cant find.. is this helpful...
see atachment
style box height
pvklink
- Domoticz version: latest b
Re: style box height
- x.png (63.73 KiB) Viewed 1129 times
Jablotron connection, Ikea
Lokonli
Yes, that helps.
It seems to be a bug in Dashticz, which happens if you have an url defined in your calendar block.
Solution 1:
remove the url parameter
Solution 2:
In file js/calendar.js add two slashes in front of line 47, like this:
// calobject.attr('data-id', '');
If solution 2 is working then I'll make a fix for the next beta version of Dashticz.
pvklink
do you mean the xxx part or the yyy part
calendars.fam = { key:'dvfam', maxitems: 6, title: 'Familie kalender', url: 'https://xxx',icalurl: 'yyyy/basic.ics' }
pvklink
ok, when i remove xxx part the sizechanges work!
pvklink
ok, the // also work!
thanks lokonli!
thanks lokonli!
pvklink
@lokonli, all looks GREAT !
Thank you VERY much! EVERYTHING works...
Would like to show te result(screendump) but the file is to big to upload....so you can see what the result is off your effort and that from @waaren
Lokonli
Thanks for the feedback. Enjoypvklink wrote: Saturday 08 June 2019 12:24 @lokonli, all looks GREAT !
