Blockly and user variables for basic heater
alarm_guy1
Hi guys
I have a blockly that basically is
If garage temp is <15 then turn on switch 2
and if garage temp is greater than 16 turn off switch 2
This keeps the shed ticking over nicely, but if the shed is occupied for an extended period and I want to increase the temperature to say 20
Could I use a user variable to easily change the temperature elsewhere so I or others dont have to go messing in the blockly, it could be as simple as a retractive switch that overides the current temp for 1hr say or a section on the switches screen or temperature screen you just edit
cheers
cheers
knielen
Re: Blockly and user variables for basic heater
Ofcourse, most easy is an extra switch named e.g. Occupied
You blockly will something be like:
If garage temp is <15 then turn on switch2
else if garage temp is > 16 and switch Occupied is off then turn off switch2
else if garage temp is > 20 and switch Occupied is on then turn off switch 2
in the settings of the switch there's an option to turn in off after an hour (named turn on for an hour)
Gerwin
hello,
you can make a selector switch wit different actions
Gerwin
Gerwin
alarm_guy1
Cheers,
Unfortunately I have no idea where to start with that, are there any guides out there
Gerwin
Looks like this
And make a blockly that the selector switch know what action to do
Gerwin
Gerwin
- IMG_0241.PNG (307.9 KiB) Viewed 1384 times
Gerwin
Here the blockly,
Sorry for the bad picture
Gerwin
Gerwin
- IMG_0243.JPG (336.52 KiB) Viewed 1384 times
alarm_guy1
Thankyou, in the 1st picture where have you created that list
cheers for the continued support
Gerwin
hello.
go to hardware than make a dummy device (selector) than you can see them in devices
go to the device you have make and change the settings
alarm_guy1
Cheers got it now
