RFY (somfy) relay device -> on/off inverted
pire76
Post by pire76 »
I use domoticz with a Raspberry pi + RFXCom E version.
When using this kind of device :
http://www.alloalarme.fr/alarme-somfy/3 ... oCsVnw_wcB
A somfy rts (RFY protocol). On status is "off" and off status is "on".
How can I solve this issue ?
Thanks.
Somfy rts relay
Somfy rts relay
gizmocuz
Re: RFY (somfy) relay device -> on/off inverted
Post by gizmocuz »
Also with the rfxmngr application?
JLO1969
Post by JLO1969 »
I do confirm. Somfy power switches are correctly managed with rfxmngr application ( UP cmd = Switch Power ON & DOWN cmd = Switch Power OFF) but with domoticz on Raspberry pi + RFXCom E version commands are inverted :(
How can this be fixed?
kroonsteen
Post by kroonsteen »
Same here, testing the RFXcom in combination with the Somfy Powerplug (e200 RTS). Everything works correctly with the rfxmngr application, in Domoticz it's inverted, when i turn it off in the aplication, it goes on and vice versa. Hoping for a solution.... Testing now on Windows 7, i want to finally install it on a synology NAS.
kroonsteen
Same problem with the Somfy Lighting Modulis RTS Receiver Dimmer (pn: 9014281), also inverted, so can't dim in Domoticz. I can only turn it off (=on) and on (=off).
kroonsteen
i've made the next workaround to make the powerplugs work for me:
-created a dummy switch ("Tuin Waterval").
-created a real switch ("Somfy2"), the actual powerplug.
-created the next blocky:
blocky
blocky
When I turn the dummy switch "on" then "Tuin Waterval" is "on" (but the real powerplug is in domoticz "off").
xhark
Domoticz version: 2023.1
Post by xhark »
solved in 3724 version : viewtopic.php?f=6&t=9174&p=63574
FR blogger & sysAdmin
kroonsteen
xhark wrote:solved in 3724 version : viewtopic.php?f=6&t=9174&p=63574
today my somfy devices didn't turn on, after i had updated domiticz. Thx to above post i understand why. So, i've removed my virtual switches for the inverted somfys :-)
