Zigate - Devices not updating status
nay
Post by nay »
Hi All,
I am currently running with Zigate 3.1f / Latest 4.4 Zigate plugin / Latest Domoticz Beta on a Raspberry Pi and have successfully added several Philips Hue motion sensors. The sensors update the Lux and temperature but they do not log motion. Is this a known issue?
Regards,
Nay
pipiche
Re: Zigate - Devices not updating status
Post by pipiche »
It could be a pairing issue . As for the motion there is some timing issue to do things.
I lol check this week and will let you know
pipiche
Post by pipiche »
Indeed, you are right. Motion seems not to work anymore.
I'll investigate and will come back to you .
pipiche
Post by pipiche »
@nay if you can upgrade to 4.5.1 , problem should be fixed.
However, you have to remove all Motion widgets in Domoticz ( Lux, Temp, Motion) in order to redo the full pairing process.
Keep me posted
nay
Post by nay »
Thank you for the update. I am away for a week so I cannot re-pair the devices but will test and update the thread when I get back.
OedzesG
Post by OedzesG »
Hallo,
small issue here with Philips Hue also.
Seems like the Groups are not updating the devices..
Log after changing Group with Philips HUE bulbs:
2019-10-02 10:57:46.379 (ZigBee devices) UpdateGroup - (Zigbee Groep Woonkamer spots) 0:7
2019-10-02 10:57:46.358 Status: User: Admin initiated a switch command (15/Zigbee Groep Woonkamer spots/Set Level)
The Inloopkast has 2 Ikea Led Drivers, when i change this Group:
2019-10-02 10:59:26.984 (ZigBee devices) UpdateGroup - (Zigbee Groep Inloopkast) 1:100
2019-10-02 10:59:26.948 Status: User: Admin initiated a switch command (21/Zigbee Groep Inloopkast/On)
2019-10-02 10:59:27.141 (ZigBee devices) UpdateDevice - (Zigbee Inloopkast klein) 1:On
2019-10-02 10:59:27.198 (ZigBee devices) UpdateDevice - (Zigbee Inloopkast groot) 1:On
So no updating problem for the Ikea devices, only Philips HUE.
The version of the Domoticz plugin: 4.5.4
Zigate Firmware: V3.1
pipiche
Post by pipiche »
I do not have any Hue to test, but by understanding is that they do not report there status when a command is send to them.
In order to workaround that , you have to enable Polling via the Web Admin interface
OedzesG
Post by OedzesG »
door pipiche » woensdag 02 oktober 2019 11:15
Ik heb geen tint om te testen, maar door te begrijpen is dat ze hun status niet rapporteren wanneer een opdracht naar hen wordt verzonden.
Om dit te omzeilen, moet u Polling inschakelen via de Web Admin-interface
Thnx working now!
only this morning my log was full with this error
Line 809 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
After plugin reset ik works but you know what is is?
OedzesG
Post by OedzesG »
also this error appears every fiew minutes:
Code: d4 Status: Unicast frame does not have a route available but it is buffered for automatic resend
pipiche
Post by pipiche »
[/quote]
Without the full context, I cannot really diagnose anything. I suspect that something went wrong when you started the plugin.
OedzesG
Post by OedzesG »
It indeed looks like an error at startup..
now this error dont show up again..
is this message normal?
2019-10-02 13:34:26.380 Status: OpenZWave: Alarm received (Home Security: Clear), NodeID: 2 (0x02)
2019-10-02 13:34:26.420 Status: User: Admin initiated a switch command (11/Zigbee Woonkamer plafond spot 2/Set Level)
2019-10-02 13:34:47.768 (ZWave devices) Light/Switch (Eethoek motion sensor)
2019-10-02 13:34:47.771 (ZWave devices) General/Alarm (Alarm Type: Home Security 7 (0x07))
2019-10-02 13:34:47.775 (ZWave devices) Light/Switch (Eethoek sensor home security)
2019-10-02 13:34:47.765 Status: OpenZWave: Alarm received (Home Security: Motion Detected at Unknown Location), NodeID: 2 (0x02)
2019-10-02 13:34:53.506 (ZigBee devices) readCluster - 0300 - 41ca/0b unknown attribute: 0032 21 0002 b105
2019-10-02 13:34:53.507 (ZigBee devices) readCluster - 0300 - 41ca/0b unknown attribute: 0033 21 0002 4eec
2019-10-02 13:34:53.507 (ZigBee devices) readCluster - 0300 - 41ca/0b unknown attribute: 0030 21 0002 6161
2019-10-02 13:34:53.508 (ZigBee devices) readCluster - 0300 - 41ca/0b unknown attribute: 0031 21 0002 6075
2019-10-02 13:34:53.508 (ZigBee devices) readCluster - 0300 - 41ca/0b unknown attribute: 0036 21 0002 2b84
2019-10-02 13:34:53.509 (ZigBee devices) readCluster - 0300 - 41ca/0b unknown attribute: 0037 21 0002 b332
2019-10-02 13:34:53.510 (ZigBee devices) readCluster - 0300 - 41ca/0b unknown attribute: 0034 20 0001 40
2019-10-02 13:34:53.511 (ZigBee devices) readCluster - 0300 - 41ca/0b unknown attribute: 001a 21 0002 0c2c
2019-10-02 13:34:53.615 (ZigBee devices) UpdateDevice - (Zigbee Keuken plafond spot 2) 1:100
2019-10-02 13:35:18.351 (ZWave devices) Light/Switch (Eethoek motion sensor)
2019-10-02 13:35:18.354 (ZWave devices) General/Alarm (Alarm Type: Home Security 7 (0x07))
2019-10-02 13:35:18.360 (ZWave devices) Light/Switch (Eethoek sensor home security)
2019-10-02 13:35:18.348 Status: OpenZWave: Alarm received (Home Security: Clear), NodeID: 2 (0x02)
2019-10-02 13:35:23.551 (ZigBee devices) readCluster - 0300 - b665/0b unknown attribute: 0032 21 0002 accc
2019-10-02 13:35:23.552 (ZigBee devices) readCluster - 0300 - b665/0b unknown attribute: 0033 21 0002 526e
2019-10-02 13:35:23.553 (ZigBee devices) readCluster - 0300 - b665/0b unknown attribute: 0030 21 0002 6161
2019-10-02 13:35:23.553 (ZigBee devices) readCluster - 0300 - b665/0b unknown attribute: 0031 21 0002 6075
2019-10-02 13:35:23.554 (ZigBee devices) readCluster - 0300 - b665/0b unknown attribute: 0034 20 0001 40
2019-10-02 13:35:23.555 (ZigBee devices) readCluster - 0300 - b665/0b unknown attribute: 0010 20 0001 03
2019-10-02 13:35:23.556 (ZigBee devices) readCluster - 0300 - b665/0b unknown attribute: 001a 21 0002 0a3d
2019-10-02 13:35:23.557 (ZigBee devices) readCluster - 0300 - b665/0b unknown attribute: 001b 20 0001 0b
2019-10-02 13:35:28.525 (ZigBee devices) readCluster - 0300 - 3069/0b unknown attribute: 0032 21 0002 accc
2019-10-02 13:35:28.526 (ZigBee devices) readCluster - 0300 - 3069/0b unknown attribute: 0033 21 0002 526e
2019-10-02 13:35:28.526 (ZigBee devices) readCluster - 0300 - 3069/0b unknown attribute: 0030 21 0002 6161
2019-10-02 13:35:28.527 (ZigBee devices) readCluster - 0300 - 3069/0b unknown attribute: 0031 21 0002 6075
2019-10-02 13:35:28.528 (ZigBee devices) readCluster - 0300 - 3069/0b unknown attribute: 0034 20 0001 40
2019-10-02 13:35:28.528 (ZigBee devices) readCluster - 0300 - 3069/0b unknown attribute: 0010 20 0001 03
2019-10-02 13:35:28.529 (ZigBee devices) readCluster - 0300 - 3069/0b unknown attribute: 001a 21 0002 0a3d
2019-10-02 13:35:28.530 (ZigBee devices) readCluster - 0300 - 3069/0b unknown attribute: 001b 20 0001 0b
2019-10-02 13:35:38.656 (ZigBee devices) readCluster - 0300 - f74b/0b unknown attribute: 0032 21 0002 b105
2019-10-02 13:35:38.657 (ZigBee devices) readCluster - 0300 - f74b/0b unknown attribute: 0033 21 0002 4eec
2019-10-02 13:35:38.657 (ZigBee devices) readCluster - 0300 - f74b/0b unknown attribute: 0030 21 0002 6161
2019-10-02 13:35:38.658 (ZigBee devices) readCluster - 0300 - f74b/0b unknown attribute: 0031 21 0002 6075
2019-10-02 13:35:38.658 (ZigBee devices) readCluster - 0300 - f74b/0b unknown attribute: 0036 21 0002 2b84
2019-10-02 13:35:38.659 (ZigBee devices) readCluster - 0300 - f74b/0b unknown attribute: 0037 21 0002 b332
2019-10-02 13:35:38.659 (ZigBee devices) readCluster - 0300 - f74b/0b unknown attribute: 0034 20 0001 40
2019-10-02 13:35:38.661 (ZigBee devices) readCluster - 0300 - f74b/0b unknown attribute: 001a 21 0002 0c2c
2019-10-02 13:35:53.653 (ZigBee devices) readCluster - 0300 - 2d14/0b unknown attribute: 0032 21 0002 b105
2019-10-02 13:35:53.653 (ZigBee devices) readCluster - 0300 - 2d14/0b unknown attribute: 0033 21 0002 4eec
2019-10-02 13:35:53.654 (ZigBee devices) readCluster - 0300 - 2d14/0b unknown attribute: 0030 21 0002 6161
2019-10-02 13:35:53.654 (ZigBee devices) readCluster - 0300 - 2d14/0b unknown attribute: 0031 21 0002 6075
2019-10-02 13:35:53.655 (ZigBee devices) readCluster - 0300 - 2d14/0b unknown attribute: 0036 21 0002 2b84
2019-10-02 13:35:53.655 (ZigBee devices) readCluster - 0300 - 2d14/0b unknown attribute: 0037 21 0002 b332
2019-10-02 13:35:53.656 (ZigBee devices) readCluster - 0300 - 2d14/0b unknown attribute: 0034 20 0001 40
2019-10-02 13:35:53.658 (ZigBee devices) readCluster - 0300 - 2d14/0b unknown attribute: 001a 21 0002 0c2c
2019-10-02 13:35:53.761 (ZigBee devices) UpdateDevice - (Zigbee Keuken plafond spot 4) 1:100
2019-10-02 13:35:58.431 (ZigBee devices) UpdateGroup - (Zigbee Groep Woonkamer spots) 1:27
2019-10-02 13:35:58.539 (ZigBee devices) readCluster - 0300 - e306/0b unknown attribute: 0032 21 0002 b105
2019-10-02 13:35:58.540 (ZigBee devices) readCluster - 0300 - e306/0b unknown attribute: 0033 21 0002 4eec
2019-10-02 13:35:58.540 (ZigBee devices) readCluster - 0300 - e306/0b unknown attribute: 0030 21 0002 6161
2019-10-02 13:35:58.541 (ZigBee devices) readCluster - 0300 - e306/0b unknown attribute: 0031 21 0002 6075
2019-10-02 13:35:58.541 (ZigBee devices) readCluster - 0300 - e306/0b unknown attribute: 0034 20 0001 40
2019-10-02 13:35:58.542 (ZigBee devices) readCluster - 0300 - e306/0b unknown attribute: 0010 20 0001 03
2019-10-02 13:35:58.543 (ZigBee devices) readCluster - 0300 - e306/0b unknown attribute: 001a 21 0002 0c2c
2019-10-02 13:35:58.543 (ZigBee devices) readCluster - 0300 - e306/0b unknown attribute: 001b 20 0001 0b
2019-10-02 13:37:23.546 (ZigBee devices) readCluster - 0300 - 0efe/0b unknown attribute: 0032 21 0002 b105
2019-10-02 13:37:23.546 (ZigBee devices) readCluster - 0300 - 0efe/0b unknown attribute: 0033 21 0002 4eec
2019-10-02 13:37:23.547 (ZigBee devices) readCluster - 0300 - 0efe/0b unknown attribute: 0030 21 0002 6161
2019-10-02 13:37:23.548 (ZigBee devices) readCluster - 0300 - 0efe/0b unknown attribute: 0031 21 0002 6075
2019-10-02 13:37:23.548 (ZigBee devices) readCluster - 0300 - 0efe/0b unknown attribute: 0036 21 0002 2b84
2019-10-02 13:37:23.549 (ZigBee devices) readCluster - 0300 - 0efe/0b unknown attribute: 0037 21 0002 b332
2019-10-02 13:37:23.550 (ZigBee devices) readCluster - 0300 - 0efe/0b unknown attribute: 0034 20 0001 40
2019-10-02 13:37:23.651 (ZigBee devices) readCluster - 0300 - 0efe/0b unknown attribute: 001a 21 0002 0c2c
2019-10-02 13:37:23.654 (ZigBee devices) UpdateDevice - (Zigbee Keuken plafond spot 1) 1:100
2019-10-02 13:37:43.560 (ZigBee devices) readCluster - 0300 - 379e/0b unknown attribute: 0032 21 0002 b105
2019-10-02 13:37:43.561 (ZigBee devices) readCluster - 0300 - 379e/0b unknown attribute: 0033 21 0002 4eec
2019-10-02 13:37:43.561 (ZigBee devices) readCluster - 0300 - 379e/0b unknown attribute: 0030 21 0002 6161
2019-10-02 13:37:43.562 (ZigBee devices) readCluster - 0300 - 379e/0b unknown attribute: 0031 21 0002 6075
2019-10-02 13:37:43.562 (ZigBee devices) readCluster - 0300 - 379e/0b unknown attribute: 0036 21 0002 2b84
2019-10-02 13:37:43.563 (ZigBee devices) readCluster - 0300 - 379e/0b unknown attribute: 0037 21 0002 b332
2019-10-02 13:37:43.564 (ZigBee devices) readCluster - 0300 - 379e/0b unknown attribute: 0034 20 0001 40
2019-10-02 13:37:43.565 (ZigBee devices) readCluster - 0300 - 379e/0b unknown attribute: 001a 21 0002 0c2c
2019-10-02 13:37:48.433 (ZigBee devices) UpdateGroup - (Zigbee Groep Keuken spots) 1:77
2019-10-02 13:41:49.521 (ZWave devices) Light/Switch (Eethoek motion sensor)
pipiche
Post by pipiche »
Could you let me know what are those devices ? Seems to be a Light
OedzesG
Post by OedzesG »
Yes there Hue bulbs...
OedzesG
Post by OedzesG »
Are there some special settings needed for Hue?
Also now with polling its verry strange..
When ik switch the Group.. Zigate is updating the group instead of the devices.
For example.. when ik set manualy the slider of the dimmer to 90% in flashes back to 60%
And the seperated devices in Domoticz witch belongs to that group are not updated...
2019-10-02 14:52:26.853 (ZigBee devices) UpdateGroup - (Zigbee Groep Keuken spots) 1:52
2019-10-02 14:52:26.813 Status: User: Admin initiated a switch command (16/Zigbee Groep Keuken spots/Set Level)
Group dimmer:
Group devices:
Group management:
Group settings.JPG (24.29 KiB) Viewed 2327 times
pipiche
Post by pipiche »
When using the Group command, the device will be updated via the polling, so until we have the polling done on the device, it will remain on the previous state.
Then after the group command, the group can be updated by the plugin at the next cycle with the devices state which belongs to this group.
This is problably what you experienced.
As the Hue Automatic Reporting doesn't work, this explain and we do not have much option than expecting an update of the devices accoridngly to the polling frequency
OedzesG
Post by OedzesG »
Can i change the frequency somewhere?
OedzesG
Post by OedzesG »
and here we go again.... :oops: :|
2019-10-02 15:16:03.582 Error: (ZigBee devices) ----> Line 828 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:03.582 Error: (ZigBee devices) ----> Line 696 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:03.582 Error: (ZigBee devices) ----> Line 759 in '/usr/local/domoticz/var/plugins/Zigate/Classes/OTA.py', function heartbeat
2019-10-02 15:16:08.592 Error: (ZigBee devices) 'onHeartbeat' failed 'KeyError'.
2019-10-02 15:16:08.592 Error: (ZigBee devices) ----> Line 828 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:08.593 Error: (ZigBee devices) ----> Line 696 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:08.593 Error: (ZigBee devices) ----> Line 580 in '/usr/local/domoticz/var/plugins/Zigate/Classes/OTA.py', function heartbeat
2019-10-02 15:16:13.603 Error: (ZigBee devices) 'onHeartbeat' failed 'KeyError'.
2019-10-02 15:16:13.603 Error: (ZigBee devices) ----> Line 828 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:13.603 Error: (ZigBee devices) ----> Line 696 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:13.603 Error: (ZigBee devices) ----> Line 580 in '/usr/local/domoticz/var/plugins/Zigate/Classes/OTA.py', function heartbeat
2019-10-02 15:16:18.564 Error: (ZigBee devices) 'onHeartbeat' failed 'KeyError'.
2019-10-02 15:16:18.564 Error: (ZigBee devices) ----> Line 828 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:18.564 Error: (ZigBee devices) ----> Line 696 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:18.564 Error: (ZigBee devices) ----> Line 580 in '/usr/local/domoticz/var/plugins/Zigate/Classes/OTA.py', function heartbeat
2019-10-02 15:16:23.022 (ZWave devices) Light/Switch (Eethoek motion sensor)
2019-10-02 15:16:23.024 (ZWave devices) General/Alarm (Alarm Type: Home Security 7 (0x07))
2019-10-02 15:16:23.028 (ZWave devices) Light/Switch (Eethoek sensor home security)
2019-10-02 15:16:23.019 Status: OpenZWave: Alarm received (Home Security: Clear), NodeID: 2 (0x02)
2019-10-02 15:16:23.575 Error: (ZigBee devices) 'onHeartbeat' failed 'KeyError'.
2019-10-02 15:16:23.575 Error: (ZigBee devices) ----> Line 828 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:23.575 Error: (ZigBee devices) ----> Line 696 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:23.575 Error: (ZigBee devices) ----> Line 580 in '/usr/local/domoticz/var/plugins/Zigate/Classes/OTA.py', function heartbeat
2019-10-02 15:16:28.584 Error: (ZigBee devices) 'onHeartbeat' failed 'KeyError'.
2019-10-02 15:16:28.585 Error: (ZigBee devices) ----> Line 828 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:28.585 Error: (ZigBee devices) ----> Line 696 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:28.585 Error: (ZigBee devices) ----> Line 580 in '/usr/local/domoticz/var/plugins/Zigate/Classes/OTA.py', function heartbeat
2019-10-02 15:16:33.595 Error: (ZigBee devices) 'onHeartbeat' failed 'KeyError'.
2019-10-02 15:16:33.595 Error: (ZigBee devices) ----> Line 828 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:33.595 Error: (ZigBee devices) ----> Line 696 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:33.596 Error: (ZigBee devices) ----> Line 580 in '/usr/local/domoticz/var/plugins/Zigate/Classes/OTA.py', function heartbeat
2019-10-02 15:16:38.606 Error: (ZigBee devices) 'onHeartbeat' failed 'KeyError'.
2019-10-02 15:16:38.606 Error: (ZigBee devices) ----> Line 828 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:38.607 Error: (ZigBee devices) ----> Line 696 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:38.607 Error: (ZigBee devices) ----> Line 580 in '/usr/local/domoticz/var/plugins/Zigate/Classes/OTA.py', function heartbeat
2019-10-02 15:16:43.567 Error: (ZigBee devices) 'onHeartbeat' failed 'KeyError'.
2019-10-02 15:16:43.567 Error: (ZigBee devices) ----> Line 828 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:43.567 Error: (ZigBee devices) ----> Line 696 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:43.567 Error: (ZigBee devices) ----> Line 580 in '/usr/local/domoticz/var/plugins/Zigate/Classes/OTA.py', function heartbeat
2019-10-02 15:16:48.577 Error: (ZigBee devices) 'onHeartbeat' failed 'KeyError'.
2019-10-02 15:16:48.577 Error: (ZigBee devices) ----> Line 828 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:48.577 Error: (ZigBee devices) ----> Line 696 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:48.577 Error: (ZigBee devices) ----> Line 580 in '/usr/local/domoticz/var/plugins/Zigate/Classes/OTA.py', function heartbeat
2019-10-02 15:16:53.243 (ZWave devices) Light/Switch (Eethoek motion sensor)
2019-10-02 15:16:53.246 (ZWave devices) General/Alarm (Alarm Type: Home Security 7 (0x07))
2019-10-02 15:16:53.250 (ZWave devices) Light/Switch (Eethoek sensor home security)
2019-10-02 15:16:53.240 Status: OpenZWave: Alarm received (Home Security: Motion Detected at Unknown Location), NodeID: 2 (0x02)
2019-10-02 15:16:53.588 Error: (ZigBee devices) 'onHeartbeat' failed 'KeyError'.
2019-10-02 15:16:53.588 Error: (ZigBee devices) ----> Line 828 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:53.588 Error: (ZigBee devices) ----> Line 696 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:53.588 Error: (ZigBee devices) ----> Line 580 in '/usr/local/domoticz/var/plugins/Zigate/Classes/OTA.py', function heartbeat
2019-10-02 15:16:58.598 Error: (ZigBee devices) 'onHeartbeat' failed 'KeyError'.
2019-10-02 15:16:58.598 Error: (ZigBee devices) ----> Line 828 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:58.599 Error: (ZigBee devices) ----> Line 696 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:16:58.599 Error: (ZigBee devices) ----> Line 580 in '/usr/local/domoticz/var/plugins/Zigate/Classes/OTA.py', function heartbeat
2019-10-02 15:17:03.610 Error: (ZigBee devices) 'onHeartbeat' failed 'KeyError'.
2019-10-02 15:17:03.610 Error: (ZigBee devices) ----> Line 828 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:17:03.610 Error: (ZigBee devices) ----> Line 696 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:17:03.610 Error: (ZigBee devices) ----> Line 580 in '/usr/local/domoticz/var/plugins/Zigate/Classes/OTA.py', function heartbeat
2019-10-02 15:17:08.570 Error: (ZigBee devices) 'onHeartbeat' failed 'KeyError'.
2019-10-02 15:17:08.571 Error: (ZigBee devices) ----> Line 828 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:17:08.571 Error: (ZigBee devices) ----> Line 696 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:17:08.571 Error: (ZigBee devices) ----> Line 580 in '/usr/local/domoticz/var/plugins/Zigate/Classes/OTA.py', function heartbeat
2019-10-02 15:17:13.580 Error: (ZigBee devices) 'onHeartbeat' failed 'KeyError'.
2019-10-02 15:17:13.581 Error: (ZigBee devices) ----> Line 828 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:17:13.581 Error: (ZigBee devices) ----> Line 696 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:17:13.581 Error: (ZigBee devices) ----> Line 580 in '/usr/local/domoticz/var/plugins/Zigate/Classes/OTA.py', function heartbeat
2019-10-02 15:17:18.591 Error: (ZigBee devices) 'onHeartbeat' failed 'KeyError'.
2019-10-02 15:17:18.591 Error: (ZigBee devices) ----> Line 828 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:17:18.591 Error: (ZigBee devices) ----> Line 696 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
2019-10-02 15:17:18.591 Error: (ZigBee devices) ----> Line 580 in '/usr/local/domoticz/var/plugins/Zigate/Classes/OTA.py', function heartbeat
2019-10-02 15:17:23.602 Error: (ZigBee devices) 'onHeartbeat' failed 'KeyError'.
2019-10-02 15:17:23.602 Error: (ZigBee devices) ----> Line 828 in '/usr/local/domoticz/var/plugins/Zigate/plugin.py', function onHeartbeat
pipiche
Post by pipiche »
OedzesG wrote: Wednesday 02 October 2019 15:14
You have to enable Advanced mode in the Web Admin page , and you'll get access to Polling frequency adjustment. Please do consider that increasing the frequency will impact the load on the Zigate and could generate some latency on ad-hoc commands.
If you use Group Commands , the polling doesn't need to be change as there are some trick done on the plugin side to trigger an immediate poll
https://github.com/pipiche38/Domoticz-Zigate/issues/476
