August 2019 8:20 Thank you for the update. Did a quick check, the graphs have the same height now.
Furthermore:
1) Domotics_refresh is the refresh rate for the Domoticz device information, in seconds.
Dashticz_refresh is the reload of the whole dashboard, in minutes.
Currently the graph refresh rate is disabled (in fact it is 5000 minutes ...) . It will become 5 minutes in the next update. This is also the frequency on which Domoticz updates the graph data. (A faster refresh in dashticz doesn't make sense)
2) Yes, nice enhancement. I will add it to the feature request list. It will be quite some work to implement it.
Lokonli
Post by Lokonli »
New version:
graph height now scales with the graph width, limited to the screen height.
Tooltips will be shown when you touch the graph anywhere.
Refresh rate 5 minutes.
Gianni
Post by Gianni »
update to v 3.0.6
get the newest graph.js
add some colors to my js and everything works fine
