Other than the older Fibaro door sensor, is there
a) a bottery-operated doorbell (ie, really just a zwave button with battery that can be glued/screwed/tied near the gate
or
b) a door sensor which can take a signal from an external contact and thus trigger a scene?
or another solution for a doorbell that does not require power at the
door/gate? The cheaper the better
Z-Wave battery operated boorbell (or door sensor with external contact)
- philchillbill
Re: Z-Wave battery operated boorbell (or door sensor with external contact)
I use the Neo Coolcam door sensor with two wires soldered in parallel over the magnetic reed switch. Works perfectly and cheaper than Fibaro.
Alexa skills author: EvoControl, Statereport, MediaServer, LMS-lite
hoeby
- Domoticz version: V2022.1
This also works with xiaomi doorsensor.philchillbill wrote: Tuesday 06 August 2019 9:00 two wires soldered in parallel over the magnetic reed switch. Works perfectly and cheaper than Fibaro.
I soldered out the reed switch. And on the 2 point where the reed switch was connected, i soldered the new wires
Just like the image (not mine, but the same idea)
Thin-client --> Docker Domoticz main environment
Pi3A+ --> Google home (GAssistPi)
Pi3B+ --> Docker (P1monitor, Domoticz test environment, Ubiquity controller)
