style box height
pvklink
Domoticz version: latest b
Re: style box height
Post by pvklink »
cant find.. is this helpful...
see atachment
Jablotron connection, Ikea
Lokonli
Post by Lokonli »
pvklink wrote: Friday 07 June 2019 22:16 cant find.. is this helpful...
see atachment
Yes, that helps.
It seems to be a bug in Dashticz, which happens if you have an url defined in your calendar block.
Solution 1:
remove the url parameter
Solution 2:
In file js/calendar.js add two slashes in front of line 47, like this:
          //  calobject.attr('data-id', '');
Can you first test solution 1, then add the url parameter and test solution 2?
If solution 2 is working then I'll make a fix for the next beta version of Dashticz.
pvklink
Post by pvklink »
do you mean the xxx part or the yyy part
calendars.fam = { key:'dvfam', maxitems: 6, title: 'Familie kalender', url: 'https://xxx',icalurl: 'yyyy/basic.ics' }
pvklink
Post by pvklink »
ok, when i remove xxx part the sizechanges work!
pvklink
Post by pvklink »
ok, the // also work!
thanks lokonli!
pvklink
Post by pvklink »
@lokonli, all looks GREAT !
Thank you VERY much! EVERYTHING works...
Would like to show te result(screendump) but the file is to big to upload....so you can see what the result is off your effort and that from @waaren
Lokonli
Post by Lokonli »
pvklink wrote: Saturday 08 June 2019 12:24 @lokonli, all looks GREAT !
Thanks for the feedback. Enjoy :)
