neo coolcam motion sensor with temp sensor, unknown in domoticz
ActionHenk
Post by ActionHenk »
I have 3 neo coolcam pir sensors PD01Z, they work oke and i can set any parameters in the open z-wave hardware settings tab in domoticz.
013 (0x0d) pir xxxx Neo CoolCam Battery Powered PIR Sensor Neo CoolCam 0x1083 0x0003 2018-04-14 21:32:45 Nee
003 (0x03) pir xxxx Neo CoolCam Battery Powered PIR Sensor Neo CoolCam 0x1083 0x0003 2018-04-14 22:34:15 Nee
002 (0x02) pir xxxx Neo CoolCam Battery Powered PIR Sensor Neo CoolCam 0x1083 0x0003 2018-04-14 22:39:07 Nee
Now i received 3 x neo coolcam pir sensors with temp sensor and it seems they are not fully regonized in latest stable build domoticz v3.8153. They work and they give me 7 devices in the device list. So thats oke, i get the motion, lux and temp sensors. But, i can't set any parameters in the open z-wave hardware settings tab in domoticz. The only thing i can set is the wakeup interval in seconds.
What do i need to do to make domoticz or the z-wave stick (Aeotec ZW090 Z-Stick Gen5 EU) regonize my new pir+temp motion sensors?
I readed about someone that said that later beta builds of domoticz do regonize newer z-wave products. But i want to stay at this stable build. Is their a way i can import the needed files from a beta domoticz build into my stable v3.8153 build? Thanks!!!
022 (0x16) pir xxxx Neo CoolCam Unknown: type=0003, id=108d Neo CoolCam 0x108d 0x0003 2018-04-14 15:38:42 Nee
021 (0x15) pir xxxx Neo CoolCam Unknown: type=0003, id=108d Neo CoolCam 0x108d 0x0003 2018-04-14 15:38:09 Nee
020 (0x14) pir xxxx Neo CoolCam Unknown: type=0003, id=108d Neo CoolCam 0x108d 0x0003 2018-04-14 22:34:25 Nee
the new pir temp settings
new pir.jpg (38.34 KiB) Viewed 5183 times
admin
Site Admin
Re: neo coolcam motion sensor with temp sensor, unknown in domoticz
Post by admin »
Try excluding, updating to the latest beta and include again
ActionHenk
oke, but then i have holes in my node ID's :D i'm a little autistic and last time i tried to exclude a node, i found out the hard way that the node id that is excluded isn't free. So as autistic as i am i wanted to fill up that hole and i hard resetted everything and included all sensors again. Luckely i found out that if i included all the sensors in the same order as they where before the hard reset, all the devices id's and name's and scenes in domotics where working again without changing anything!
Anyway, i have +- 200 sensors in my devices list and i am stable, so going to a beta release is a bit to much for me i guess. Isn't there a way to import certain files into the stable build?
Is there any sign of a new stable domoticz release? I'm new in this world and really love domoticz but it seems the recent stable build is out for a while?
Thanks for your answer!!
Siewert308SW
Domoticz version: Stable
Post by Siewert308SW »
Why not manual download the beta zip.
Take the Zwave "Config" folder and copy it into your existing Domoticz.
Restart Domoticz and it should be recognized...
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
ActionHenk
I would like that! But, all downloads are .tgz Linux files except for the windows version wich is a zip file but only has an .exe in it.
Can i install the windows version and take the zwave config folder? Or do i have to get the zwave config folder from a Linux/raspberry install? Thanks!
Siewert308SW
Why not unzipping the .tgz and copy those config files to your rpi?
There are tons of programs to unzip like 7zip
Setup:
- DS923+ Docker
ActionHenk
Oke i tried it, didnt work out :( also excluded and included a sensor.
I guess i have to wait till an new stable build comes out. By the way, i copied the zwave.me folder from the beta .tgz file to the config folder of my raspberry where i first deleted the original zwave.me folder.
tonbor
Post by tonbor »
ActionHenk wrote: Sunday 15 April 2018 23:54 Oke i tried it, didnt work out :( also excluded and included a sensor.
One year later, got the same problem, ozw 1.6 (same was with 1,4) parameters can not be changed. Did you mange to fix it?
tonbor
Post by tonbor »
Solved, openzwave has the wrong xml connected to this new version. As you can see to the index values they do not match the xml. https://www.cd-jackson.com/index.php/zw ... =openzwave. I altered this xml so it fits openzwave/ domoticz. <Product config="shenzen_neo/nas-pd03z.xml" id="108d" name="Battery Powered PIR Sensor PD03Z" type="0003"/> (sorry the same type and id as de former pir, helas……….)
tonbor
Post by tonbor »
nas-pd03z.xml
(3.97 KiB) Downloaded 189 times
tonbor
Post by tonbor »
tonbor
Post by tonbor »
tonbor
Post by tonbor »
this is the one….. magnetic attachment, there is this xml for
poudenes
Domoticz version: 3.8993
Post by poudenes »
I have same one. Work correct without any modifications.
tonbor
Post by tonbor »
Fine for you poudenes that you has nothing to change. We are not so lucky. Neo Cam changes the features of its objects without changing the type and id number. So you get stuck as you wandering why parameters will not change. I got a manual where disable blinking is at index 11 not 10 as in the xml. So if disable blinking can not be set, we go searching for another XML where blinking is definded at index 11. With a battery powered device which is mostly asleep it is difficult to trace what is going wrong...… any suggestions? What are your id and library where you have nothing to change?
Neo Coolcam PIR-2.jpg (281.51 KiB) Viewed 3909 times
20190702_155947 (Copy).jpg (120.83 KiB) Viewed 3909 times
poudenes
Post by poudenes »
I see, the blinking issue I have it also. Here also at 10 instead of 11...
Im not that techie to change the XML or add one...
renerene
Post by renerene »
Following. Same issue here: blinking can not be disabled
Please place step by step instructions how to change from parameter 10 to 11
poudenes
Post by poudenes »
renerene wrote:Following. Same issue here: blinking can not be disabled
https://www.domoticz.com/forum/viewtopic.php?t=28582
Remove node, change xml, restart domoticz and add node again.
Verzonden vanaf mijn iPhone met Tapatalk Pro
tonbor
Post by tonbor »
More Help Text.jpg (325.8 KiB) Viewed 3864 times
Same xml but more help text.
nas-pd02ze.xml
(6.35 KiB) Downloaded 130 times
poudenes
Post by poudenes »
tonbor wrote: Thursday 04 July 2019 9:18 More Help Text.jpg
Thanks for the XML. Did you also add this in Github to update it in the install?
