dzVents ping tool, yet another option  [Solved]
hoeby
Domoticz version: V2022.1
Post by hoeby »
I want to make my own dzVents ping tool.
Maybe there are some on the WWW, but i am having fun making things and think about it. And of course, trying to learn something out of it.
The scripts i started with, that works for 1 device.
But would like to have multi devices in the same script.
Tried it with this code. But somehow it doesn't take the IP address out of the list.
Is there somebody wo can help?
       devices = {'Samsung werk'
--                                Device name        IP-adres
        local devices_ping =  {
	                            ['Gateway']        = 'xxx.xxx.xxx.xxx',
        for _, node in pairs(devices_ping) do
            local ip = devices_ping[node]
            print(ip)
            --local ip = 'xxx.xxx.xxx.xxx'
            ping_success=""
            ping_success=os.execute('ping -c1 -w1 ' .. ip)
                if ping_success then
                    print("ping success ")
                    print("ping failed ")
Thin-client --> Docker Domoticz main environment
Pi3A+ --> Google home (GAssistPi)
Pi3B+ --> Docker (P1monitor, Domoticz test environment, Ubiquity controller)
Re: dzVents ping tool, yet another option
hoeby wrote: Wednesday 19 June 2019 22:41 ... tried it, but somehow it doesn't take the IP address out of the list.
Is there somebody who can help?
you can practice this type of constructs also on the CLI if you installed Lua on your PI
sudo apt install lua5.2
Have a look at this example of the 'in pairs' construct
#lua
Lua 5.2.4  Copyright (C) 1994-2015 Lua.org, PUC-Rio
 devices_ping =
>>   ['Gateway2'] = 'yyy.yyy.yyy.yyy',
>for  key, value in pairs(devices_ping) do
>>   print( key .. " ==>> " .. value)
>>end
Gateway ==>> xxx.xxx.xxx.xxx
Gateway2 ==>> yyy.yyy.yyy.yyy
Or use a Lua IDE on your desktop (ZeroBrane or another)
ZeroBrane IDE
ZeroBrane IDE
hoeby
Post by hoeby »
Thanks waaren, i will take a look at zerobrane.
I think i finished the script for now.
I am always open for options of changes
--[[Version: 19062001
Script works in dzVents --> timer.
With this script is it possible to to a ping to netwerk devices.
The script does 1 ping to each device, when the script is triggerd.
It doesn't do a continuous ping every second untill timeouts.
Setup the settings needed and/or wanted.
There is a line which says: -- Don't change things undernead this line
If you have no idea how the scripts works, please lissen to this.
If you know how it works and have ideas, please post them on http://www.domoticz.com/forum/viewtopic.php?f=59&t=28420
       --devices = {'trigger device'},
       --timer      = { "every 10 minutes" },
       timer        =  {'every minute'},
    data = { timeoutcount = { initial = {} } },
    execute = function(dz, device)
-- SETTINGS:
-- Setup the device and the IP-address which this device has.
-- When wanted to switch a (dummy) device with this script, be aware that the device name is exactly the same as your (dummy) device
	                            ['Dummy1']        = 'XXX.XXX.XXX.XXX',
	                            ['Dummy2']        = 'XXX.XXX.XXX.XXX',
	                            ['Dummy3']        = 'XXX.XXX.XXX.XXX',
-- How many timeouts, before a notification or switch off will be executed.
        local timeout = 10
-- This is the name which the notification starts with
        local notifyHead = 'Ping-tool'
-- Switch dummy device
-- When this is set to true, than the script will switch the pinged devices. Besure that the device is present in domoticz.
-- When you don't want to switch a device, set it to false.
-- When true, than at ping success the switch will be ON, when failed the switch will be OFF.
        local dummydev    = false
-- Telegram settings
-- Set true for sending telegram, set false for NOT sending telegram.
        local telegram    = false
-- Email settings (domoticz email settings have to be filled in)
-- Set true for sending email, set false for NOT sending email.
        local email       = false
        local mailaddress = '[email protected]'
        local timeoutcount    = dz.data.timeoutcount -- short reference
        for deviceName, ipaddr in pairs(devices_ping) do
            ping_success=""
            ping_success=os.execute('ping -c1 -w1 ' .. ipaddr)
                if timeoutcount[deviceName] == nil then
                    timeoutcount[deviceName] = 0
                    if timeoutcount[deviceName] == 0 then
                        print("ping "..deviceName.." success ")
                        print("ping "..deviceName.." success, device is back.")
                        timeoutcount[deviceName] = 0 -- reset the counter
                        if telegram then
                            dz.notify(notifyHead, notifyHead ..", ".. deviceName .." is back.",dz.PRIORITY_NORMAL,nil,nil,dz.NSS_TELEGRAM)
                        if email then
                            dz.email('Domoticz ping tool', '' ..notifyHead.. ', '.. deviceName .." is back.", ''..mailaddress..'')
                    if dummydev then
                        if dz.devices(deviceName).state == 'Off' then
                        dz.devices(deviceName).switchOn()
                    timeoutcount[deviceName] = timeoutcount[deviceName] + 1
                    print (deviceName .." ping ".. timeoutcount[deviceName] .." times failed.")
                if (timeoutcount[deviceName] == timeout) then
                    print (deviceName .." has " ..timeout.. " timeouts, this exceeds the timeout counter.")
                    if dummydev then
                        dz.devices(deviceName).switchOff()
                    if telegram then
                        dz.notify(notifyHead, notifyHead ..", ".. deviceName .." has " ..timeout.. " timeouts, this exceeds the timeout counter.",dz.PRIORITY_NORMAL,nil,nil,dz.NSS_TELEGRAM)
                    if email then
                        dz.email('Domoticz ping tool', '' ..notifyHead.. ', '.. deviceName .." has " ..timeout.. " timeouts, this exceeds the timeout counter.", ''..mailaddress..'')
hoeby wrote: Thursday 20 June 2019 20:13 I think i finished the script for now.
If you want to extent the script to use nmap (kind of ping to IP:PORT), you might want to have a look at this. I would implement it in a different way now but the basics are still usable
hoeby
Post by hoeby »
Sorry, i didn't know you already made a fantastic script :oops: .
I searched for ping tool in dzvents, but yours i didn't found.
Mine looks like a very very very basic copy of yours.
Will take a look at yours, could be that i copy it and replace mine.
Re: dzVents ping tool, yet another option  [Solved]
hoeby wrote: Thursday 20 June 2019 21:18 Sorry, i didn't know you already made a fantastic script :oops: .
Absolutely no need to be sorry. I completely agree with you that just the writing and learning how stuff works is a lot of fun. I only tried to encourage you !
hoeby
Post by hoeby »
new version, 2 thinks changed/added
Version 19062001 only switch the device ON / OFF when timeout was exceeded, but did this only once. Now on every fail after timeout setting it checks the status of your device, and set it back in sync, if needed.
For windows the ping script needs to be different.
This is added. But a manual action to activate or deactivated what you need
Port function not added. Not yet for now, but when it will, i don't know
--[[Version: 19062701
With this script it is possible to do a ping to multi netwerk devices.
       --devices = {'Trigger device'},
-- SETTINGS:
--	                            ['Dummy3']              = 'XXX.XXX.XXX.XXX',
        local timeout = 10
-- When this is set to true, than the script will switch the pinged devices. Besure that the device is pressent in domoticz.
        local dummydev    = true
        local email       = false
            ping_success=""
            ping_success=os.execute('ping -c1 -w1 ' .. ipaddr) -- For domoticz on Pi
--          ping_success=os.execute('ping ' ..ipaddr.. ' -w 100') -- For domoticz on Windows
                        print("ping "..deviceName.." succes ")
                        print("ping "..deviceName.." succes, device is back.")
                        if telegram then
                        if email then
                    if dummydev then
                elseif timeoutcount[deviceName] < timeout then
                    print ("ping ".. deviceName .." ".. timeoutcount[deviceName] .." times failed.")
                if timeoutcount[deviceName] >= timeout then
                    print ("ping ".. deviceName .." has " ..timeoutcount[deviceName].. " timeouts, this exceeds the timeout number setting.")
                    if dummydev then
                        if dz.devices(deviceName).state == 'On' then
                    if telegram then
                    if email then
History
19062701 - Changed dummydev, so it will be in sync with status.
         - Domoticz windows ping function added
19062001 - Start of scripts
