need a loop for reading messages for logging  [Solved]
pvklink
Domoticz version: latest b
Post by pvklink »
Hi, i made one script for all my timers and groups with dzvents, so no domoticz timers and groups..
after a manual event or a timed event groups of switches are executed and switches for my dayly cycle (sun op, wake up breakf, etc are put to on-off.. works very nice!
i also made my own logging, not for errors and sensor info, only clear results..
With these rules i can log to domoticz and to my own logging...
for each group of devices: msgtxt = 'LAATSTE SCENES gereset ...'
and at the end of my script:
dz.log('Script: ' .. info.scriptName .. ', device: ' .. item.name .. ' ' .. msgtxt, dz.LOG_INFO)
timertekst = dz.time.rawDate .. ' ' .. dz.time.rawTime .. ' : ' .. msgtxt .. '<br>' .. dz.devices('timerlog').text
dz.devices('timerlog').updateText(timertekst)
Question
In the script below there can be executed more then one scenes/groups.. so my msgtxt is overwritten and only the last one is executed in the log
So i need:
- an array for setting msgtxt
- and a construct that reads all defined msgtxt(1-n) (see the end of my script)
Can somebody give a hand? Script is working more than fine! almost finished
-- dit script draait bij avond slapen, zon op, ontbijten, van huis, thuis en opstaan, uit huis thuis
local OnTimer1      = '15 minutes before sunset on mon,tue,wed,thu,fri,sat,sun'         -- HUIS SFEERVERLICHTING AAN
local OnTimer2      = '15 minutes after sunset on mon,tue,wed,thu,fri,sat,sun'          -- TUIN SFEERVERLICHTING AAN
local OffTimer1     = 'at 23:00 on mon,tue,wed,thu,sun'                                 -- EINDE AVOND ALLES UIT DOOR DE WEEK
local OffTimer2     = 'at 23:45 on fri,sat'                                             -- EINDE AVOND ALLES UIT IN HET WEEKEND
local OnTimer3      = 'at 23:05 on mon,tue,wed,thu,sun'                                 -- SLAPEN START door de week
local OnTimer4      = 'at 23:50 on fri,sat'                                             -- SLAPEN START in het weekend
local OffTimer3     = 'at 06:08 on mon,tue,thu,fri'                                     -- EINDE SLAPEN peter
local OffTimer4     = 'at 07:08 on mon,tue,wed,thu,fri'                                 -- EINDE SLAPEN MO
local OnTimer5      = 'at 06:10 on mon,tue,thu,fri'                                     -- OPSTAAN peter
local OnTimer6      = 'at 07:10 on mon,tue,wed,thu,fri'                                 -- OPSTAAN mo
local OffTimer5     = 'at 06:15 on mon,tue,thu,fri'                                     -- EINDE OPSTAAN peter
local OffTimer6     = 'at 07:25 on mon,tue,wed,thu,fri'                                 -- EINDE OPSTAAN mo
local OnTimer7      = '2 minutes after sunrise on mon,tue,wed,thu,fri,sat,sun'          -- ZON OP
local OffTimer7     = '2 minutes after sunset on mon,tue,wed,thu,fri,sat,sun'           -- ZON ONDER
local OnTimer8      = 'at 06:13 on mon,tue,thu,fri'                                     -- ONTBIJTEN AAN PETER
local OnTimer9      = 'at 07:20 on mon,tue,wed,thu,fri'                                 -- ONTBIJTEN AAN MO
local OnTimer10     = 'at 09:20 on sat,sun'                                             -- ONTBIJTEN AAN WEEKEND
local OffTimer8     = 'at 06:44 on mon,tue,thu,fri'                                     -- ONTBIJTEN UIT PETER
local OffTimer9     = 'at 08:00 on mon,tue,wed,thu,fri'                                 -- ONTBIJTEN UIT MO
local OffTimer10    = 'at 11:00 on sat,sun'                                             -- ONTBIJTEN UIT WEEKEND
    on = {  devices = {'Schakelgroepen','Jablotronenabled'},
            timer = {OnTimer1, OnTimer2, OnTimer3, OnTimer4, OnTimer5, OnTimer6, OnTimer7, OnTimer8, OnTimer9, OnTimer10, OffTimer1, OffTimer2, OffTimer3, OffTimer4, OffTimer5, OffTimer6, OffTimer7, OffTimer8, OffTimer9, OffTimer10}
    logging =   { level   = domoticz.LOG_DEBUG,
                  marker  = "Timers"},
    execute = function(dz,item,info)
    if (
        (item.isTimer and (item.trigger == OnTimer1))                                           -- START AVOND HUIS sfeerverlichting binnen
        or (item.isDevice and item.name == 'Schakelgroepen' and (item.state == 'Aan' or item.state == 'Sfeerverlichting binnen'))
        ) then
            --if (item.isTimer) then  dz.devices('Schakelgroepen').switchSelector(10)  end              -- weet niet of deze nodig is n keer remarken
            dz.devices('Opstaan').switchOff()
            dz.devices('Ontbijten').switchOff()
            dz.devices('Slapen').switchOff()
            dz.devices('Avond').switchOn()
            dz.devices('usb lamp').switchSelector(40)
            dz.devices('lantaarn').switchOn()
            dz.devices('Lamp dressoir links').switchOn()
            dz.devices('Lamp dressoir rechts').switchOn()
            dz.devices('Lamp tv links').switchOn()
            dz.devices('Lamp tv rechts').switchOn()
            msgtxt = 'Verlichting huis wordt AAN gezet...'
    if (
        (item.isTimer and (item.trigger == OnTimer2))                                           -- START AVOND TUIN sfeerverlichting buiten
        or (item.isDevice and item.name == 'Schakelgroepen'  and (item.state == 'Aan' or item.state == 'Sfeerverlichting tuin'))
        ) then
            --if (item.isTimer) then  dz.devices('Schakelgroepen').switchSelector(20)  end           -- weet niet of deze nodig is
            dz.devices('Achtertuin huis terraslamp').switchOn()
            dz.devices('Borderverlichting').switchOn()
            dz.devices('Achtertuin schuur bewegingslamp').switchOn()
            dz.devices('Voordeurlamp').switchOn()
            dz.devices('Buiten_led_kerstlantaarn').switchOn()
            msgtxt = 'Verlichting tuin wordt AAN gezet'
    if (
        (item.isTimer and dz.devices('Visite_disable_timers').state == 'Off' and (item.trigger == OffTimer1 or item.trigger == OffTimer2 ))    -- EINDE AVOND via timer of handmatig alles uit
        or (item.isDevice and item.name == 'Schakelgroepen'  and item.state == 'Uit')
        ) then
            --if (item.isTimer) then dz.devices('Schakelgroepen').switchSelector(0)   end   -- weet niet of deze nodig is
            dz.devices('Avond').switchOff()
            dz.devices('Achtertuin huis terraslamp').switchOff()
            dz.devices('Borderverlichting').switchOff()
            dz.devices('Achtertuin schuur bewegingslamp').switchOff()
            dz.devices('Voordeurlamp').switchOff()
            dz.devices('Buiten_led_kerstlantaarn').switchOff()
            dz.devices('usb lamp').switchSelector(0)
            dz.devices('lantaarn').switchOff()
            dz.devices('Lamp dressoir links').switchOff()
            dz.devices('Lamp dressoir rechts').switchOff()
            dz.devices('Lamp tv links').switchOff()
            dz.devices('Lamp tv rechts').switchOff()
            msgtxt = 'ALLE verlichting huis wordt UIT gezet'
    if (
        (item.isTimer and (item.trigger == OnTimer3 or item.trigger == OnTimer4))               -- START SLAPEN
        or (item.isDevice and item.name == 'Schakelgroepen'  and (item.state == 'Aan' or item.state == 'Slapen'))
        ) then
            --if (item.isTimer) then  dz.devices('Schakelgroepen').switchSelector(30)  end        -- weet niet of deze nodig is
            dz.devices('Slapen').switchOn()
            if item.isTimer and item.trigger == OnTimer3 then
                dz.devices('Bewegingsservice').switchOn().checkFirst().afterMin(70)
            elseif item.isTimer and item.trigger == OnTimer4 then
                dz.devices('Bewegingsservice').switchOn().checkFirst().afterMin(30)
            elseif item.isDevice and item.state == 'Slapen' then
            msgtxt = 'SLAPEN, nachtverlichting en bewegingsservice wordt AAN gezet...'
    if (
        (item.isTimer and (item.trigger == OffTimer3 or item.trigger == OffTimer4))    -- EINDE SLAPEN
            ) then
        msgtxt = 'SLAPEN voorbij ...'
    if (
        (item.isTimer and (item.trigger == OnTimer7))                                       -- ZON OP
        or (item.isDevice and item.name == 'Schakelgroepen'  and item.state == 'Zon op')                                       -- handmatig Zon op
        ) then
        --if (item.isTimer) then  dz.devices('Schakelgroepen').switchSelector(30)  end      -- niet nodig
            dz.devices('Zon op').switchOn()
            dz.devices('Zon onder').switchOff()
            -- ONTBIJT DEVICES Kunnen al aan staan evt uitzetten !!!
            msgtxt = 'ZON OP....'
    if (
        (item.isTimer and (item.trigger == OffTimer7))                                       -- ZON ONDER
        or (item.isDevice and item.name == 'Schakelgroepen'  and item.state == 'Zon onder')                                     -- handmatig Zon onder
        ) then
            dz.devices('Zon op').switchOff()
            dz.devices('Zon onder').switchOn()
            msgtxt = 'ZON ONDER....'
    if (
        (item.isTimer and (item.trigger == OnTimer5 or item.trigger == OnTimer6))           -- START OPSTAAN
        or (item.isDevice and item.name == 'Schakelgroepen'  and (item.state == 'Aan'  or item.state == 'Opstaan')) -- is nog niet gemaakt
        ) then
        --if (item.isTimer) then  dz.devices('Schakelgroepen').switchSelector(40)  end                 -- weet niet of deze nodig is
        dz.devices('Opstaan').switchOn()
	    if  dz.devices('Jablotronenabled').state == 'Unlocked' then                        -- huis is van alarm, er is iemand thuis
            dz.devices('Nachtlamp').switchOn()
            dz.devices('Bewegingsservice').switchOff().checkFirst()
            msgtxt = 'OPSTAAN wordt uitgevoerd, want er is iemand thuis....'
        elseif  dz.devices('Jablotronenabled').state == 'Locked' then                                -- huis op alarm, iedereen is weg, dus niets aanzetten
            msgtxt = 'OPSTAAN wordt niet uitgevoerd, want er is niemand thuis....'
    if (
        (item.isTimer and (item.trigger == OffTimer5 or item.trigger == OffTimer6))         -- EINDE OPSTAAN
    ) then
        --if (item.isTimer) then  dz.devices('Schakelgroepen').switchSelector(30)  end               -- niet nodig er is geen uit knop
            dz.devices('Nachtlamp').switchOff()
            msgtxt = 'OPSTAAN voorbij....'
    if (
        (item.isDevice and item.name == 'Schakelgroepen' and item.state == 'Uit huis')                                  -- UIT HUIS
        or (item.isDevice and item.name == 'Jablotronenabled' and item.state == 'Locked')                               -- op alarm
        ) then
            dz.devices('Opstaan').switchOff()                                           -- basisvoorziening UIT want er is niemand thuis
            dz.devices('Ontbijten').switchOff()                                         -- basisvoorziening UIT want er is niemand thuis
            dz.devices('Thuis').switchOff()                                             -- basisvoorziening UIT want er is niemand thuis
            dz.devices('Uit huis').switchOn()                                           -- basisvoorziening UIT want er is niemand thuis
            msgtxt = 'UIT HUIS, basisvoorzieningen uit, bewegingservice AAN...'
    if (
        (item.isDevice and item.name == 'Schakelgroepen' and item.state == 'Thuis')                                     -- THUIS
        or (item.isDevice and item.name == 'Jablotronenabled' and item.state == 'Unlocked')                                -- van alarm af
        ) then
            dz.devices('Uit huis').switchOff()                                          -- basisvoorziening UIT want er is niemand thuis
            dz.devices('Thuis').switchOn()                                              -- basisvoorziening UIT want er is niemand thuis
            msgtxt = 'THUIS, basisvoorzieningen aan, bewegingservice UIT...'
    if (
        (item.isTimer and (item.trigger == OnTimer5 or item.trigger == OnTimer6))       -- BASISVOORZIENING AAN  bij timer OPSTAAN
        or (item.isDevice and item.name == 'Schakelgroepen'  and (item.state == 'Basisvoorziening' or item.state == 'Opstaan' or item.state == 'Thuis'))      -- AANZETTEN bij handmatig BASISVOORZIENING, OPSTAAN en THUIS
        ) then
            dz.devices('boiler').switchOn()
            dz.devices('printer').switchOn()
            msgtxt = 'BASISVOORZIENING AAN...'
    if (
        (item.isTimer and (item.trigger == OnTimer1 or item.trigger == OnTimer2))       -- BASISVOORZIENING UIT bij einde avond
        or (item.isDevice and item.name == 'Schakelgroepen'  and (item.state == 'Uit' or item.state == 'Slapen' or item.state == 'Uit huis'))                  -- ACTIVEREN bij handmatig Uit, Slapen en Uit huis
        ) then
            dz.devices('boiler').switchOff()
            dz.devices('printer').switchOff()
    if (
        (item.isTimer and (item.trigger == OnTimer8 or item.trigger == OnTimer9 or item.trigger == OnTimer10))  -- START ONTBIJTEN
        or (item.isDevice and item.name == 'Schakelgroepen'  and (item.state == 'Aan'  or item.state == 'Ontbijten'))
        ) then
        dz.devices('Ontbijten').switchOn()
        	if dz.devices('Zon onder').state == 'On' then -- als de zon nog niet op is
                msgtxt = 'ONTBIJTEN wordt uitgevoerd, want er is iemand thuis en het is nog donker...'
                msgtxt = 'ONTBIJTEN wordt niet uitgevoerd, want de zon is op ....'
            msgtxt = 'ONTBIJTEN wordt niet uitgevoerd, want er is niemand thuis....'
    if (
        (item.isTimer and (item.trigger == OffTimer8 or item.trigger == OffTimer9 or item.trigger == OffTimer10))    -- EINDE ONTBIJTEN
            ) then
        msgtxt = 'ONTBIJTEN is afgelopen ...'
    if (
        (item.isDevice  and item.name == 'Schakelgroepen' and item.state == 'Uit')        -- RESET VAN DE LAATSTE SCENES BIJ handmatig UIT, rest is al gereset
            ) then
        if dz.time.isNightTime then                                                             -- als de zon nog niet op is
Jablotron connection, Ikea
pvklink
Re: need a loop for reading messages for logging
Post by pvklink »
Is this a better way to do it, see pvklog part of the global lua
dz.helpers.pvklog(dz, item, info, "dit is de booschap", 3) ?
only problem is that the scripts where i want to call this function use:
or execute = function(dz,device,info)
and these scripts are trigger by webhooks, variables, devices, timers and combinations of this...
Is this gonna work, i think the global helper needs all the info from the calling script, timer or device, or item etc.
return
    data =
        myGlobalVar = { initial = 12 }
    helpers =
        alertLidl = function(dz, action, period)
            local controlVar = dz.variables("controlVar")
            local value = controlVar.value
            if controlVar.value ~= action then
                controlVar.set(action)
                if period then
                    controlVar.set(value).afterSec(period)
                    dz.log("alert requested; controlVar set to " .. action .. ". It will return to ".. value .. " after " .. period .. " seconds." ,dz.LOG_FORCE)
                    dz.log("alert requested; controlVar set to " .. action  ,dz.LOG_FORCE)
                dz.log("No changed needed; controlVar is already set to " .. value,dz.LOG_DEBUG)
        end,
        pvklog = function(dz, item, info, msgtxt, loglevel)
        	if loglevel == 1 or loglevel > 2 then
		elseif loglevel == 2 or loglevel > 2 then
pvklink wrote: Friday 28 June 2019 18:33 In the script below there can be executed more then one scenes/groups.. so my msgtxt is overwritten and only the last one is executed in the log
So i need:
Please have a look at this one.
                  marker  = "Timers"},
        local messages = {}
        local function addMessage(message)
            local trigger =  item.isDevice and (", Device: " .. item.name ) or (", Timer: " .. item.trigger)
            messages[#messages + 1] = {}
            messages[#messages].log  = 'scriptname: ' .. info.scriptName .. trigger .. ' ' .. message
            messages[#messages].text = dz.time.rawDate .. '  ' .. dz.time.rawTime .. ' : ' .. message
        local function dumpMessages()
            local textDevice = dz.devices('timerlog')
            local currentText = textDevice.text
            local newText = currentText
            for i, record in ipairs(messages) do
                dz.log(record.log, dz.LOG_INFO)
                newText = record.text .. '<br>' .. newText
            if newText ~= currentText then
               textDevice.updateText(newText)
    if (
        ) then
            addMessage('Verlichting huis wordt AAN gezet...')
    if (
        ) then
            addMessage('Verlichting tuin wordt AAN gezet')
    if (
        ) then
            addMessage('ALLE verlichting huis wordt UIT gezet')
    if (
        ) then
            addMessage('SLAPEN, nachtverlichting en bewegingsservice wordt AAN gezet...')
    if (
            ) then
        addMessage('SLAPEN voorbij ...')
    if (
        ) then
            addMessage('ZON OP....')
    if (
        ) then
            addMessage('ZON ONDER....')
    if (
        ) then
            addMessage('OPSTAAN wordt uitgevoerd, want er is iemand thuis....')
            addMessage('OPSTAAN wordt niet uitgevoerd, want er is niemand thuis....')
    if (
    ) then
            addMessage('OPSTAAN voorbij....')
    if (
        ) then
            addMessage('UIT HUIS, basisvoorzieningen uit, bewegingservice AAN...')
    if (
        ) then
            addMessage('THUIS, basisvoorzieningen aan, bewegingservice UIT...')
    if (
        ) then
            addMessage('BASISVOORZIENING AAN...')
    if (
        ) then
    if (
        ) then
                addMessage('ONTBIJTEN wordt uitgevoerd, want er is iemand thuis en het is nog donker...')
                addMessage('ONTBIJTEN wordt niet uitgevoerd, want de zon is op ....')
            addMessage('ONTBIJTEN wordt niet uitgevoerd, want er is niemand thuis....')
    if (
            ) then
        addMessage('ONTBIJTEN is afgelopen ...')
    if (
            ) then
        addMessage('LAATSTE SCENES gereset ...')
    dumpMessages()
Please note that you need some kind of housekeeping to prevent your textdevice from overflowing.
pvklink wrote: Friday 28 June 2019 20:50 Is this a better way to do it, see pvklog part of the global lua
Only if you will be using the same method of logging from multiple scripts. Then it will be best to construct your complete messages in the original script and only send constructed message (and maybe target textdevice) to helper function.
pvklink
Post by pvklink »
ok!
learning more and more!
pvklink
Post by pvklink »
I gonna try all your tips..
i changed my global, and only use dz, msgtxt and loglevel
how do i seperate the helpers? by {} or bu , or ; ?
it does not work
dz.helpers.pvklog(dz, "dit is de booschap", 3) ....
return
    data =
    helpers =
                if period then
        pvklog = function(dz,msgtxt, loglevel)
		    dz.log(msgtxt, dz.LOG_INFO)
pvklink wrote: Friday 28 June 2019 21:56 i changed my global, and only use dz, msgtxt and loglevel
how do i separate the helpers? by {} or by , or ; ?
dz.helpers is a Lua table and a Lua table can contain values, variables, functions and ... tables
The contents of a Lua table can be separated by a , or a ;
so in an example global_data.lua
return
    data = { myGlobalVar = { initial = 100 }},
    helpers =
       MY_CONSTANT_STRING = "text"; -- call with dz.helpers.MY_CONSTANT_STRING
       MY_CONSTANT_NUMBER = 12; -- call with dz.helpers.MY_CONSTANT_NUMBER
       MY_CONSTANT_BOOLEAN = true, -- call with dz.helpers.MY_CONSTANT_BOOLEAN
       myVar = dz.globalData.myGlobalVar, -- call with dz.helpers.myVar
       myFunction1 = function(msg)  -- call with dz.helpers.myFunction1("test message") ==>> print test message
           print( tostring(msg) )
      end,
      myFunction2 = function(dz, myDeviceName)  -- call with dz.helpers.myFunction2(dz, item) ==>> returns true or false
           return dz.devices(myDeviceName).state == "On"
      end,
      t = {1,2,3,99,"a","b" , key = "master" }, -- call with dz.helpers.t[4] => returns 99,  dz.helpers.t[5] => returns a , dz.helpers.t.key => returns master
it does not work
You have to be a bit more descriptive than that :)
pvklink
Post by pvklink »
Your other solution works perfect! i also made a function to delete the log in the textfile..
Now i am trying to get the global_data solution to work...
pvklink
Post by pvklink »
Ok, i will be more specific !
I get an error
2019-06-29 07:37:13.211 Error: dzVents: Error: (2.4.23) An error occurred when calling event handler test
2019-06-29 07:37:13.211 Error: dzVents: Error: (2.4.23) ...e/pi/domoticz/scripts/dzVents/generated_scripts/test.lua:16: attempt to call field 'addMessages' (a nil value)
2
i like to use this concept in every script, so
1. put the message functions in global_data
first, trying myself, something like this:
return
    data =
    helpers =
                if period then
        end,
    addMessage = function(dz,item,info,message)
		return messages
    	end,
    dumpMessages = function(dz,info,messages)
2. and in the callng scripts something like this:
		devices = {
			'test'
	execute = function(dz, item, info)
    local messages = {}
        if item.state == 'On' then
            message = 'dit is een test1'
            messages = dz.helpers.addMessages(dz,item, info,'test1')
            message = 'dit is een test2'
            messages = dz.helpers.addMessages(dz,item,info,'test2')
        dz.helpers.dumpMessages(dz,info,messages)
pvklink wrote: Saturday 29 June 2019 7:02 2019-06-29 07:37:13.211 Error: dzVents: Error: (2.4.23) ...e/pi/domoticz/scripts/dzVents/generated_scripts/test.lua:16: attempt to call field 'addMessages' (a nil value)
Please have a look at this.
global_data.lua
return
    data =
    helpers =
                if period then
    end,
    addMessage =
        function(dz, item, info, message, messages)
            return messages
        end,
    dumpMessages =
        function(dz, messages)
            local lf = '<br>'
            local maxLines = 8
                newText = record.text .. lf .. newText
                lines = dz.utils.stringSplit(newText, lf)  -- create lines table from newText string
                newText = table.concat(lines, lf, 1, maxLines) -- recreate newText string from first maxLines
        end,
testScript
    on = { devices = { 'test' }},
        local messageTable = {}
        local add = 'add'
        local function globalMessage(action, message )
            if action == add then
                messageTable = dz.helpers.addMessage(dz, item, info, message, messageTable )
                dz.helpers.dumpMessages(dz, messageTable)
        message = item.name .. ' switched ' .. item.state
        globalMessage(add, message .. ' test-1')
        globalMessage(add, message .. ' test-2')
        globalMessage(add, message .. ' test-3')
        globalMessage() -- dump
code]
pvklink
Post by pvklink »
YESSSS , that works great!
Only my rules are not on one line and some leters are missing?
--local OnTimer5      = 'at 23:05 on mon,tue,wed,thu,fri,sat,sun'         -- test
                  marker  = "Timers"},
        local add = 'add'
    if (
        ) then
            globalMessage(add, message .. 'Verlichting huis wordt AAN gezet...')
    if (
        ) then
            globalMessage(add, message .. 'Verlichting tuin wordt AAN gezet')
    if (
        ) then
            globalMessage(add, message .. 'ALLE verlichting huis wordt UIT gezet')
    if (
        ) then
            globalMessage(add, message .. 'SLAPEN, nachtverlichting en bewegingsservice wordt AAN gezet...')
    if (
            ) then
            globalMessage(add, message .. 'SLAPEN voorbij ...')
    if (
        ) then
            globalMessage(add, message .. 'ZON OP....')
    if (
        ) then
            globalMessage(add, message .. 'ZON ONDER....')
    if (
        ) then
            globalMessage(add, message .. 'OPSTAAN wordt uitgevoerd, want er is iemand thuis....')
            globalMessage(add, message .. 'OPSTAAN wordt niet uitgevoerd, want er is niemand thuis....')
    if (
    ) then
            globalMessage(add, message .. 'OPSTAAN voorbij....')
    if (
        ) then
            globalMessage(add, message .. 'UIT HUIS, basisvoorzieningen uit, bewegingservice AAN...')
    if (
        ) then
            globalMessage(add, message .. 'THUIS, basisvoorzieningen aan, bewegingservice UIT...')
    if (
        ) then
            globalMessage(add, message .. 'BASISVOORZIENING AAN...')
    if (
        ) then
            globalMessage(add, message .. 'BASISVOORZIENING UIT...')
    if (
        ) then
                globalMessage(add, message .. 'ONTBIJTEN wordt uitgevoerd, want er is iemand thuis en het is nog donker...')
                globalMessage(add, message .. 'ONTBIJTEN wordt niet uitgevoerd, want de zon is op ....')
            globalMessage(add, message .. 'ONTBIJTEN wordt niet uitgevoerd, want er is niemand thuis....')
    if (
            ) then
        globalMessage(add, message .. 'ONTBIJTEN is afgelopen ...')
    if (
            ) then
        globalMessage(add, message .. 'LAATSTE SCENES gereset ...')
pvklink wrote: Saturday 29 June 2019 12:33 YESSSS , that works great!
OK please try and change
local lf = '<br>'
to
local lf = '\n'
pvklink
Post by pvklink »
that gives:
019-06-29 14:41:37.991 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-06-29 14:41:37.990 Error: dzVents: Error: (2.4.23) Timers: An error occurred when calling event handler DZ_schakelgroepen
2019-06-29 14:41:37.990 Error: dzVents: Error: (2.4.23) Timers: /home/pi/domoticz/scripts/dzVents/scripts/global_data.lua:51: invalid value (nil) at index 3 in table for 'concat'
pvklink
Post by pvklink »
When i remark those 2 lines in global_data.lua, the result is looking better..
--lines = dz.utils.stringSplit(newText, lf) -- create lines table from newText string
--newText = table.concat(lines, lf, 1, maxLines) -- recreate newText string from first maxLines
pvklink wrote: Saturday 29 June 2019 14:44 that gives:
can you try this one ?
return
    data =
    helpers =
                if period then
    end,
    addMessage =
            return messages
        end,
    dumpMessages =
            local lf = "\r\n"
            local maxLines = 8
            dz.log(newText, dz.LOG_INFO)
                newText = table.concat(lines, lf, 1, (math.min(maxLines,#lines))) -- recreate newText string from first maxLines
        end,
pvklink
Post by pvklink »
dit one is much better, uses the whole textswitch. Only an enter missing after a rule....
pvklink wrote: Sunday 30 June 2019 17:28 This one is much better, uses the whole textswitch. Only an enter missing after a rule....
I cannot reproduce this behavior. The helper function does add a CR/LF between the messages. What is the user interface theme where you see this ?
pvklink
Post by pvklink »
the default theme in dashtics
pvklink
Post by pvklink »
browser chrome
pvklink wrote: Sunday 30 June 2019 18:55 the default theme in dashtics
And what do you see in the device in the domoticz Gui ?
Could it be that dashticz behaves different on a LineFeed then domoticz does ?
