GoodWe Solar: get data from the new semsportal (lua script)
sandeman684
Re: GoodWe Solar: get data from the new semsportal (lua script)
Post by sandeman684 »
Flitske wrote: Wednesday 08 May 2019 7:51 I'm trying to get this working however i cannot get the curl command to work. I run windows 10 on my desktop and domoticz on a raspberry pi. Where do i put in the curl command? In de CMD on win 10 or in on the Raspberry Pi??
I think in Windows 10 you can run curl (https://stackoverflow.com/questions/950 ... on-windows) but it is probably better to do it on the RPi as domoticz will also use it from there. You should get the same response on both.
Marcjeok
Post by Marcjeok »
CrazyFrog wrote: Monday 22 April 2019 20:52 you have create your own sensor.
for hardware you have to create a virtual sensor from the type "Dummy (Does nothing, use for virtual switches only)".
then click on "Create Virtual Sensors", name the sensor "solar panels" and choose "sensor type" - "Electric (instant + counter)"
Do you have to create a new sensor or is it possible to use your existing "Goodwe solar inverter via Web API" idx-code?
CrazyFrog
Post by CrazyFrog »
you have to create your own sensor.
Marktap
Post by Marktap »
I have implemented this script without to much problems. The only thing i see after a couple of days is that the total value of monday is al wrong. It's not 19.2 kWh, but more around 8.8 kWh if i check it in the semsportal.
All of the other days are correct, i dont get it. Does anybody have an idea?
Kencirot
Post by Kencirot »
I experience the same issue as Marktap. The daily total of previous day is being used untill the currect day is higher for me.
I also notice when there is no power output I still get the last remain known output showing up (e.g 36Watts from 22:00h onwards till the morning).
Is there a way to set it to "0" when the solar system is offline?
Merlin1201
Post by Merlin1201 »
I have installed the script and it works great.
There is one error remaining:
2019-06-08 07:28:10.493 Error: EventSystem: Warning!, lua script Solar Panels has been running for more than 10 seconds
2019-06-08 07:36:10.126 Error: EventSystem: Warning!, lua script Solar Panels has been running for more than 10 seconds
2019-06-08 07:44:10.300 Error: EventSystem: Warning!, lua script Solar Panels has been running for more than 10 seconds
2019-06-08 07:48:10.291 Error: EventSystem: Warning!, lua script Solar Panels has been running for more than 10 seconds
2019-06-08 07:52:10.378 Error: EventSystem: Warning!, lua script Solar Panels has been running for more than 10 seconds
2019-06-08 08:00:10.419 Error: EventSystem: Warning!, lua script Solar Panels has been running for more than 10 seconds
i also try the upload to pvoutput script, but that needs some more work and my scripting is not that good.
https://www.domoticz.com/wiki/Upload_en ... o_PVoutput
sincze
Domoticz version: 2024.4
Post by sincze »
lua script works like a charm. Up and running in no time. Thank you so much.
As by default I always build the stuff in Pass2PHP (and have some sort of multi-threading). :D
I updated my Github.
https://github.com/sincze/Domoticz/blob ... Goodwe.php
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
Merlin1201
? so you make a php file from the Lua script?
sincze
Post by sincze »
Merlin1201 wrote: Sunday 09 June 2019 15:53 ? so you make a php file from the Lua script?
:lol:
Yes, basically I rewrote the whole thing in PHP. As all my scripts use PHP. (Pass2PHP user)
This for me has the following advantages:
- I can run it outside of Domoticz and not be scared of 'script has been running for more than 10 seconds ' clogging up my 850 devices and 10 (different branded) inverters.
- In addition I could build some additional failure checks. If the webserver is not available. :P
- It integrates in Pass2PHP
- It can be used for non Pass2PHP users.
However for the typical user I would go for the lua.
- It works fine.
- Easy to implement
I even have it running on my spare pi. :D
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Merlin1201
impressive, ia'm truck with copy and paste only.
pvdgulik
Domoticz version: 2023.1
Post by pvdgulik »
Also same problem.. Think of editing the database to correct..
Kencirot wrote: Wednesday 05 June 2019 14:56 I experience the same issue as Marktap. The daily total of previous day is being used untill the currect day is higher for me.
sincze
Post by sincze »
pvdgulik wrote: Friday 14 June 2019 22:21 Also same problem.. Think of editing the database to correct..
This seems to be an issue with all my different branded inverters indeed within domoticz.
Seems like a Domoticz representation graph issue to me as the json request is processed correctly and device is updated correctly as well. I am running Domoticz V4.10730.
pvdgulik wrote: Friday 14 June 2019 22:21 I also notice when there is no power output I still get the last remain known output showing up (e.g 36Watts from 22:00h onwards till the morning).
That I corrected with a statement (not within lua) to check if the current time is after sunset. If so I update the device with
0;<daily_generation>.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
klaaspiet
Post by klaaspiet »
Merlin1201 wrote: Friday 07 June 2019 11:14 Hi
ik got this problem 2 how to solve it?? i can't gat the solution
if have made som changed so i have a 0 value when de inverter is nog genarating
i get de status of the inverter
Status = getValue(splitString, "status")
if that is
1 = Generating,
0 = Waiting</option>
2 = Fault
-1 = Offline
if Status == "1" then
status_text = "Generating"
elseif Status == "0" then
status_text = "Waiting"
elseif Status == "2" then
status_text = "Fault"
status_text = "Offline"
so i can create a 0 when the status is 0,2 of -1
UpdateDevice(sensorSolarPanels, current..";"..zonTotal)
current = "0"
print("current :" .. current)
and i use eTotal = getValue(splitString, "eTotal")
so i can get the total of my production
pvdgulik
Post by pvdgulik »
Thank you for your response. I’m not that experienced with Domoticz, can you tell in detail how to:
Thank you!
sincze
Post by sincze »
pvdgulik wrote: Sunday 23 June 2019 16:29 Thank you for your response. I’m not that experienced with Domoticz, can you tell in detail how to:
Thank you!
I can help you if you are willing to consider moving to a Pass2PHP script kind of a solution.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Wiljums
Post by Wiljums »
I get the following error:
2019-07-19 15:32:00.126 Error: EventSystem: in script_device_solar.lua: [string "-- Created by Raymond Wiertz
..."]:129: bad argument #1 to 'sub' (string expected, got nil)
How to fix this?
Wiljums
Post by Wiljums »
Wiljums wrote: Friday 19 July 2019 15:36 I get the following error:
How to fix this?
And now this one:
2019-07-19 15:49:01.219 Error: EventSystem: in script_device_solar.lua: [string "-- Created by Raymond Wiertz
..."]:102: attempt to perform arithmetic on global 'endPos' (a nil value)
Wiljums
Post by Wiljums »
dospider wrote: Tuesday 30 April 2019 9:14 I still have a problem retrieving the data.
Does anybody have an idea how to solved this error?
2019-04-30 09:08:43.249 Error: EventSystem: in Goodwe portal: [string "
..."]:88: attempt to perform arithmetic on global 'endPos' (a nil value)
Have you been able to fix this error?
Peter2807
Post by Peter2807 »
Anybody who has this script working on a Synolgy NAS, as I'm unable to find much about syntax differences between Pi and Synology if there are any.
First error already occurs at the first line of executable code: local Username = ... Unexpected keyword local near Username
sincze
Post by sincze »
Peter2807 wrote: Tuesday 30 July 2019 23:14 Anybody who has this script working on a Synolgy NAS, as I'm unable to find much about syntax differences between Pi and Synology if there are any.
Yes it is working on a DS412 as an alternative I created
However you could also look at: https://github.com/sincze/Domoticz/blob ... Goodwe.php
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
