Batch file in windows environment.
All kinds of 'OS' scripts
PVerburg
Post by PVerburg »
I have been reading for days and am lost on what is supported under script:\\ in a windows environment.
can I call a batch file don't look like it, do I have to use lua to call cmd/batch.
Or is there no support under windows/dos OS.
I'm not strong in unix and run some dos only based sensors "watts clever" power meter so like to stay with windows at this stage.
Thanks,
Paul V.
Re: Batch file in windows environment.
PVerburg wrote: Sunday 09 June 2019 23:54 I have been reading for days and am lost on what is supported under script:\\ in a windows environment.
Yes you can. Do this from the On/Off actions fields and use something like
script://c:\users\<user name>\<bat name>.bat
C:\Users\XXXX>more ff.bat
timeout 8
echo hi > c:\users\XXXX\ff.txt
C:\Users\XXXX>more ff.txt
hi
C:\Users\XXXX>dir ff.txt
 Volume in drive C has no label.
 Volume Serial Number is FCAE-F424
 Directory of C:\Users\XXXX
10-06-2019  00:06                 5 ff.txt
               1 File(s)              5 bytes
               0 Dir(s)  40.349.782.016 bytes free
PVerburg
Post by PVerburg »
Thanks, that worked the problem was that the sound command won't work when called in a batch file like that.
will experiment with different options i'm sure i will find the cause.
