At home, I have a Windows7 VM that controls my domoticz installation. Also I have a RFXCOM 433E controller, which controlls my Somy sunscreen. I am looking to automate the sunscreen according to the weather.
Is this Cresta a good device to controll my sunscreen? I have DarkSky running, but it is not always accurate.
Thanks in advance.
https://www.weerstationkopen.nl/accesso ... kan-sensor
Sunscreen tempature and humidity
niki_lauda
Re: Sunscreen tempature and humidity
I use darksky with Somfy and I find it accurate enough. Most important for me is the wind I als use multiple cresta's but for the Somfy Darksky is accurate enough.coppess wrote: Tuesday 11 June 2019 12:23 Hi all,
Thanks in advance.
- EdwinK
- Domoticz version: BETA
This is what I found at Conrad.nlcoppess wrote: Tuesday 11 June 2019 12:23 Hi all,
Thanks in advance.
Prima Thermo/Hygro Sensor voor Domoticz
Ik heb deze Thermo/Hygro Sensor aangeschaft voor gebruik in Domoticz met RFXCOM. Sensor werd zonder problemen gedetecteerd. Er gaan er zeker een aantal meer komen. Prijs naar mijn mening wel redelijk aan de hoge kant.
- EdwinK
Bought one last week, but can't get it to work in Domoticz
Maybe I need to change some settings in RFXcom
Some more info found on the Dutch Conrad site:
Packettype = TEMP_HUM subtype = TH7 - Cresta, TFA TS34C
Edit: Found out you need to select Hideki in the 'set mode' menu for the RFXcom transceiver.
For some reason, my notifications don't always seem to work. I'm going to buy that version to see if it works for me!
