You may want to delete the plugin folder and reinstall from scratch ?Kender wrote: Friday 24 May 2019 11:15 I can't update![]()
git command give me: error: "cannot open .git/FETCH_HEAD: Permission denied"
Python plugin: UPS Monitor
Logread
Re: Python plugin: UPS Monitor
Kender
I solved downlading only the plugin.py from the web page of Git.
I can tell you that the versione 2.3 work prefectly !!
Thank you very much !
Dim33
I use version 0.2.3 of UPS monitor plugin with Domoticz 4.9701.
My UPS server is on NAS DS214+ DSM 6.2.2-24922.
Without user/mdp, I read in domoticz logs : "Error: (Onduleur) Error reading UPS variables: ERR ACCESS-DENIED"
With user/mdp (monuser/secret or xxxxx), I read in domoticz logs "Error: (Onduleur) Authentication error: ('ERR ACCESS-DENIED')"
An idea ? I don't see the problem.
Logread
Did you add the IP address of the domoticz host to the whitelist in DSM (UPS tab in config) ?Dim33 wrote: Wednesday 19 June 2019 0:36 Hello,
Dim33
YesLogread wrote: Wednesday 19 June 2019 7:39Did you add the IP address of the domoticz host to the whitelist in DSM (UPS tab in config) ?Dim33 wrote: Wednesday 19 June 2019 0:36 Hello,
Logread
@Dim33,
I cannot replicate the error you are seeing (I am running same version of DSM than yours, version 0.2.3 of the plugin and domoticz 4.10717 - the latest stable - on a Raspberry Pi). You may want to test using CLI NUT tools (upsc client if you are on linux) and see if you can connect ?
Dim33
Thanks Logread.
NUT Client is installed on my NUC (with Domoticz) and can't connect to UPS server.
Output of sudo upsc [email protected]
WinNUT is also installed on my PC and no problem !
Init SSL without certificate database
Error: Access denied
blackie
I consider to use this plugin, I have a local NUT installation on RPi->USB->APC UPS.
In my home the UPS comes onbattery maybe 2xday for 1-2s - short outages.
Can I use this plugin to get long-term statistics of such short outages or the plugin just reads the actual NUT data every 60s?
If not, I would like to use the local NUT server script triggered when outage occurres to update the UPS sensors. Can this be done somehow with the plugin sensors?
xavbzh
I try to use this plugin, but I don't manage.
Fresh installation of pi 3, latest raspios :
If anyone could help...
Latest domoticz stable release :root@raspberrypi:/# cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
The plugin is in the plugin directory, I restart domoticz, everything is OK. I add the hardware, UPS Monitor type, correct credentials, then the user interface crash. When I check the service :Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 13:47:55
dzVents Version: 3.0.2
Python Version: 3.7.3 (default, Jul 25 2020, 13:03:44) [GCC 8.3.0]
I delete the NUT plugin directory then restart domoticz, it's OK. In the log :root@raspberrypi:/usr/domoticz/plugins/NUT_UPS# /etc/init.d/domoticz.sh status
● domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; generated)
Active: active (exited) since Sun 2020-11-15 20:56:53 CET; 6s ago
Docs: man:systemd-sysv-generator(8)
Process: 25177 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
nov. 15 20:56:53 raspberrypi systemd[1]: Starting LSB: Home Automation System...
nov. 15 20:56:53 raspberrypi domoticz.sh[25177]: 2020-11-15 20:56:53.754 Status: Domoticz V2020.2 (c)2012-20…izMoCuz
nov. 15 20:56:53 raspberrypi domoticz.sh[25177]: 2020-11-15 20:56:53.754 Status: Build Hash: b63341bc0, Date…3:47:55
nov. 15 20:56:53 raspberrypi domoticz.sh[25177]: 2020-11-15 20:56:53.754 Status: Startup Path: /usr/domoticz/
nov. 15 20:56:53 raspberrypi domoticz.sh[25177]: domoticz: Domoticz is starting up....
nov. 15 20:56:53 raspberrypi domoticz[25183]: Domoticz is starting up....
nov. 15 20:56:53 raspberrypi domoticz[25184]: Domoticz running...
nov. 15 20:56:53 raspberrypi systemd[1]: Started LSB: Home Automation System.
Hint: Some lines were ellipsized, use -l to show in full.
After an alternative python3.4 install, I tried to modify this path adding in the plugin.py :2020-11-15 20:57:38.198 Error: (NUT_UPS) failed to load 'plugin.py', Python Path used was ':/usr/lib/python37.zip:/usr/lib/python3.7:/usr/lib/python3.7/lib-dynload:/usr/local/lib/python3.7/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.7/dist-packages'.
2020-11-15 20:57:38.198 Error: (onduleur) Module Import failed, exception: 'ModuleNotFoundError'
2020-11-15 20:57:38.198 Error: (onduleur) Module Import failed: ' Name: plugin'
2020-11-15 20:57:38.198 Error: (onduleur) Error Line details not available.
No success... same error in log.import sys
sys.path.append('/usr/lib/python3.4')
Logread
@xavbzh,
Did you try other python plugins ? This looks to me as a python issue rather than a plugin issue... some search might help you as I think there are many posts on similar issues on the forum
ikkezelf
I had to install the python-dev for the hardware tot popup in the pull-down list.
I'm using a APC-UPS
it's working fine now, If I want to show more variables, I just have to edit the .py script ?
I'm using a APC-UPS
ikkezelf
expanding the plugin script succeeded.
However I have installed all on my slave pi. Now as I want to make the devices visible on the master pi, they don't seem to be adde as new devices on the master.
Any idea why these are not recognised as devices from the slave? (and yes I included them as available for the logged in user).
- Antori91
- Domoticz version: 4.10717
Hi,ikkezelf wrote: Wednesday 23 December 2020 18:43 Any idea why these are not recognised as devices from the slave? (and yes I included them as available for the logged in user).
It's a known issue. Domoticz feature for synchronization (Domoticz remote server) doesn't work for devices created and updated by a plugin. As you, I've installed this plugin on my backup server. To synchronize my main server, I use my own replication system (see viewtopic.php?f=38&t=24088)
Domoticz High Availability Cluster: Synology Dz V4.10693 (Main) - Raspberry Dz V4.10717 (Backup) - Scripts Node.js
Alarm server: Raspberry - motionEye - iot_ALARM-SVR Node.js
Sensors/Actuators: ESP8266-Arduino
https://github.com/Antori91/Home_Automation
ilex
Hi to All,
I succefully use UPS Monitor Plugin but there is one thing I would like to change which is the UPS runtime information from seconds to minutes.
Can anyone give ma a hint what to change in plugin.py file ?
BR.
BR.
- FireWizard
Hi, @ilex
You can change line 49, in plugin.py
You can change that to another value, but it has to be in seconds.
Currently the pollinterval = 60 seconds.(self.pollinterval = 60 #Time in seconds between two polls)
ilex
I am not sure if I have made myself clear.
I want in Domoticz the UPS runtime to be displayed in minutes (not in seconds as it is now)
blackie
I have installed this plugin to my RPi with Domoticz and local NUT installation.
In my home the UPS comes onbattery cca 2x per day for 1-2 seconds.
Seems the plugin is unable to detect these short power outages because plugin reads the actual UPS data every 60s.
I have an idea to use local NUT server script /usr/bin/upssched-cmd triggered after power status change to catch these short outages.
Can this python plugin be called somehow from upssched-cmd script to update Domoticz UPS sensors every time UPS status changes?
If i try to execute plugin manually from a shell i get an error:
root@OMV:/home/domoticz/plugins/NUT_UPS# python3 plugin.py
File "plugin.py", line 36, in <module>
import Domoticz
ModuleNotFoundError: No module named 'Domoticz'
Thanks in advance for help
import Domoticz
Kyrille
- Domoticz version: 2020.01
The plugin is working fine in my environment but I can't succeed in creating a notification for the Status.
When I set a condition for the value "ONBATTERY DISCHARGING" in order for Pushover to warn me about a power shutdown, nothing happen.
I noticed that when I come back to the corresponding notification, the field for Value is empty. It seems that my chain of characters was not accepted when creating it. I tried to put the text between " " but same (no) effect.
Any clue ?
Thank you in advance.
Envoyé de mon Pixel 4a en utilisant Tapatalk
Any clue ?
Raspberry Pi 4 (8GB) & 3B+ (buster) / Conbee II / Z-Stick Gen 5 / RFXCOM 433 XL / Domoticz 2020.02
Pi zero 2 ordered
Pi zero 2 ordered
nico21311
Hello
I have installed a fresh installation of Domoticz on the news debian bulleyes with python 3.9.2.
Domoticz works well. However when I installed the plugin NUT UPS or UPS monitor, Domoticz do not start.
According my investigation, the issue come form new python 3.9.2 and the script.
I am not enough skill to solved the issue.
I really appreciate if someone could help me.
Thanks in advance for your support
PieterS
- Domoticz version: 2024.7
For a while (maybe since running Domoticz in Docker??) I am not able to monitor my APC UPS which is connected by USB to my Synology. The error in the logfile: Error reading UPS variables: ERR ACCESS-DENIED
This is the (filtered) logfile:
In Docker I have installed the plugin as described in https://www.domoticz.com/wiki/Plugins/NUT_UPS.html
In the configuration of the container of Domoticz (V14369) I have a problem I cannot solve:
When I fill in port 3493 for the host I get an error because that port is in use by the host...
This is a part of the portsettings of the container of Domoticz in Docker:
So how to configure the software of Docker that port 3493 (which is used by the host) can talk to the plugin in Domoticz??
- Spoiler: show
Synology with Domoticz build (V2024.7) in Docker
Users browsing this forum: Xenomes and 1 guest
