[REQUEST] Plugin for Tuya
Re: [REQUEST] Plugin for Tuya
I'm trying to configure a teckin sp22 plug but I get this message:
pi@domoticz:~/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin $ ./get_dps.py 192.168.0.171 60417563840d8e68fe98
Unexpected status() payload=b'3.3\x00\x00\x00\x00\x00\x00\x9d\xa4\x00\x00\x00\x01N\xcc\x8f\xb0>@,B=\xbe\xe9 \xcf\xd2\x8f\\M\xce\xd4)U\xbe\xdb#x\x8dIF_\xd989\xc6\xd7x\x90\x00\xa8\xfa\xaf\x7f\xfb\xb0\x9a(\xf3\xa0\xb5\xad\x82\xd6\x06-\xa6)M\xcb\xffL\xf1u\x0cm\xf5\n\xeb\x8d\x94F\xd0\x8a\x9a\x1b\\^\xd2\x02\xe1\r\xea\xb1r\x08\x12}\xa0\xe5y3\xe9P\x07\x8f\xa5\xc0\xc3'
Plug State Information:
Plug DPS List:
File "./get_dps.py", line 58, in <module>
for key in data['dps'].keys():
TypeError: byte indices must be integers or slices, not str
I've got some more configured(not this model) and not had had any problems
Any suggest ?
Plug DPS List:
Any suggest ?
My understanding is that the tuya devices ( sensors ) or zigbee compliant and have been tested on Zigate.
Wiki is available here.
Zigbee for Domoticz FAQ
No, these are not zigbee.
It seems as the output was different from what it expected.
Indeed , you are right plug and bulb are not zigbeetete wrote:No, these are not zigbee.
And some more time later ...
I've solved the mistery.
I was working with pytuya 7.0.3, but now I've seen that there is a 7.0.4 that includes support for 3.3 protocol while the previous one was just for 3.1.
Now, using that pytuya and adding a device.set_version(3.3) in the get_dps.py just before the device.status call it seems to work fine
Now I'll try the plugin, but the right solution would be to include this option as a parameter in Domoticz.
- Spoiler: show
merlot wrote: ↑Sunday 16 June 2019 10:51 Simw time later ...
I have returned the previous smart plug and I've bought a new one, a double one for 16A.
And I'm having the same problems
So, let's start form the begining.
Is a packet like the one below correct to get the devId and localkey?
Is this a packet that belongs to a tuya device that can be used by this plugin?
Thank you very much indeed
Plugin for a SMA Sunny Boy 1.5 https://github.com/merlot-dev/Domoticz-SMA-SunnyBoy
- sincze
- Domoticz version: 2024.4
We could look into that integration indeed with a dropdown box 3.1 / 3.3 for now ?merlot wrote: ↑Sunday 04 August 2019 16:29 And some more time later ...
Now I have modified my copy of tixi_sincze plugin to set the protocol of my devices to 3.3.
- Spoiler: show
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Will you do? Or are you asking me to do it? I can try, but I'm a newbie in git and I'm not sure how to contribute.
Anyway, after solving this issue, now, with the tixi_sincze plugin, after adding a dual plug, I get this error
- Spoiler: show
And in devices, this is what I get
2 Usage in W, the Voltage =0 (although get_dps_py returns 2325 for the ID=20) and not the second switch
have I configured something wrong in the parameters?
Thank you
payload=b'3.3 indicates your device is using protocol 3.3. So, which version of pytuya are you using? You need 7.0.4tete wrote: ↑Sunday 28 July 2019 19:30 I'm trying to configure a teckin sp22 plug but I get this message:
Plug DPS List:
Any suggest ?
I answer myself. The problem for a dual socket plug is in this codemerlot wrote: ↑Sunday 04 August 2019 23:15Will you do? Or are you asking me to do it? I can try, but I'm a newbie in git and I'm not sure how to contribute.
I have set DPS=1;2 and ID Amp;Watt;Volt =18;19;20 (I've got the ID's from Packet capture)
- Spoiler: show
Thank you
- Spoiler: show
It should be something like this
- Spoiler: show
Thank you
merlot wrote: ↑Sunday 04 August 2019 23:17payload=b'3.3 indicates your device is using protocol 3.3. So, which version of pytuya are you using? You need 7.0.4tete wrote: ↑Sunday 28 July 2019 19:30 I'm trying to configure a teckin sp22 plug but I get this message:
Plug DPS List:
Any suggest ?
Hi merlot,
I don't know what version I am using. How can I find out the version? How can I update it?
sudo pip3 show pytuya
Unfortunately, I couldnn't upgrade using the --upgrade option in pip3 and I had to copy/paste the __init from the project git site.
I ran this command but nothing appears, but I have installed it during the plugin installation (git clone https://github.com/clach04/python-tuya.git)
If I run the test.py file of the pytuya installation, I get this output
pi@domoticz:~/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin/python-tuya $ ./tests.py
INFO:pytuya:pytuya version 7.0.4
INFO:pytuya:Python 3.5.3 (default, Sep 27 2018, 17:25:39)
[GCC 6.3.0 20170516] on linux
INFO:pytuya:Using PyCrypto (2, 6, 1, 'final', 0)
INFO:pytuya:Using PyCrypto from '/home/pi/.local/lib/python3.5/site-packages/Crypto/__init__.py'
Then you can add device.set_version(3.3) in the get_dps.py after creating the device and the get_dps.py should worktete wrote: ↑Monday 05 August 2019 11:51
Sorry, could you tell me how to do it?merlot wrote: ↑Monday 05 August 2019 12:31Then you can add device.set_version(3.3) in the get_dps.py after creating the device and the get_dps.py should worktete wrote: ↑Monday 05 August 2019 11:51
Thanks in advance.
@sincze I have modified the code and requested a pull in github.merlot wrote: ↑Monday 05 August 2019 0:02
If in the dps_ide_list I have 1 and 2, as it's my case, in the first loop it tries to create Unit 1 to 5, and in the second one 2 to 6.
- Spoiler: show
It should be something like thisI think that the else statment for the group should also be corrected, but I'm setting to None, so I don't mind
- Spoiler: show
Thank you
This afternoon I'll try to create a new params (Port or SerialPort) to select 3.1 or 3.3 protocol.
Anyway, I think the plugin is not working for 3.3 (I get no data in the devices) and I think that it's because the plugin is not using the pytuya methods to get the status
I've added the line in the get_dps.py and it doesn't works.merlot wrote: ↑Monday 05 August 2019 12:31Then you can add device.set_version(3.3) in the get_dps.py after creating the device and the get_dps.py should worktete wrote: ↑Monday 05 August 2019 11:51
pi@domoticz:~/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin $ sudo ./get_dps.py 192.168.0.171 60417563840d8e68fe98
File "./get_dps.py", line 49, in <module>
data = device.status()
File "/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlugMaster-Plugin/pytuya/__init__.py", line 279, in status
payload = self.generate_payload('status')
File "/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlugMaster-Plugin/pytuya/__init__.py", line 219, in generate_payload
json_payload = self.cipher.encrypt(json_payload, False)
File "/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlugMaster-Plugin/pytuya/__init__.py", line 64, in encrypt
cipher = AES.new(self.key, mode=AES.MODE_ECB)
File "/usr/lib/python3/dist-packages/Crypto/Cipher/AES.py", line 94, in new
return AESCipher(key, *args, **kwargs)
File "/usr/lib/python3/dist-packages/Crypto/Cipher/AES.py", line 59, in __init__
blockalgo.BlockAlgo.__init__(self, _AES, key, *args, **kwargs)
File "/usr/lib/python3/dist-packages/Crypto/Cipher/blockalgo.py", line 141, in __init__
self._cipher = factory.new(key, *args, **kwargs)
ValueError: Key cannot be the null string
Yesterday, before introducing the version param, I tried to get it working by replicating the pytuya code for 3.3 protocol to extract_status, but without success.merlot wrote: ↑Monday 05 August 2019 13:37
I don't know the reason why the plugin was developed using connection and onMessage strategy, but I'll try a different approach: just using the self.__device.send_receive method when sending a command, in the onCommand cal, and self.__device.status() to get the status on each hearbeat. In the get_dps.py it works this status() method, so I hope it also does in the plugin, and it seems to me a cleaner solution, or at least simpler.
I'll keep you informed
Thank you
Got it
The only problem is that I get this error after switching on or off the plug. But it is turned on or off
The code in my pytuya-device branch
https://github.com/merlot-dev/Domoticz- ... uya-device
- Spoiler: show
My modified plugin works fine, with the mentioned errors, for multisocket plug
Some weird problems
You can see that V*A != W. But I have observed that I get the same values in Smart Life app. It's like the W is calculated for 110V not the real one. So, perhaps I'll modify to set the W as a calculation, not from the corresponding DPS.
If I plug something it takes much time (5 or more minutes) to get the right information. I haven't tried with the Smart Life app, but the get_dps.py gets the same zero values for A and W DPS
Comments are welcome
Some weird problems
Bon dia Merlot,merlot wrote: ↑Wednesday 07 August 2019 19:24 Got it
I'll keep investigating, but any suggestion is welcome
- Spoiler: show
I have tested your code and I receive the same error as before.
I am doing something wrong ?
pi@domoticz:~/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin-pytuya-device $ ./get_dps.py 192.168.0.171 60417563840d8e68fe98
File "./get_dps.py", line 51, in <module>
File "/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin-pytuya-device/pytuya/__init__.py", line 279, in status
File "/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin-pytuya-device/pytuya/__init__.py", line 219, in generate_payload
File "/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin-pytuya-device/pytuya/__init__.py", line 64, in encrypt
File "/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin-pytuya-device/Crypto/Cipher/AES.py", line 95, in new
File "/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin-pytuya-device/Crypto/Cipher/AES.py", line 59, in __init__
File "/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin-pytuya-device/Crypto/Cipher/blockalgo.py", line 141, in __init__
