Buienradar Weather Lookup Plugin
DosN
Re: Buienradar Weather Lookup Plugin
Did git pull . files where updated to latest version
Now i have no logging at domoticz . only that it is started ., then system hanging
gerbenvanasselt
- Domoticz version: Beta 4.1
Same for me, the last update gives no error in the domo-log but system (pi) is not accessible any more after a while and need a hard reboot.
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
Ewaldharmsen
What versions are you on?gerbenvanasselt wrote: Saturday 06 April 2019 15:10 Same for me, the last update gives no error in the domo-log but system (pi) is not accessible any more after a while and need a hard reboot.
I am on Domoticz 4.10548 and python 3.5.3 and here everything works perfectly
gerbenvanasselt
See above for version.gerbenvanasselt wrote:After updating the plugin i have the following error.
Running domo beta v.10572 with python version 3.5.3 rpi 3b.
Befere the update it worked well.
First did a git pull and the following error occured. Then I deleted the plugin from hardware tab and remove the plugin from the domo plugin folder. After that i did a git clone and installed the hardware again. But the same error occured.
2019-04-05 13:37:10.872 Error: (Buienradar) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/domoticz-buienradar/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload:/usr/local/lib/python3.5/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.5/dist-packages'.
2019-04-05 13:37:10.872 Error: (Buienradar) Module Import failed, exception: 'ImportError'
2019-04-05 13:37:10.872 Error: (Buienradar) Error Line details not available.
flyboarder
Thanks, that has solved the issue.Ewaldharmsen wrote: Thursday 04 April 2019 21:09can you update the plugin with git pull and try again?flyboarder wrote: Thursday 04 April 2019 20:38 I installed the plug-in following the steps on the git page. But after I add Buienrader on the hardware page I see the following error in the log:
2019-04-03 23:14:03.318 Error: (Buienradar) 'onStart' failed 'TypeError':'__init__() takes from 1 to 4 positional arguments but 5 were given'.
2019-04-03 23:14:03.318 Error: (Buienradar) ----> Line 152 in /home/pi/domoticz/plugins/domoticz-buienradar/plugin.py, function onStart
2019-04-03 23:14:03.318 Error: (Buienradar) ----> Line 120 in /home/pi/domoticz/plugins/domoticz-buienradar/plugin.py, function onStart
Does anyone has a clue what is going wrong here?
DosN
i run Domoticz v4.10602
gerbenvanasselt
After I have updated Domoticz to v4.10602. the problem with stalling seems to be solved. My pi 3b+ is running for a few days now without any problems.
Ewaldharmsen
Good to hear
htca
Hi I started from scratch last weekend. I got the following error in my log:
plugin.py is in the path indicated:
Domoticz Version: 4.9700
Buienradar Version: April 4
Python Version: 3.5.3
solved:
- changed to beta
- added executable permission to plugin.py
2019-04-14 20:53:55.457 Status: (Buienradar) Started.
2019-04-14 20:53:56.362 Error: (Buienradar) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/domoticz-buienradar/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2019-04-14 20:53:56.362 Error: (Buienradar) Module Import failed, exception: 'ImportError'
2019-04-14 20:53:56.363 Error: (Buienradar) Module Import failed: ' Name: requests'
2019-04-14 20:53:56.363 Error: (Buienradar) Error Line details not available.
2019-04-14 20:55:00.501 Error: Buienradar hardware (5) thread seems to have ended unexpectedlyCode: Select all
pi@raspberrypi:~/domoticz/plugins $ pwd
pi@raspberrypi:~/domoticz/plugins $ cd domoticz-buienradar/
pi@raspberrypi:~/domoticz/plugins/domoticz-buienradar $ ls
buienradar-logo.zip buienradar.xml ChangeLog.md LICENSE.md localtest_rf.py __pycache__ raintext.txt
buienradar.py buienradar.zip fakeDomoticz.py localtest.py plugin.py rainforecast.py ReadMe.md
solved:
- changed to beta
DosN
i also installed the plugin , but it is not working at all
the PI3B will crash .
at the logging in Domticz i see:
2019-04-01 18:39:25.780 Status: (Weersverwachting (Buienradar)) Started.
2019-04-01 18:40:38.962 Error: Weersverwachting (Buienradar) hardware (24) thread seems to have ended unexpectedly
2019-04-01 18:40:52.965 Error: Weersverwachting (Buienradar) hardware (24) thread seems to have ended unexpectedly
2019-04-01 18:41:06.968 Error: Motherboard sensors hardware (23) thread seems to have ended unexpectedly
2019-04-01 18:41:06.968 Error: Weersverwachting (Buienradar) hardware (24) thread seems to have ended unexpectedly
i already updated domoticz to the lates version, and updated buienradar plugin ,, nothing helped
cmartens75
After updating the Buienradar plugin, the following message is being displayed in the Domoticz log:
2019-04-24 21:48:13.331 Error: (Buienradar) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/domoticz-buienradar/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload:/usr/local/lib/python3.5/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.5/dist-packages'.
2019-04-24 21:48:13.331 Error: (Weer) Module Import failed, exception: 'ImportError'
2019-04-24 21:48:13.331 Error: (Weer) Module Import failed: ' Name: requests'
2019-04-24 21:48:13.331 Error: (Weer) Error Line details not available.
2019-04-24 21:49:18.584 Error: Weer hardware (11) thread seems to have ended unexpectedly
The buienradar plugin does not work anymore, also after a restart of the Raspberry. Does anybody know a solution for this issue?
Kind regards, Corne
Kind regards, Corne
coen17st
I recently installed the rain radar plugin and so I don't know if it would have worked therefore.
I also get the following:
Hopefully someone has or knows a fix for this
Domoticz: V4.9700
Python: 3.5.3
OS: Windows Server 2016
2019-04-25 07:52:11.288 Error: (Buienradar) failed to load 'plugin.py', Python Path used was 'C:\Program Files (x86)\Domoticz\plugins\buienradar\;C:\Program Files (x86)\Python35-32\python35.zip;C:\Program Files (x86)\Python35-32\Lib\;C:\Program Files (x86)\Python35-32\DLLs\;C:\Program Files (x86)\Domoticz'.
2019-04-25 07:52:11.288 Error: (Buienradar) Module Import failed, exception: 'ImportError'
2019-04-25 07:52:11.288 Error: (Buienradar) Module Import failed: ' Name: requests'
2019-04-25 07:52:11.289 Error: (Buienradar) Error Line details not available.Domoticz: V4.9700
Python: 3.5.3
Ewaldharmsen
you should install requests: sudo pip3 install requestscoen17st wrote: Thursday 25 April 2019 8:05 I recently installed the rain radar plugin and so I don't know if it would have worked therefore.
Hopefully someone has or knows a fix for thisCode: Select all
2019-04-25 07:52:11.288 Error: (Buienradar) failed to load 'plugin.py', Python Path used was 'C:\Program Files (x86)\Domoticz\plugins\buienradar\;C:\Program Files (x86)\Python35-32\python35.zip;C:\Program Files (x86)\Python35-32\Lib\;C:\Program Files (x86)\Python35-32\DLLs\;C:\Program Files (x86)\Domoticz'. 2019-04-25 07:52:11.288 Error: (Buienradar) Module Import failed, exception: 'ImportError' 2019-04-25 07:52:11.288 Error: (Buienradar) Module Import failed: ' Name: requests' 2019-04-25 07:52:11.289 Error: (Buienradar) Error Line details not available.
Domoticz: V4.9700
Python: 3.5.3
buitje
Same issue here installed the pip requests however still the same result
Any other suggestions or ideas?
pip 3 list:
2019-05-04 16:02:50.161 Error: (Buienradar) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/domoticz-buienradar/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2019-05-04 16:02:50.162 Error: (Buienradar) Module Import failed, exception: 'ImportError'
2019-05-04 16:02:50.162 Error: (Buienradar) Module Import failed: ' Name: requests'
2019-05-04 16:02:50.162 Error: (Buienradar) Error Line details not available.pip 3 list:
chardet (2.3.0)
requests (2.12.4)
SecretStorage (2.3.1)
buitje
Got it to work again by updating the python path by adding the following lines in the beginning of the plugin.py before the import requests call is made
import sys
sys.path.append('/usr/lib/python3/dist-packages')
- Ragdag
Having the same error when installing from Github:
Domoticz
Version: 4.10686
Build Hash: f7fc1571
Compile Date: 2019-05-04 13:17:04
dzVents Version: 2.4.18
Python Version: 3.5.3 (default, Sep 27 2018, 17:25:39) [GCC 6.3.0 20170516]
2019-05-04 17:11:53.173 Error: (Buienradar) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/domoticz-buienradar/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload:/usr/local/lib/python3.5/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.5/dist-packages'.
2019-05-04 17:11:53.173 Error: (BuienRadar) Module Import failed, exception: 'ImportError'
2019-05-04 17:11:53.174 Error: (BuienRadar) Module Import failed: ' Name: requests'
2019-05-04 17:11:53.174 Error: (BuienRadar) Error Line details not available.
Version: 4.10686
Roedii66
An additional install of:Ragdag wrote: Saturday 04 May 2019 17:14 Having the same error when installing from Github:
DomoticzCode: Select all
2019-05-04 17:11:53.173 Error: (Buienradar) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/domoticz-buienradar/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload:/usr/local/lib/python3.5/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.5/dist-packages'. 2019-05-04 17:11:53.173 Error: (BuienRadar) Module Import failed, exception: 'ImportError' 2019-05-04 17:11:53.174 Error: (BuienRadar) Module Import failed: ' Name: requests' 2019-05-04 17:11:53.174 Error: (BuienRadar) Error Line details not available.
Version: 4.10686
sudo apt-get install python3-pip
helped me out of these errors.
Good luck.
Derik
- Domoticz version: BETA
mmmRoedii66 wrote: Sunday 16 June 2019 13:19An additional install of:Ragdag wrote: Saturday 04 May 2019 17:14 Having the same error when installing from Github:
Version: 4.10686
Good luck.
This is not a apt-get install?
This give me a error:
pi@odroid:~$ sudo pip3 install requests
The directory '/home/pi/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/home/pi/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and own er of that directory. If executing pip with sudo, you may want sudo's -H flag.
Requirement already satisfied: requests in /usr/lib/python3/dist-packages
gerbenvanasselt
Hi there,
This week I tried installing the Buienradar plugin on a new sdcard with raspbian buster as OS. The domoticz runs with python v 3.7.3.
When I install the Buienradar plugin and add it in the hardware section. Domoticz stops working, even after a restart of Domo and and a reboot of my pi domoticz won't start. After deleting the plugin from the folder in domoticz it starting domoticz again. Could it be that the plugin is not suitable for python 3.7.3?
Are there other people who experience the same?
I hope there will be a solution, because I really enjoy my Buienradar plugin.
Thanks in advance!
Thanks in advance!
darkrain
The plugin system seems to not work with buster and the python 3.7.3.
I ran into the same issue with another plugin and then decided to go back to stretch and python 3.5.3.
There is also an issue with https at the moment, please see: https://www.domoticz.com/forum/viewtopi ... =6&t=28617 and some other topics.
