P1 counter value math [Solved]
StefanWouters
I am new with LUA, normaly i program PLC (Siemens S7). is their an easy way to store several values temperarely? I have made a script that analyses the data of the energymeter. But as soon the command "end" passes the value in de global/local variable is nil.
I want to make some calculations with several values, after i get all the values (delivery en Usage)
I have tried Blockly, but blockly has no math operators.....
- waaren
Re: P1 counter value math
In Lua you will have to store your temp results in domoticz uservariables to preserve them until a next run. Using dzVents you can you use persistent data.StefanWouters wrote: Tuesday 18 June 2019 17:19 I am new with LUA. Is their an easy way to store several values temperarely? I have made a script that analyses the data of the energymeter. But as soon the command "end" passes the value in de global/local variable is nil.
dzVents is an easy to use API to domoticz. Written in- and on top of Lua.
If you are not yet familiar with dzVents then please look at the 10 lines using dzVents with Domoticz for an intro to dzVents.
StefanWouters
i have found several methods but something is going wrong..
trying to get 1 value stored...
- Nieuw tekstdocument.txt
- (2.54 KiB) Downloaded 54 times
- Knipsel.PNG (137.78 KiB) Viewed 1758 times
- waaren
This message is about dzVents recognize the situation that the script wants to put a table value in the sValue field of a device which would lead to a crash off domoticz. So dzvents will not allow this to happen.StefanWouters wrote: Thursday 20 June 2019 21:25 i have found several methods but something is going wrong..trying to get 1 value stored...
Please remove the -- from line 20.
The script will then produce some extra log lines which might make it easier to understand what is happening.
StefanWouters
Bij deze
2019-06-20 22:44:59.147 EventSystem: Event triggered: Script #6 stop eerste vrijgave_1
2019-06-20 22:44:59.021 Status: dzVents: Info: Handling events for: "Power", value: "24086340;17373198;3070180;6587818;748;0"
2019-06-20 22:44:59.021 Status: dzVents: Info: SME 0.1.6: ------ Start internal script: Script #1: Device: "Power (Slimmemeter)", Index: 1
2019-06-20 22:44:59.022 Status: dzVents: Debug: SME 0.1.6: Processing device-adapter for Test7: Counter device adapter
2019-06-20 22:44:59.023 Status: dzVents: Debug: SME 0.1.6: Gebruik laag = 24086340
2019-06-20 22:44:59.023 Status: dzVents: Debug: SME 0.1.6: Processing device-adapter for Test8: Counter device adapter
2019-06-20 22:44:59.023 Status: dzVents: Debug: SME 0.1.6: Gebruik hoog = 17373198
2019-06-20 22:44:59.024 Status: dzVents: Debug: SME 0.1.6: Processing device-adapter for Test9: Counter device adapter
2019-06-20 22:44:59.024 Status: dzVents: Debug: SME 0.1.6: Levering laag = 3070180
2019-06-20 22:44:59.025 Status: dzVents: Debug: SME 0.1.6: Processing device-adapter for Test10: Counter device adapter
2019-06-20 22:44:59.025 Status: dzVents: Debug: SME 0.1.6: Levering hoog = 6587818
2019-06-20 22:44:59.026 Status: dzVents: Debug: SME 0.1.6: Processing device-adapter for Test11: Counter device adapter
2019-06-20 22:44:59.026 Status: dzVents: Debug: SME 0.1.6: Actuele Gebruik = 748
2019-06-20 22:44:59.026 Status: dzVents: Debug: SME 0.1.6: Processing device-adapter for Test12: Counter device adapter
2019-06-20 22:44:59.027 Status: dzVents: Debug: SME 0.1.6: Actuele Levering = 0
2019-06-20 22:44:59.027 Status: dzVents: Debug: SME 0.1.6: Processing device-adapter for Uitgang 4: Switch device adapter
2019-06-20 22:44:59.027 Status: dzVents: Debug: SME 0.1.6: Constructed timed-command: Off
2019-06-20 22:44:59.028 Status: dzVents: Debug: SME 0.1.6: Processing device-adapter for Test14: Counter device adapter
2019-06-20 22:44:59.029 Status: dzVents: Info: SME 0.1.6: ------ Finished Script #1
2019-06-20 22:44:59.128 Status: Levering:
2019-06-20 22:44:59.128 Status: 0.0
2019-06-20 22:44:59.128 Status: Verbruik:
2019-06-20 22:44:59.128 Status: 224.0
2019-06-20 22:44:59.129 Status: 278.0
2019-06-20 22:44:59.129 Status: 246.0
2019-06-20 22:44:59.175 Status: Executing script: /home/pi/domoticz/scripts/uitgang2-uit
2019-06-20 22:44:59.028 Error: dzVents: Error: (2.4.23) SME 0.1.6: no updateCounter with value of type table allowed !!- waaren
OK.StefanWouters wrote: Thursday 20 June 2019 22:43 LogCode: Select all
2019-06-20 22:44:59.175 Status: Executing script: /home/pi/domoticz/scripts/uitgang2-uit 2019-06-20 22:44:59.028 Error: dzVents: Error: (2.4.23) SME 0.1.6: no updateCounter with value of type table allowed !!
53 domoticz.data.counter = domoticz.devices(idxcons).updateCounter(SMdata[5])
54 end
55
56 domoticz.devices (warmtevraag) .switchOff ().checkFirst()
57 domoticz.devices(test3).updateCounter(domoticz.data.counter)
In line 53 domoticz.data.counter is set as a table. In line 57 device 44 is updated with this table. This is not allowed and therefore the script will abort and no devices will be updated.
StefanWouters
I have Made soms tests in the script. I want to store some values, so that i can use them at the end of the script For some calculations. In want to know of their is power deliverd (> 1000W), or used. When their is enough delivery of power my energy system is going to heat up the boiler. When their is more power deliverd then (for example) 3000W the addition heating element wil be enabled.
- waaren
OK. To set the value of device test3 you should modify the lines toStefanWouters wrote: Friday 21 June 2019 18:33 I have Made soms tests in the script. I want to store some values, so that i can use them at the end of the script For some calculations. In want to know of their is power deliverd (> 1000W), or used. When their is enough delivery of power my energy system is going to heat up the boiler. When their is more power deliverd then (for example) 3000W the addition heating element wil be enabled.
domoticz.data.counter = SMdata[5]
domoticz.devices(warmtevraag).switchOff().checkFirst()
StefanWouters
that works!!
