Zigate support in domoticz?
tjabas
Post by tjabas »
I use a conbee on my raspberry with deconz. But since conbee doesnt have direct support in domoticz i use the phoscon software also.
But can i use the zigate directly in domoticz, just like I use the aeon z-wave stick, without any other software running on the pie?
Or do i need to use phoscon software for it to work?
pipiche
Re: Zigate support in domoticz?
Post by pipiche »
The Zigate doesn't need any additional software except to have the Python Plugin installed, as it rely not on native Domoticz plugin but the Python plugin framework.
You might find more information on the wiki: https://github.com/pipiche38/Domoticz-Z ... ng/Home.md
Wiki is available here.
Zigbee for Domoticz FAQ
tjabas
Post by tjabas »
Thank you very much for the quick reply, i have had a quick look at the zigate, but it seems like the zigate device isnt just plug and play?
Do i need to build the zigate device by myself and then program it before i can use it in domoticz?
pipiche
Post by pipiche »
tjabas wrote: Tuesday 13 August 2019 20:49 Thank you very much for the quick reply, i have had a quick look at the zigate, but it seems like the zigate device isn't just plug and play?
If you go for a USB-TTL Zigate, you will receive 3 components a USB-TTL module and a Zigbee Module, that you have to plug together. A 3rd part is provided which is the box where you can put the plugged USB-TTL+Zigbee module in it and the you have 2 screws to close the box.
So yes it is not plug and play, it is DIY, but in a very limited way.
Last, it might came a bit more complicated when it is about firmware update, as the Zigate has a firmware embedded and time to time you have to update it.
pocock
Post by pocock »
It is also easier to install and update if you use the packages, they are described in this thread:
viewtopic.php?f=47&t=28951
Daniel Pocock, Debian Developer
https://danielpocock.com
tjabas
Post by tjabas »
pocock wrote: Wednesday 14 August 2019 21:47 It is also easier to install and update if you use the packages, they are described in this thread:
so i need to install all of these files in the link?
sorry but im a bit of a newbie to this.
ahattink
Domoticz version: Stable
Post by ahattink »
Hi All. I just bought an Zigate and am very impressed with the workings and simplicity.
The working is almost the same as an Zwave stick. Only thing is you need to put some components together. Nothing difficult tough.
The site of Zigate is clear on how you should do this and install software.
Pi 3B, latest stable
RFXCOM, Z-wave, Zigate, Hue, Harmony hub, Netatmo Weather station, Opentherm Gateway, EnOcean,P1 SmartMeter, Plugwise Anna & Adam, Xiaomi Roborock, Sonos One, Google Home, Philips Hue, Homey, D-link and Bitron Video camera.
Domoticz version: 2024.7
Fo a RPi you can buy the PiZigate, almost plug and play (depends on RPi version)
https://zigate.fr/produit/pizigate-v1-0/
